Technical Data Sheet
Plug Valve Lockout
TDS No. LOTO-52
Effective Date: 10/11/2017
Description:
Design
Available in four sizes to accommodate a wide
range of plug valves
Effective fit for difficult-to-secure plug valves
Durable and tamper-resistant
Compact in size and easy to use
Material
Body, base: polypropylene
○ Color: Red (PMS1805C)
Hose Clamp: Steel
Temperature Range
Polypropylene: - 20° to 80°C (0° to 175°F)
Chemical Resistance
All approved chemicals listed are based on the
manufactures specified chemical resistance chart for
plastic material only
Dimensions
A
B
C
D
E
Chemical
°C
Chemical
°C
Acetone
25
Petroleum
25
Acetone
60
Turpentine oil
25
Chlorine, chlorine water
25
Turpentine substitute (white
spirit)
25
Fuel, engine: Gasoline
(normal & premium grade)
85
Trichloroethane 1,1,1
45
< 120
Lubricating oil: HD engine
oils, hydraulic oils,
transformer oils
< 120
Fuel, engine: M15 mixture
(15% methanol)
70
Water (including seawater)
25
Methanol
25
Water (including seawater),
chlorinated (
很抱歉,暂时无法提供与“113233”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+425.729901+54.62596
