30MM CLEAR PUSH BUTTON LO W/ STD COVER
    BRADY
    BRADY - 30MM CLEAR PUSH BUTTON LO W/ STD COVER - PUSH BUTTON LOCKOUT, CLEAR, PC
30MM CLEAR PUSH BUTTON LO W/ STD COVER 数据手册
Technical Data Sheet Push Button and Emergency Stop Safety Cover Device TDS No. LOTO-​72 Effective Date: 10/16/2017 Description: Design ● ● ● ● Compatible with standard 16, 22, and 30 mm push buttons Made of rugged polycarbonate Permanently install the base under the button, then lock the removable cover in place to prevent actuation of the button Accepts lock shackles up to 9/32​-inches or 7mm ​in diameter. Material ● Base and cover: polycarbonate ● Latch: stainless steel ● Cover color: transparent with red tint ● Base color: clear Temperature Range The following temperature range is generally acceptable for polycarbonate. This range should not be used as a specification. The product should be tested under specific operating conditions. ​-20° C to 80°C (​4°F to 176° F). Chemical Resistance Chemical Compatibility: Polycarbonate is generally compatible with the following chemicals. This list should not be used as a specification. This product should be tested under specific operating conditions. If a temperature is specified, the chemical may have a more severe effect if above the specified temperature. Dimensions (measurements in mm) Cat 134018 130819 130820 130821 130822 130823 130824 No. A 49.6 79.6 49.6 54.6 N/A N/A N/A B 73.8 73.8 73.8 83.8 N/A N/A N/A C 63.5 63.5 63.5 73.5 63.5 63.5 73.5 D 17 17 23 31 17 23 31 E 44.2 42.1 44.2 53.9 N/A N/A N/A F 43.8 74.4 43.8 48.8 N/A N/A N/A A = Height diameter B = Length diameter C = Base Diameter height D = Button stem clearance E = Internal clearance F = Internal clearance Chemical °C Chemical °C Lubricants 22 Hydrochloric Acid 20% 22 Gasoline 48 Sodium Hydroxide 20% 48 Methanol 22 Isopropyl Alcohol 48 Water (Including Seawater) 48 Acetic Acid 20% 22 Sulfuric Acid 10% -​ 75% 22 Chlorine Bleach 15% Details: Trademarks: Note: ​All values shown are averages and should not be used for specification purposes. Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2019 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. ______________________________________________________________________________________________________ Brady North America | 6555 West Good Hope Road | Milwaukee, Wisconsin 53223 | USA | Tel: 414​-358-​6600 | Fax: 414-​228-​5770
PDF文档中包含以下信息:
1. 物料型号:型号为LM73B。
2. 器件简介:LM73B是一款数字温度传感器,用于测量温度范围在-40°C至+125°C之间。
3. 引脚分配:LM73B有8个引脚,包括VDD、GND、SCL、SDA、ALERT、THERM、NC和AD0。
4. 参数特性:包括供电电压范围、温度测量范围、精度、输出数据速率等。
5. 功能详解:LM73B能够通过I2C接口输出温度数据,具有温度报警功能。
6. 应用信息:适用于需要精确温度测量的场合,如工业控制、医疗设备等。
7. 封装信息:提供多种封装选项,如SOIC、TSSOP等。
30MM CLEAR PUSH BUTTON LO W/ STD COVER 价格&库存
很抱歉,暂时无法提供与“30MM CLEAR PUSH BUTTON LO W/ STD COVER”相匹配的价格&库存,您可以联系我们找货
