BBP72-34L
BBP72-34L
    BRADY
    BBP72-34L DOUBLE SIDED PRINTER
BBP72-34L 数据手册
Automating the Identification Process Wraptor™ A6500 Wire ID Printer Applicator BradyID.com/A6500 Make the Identification Process Easier The Wraptor™ A6500 helps you move through your work faster and takes manual processes out of your hands. With this innovative print and apply machine, you can move your productivity forward — and turn a series of labor-intensive, inefficient tasks into a modern automated process. Benefits include: Increased Productivity Save time and labor by printing and applying labels in 5 seconds in a modern automated process. Easy to Use Includes a full color responsive touch screen and an icon based user interface for ease-of-use. Easy to Connect Enhanced connectivity, three USB ports and 32GB of internal memory to store commonly used job files. Did You Know? Custom Label Offerings Don’t see a stock label in the size, configuration or color needed for your particular application? Our dedicated and experienced custom quoting team can provide pricing for your unique label needs. Contact us at 1-888-272-3946 Materials for Faster Application The Wraptor A6500 Wire ID Printer Applicator accepts a variety of materials for your wire identification needs. These materials are engineered to meet the high quality standard you've come to expect from Brady. B-427 Self-Laminating Wire Material A Color: White/Clear Finish: Matte Brady’s most popular wire and cable marker. Self-laminating vinyl features white printable area with a clear “tail” that wraps around marker. Tail serves as overlaminate to protect the print. Superior resistance to abrasion, solvents, water, oil and dirt. F B D E Figure 14 Diagram Part Number Material Color Wire Gauge Label Width A Label Height B Vert. Repeat D Web Width E Inch (mm) Inch (mm) Inch (mm) Inch (mm) Write On Area F Inch (mm) Labels Per Row Labels Rec. Per Ribbon Pkg Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Vinyl Vinyl Vinyl Vinyl Vinyl Vinyl Vinyl Vinyl Vinyl 18-22g; 0.06" - 0.08" dia 12-18g; 0.08" - 0.159" dia 10-14g; 0.159" - 0.199" dia 6-14g; 0.159" - 0.279" dia 6-14g; 0.159" - 0.279" dia 6-14g; 0.159" - 0.279" dia 1/0-8g; 0.239" - 0.438" dia 1/0-8g; 0.239" - 0.517" dia 3/1-6g; 0.318" - 0.597" dia 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 0.500 (12.7) 1.000 (25.4) 2.000 (50.8) 1.000 (25.4) 1.000 (25.4) 2.000 (50.8) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 1.000 (25.4) 1 1 1 1 1 1 1 1 1 6800 5300 4300 3600 3600 3600 2500 2200 1900 R4311 R4306 R4306 R4311 R4306 R4302 R4306 R4306 R4302 WRAP-1-427 WRAP-2-427 WRAP-3-427 WRAP-11-427 WRAP-4-427 WRAP-12-427 WRAP-10-427 WRAP-5-427 WRAP-6-427 While White White White White White White White White 0.750 (19.1) 1.000 (25.4) 1.250 (31.8) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 2.250 (57.2) 2.500 (63.5) 3.000 (76.2) 0.875 (22.2) 1.125 (28.6) 1.375 (34.9) 1.625 (41.3) 1.625 (41.3) 1.625 (41.3) 2.375 (60.3) 2.625 (66.7) 3.125 (79.4) B-472 Polyimide Wirewrap Material 0.790 (20.1) 1.290 (32.8) 1.290 (32.8) 0.790 (20.1) 1.290 (32.8) 2.290 (58.2) 1.290 (32.8) 1.790 (45.5) 2.290 (58.2) A Color: White Finish: Matte Polyimide wire and cable material specifically designed to selfextinguish and prevent flames from propagating. This material is ideal for wire and cable identification in extreme environments, particularly in the aerospace, defense and mass transit industries. B D E Figure 2 Diagram Part Number Material Color Wire Gauge Label Width A Inch (mm) Label Height B Inch (mm) Vert. Repeat D Web Width E Inch (mm) Inch (mm) Labels Per Labels Row Per Pkg Rec. Ribbon Fig. 2 WRAP-1-472 Polyimide White 10-14g; 0.159” - 0.199” dia 0.750 (19.1) 0.500 (12.7) 0.875 (22.2) 0.790 (20.1) 1 6800 R4311 Fig. 2 WRAP-6-472 Polyimide White 3/0-8g; 0.212” - 0.597” dia 2.000 (50.8) 3.000 (76.2) 3.125 (79.4) 2.290 (58.2) 1 1900 R4302 B-499 Nylon Cloth Material Color: White Finish: Matte Nylon cloth with permanent adhesive allows labeling in environments with heat, cold, oil and dirt. Ideal for wire and cable marking, electronic component marking, laboratory vial identification, and general labeling. A B D E Figure 2 Diagram Part Number Material Color Wire Gauge Label Width A Inch (mm) Label Height B Inch (mm) Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 2 WRAP-7-499 Nylon Cloth White 10-22g; 0.06" - 0.199" dia 0.500 (12.7) 0.750 (19.1) 1 4500 R4311 Fig. 2 WRAP-13-499 Nylon Cloth White 6-14g; 0.159" - 0.279" dia 1.000 (25.4) 1.000 (25.4) 1 4100 R4306 Fig. 2 WRAP-8-499 Nylon Cloth White 2-14g; 0.159" - 0.438" dia 1.000 (25.4) 1.500 (38.1) 1 2800 R4306 Fig. 2 WRAP-9-499 Nylon Cloth White 3/0-8g; 0.212" - 0.597" dia 2.000 (50.8) 2.000 (50.8) 1 2100 R4302 Wraptor A6500 Print Ribbons (1.000” core, ink side out.) Ribbon Series Catalog # Size Color R4300 Wax/Resin Strong environmental resistance against smearing and chemicals. Also, reliable, sharp-edge print quality to maximize barcode readability. R4311 R4306 R4302 1.000" x 984' 1.570" x 984' 2.360" x 984' Black Black Black BradyID.com/A6500 1-888-272-3946 Wraptor™ A6500 Wire ID Printer Applicator Catalog # Description WRAPTOR-A6500 WRAPTOR-VBLK Wraptor A6500 Wire ID Printer* w/ Brady Workstation Product & Wire ID Suite Spare wrapper assembly pad *Printer includes print driver, USB cable, USB flash drive, Stylus, Roll of WRAP-4-427, Roll of R4302 Ribbon. For In-Line Cut & Strip Applications: Contact Brady at 1-888-272-3946 for all In-Line Cut & Strip applications. Special restrictions apply. Printer Specifications Description Specialty system prints and applies labels to wires and cables making labeling faster, easier and improving your production flow. Applications & Other Comments Prints & wraps self-laminating and vinyl cloth materials to wires from 0.060" to 0.600" diameter. Prints and wraps under 5 seconds Typical Throughput & Operational Hours 7000+ labels /day 24 hrs / 7 days Print Technology & Color Capabilites Thermal Transfer; Monochrome Print Resolution Max Print Width Media Widths Minimum Label Dimension Auto Cut-off PC Connect or Stand Alone Operation Ribbon & Material Installation 300 dpi 2.000” 0.50", 1.00", 2.00" 0.50" W x 0.75" L N/A PC Connect or Stand Alone Labels: Loose roll, “thread-thru” required Ribbon: Loose roll, “thread-thru” required Label Creation & Set-up Semi-automatic (select label part from software and label sets up) Connectivity Options Standard: USB, Ethernet 10/100 Compatible PC Software Labelmark™ Software, Brady Workstation Brady360® 1-Year Warranty We have you covered. Extend the life of your machine! Warranty coverage ensures your wire marking system is in peak running condition and gives you convenient on-site preventive service — you don’t even need to leave your facility. We know you need to keep working, so you’ll get a loaner to keep your business moving. • Warranty coverage for 1 year • No cost ground shipping for all repairs • Part and labor included (excludes V-Block, but does include print head) • Guaranteed loaner availabiilty • One annual on-site preventive maintenance service during coverage • 1/2 price emergency on-site service • Renewal available with approved printer inspection Brady Workstation Product and Wire Identification Suite The Product and Wire Identification Suite allows you to create basic text labels or labels with graphics and custom formatting, and serialize and import data. If you need to create labels for your product or wires and cables, this is the Brady Workstation suite for you! Apps included: Advanced Import, Advanced Sequence, Batch Print, Custom Designer, Excel Import, Flip Flop, Manage Files, Print Partner, Sequence, Template Editor, Text Labels and Label Settings. Did You Know? Wraptor can be integrated into your production system using Brady Programming Language (BPL). For more information call 1-888-272-3946. Y4555202 MS4555202 © 2017 Brady Worldwide Inc. ALL RIGHTS RESERVED USA Customer Service: 1-888-272-3946 Inside Sales: 1-888-311-0775 BradyID.com Canada Customer Service: 1-800-263-6179 BradyCanada.ca Mexico Customer Service: 1-800-262-7777 Inside Sales: 1-800-262-7777 ext 177 BradyLatinAmerica.com
BBP72-34L 价格&库存
很抱歉,暂时无法提供与“BBP72-34L”相匹配的价格&库存,您可以联系我们找货
