Dot Matrix Materials - Benchtops
BradyID.com
Dot Matrix / Laser / Ink Jet
General ID
Butt-Cut with Perforations,
Rounded Corners
Fig. D5
Diagram Part Number
B-#
Material
Color
Label Width A
Inch (mm)
Label Height B
Inch (mm)
Horizontal
Repeat C
Inch (mm)
Vertical
Repeat D
Inch (mm)
Web Width E
Inch (mm)
Labels Labels
Per
Per
Row
Pkg
Square Corners
D5
DAT-108-619-10
B-619
Polyester
White
0.300 (7.62)
0.300 (7.62)
0.300 (7.62)
0.500 (12.70)
5.800 (147.32)
16
10,000
D5
DAT-102-619-10
B-619
Polyester
White
0.800 (20.32)
0.200 (5.08)
0.800 (20.32)
0.330 (8.46)
9.000 (228.60)
10
10,000
D5
DAT-106-652-10
B-652
Polyimide
Amber
0.300 (7.62)
0.300 (7.62)
0.300 (7.62)
0.500 (12.70)
5.800 (147.32)
16
10,000
D5
DAT-101-652-10
B-652
Polyimide
Amber
0.800 (20.32)
0.200 (5.08)
0.800 (20.32)
0.330 (8.46)
9.000 (228.60)
10
10,000
Rounded Corners
D5
DAT-173-619-10
B-619
Polyester
White
0.250 (6.35)
0.250 (6.35)
0.250 (6.35)
0.500 (12.70)
6.000 (152.40)
D5
DAT-104-619-10
B-619
Polyester
White
0.800 (20.32)
0.500 (12.70)
0.800 (20.32)
0.625 (15.88)
9.000 (228.60)
10
10,000
D5
DAT-103-652-10
B-652
Polyimide
Amber
0.800 (20.32)
0.500 (12.70)
0.800 (20.32)
0.625 (15.88)
9.000 (228.60)
10
10,000
Vertical
Repeat D
Inch (mm)
Web Width E
Inch (mm)
Labels Labels
Per
Per
Row
Pkg
General ID - Slit Liner Labels
for Easy Removal
Fig. D6
Dot Matrix - Benchtops
Diagram Part Number
B-#
Material
Color
Label Width A
Inch (mm)
Label Height B
Inch (mm)
Horizontal
Repeat C
Inch (mm)
D6
BCDAT-12-619-10
B-619
Polyester
White
1.500 (38.10)
0.750 (19.05)
1.700 (43.18)
1.000 (25.40)
7.600 (193.04)
4
10,000
D6
DAT-3-637-10
B-637
Polyvinylfluoride
White
1.500 (38.10)
0.750 (19.05)
1.700 (43.18)
1.000 (25.40)
7.600 (193.04)
4
10,000
D6
DAT-4-637-10
B-637
Polyvinylfluoride
Yellow
1.500 (38.10)
0.750 (19.05)
1.700 (43.18)
1.000 (25.40)
7.600 (193.04)
4
10,000
B-969
Metallized
Polyester
Silver
1.500 (38.10)
0.750 (19.05)
1.700 (43.18)
1.000 (25.40)
7.600 (193.04)
4
10,000
Vertical
Repeat D
Inch (mm)
Web Width E
Inch (mm)
Labels Labels
Per
Per
Row
Pkg
D6
DAT-48-969-10
General ID - Center Perforated
Labels (Vertical)
Fig. D7
Diagram Part Number
B-#
Material
Color
Label Width A
Inch (mm)
Label Height B
Inch (mm)
Horizontal
Repeat C
Inch (mm)
D7
DAT-28-121-10
B-121
Paper
White
1.500 (38.10)
0.250 (6.35)
1.800 (45.72)
0.330 (8.46)
7.900 (200.66)
4
10,000
D7
DAT-29-502-10
B-502
Vinyl Cloth
White
1.500 (38.10)
0.250 (6.35)
1.800 (45.72)
0.330 (8.46)
7.900 (200.66)
4
10,000
Static Awareness Labels
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
STATIC
SENSITIVE
Fig. D10
Diagram Part Number
B-#
Material
Color
Label Width A Label Height B Print-On
Inch (mm)
Inch (mm)
Area
Horizontal
Repeat
Inch (mm)
Vertical
Repeat
Inch (mm)
Web Width
Inch (mm)
Labels
Per
Pkg
D10
SLDAT-1-502-10
B-502
Vinyl Cloth Black on Yellow
1.000 (25.40)
0.500 (12.70)
0.312 (7.92)
1.100 (27.94)
0.670 (17.02)
8.600 (218.44)
10,000
D10
SLDAT-1-619-10
B-619
Polyester
1.000 (25.40)
0.500 (12.70)
0.312 (7.92)
1.100 (27.94)
0.670 (17.02)
8.600 (218.44)
10,000
Black on Yellow
Full Material Properties on page 237.
210
很抱歉,暂时无法提供与“DAT-104-619-10”相匹配的价格&库存,您可以联系我们找货
