149456
149456
    BRADY
    BRADYPRINTER I5100 600DPI
149456 数据手册
BradyPrinter i5100 Industrial Label Printer Specifications When you’re looking for a printer with the fundamental printing capabilities for the work you need to get done every day, look no further than the i5100 printer. You’ll get the perfect combination of high-volume performance and smart printing technology to make high-mix printing easier throughout your facility. Model(s): Model name Media alignment User Interface: Display type Display size (diagonal) Display resolution (h x w) i5100 Industrial Label Printer Center justified Touchscreen color LCD 4.3 in. 272 x 480 pixels Arabic (Egypt), Bulgarian, Chinese (simplified), Croatian, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Korean, Lithuanian, Macedonian, Display languages Norwegian, Persian (Farsi), Polish, Portuguese, Romanian, Russian, Serbian, Slovenian, Spanish (Castilian), Spanish (Mexico Latin Amer), Swedish, Thai, Turkish Brady mode or standard mode, ribbon and label part number istalled, amount of supplies remaining, sensor activated, where Display status bar to set sensor, receiving data, record data stream, ribbon warning, bluetooth, WLAN, ethernet, USB slave, time, presence of SD card and USB stick Print Head / Printing Characteristics: 300 dpi Print resolution 600 dpi Thermal transfer (300 or 600 dpi) Print method Direct thermal (300 dpi - material & printhead dependent) Print color capability Single print color Up to 11.8 in/sec (300 dpi) Print speed Up to 5.9 in/sec (600 dpi) Print width (max, cross-web) 4.16 in. Print length (max, down-web) 6.6 ft. Media cut-off Tear bar, optional auto-cutter model Media Characteristics: Yes - reads IP-enabled supplies for Brady IP-enabled printing Mode printing Media width (cross-web 0.24 in. to 3.35 in. (continuous sleeves) incl liner) 0.36 in. to 4.40 in. (other materials) Label width (cross-web) 0.20 in. to 4.33 in. 0.20 in. minimum (w/no backfeed) Label length (down-web)** 0.50 in. minimum (w/backfeed) 0.47 in. minimum (if cutting single label) 0.0024 in. to 0.029 in. (label materials) Media thickness 0.070 in. max (push button labels) 0.043 in. max (heat shrink sleeves) Media roll o.d. (max) 8.07 in. Media roll core i.d. 3.0 in. to 3.94 in. Media roll winding Outside or inside Internal rewind takeup roll n/a o.d. (max) Internal rewind takeup roll core i.d. Internal rewind takeup roll winding Media styles Media material types**** Media parts offering Ribbon Characteristics: Ribbon length (max) Ribbon roll o.d. (max) n/a n/a Die cut media, continuous media, 3 in. core roll-fed media, fanfolded media (external feed), tagstock liner-mounted, tagstock linerless, perforated materials, adhesive labels, heat-shrink sleeves size 125 and larger (single sided), continuous sleeves size 125 and larger externally fed, self-laminating cable labels, raised panel push button labels (with no backfeed or autocut), rapido-style cable tags, Permashield style labels IP-Enabled media and ribbon rolls (for Brady Mode printing), PE (polyethylene), PET (polyester), PET Metallized, PU (polyurethane), PVC (vinyl), PVF (polyvinyl fluoride), PVDF (polyvinylidene fluoride), PP (polypropylene), PI (polyimide), polyamide, polyether polyurethane (Heatex™), raised panel push button material, paper, destructible materials, tamper-evident and tamper-resistant materials, other materials not listed 2900+ stock parts and custom (made-tospec) parts 1000 ft. 2.74 in. No core needed (IP-enabled supplies), Ribbon roll core i.d. otherwise 1.0" Ribbon width (cross-web)*** 1.0 in. to 4.49 in. Ink side Inside or outside wound Electronics: Processor 32 bit 800 MHz clock rate Memory (RAM) 256 MB Data storage (IFFS) 50 MB SD card slot (SDHC, SDXC) 512 GB max Internal battery For internal date & time (RTC) Data storage when power off Yes Physical / Operational Characteristics: Dimensions (closed) (h x w x d) 12.5 in. x 9.5 in. x 17.1 in. Weight (empty) 14.6 lbs Power supply 100 - 240V AC, 50/60 Hz, PFC Power consumption
149456 价格&库存
很抱歉,暂时无法提供与“149456”相匹配的价格&库存,您可以联系我们找货
