BMP61-CUTTER
BMP61-CUTTER
    BRADY
    BRADY - BMP61-CUTTER - CUTTER, MANUAL, LABEL PRINTER
BMP61-CUTTER 数据手册
PERFORMANCE That Matches Your Own BMP®61 Label Printer BradyID.com/bmp61 PERFORMANCE That Matches Your Own Your Trusted Identification Companion, All Day, Every Day, for Years to Come Brady’s BMP®61 label printer is designed for quick and efficient identification of wires, cables and components. With high performance materials that can handle the toughest industrial identification applications, this printer is your rugged and reliable partner in the field and dependable workhorse in the shop. It features multiple user interfaces, touch screen capabilities and a variety of ways to connect, manage and save your data. With the BMP®61 printer in hand, you’re ready to tackle identification tasks- and finish those tasks flawlessly. 2 Table of Contents Printer Overview.......................................... 3 Wire & Cable Materials................................ 7 Terminal Block / Patch Panel Materials..... 13 Asset Tracking Materials........................... 14 General ID Materials.................................. 17 Printer, Accessories and Ribbons............. 18 Printer Specs............................................. 19 Simplicity & Efficiency ■■ Simple user interface with easy menu, curser and label navigation ■■ Large, color touch-screen display to see exactly what the label is going to look like before it’s printed ■■ Automatic label formatting with smart-cell technology ■■ Easy material loading with wide cover opening and large material bay ■■ Intuitive typing with QWERTY style keypad (AZERTY, QWERTZ, CYRILLIC), and effectively sized and spaced keys to reduce typing errors Versatility ■■ Variety of application options, including PermaSleeve® wire marking sleeves, self-laminating labels, voice & datacomm ID, safety labels, general ID and more ■■ Die-cut, continuous & custom label supplies up to 2” wide (51mm) and designed for high-performance ■■ Crisp, clear labels in small fonts to fit on your smallest wires and product ID materials, thanks to a 300 dpi print head ■■ Data connectivity with USB 2.0 ports (Type A and B), USB flash drive support and optional WiFi, allows users to quickly save, copy or send label designs from a computer, tablet or smart phone by using LabelMark™ 6 software Reliability ■■ Industrial, rugged design with rubber bumpers and tested to survive a four-foot drop ■■ Power options include either a rechargeable NiMH battery or AC power to keep you printing wherever you go ■■ 2-year warranty to ensure your printer is kept in top working condition ■■ Utility strap for improved storage and handling BradyID.com/bmp61 1-888-272-3946 3 Key Printer Features At-a-Glance Die-Cut, Continuous & Custom Label Supplies Up to 2” (51mm) Crisp Print with 300 dpi Printhead Easy Material Loading with Bulk Size Roll Option Automatic Label Formatting with Smart-Cell Technology Large, Color Touch-Screen Display USB 2.0 Ports (Type A & B); USB Flash Drive Support; Optional WiFi Label Grabber Holds Label After Cutting QWERTY Style Keypad (AZERTY, QWERTZ, CYRILLIC) Rechargeable NIHM Battery or AC Power (included) Utility Strap for Easy Storage & Handling 4 Industrial, Drop Tested Rugged Design Application Versatility Self-Laminating Labels Inside Panel Component Labels Wrap-A-Round Wire Labels Terminal Block Labels Cable Tags Cable Flags Heat Shrink Wire Markers Patch Panel Labels Fiber Optic Cable Markers Asset Tracking Labels Equipment Labels Safety Labels BradyID.com/bmp61 1-888-272-3946 5 Easy to Load Consumables The BMP®61 label printer provides easy material loading and an improved, wider and more open loading bay and door. The upgraded core design provides quick pop-in-and-out capabilites and prevents the material from rolling off the table surface and telescoping during change-overs. Smart-Cell Technology With smart-cell technology built into rolls and ribbons, the printer is able to automatically format the objects on your label so that there is no guess work on your part. If materials are not compatible, the screen will show an error. Cartridge Compatibility The BMP®61 label printer is designed to use most of the same material parts as the TLS2200 label printer. Material Options Don’t Stop Here The BMP®61 label printer supports over 600 label materials and prints on a range of die-cut and continuous materials up to 2” (51mm) wide. For a full list of consumables, visit BradyID.com or contact customer service at 888-272-3946. 6 Wire & Cable Materials Self-Laminating Vinyl B-427 Vinyl Material with Wrap-Around Tail Brady’s most popular wire and cable marker. Self-laminating vinyl features a white printable area with a clear “tail” that wraps around the marker to protect the print. Superior resistance to abrasion, solvents, water, oil and dirt. A A TEXT 1 TEXT 1 A A C C C B B B Figure 29 B = Label Height A = Label Width Diagram B Catalog Number Figure C27 = Write-On Area A = Label Width B = Label Height B-# Material Figure 32 C = Write-On Area A = Label Width B = Label Height Color Figure 43 A = Label Width B = Label Height Label Width A Inch (mm) C = Write-On Area Label Height B Inch (mm) Write On Area C Inch (mm) Approx. Labels Wire Gauge Per Row Labels Per Pkg Rec. Ribbon Fig. 29 PTL-105-427-AW B-427 Vinyl White 1.100 (27.9) 0.250 (6.4) 0.250 (6.4) All White 1 750 M61-R4310 Fig. 32 PTL-10-427 B-427 Vinyl White 0.250 (6.4) 0.750 (19.1) 0.375 (9.5) 16 to 10 1 750 M61-R4310 Fig. 32 PTL-11-427 B-427 Vinyl White 0.500 (12.7) 0.750 (19.1) 0.375 (9.5) 16 to 10 1 500 M61-R4310 Fig. 32 BM71-11-427 B-427 Vinyl White 0.500 (12.7) 0.750 (19.1) 0.375 (9.5) 16 to 10 1 5000 M61-R4310 Fig. 32 PTL-96-427 B-427 Vinyl White 1.000 (25.4) 0.750 (19.1) 0.375 (9.5) 16 to 10 1 250 M61-R4310 Fig. 29 PTL-30-427-AW B-427 Vinyl White 1.500 (38.1) 0.750 (19.1) 0.750 (19.1) All White 1 250 M61-R4310 Fig. 32 PTL-17-427 B-427 Vinyl White 0.500 (12.7) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 500 M61-R4310 Fig. 32 BM71-17-427 B-427 Vinyl White 0.500 (12.7) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 5000 M61-R4310 Fig. 32 PTL-18-427 B-427 Vinyl White 0.750 (19.1) 1.000 (25.4) 0.375 (9.5) 10 to 4 1 250 M61-R4310 Fig. 32 BM71-18-427 B-427 Vinyl White 0.750 (19.1) 1.000 (25.4) 0.375 (9.5) 10 to 4 1 2500 M61-R4310 Fig. 32 PTL-19-427 B-427 Vinyl White 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-19-642 B-427 Vinyl White 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 BM71-19-427 B-427 Vinyl White 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 2500 M61-R4310 Fig. 32 PTL-104-427 B-427 Vinyl White 1.500 (38.1) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-87-427 B-427 Vinyl White 1.750 (44.5) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 29 PTL-78-427-AW B-427 Vinyl White 1.900 (48.3) 1.000 (25.4) 1.000 (25.4) All White 1 250 M61-R4310 Fig. 32 PTL-102-427 B-427 Vinyl White 0.500 (12.7) 1.250 (31.8) 0.375 (9.5) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-103-427 B-427 Vinyl White 1.000 (25.4) 1.250 (31.8) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-28-427 B-427 Vinyl White 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427 B-427 Vinyl White 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 Fig. 32 BM71-29-427 B-427 Vinyl White 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 5000 M61-R4310 Fig. 32 PTL-30-427 B-427 Vinyl White 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 BM71-30-427 B-427 Vinyl White 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 2500 M61-R4310 Fig. 32 PTL-31-427 B-427 Vinyl White 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 BM71-31-427 B-427 Vinyl White 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 2500 M61-R4310 Fig. 32 PTL-32-427 B-427 Vinyl White 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 BM71-32-427 B-427 Vinyl White 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 1000 M61-R4310 Fig. 32 PTL-88-427 B-427 Vinyl White 1.750 (44.5) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-107-427 B-427 Vinyl White 2.000 (50.8) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 100 M61-R4310 Fig. 32 BM71-107-427 B-427 Vinyl White 2.000 (50.8) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 1000 M61-R4310 Fig. 27 PTL-74-427 B-427 Vinyl White 0.500 (12.7) 2.200 (55.8) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-21-427 B-427 Vinyl White 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-21-642 B-427 Vinyl White 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 BM71-21-427 B-427 Vinyl White 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 1000 M61-R4310 Fig. 32 PTL-157-427 B-427 Vinyl White 1.500 (38.1) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-75-427 B-427 Vinyl White 1.000 (25.4) 2.625 (66.7) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-66-427 B-427 Vinyl White 1.938 (49.2) 3.150 (80.0) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 43 PTL-64-427 B-427 Vinyl White 1.000 (25.4) 3.375 (85.7) 1.125 (28.6) Cables 1 100 M61-R4310 Fig. 43 BM71-64-427 B-427 Vinyl White 1.000 (25.4) 3.375 (85.7) 1.125 (28.6) Cables 1 1000 M61-R4310 Fig. 32 PTL-23-427 B-427 Vinyl White 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 BM71-23-427 B-427 Vinyl White 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 1000 M61-R4310 Fig. 32 PTL-33-427 B-427 Vinyl White 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-109-427 B-427 Vinyl White 1.500 (38.1) 4.000 (101.6) 1.500 (38.1) Cables 1 100 M61-R4310 M61-R4310 Fig. 32 BM71-109-427 B-427 Vinyl White 1.500 (38.1) 4.000 (101.6) 1.500 (38.1) Cables 1 500 Fig. 32 BM71-33-427 B-427 Vinyl White 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 500 M61-R4310 Fig. 32 PTL-34-427 B-427 Vinyl White 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 Fig. 32 BM71-34-427 B-427 Vinyl White 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 500 M61-R4310 Self-Laminating Vinyl continued on next page. BradyID.com/bmp61 1-888-272-3946 7 Wire & Cable Materials A TEXT 1 TEXT 1 Self-Laminating Vinyl continued B-427 Vinyl Material with Wrap-Around Tail C B Figure 32 C = Write-On Area A = Label Width B = Label Height Diagram 8 Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Write On Area C Inch (mm) Approx. Labels Wire Gauge Per Row Labels Per Pkg Rec. Ribbon Fig. 32 PTL-10-427-YL B-427 Vinyl Yellow 0.250 (6.4) 0.750 (19.1) 0.375 (9.5) 16 to 10 1 750 M61-R4310 Fig. 32 PTL-11-427-YL B-427 Vinyl Yellow 0.500 (12.7) 0.750 (19.1) 0.375 (9.5) 16 to 10 1 500 M61-R4310 Fig. 32 PTL-17-427-YL B-427 Vinyl Yellow 0.500 (12.7) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 500 M61-R4310 Fig. 32 PTL-18-427-YL B-427 Vinyl Yellow 0.750 (19.1) 1.000 (25.4) 0.375 (9.5) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-19-427-YL B-427 Vinyl Yellow 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-28-427-YL B-427 Vinyl Yellow 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427-YL B-427 Vinyl Yellow 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 Fig. 32 PTL-30-427-YL B-427 Vinyl Yellow 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-31-427-YL B-427 Vinyl Yellow 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-32-427-YL B-427 Vinyl Yellow 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-21-427-YL B-427 Vinyl Yellow 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-23-427-YL B-427 Vinyl Yellow 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-33-427-YL B-427 Vinyl Yellow 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-34-427-YL B-427 Vinyl Yellow 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 Fig. 32 PTL-19-427-BL B-427 Vinyl Blue 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-28-427-BL B-427 Vinyl Blue 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427-BL B-427 Vinyl Blue 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 Fig. 32 PTL-30-427-BL B-427 Vinyl Blue 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-31-427-BL B-427 Vinyl Blue 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-32-427-BL B-427 Vinyl Blue 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-21-427-BL B-427 Vinyl Blue 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-23-427-BL B-427 Vinyl Blue 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-33-427-BL B-427 Vinyl Blue 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-34-427-BL B-427 Vinyl Blue 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 Fig. 32 PTL-19-427-BR B-427 Vinyl Brown 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-28-427-BR B-427 Vinyl Brown 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427-BR B-427 Vinyl Brown 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 Fig. 32 PTL-30-427-BR B-427 Vinyl Brown 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-31-427-BR B-427 Vinyl Brown 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-32-427-BR B-427 Vinyl Brown 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-21-427-BR B-427 Vinyl Brown 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-23-427-BR B-427 Vinyl Brown 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-33-427-BR B-427 Vinyl Brown 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-34-427-BR B-427 Vinyl Brown 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 Fig. 32 PTL-19-427-GY B-427 Vinyl Gray 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-28-427-GY B-427 Vinyl Gray 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427-GY B-427 Vinyl Gray 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 M61-R4310 Fig. 32 PTL-30-427-GY B-427 Vinyl Gray 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 Fig. 32 PTL-31-427-GY B-427 Vinyl Gray 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-32-427-GY B-427 Vinyl Gray 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-21-427-GY B-427 Vinyl Gray 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-23-427-GY B-427 Vinyl Gray 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-33-427-GY B-427 Vinyl Gray 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-34-427-GY B-427 Vinyl Gray 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 M61-R4310 Fig. 32 PTL-19-427-GR B-427 Vinyl Green 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 Fig. 32 PTL-28-427-GR B-427 Vinyl Green 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427-GR B-427 Vinyl Green 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 Fig. 32 PTL-30-427-GR B-427 Vinyl Green 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-31-427-GR B-427 Vinyl Green 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 M61-R4310 Fig. 32 PTL-32-427-GR B-427 Vinyl Green 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 Fig. 32 PTL-21-427-GR B-427 Vinyl Green 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-23-427-GR B-427 Vinyl Green 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-33-427-GR B-427 Vinyl Green 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-34-427-GR B-427 Vinyl Green 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 Self-Laminating Vinyl continued on next page. Approx. wire gauge based on AWG for THHN wire. Wire & Cable Materials A TEXT 1 TEXT 1 Self-Laminating Vinyl continued B-427 Vinyl Material with Wrap-Around Tail C B Figure 32 C = Write-On Area A = Label Width B = Label Height Diagram Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Write On Area C Inch (mm) Approx. Labels Wire Gauge Per Row Labels Per Pkg Rec. Ribbon Fig. 32 PTL-19-427-OR B-427 Vinyl Orange 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-28-427-OR B-427 Vinyl Orange 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427-OR B-427 Vinyl Orange 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 Fig. 32 PTL-30-427-OR B-427 Vinyl Orange 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-31-427-OR B-427 Vinyl Orange 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-32-427-OR B-427 Vinyl Orange 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-21-427-OR B-427 Vinyl Orange 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-23-427-OR B-427 Vinyl Orange 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-33-427-OR B-427 Vinyl Orange 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-34-427-OR B-427 Vinyl Orange 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 Fig. 32 PTL-19-427-PL B-427 Vinyl Purple 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-28-427-PL B-427 Vinyl Purple 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427-PL B-427 Vinyl Purple 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 Fig. 32 PTL-30-427-PL B-427 Vinyl Purple 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-31-427-PL B-427 Vinyl Purple 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-32-427-PL B-427 Vinyl Purple 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-21-427-PL B-427 Vinyl Purple 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-23-427-PL B-427 Vinyl Purple 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-33-427-PL B-427 Vinyl Purple 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-34-427-PL B-427 Vinyl Purple 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 Fig. 32 PTL-19-427-RD B-427 Vinyl Red 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 12 to 10 1 250 M61-R4310 Fig. 32 PTL-28-427-RD B-427 Vinyl Red 0.250 (6.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 750 M61-R4310 Fig. 32 PTL-29-427-RD B-427 Vinyl Red 0.500 (12.7) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 500 M61-R4310 Fig. 32 PTL-30-427-RD B-427 Vinyl Red 0.750 (19.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-31-427-RD B-427 Vinyl Red 1.000 (25.4) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-32-427-RD B-427 Vinyl Red 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 10 to 4 1 250 M61-R4310 Fig. 32 PTL-21-427-RD B-427 Vinyl Red 1.000 (25.4) 2.500 (63.5) 0.750 (19.1) Cables 1 100 M61-R4310 Fig. 32 PTL-23-427-RD B-427 Vinyl Red 1.000 (25.4) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-33-427-RD B-427 Vinyl Red 1.500 (38.1) 4.000 (101.6) 1.000 (25.4) Cables 1 100 M61-R4310 Fig. 32 PTL-34-427-RD B-427 Vinyl Red 1.500 (38.1) 6.000 (152.4) 1.500 (38.1) Cables 1 50 M61-R4310 Self-Laminating Label Heights If you know your wire diameter or wire circumference, you can easily determine the correct label height by using the formula below. Step 1: wire dia. x 3.147 (pi) wire circumference Step 2: wire circumference x 1.5 total label length (Multipying by 1.5 allows the label to wrap 1.5 times around the wire) Approx. wire gauge based on AWG for THHN wire. BradyID.com/bmp61 1-888-272-3946 9 Wire & Cable Materials Nylon Cloth B-499 Permanent Adhesive Nylon Material Nylon cloth with permanent adhesive for environments with heat, cold, oil and dirt. Ideal for wire and cable marking, electronic component marking, and general ID. A B Figure 29 Diagram Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Approx. Wire Gauge Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 PTL-7-499 BM71-11-499 PTL-11-499 PTL-16-499 PTL-18-499 PTL-19-499 PTL-28-499 PTL-29-499 PTL-30-499 PTL-31-499 PTL-21-499 PTL-23-499 PTL-81-499 PTL-84-499 PTL-78-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 B-499 Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon White White White White White White White White White White White White White White White 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.375 (9.5) 0.750 (19.1) 1.000 (25.4) 0.250 (6.4) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.900 (48.3) 0.900 (22.9) 1.900 (48.3) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 2.500 (63.5) 4.000 (101.6) 0.250 (6.3) 0.500 (12.7) 1.000 (25.4) 22 to 16 16 to 10 16 to 10 12 to 10 12 to 10 12 to 10 10 to 4 10 to 4 10 to 4 10 to 4 Cables Cables - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 500 5000 500 500 250 250 750 500 250 250 100 100 750 500 250 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 Heat-Shrinkable Polyolefin Wire Marking Sleeves B-321 Solvent-Resistant, Heat-Shrinkable Material Dot matrix printable, wire and cable heat shrinkable sleeve. Excellent resistance to oil and solvents. A B Figure 36 Diagram Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Approx. Wire Gauge Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 36 Fig. 36 Fig. 36 Fig. 36 Fig. 36 Fig. 36 Fig. 36 Fig. 36 Fig. 36 Fig. 36 PTS-0.45-350-321 PTS-0.95-350-321 PTS-1.90-350-321 PTS-0.45-500-321 PTS-0.95-500-321 PTS-1.90-500-321 PTS-0.95-750-321 PTS-1.90-750-321 PTS-0.95-1000-321 PTS-1.90-1000-321 B-321 B-321 B-321 B-321 B-321 B-321 B-321 B-321 B-321 B-321 Polyolefin Polyolefin Polyolefin Polyolefin Polyolefin Polyolefin Polyolefin Polyolefin Polyolefin Polyolefin White White White White White White White White White White 0.450 (11.4) 0.950 (24.1) 1.900 (48.3) 0.450 (11.4) 0.950 (24.1) 1.900 (48.3) 0.950 (24.1) 1.900 (48.3) 0.950 (24.1) 1.900 (48.3) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 16 to 10 16 to 10 16 to 10 10 to 8 10 to 8 10 to 8 4 to 2 4 to 2 1 to 00 1 to 00 1 1 1 1 1 1 1 1 1 1 500 500 500 500 500 500 250 250 250 250 M61-R6210 M61-R6210 M61-R6210 M61-R6210 M61-R6210 M61-R6210 M61-R6210 M61-R6210 M61-R6210 M61-R6210 Approx. wire gauge based on AWG for THHN wire. 10 Wire & Cable Materials PermaSleeve® Single-Sided Polyolefin Wire Marking Sleeves B-342 Heat-Shrinkable Sleeve Material 3:1 heat shrinkable sleeve fits snuggly around wire for identification and protection. Fade resistant and flame retardant. Meets the following material and physical property specifications: • SAE-AMS-DTL-23053/5C (Class 1) • SAE-AS-81531 Tested per: • MIL-STD-202 • ASTM E162 • RoHS Compliant • ASTM E662 • UL Recognized B (Ø diameter) A A B (Ø diameter) Figure 44 A = Sleeve Width Figure 77 A = Sleeve Width B = Supplied Diameter B = Supplied Diameter Diagram Catalog Number Color Approx. Wire Gauge Range of Wire Diameter Inch (mm) Min. Max. Supplied Diameter B Inch (mm) Sleeve Length A Inch (mm) Recovered Diameter Inch (mm) Recovered Wall Thickness Inch (mm) Sleeves Per Roll Rec. Ribbon Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 77 Fig. 77 PSPT-094-1-WT BM71-94-1-342 PSPT-094-175-WT BM71-94-175-342 PSPT-094-2-WT-R PSPT-094-2-YL-R White White White White White Yellow 28 to 20 28 to 20 28 to 20 28 to 20 28 to 20 28 to 20 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) 0.094 (2.4) 0.094 (2.4) 0.094 (2.4) 0.094 (2.4) 0.094 (2.4) 0.094 (2.4) 1.015 (25.8) 1.015 (25.8) 1.765 (44.8) 1.765 (44.8) 2.000 (50.8) 2.000 (50.8) 0.024 (0.6) 0.024 (0.6) 0.024 (0.6) 0.024 (0.6) 0.024 (0.6) 0.024 (0.6) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) 100 2500 100 2500 70 70 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 Fig. 77 PSPT-094-2-BK-R Black 28 to 20 0.023 (0.6) - 0.080 (2.0) 0.094 (2.4) 2.000 (50.8) 0.024 (0.6) .024 (0.6) ± .003 (0.07) 70 M61-R4410-WT Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 77 Fig. 77 Fig. 77 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 77 Fig. 77 Fig. 77 Fig. 44 Fig. 44 Fig. 44 PSPT-125-1-WT BM71-125-1-342 PSPT-125-175-WT BM71-125-175-342 PSPT-125-2-WT-R PSPT-125-2-YL-R PSPT-125-2-BK-R PSPT-187-1-WT BM71-187-1-342 PSPT-187-175-WT BM71-187-175-342 PSPT-187-2-WT-R PSPT-187-2-YL-R PSPT-187-2-BK-R PSPT-250-1-WT BM71-250-1-342 PSPT-250-175-WT White White White White White Yellow Black White White White White White Yellow Black White White White 22 to 16 22 to 16 22 to 16 22 to 16 22 to 16 22 to 16 22 to 16 20 to 10 20 to 10 20 to 10 20 to 10 20 to 10 20 to 10 20 to 10 16 to 8 16 to 8 16 to 8 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.023 (0.5) - 0.080 (2.0) 0.023 (0.5) - 0.080 (2.0) 0.023 (0.5) - 0.080 (2.0) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.125 (3.2) 0.125 (3.2) 0.125 (3.2) 0.125 (3.2) 0.125 (3.2) 0.125 (3.2) 0.125 (3.2) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 1.015 (25.8) 1.015 (25.8) 1.765 (44.8) 1.765 (44.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 1.015 (25.8) 1.015 (25.8) 1.765 (44.8) 1.765 (44.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 1.015 (25.8) 1.015 (25.8) 1.765 (44.8) 0.047 (1.2) 0.047 (1.2) 0.047 (1.2) 0.047 (1.2) 0.047 (1.2) 0.047 (1.2) 0.047 (1.2) 0.062 (1.6) 0.062 (1.6) 0.062 (1.6) 0.062 (1.6) 0.062 (1.6) 0.062 (1.6) 0.062 (1.6) 0.093 (2.4) 0.093 (2.4) 0.093 (2.4) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) 100 1000 100 1000 70 70 70 100 1000 100 1000 70 70 70 100 1000 100 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4410-WT M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4410-WT M61-R4310 M61-R4310 M61-R4310 Fig. 44 BM71-250-175-342 White 16 to 8 0.094 (2.4) - 0.215 (5.5) 0.250 (6.4) 1.765 (44.8) 0.093 (2.4) .025 (0.6) ± .003 (0.07) 1000 M61-R4310 Fig. 77 Fig. 77 Fig. 77 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 77 Fig. 77 Fig. 77 Fig. 44 PSPT-250-2-WT-R PSPT-250-2-YL-R PSPT-250-2-BK-R PSPT-375-1-WT BM71-375-1-342 PSPT-375-175-WT BM71-375-175-342 PSPT-375-2-WT-R PSPT-375-2-YL-R PSPT-375-2-BK-R PSPT-500-1-WT White Yellow Black White White White White White Yellow Black White 16 to 8 16 to 8 16 to 8 12 to 4 12 to 4 12 to 4 12 to 4 12 to 4 12 to 4 12 to 4 8 to 1 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.187 (4.8) - 0.450 (11.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 1.015 (25.8) 1.015 (25.8) 1.765 (44.8) 1.765 (44.8) 0.645 (16.4) 0.645 (16.4) 0.645 (16.4) 1.015 (25.8) 0.093 (2.4) 0.093 (2.4) 0.093 (2.4) 0.125 (3.1) 0.125 (3.1) 0.125 (3.1) 0.125 (3.1) 0.125 (3.1) 0.125 (3.1) 0.125 (3.1) 0.187 (4.7) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) 70 70 70 100 1000 100 1000 70 70 70 100 M61-R4310 M61-R4310 M61-R4410-WT M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4410-WT M61-R4310 Fig. 44 BM71-500-1-342 White 8 to 1 0.187 (4.8) - 0.450 (11.4) 0.500 (12.7) 1.015 (25.8) 0.187 (4.7) .025 (0.6) ± .003 (0.07) 1000 M61-R4310 Fig. 44 Fig. 44 Fig. 77 Fig. 77 Fig. 77 Fig. 77 Fig. 77 Fig. 77 Fig. 44 Fig. 44 Fig. 44 Fig. 77 Fig. 77 Fig. 77 PSPT-500-175-WT BM71-500-175-342 PSPT-500-2-WT-R PSPT-500-2-YL-R PSPT-500-2-BK-R PSPT-750-2-WT-R PSPT-750-2-YL-R PSPT-750-2-BK-R PSPT-1000-1-WT PSPT-1000-175-WT BM71-1000-175-342 PSPT-1000-2-WT-R PSPT-1000-2-YL-R PSPT-1000-2-BK-R White White White Yellow Black White Yellow Black White White White White Yellow Black 8 to 1 8 to 1 8 to 1 8 to 1 8 to 1 6 to 4/10 6 to 4/10 6 to 4/10 2 to 0.95 2 to 0.95 2 to 0.95 2 to 0.95 2 to 0.95 2 to 0.95 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.250 (6.4) - 0.700 (17.8) 0.250 (6.4) - 0.700 (17.8) 0.250 (6.4) - 0.700 (17.8) 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.750 (19.5) 0.750 (19.5) 0.750 (19.5) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.765 (44.8) 1.765 (44.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 1.015 (25.8) 1.765 (44.8) 1.765 (44.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) 100 1000 70 70 70 70 70 70 50 50 500 70 70 70 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4410-WT M61-R4310 M61-R4310 M61-R4410-WT M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4310 M61-R4410-WT Approx. wire gauge based on AWG for THHN wire. BradyID.com/bmp61 1-888-272-3946 11 Wire & Cable Materials Repositionable Vinyl Cloth B-498 Removable Adhesive Cloth Material Repositionable vinyl cloth material for wire, cable and component marking. Adhesive and cloth backing offers excellent holding power, while easily being repositioned and removed. A B Figure 29 Diagram Catalog Number B-# Material Label Width A Inch (mm) Color Label Height B Inch (mm) Approx. Wire Gauge Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 29 PTL-15-498 B-498 Vinyl White 1.000 (25.4) 0.275 (7.0) 22 to 16 1 750 M61-R6210 Fig. 29 PTL-7-498 B-498 Vinyl White 0.500 (12.7) 0.500 (12.7) 22 to 16 1 500 M61-R6210 Fig. 29 PTL-10-498 B-498 Vinyl White 0.250 (6.4) 0.750 (19.1) 16 to 10 1 750 M61-R6210 Fig. 29 BM71-11-498 B-498 Vinyl White 0.500 (12.7) 0.750 (19.1) 16 to 10 1 5000 M61-R6210 Fig. 29 PTL-11-498 B-498 Vinyl White 0.500 (12.7) 0.750 (19.1) 16 to 10 1 500 M61-R6210 Fig. 29 PTL-17-498 B-498 Vinyl White 1.000 (25.4) 0.500 (12.7) 12 to 10 1 500 M61-R6210 Fig. 29 PTL-16-498 B-498 Vinyl White 0.375 (9.5) 1.000 (25.4) 12 to 10 1 500 M61-R6210 Fig. 29 BM71-18-498 B-498 Vinyl White 0.750 (19.1) 1.000 (25.4) 12 to 10 1 2500 M61-R6210 Fig. 29 PTL-18-498 B-498 Vinyl White 0.750 (19.1) 1.000 (25.4) 12 to 10 1 250 M61-R6210 Fig. 29 BM71-19-498 B-498 Vinyl White 1.000 (25.4) 1.000 (25.4) 12 to 10 1 2500 M61-R6210 Fig. 29 PTL-19-498 B-498 Vinyl White 1.000 (25.4) 1.000 (25.4) 12 to 10 1 250 M61-R6210 Fig. 29 PTL-28-498 B-498 Vinyl White 0.250 (6.4) 1.500 (38.1) 10 to 4 1 750 M61-R6210 Fig. 29 BM71-29-498 B-498 Vinyl White 0.500 (12.7) 1.500 (38.1) 10 to 4 1 5000 M61-R6210 Fig. 29 PTL-30-498 B-498 Vinyl White 0.750 (19.1) 1.500 (38.1) 10 to 4 1 250 M61-R6210 Fig. 29 PTL-31-498 B-498 Vinyl White 1.000 (25.4) 1.500 (38.1) 10 to 4 1 250 M61-R6210 Fig. 29 PTL-32-498 B-498 Vinyl White 1.500 (38.1) 1.500 (38.1) 10 to 4 1 250 M61-R6210 Fig. 29 PTL-21-498 B-498 Vinyl White 1.000 (25.4) 2.500 (63.5) Cables 1 100 M61-R6210 Fig. 29 PTL-23-498 B-498 Vinyl White 1.000 (25.4) 4.000 (101.6) Cables 1 100 M61-R6210 Fig. 29 PTL-33-498 B-498 Vinyl White 1.500 (38.1) 4.000 (101.6) Cables 1 100 M61-R6210 Fig. 29 PTL-34-498 B-498 Vinyl White 1.500 (38.1) 6.000 (152.4) Cables 1 50 M61-R6210 Polypropylene Flags B-425 Solvent-Resistant Material White polypropylene material with matte/opaque finish for thermal transfer printing or write-on applications. Excellent solvent resistance and print performance; not recommended for long-term outdoor use. A A B B Figure 47B = Label Height FigureB 48 = Label Height A = Label Width A = Label Width Diagram Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 47 Fig. 48 Fig. 47 PTLFP-01-425 PTLFT-01-425 PTLFP-02-425 B-425 B-425 B-425 Polypropylene Polypropylene Polypropylene White White White 1.180 (30.0) 1.180 (30.0) 1.750 (44.5) 0.788 (20.0) 0.788 (20.0) 1.000 (25.4) 1 1 1 250 250 100 M61-R6210 M61-R6210 M61-R6210 Approx. wire gauge based on AWG for THHN wire. 12 Terminal Block / Patch Panel Materials Polyester Variety of continuous materials for terminal blocks and patch panels, with different glosses and adhesives for multiple applications: • B-422 White Polyester Material with 2 mils of adhesive for rough surface applications • B-423 White Polyester Material widely used for component identification, barcoding, asset and inventory tracking • B-428 Metallized Polyester Material with matte finish that withstands solvents and variable temps • B-430 Clear Polyester Material with permanent adhesive • B-483 White Polyester Material with aggressive adhesive specifically designed for powered coated surfaces A • B-498 Repositionable Vinyl Cloth Material with adhesive and cloth backing B A B Figure 33 Figure 30 B = Label Height A = Label Width Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 33 M61C-375-422 B-422 Polyester White 0.375 (9.5) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410 Fig. 33 M61C-475-422 B-422 Polyester White 0.475 (12.1) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410 Fig. 33 M61C-500-422 B-422 Polyester White 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410 Fig. 33 M61C-625-422 B-422 Polyester White 0.625 (15.8) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410 M61C-500-423 B-423 Polyester White 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410 M61C-500-428 B-428 Polyester Silver 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4310 Fig. 33 M61C-500-430 B-430 Polyester White 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410 Fig. 33 M61C-375-430 B-430 Polyester White 0.375 (9.5) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410 M61C-500-483 B-483 Polyester White 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410 Fig. 30 PTLTB-498-240 B-498 Vinyl White 0.240 (6.1) 30 ft. (9.1 m) 1 1 Roll Cont. M61-R6210 Fig. 30 BPTLTB-498-240 B-498 Vinyl White 0.240 (6.1) 300 ft. (91.4 m) 1 1 Roll Cont. M61-R6210 Fig. 30 PTLTB-498-318 B-498 Vinyl White 0.318 (8.1) 30 ft. (9.1 m) 1 1 Roll Cont. M61-R6210 Fig. 30 BPTLTB-498-318 B-498 Vinyl White 0.318 (8.1) 300 ft. (91.4 m) 1 1 Roll Cont. M61-R6210 Fig. 30 PTLTB-498-375 B-498 Vinyl White 0.375 (9.5) 30 ft. (9.1 m) 1 1 Roll Cont. M61-R6210 Fig. 30 BPTLTB-498-375 B-498 Vinyl White 0.375 (9.5) 300 ft. (91.4 m) 1 1 Roll Cont. M61-R6210 Fig. 30 M61C-375-498 B-498 Vinyl White 0.375 (9.5) 30 ft. (9.1 m) 1 1 Roll Cont. M61-R6210 Fig. 30 BM61C-375-498 B-498 Vinyl White 0.375 (9.5) 300 ft. (91.4 m) 1 1 Roll Cont. M61-R6210 Fig. 30 M61C-240-498 B-498 Vinyl White 0.240 (6.1) 30 ft. (9.1 m) 1 1 Roll Cont. M61-R6210 Fig. 30 BM61C-240-498 B-498 Vinyl White 0.375 (9.5) 300 ft. (91.4 m) 1 1 Roll Cont. M61-R6210 Fig. 30 M61C-318-498 B-498 Vinyl White 0.318 (8.1) 30 ft. (9.1 m) 1 1 Roll Cont. M61-R6210 Fig. 30 BM61C-318-498 B-498 Vinyl White 0.375 (9.5) 300 ft. (91.4 m) 1 1 Roll Cont. M61-R6210 Diagram B-422 B-423 Fig. 33 B-428 Fig. 33 B-430 B-483 Fig. 33 B-498 Approx. wire gauge based on AWG for THHN wire. BradyID.com/bmp61 1-888-272-3946 13 Asset Tracking Materials Polyester B-483 Aggressive Adhesive Polyester Material White polyester with glossy finish and aggressive adhesive specifically designed for powder coated surfaces. A A A HEADER A B B B B HEADER Figure 29 Figure 33 Figure 46 (Includes black border) Figure 72 (Includes pre-printed header) Diagram Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 33 PTL-101-483 B-483 Polyester White 0.250 (6.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-8-483 B-483 Polyester White 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 29 PTL-16-483 B-483 Polyester White 1.000 (25.4) 0.375 (9.5) 1 500 M61-R6010 Fig. 29 PTL-17-483 B-483 Polyester White 1.000 (25.4) 0.500 (12.7) 1 500 M61-R6010 Fig. 29 PTL-19-483 B-483 Polyester White 1.000 (25.4) 1.000 (25.4) 1 250 M61-R6010 Fig. 33 PTL-42-483 B-483 Polyester White 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 46 PTL-24-483-BK B-483 Polyester Black border 1.130 (28.7) 0.500 (12.7) 1 500 M61-R6010 Fig. 33 PTL-100-483 B-483 Polyester White 1.300 (33.0) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 29 PTL-65-483 B-483 Polyester White 1.375 (34.9) 1.000 (25.4) 1 250 M61-R6010 Fig. 29 PTL-29-483 B-483 Polyester White 1.500 (38.1) 0.500 (12.7) 1 500 M61-R6010 Fig. 29 PTL-30-483 B-483 Polyester White 1.500 (38.1) 0.750 (19.1) 1 250 M61-R6010 Fig. 29 PTL-31-483 B-483 Polyester White 1.500 (38.1) 1.000 (25.4) 1 250 M61-R6010 Fig. 29 PTL-32-483 B-483 Polyester White 1.500 (38.1) 1.500 (38.1) 1 250 M61-R6010 Fig. 33 PTL-43-483 B-483 Polyester White 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 29 PTL-20-483 B-483 Polyester White 2.000 (50.8) 1.000 (25.4) 1 100 M61-R6010 Fig. 29 PTL-61-483 B-483 Polyester White 2.000 (50.8) 0.500 (12.7) 1 100 M61-R6010 Fig. 29 PTL-37-483 B-483 Polyester White 3.000 (76.2) 1.900 (48.3) 1 100 M61-R6010 Fig. 72 PTL-37-483-WARNING B-483 Polyester Orange/Black on White 3.000 (76.2) 1.900 (48.3) 1 100 M61-R6010 Fig. 29 PTL-23-483 B-483 Polyester White 4.000 (101.6) 1.000 (25.4) 1 100 M61-R6010 Fig. 72 PTL-38-483-WARNING B-483 Polyester Orange/Black on White 4.000 (101.6) 1.900 (48.3) 1 100 M61-R6010 Hundreds of Additional Label Parts and Custom Parts Available The BMP®61 label printer supports over 600 label materials and prints on a range of die-cut and continuous materials up to 2” (51mm) wide. For a full list of consumables, visit BradyID.com or contact customer service at 888-272-3946 for custom options. 14 Asset Tracking Materials Polyester B-422 Solvent-Resistant Polyester Material White label stock with glossy finish and 2 mils of adhesive for rough surface applications, including low surface energy plastics. Designed to withstand solvent exposure. UL rated for surfaces commonly used in solar panel manufacturing. Also used for component identification, barcoding, asset and inventory tracking. A C A A A B B Figure 29 DB B Figure 33 A Figure 34 B Figure 40 Figure 54 Diagram Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 34 PTL-39-422 B-422 Polyester White 0.375 (9.5) 0.600 (15.2) 1 750 M61-R6010 Fig. 33 PTL-46-422 B-422 Polyester White 0.375 (9.5) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 29 PTL-44-422 B-422 Polyester White 0.500 (12.7) 0.375 (9.5) 1 500 M61-R6010 Fig. 29 PTL-7-422 B-422 Polyester White 0.500 (12.7) 0.500 (12.7) 1 500 M61-R6010 Fig. 29 PTL-5-422 B-422 Polyester White 0.500 (12.7) 0.200 (5.1) 1 750 M61-R6010 Fig. 33 PTL-8-422 B-422 Polyester White 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 29 PTL-16-422 B-422 Polyester White 1.000 (25.4) 0.375 (9.5) 1 500 M61-R6010 Fig. 29 PTL-17-422 B-422 Polyester White 1.000 (25.4) 0.500 (12.7) 1 500 M61-R6010 Fig. 40 PTPSL-17-422 B-422 Polyester White 1.000 (25.4) 0.500 (12.7) 1 500 M61-R6010 Fig. 29 PTL-19-422 B-422 Polyester White 1.000 (25.4) 1.000 (25.4) 1 250 M61-R6010 Fig. 33 PTL-42-422 B-422 Polyester White 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 29 PTL-29-422 B-422 Polyester White 1.050 (38.1) 0.500 (12.7) 1 500 M61-R6010 Fig. 29 PTL-45-422 B-422 Polyester White 1.050 (38.1) 0.375 (9.5) 1 500 M61-R6010 Fig. 29 PTL-30-422 B-422 Polyester White 1.500 (38.1) 0.750 (19.1) 1 250 M61-R6010 Fig. 29 PTL-32-422 B-422 Polyester White 1.500 (38.1) 1.500 (38.1) 1 250 M61-R6010 Fig. 54 PTL-35-422-PROP B-422 Polyester Black on Silver 1.630 (41.4) 0.750 (19.1) 1 250 M61-R6010 Fig. 33 PTL-43-422 B-422 Polyester White 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 29 PTL-20-422 B-422 Polyester White 2.000 (50.8) 1.000 (25.4) 1 100 M61-R6010 Fig. 40 PTPSL-20-422 B-422 Polyester White 2.000 (50.8) 1.000 (25.4) 1 100 M61-R6010 Fig. 40 PTPSL-26-422 B-422 Polyester White 2.750 (69.9) 1.250 (31.8) 1 100 M61-R6010 Fig. 29 PTL-22-422 B-422 Polyester White 3.000 (76.2) 1.000 (25.4) 1 100 M61-R6010 Fig. 29 PTL-37-422 B-422 Polyester White 3.000 (76.2) 1.900 (48.3) 1 100 M61-R6010 Fig. 40 PTPSL-50-422 B-422 Polyester White 3.000 (76.2) 1.650 (41.9) 1 100 M61-R6010 Fig. 29 PTL-23-422 B-422 Polyester White 4.000 (101.6) 1.000 (25.4) 1 100 M61-R6010 Fig. 29 PTL-38-422 B-422 Polyester White 4.000 (101.6) 1.900 (48.3) 1 100 M61-R6010 BMP®61 Magnet Accessory (Catalog Number: BMP-MAGNET-1) The heavy-duty magnet accessory* allows you to go hands-free with your BMP®61 printer. Simply attach the magnet to the back of your printer and then stick it to any magnetized surface. *Sold separately. BradyID.com/bmp61 1-888-272-3946 15 Asset Tracking Materials Polyester B-423 Glossy Polyester Material White polyester thermal transfer label with a glossy finish. Widely used for component identification, barcoding, asset and inventory tracking. A B B Figure 29 16 Figure 33 B B B Figure 46 (Includes black border) A A A A Figure 51 A A B Figure 52 B Figure 53 Figure 54 Diagram Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 29 PTL-1-423 B-423 Polyester White 0.250 (6.4) 0.250 (6.4) 1 750 M61-R6010 Fig. 29 PTL-3-423 B-423 Polyester White 0.375 (9.5) 0.375 (9.5) 1 500 M61-R6010 Fig. 29 PTL-4-423 B-423 Polyester White 0.400 (10.6) 0.400 (10.2) 1 500 M61-R6010 Fig. 29 PTL-5-423 B-423 Polyester White 0.500 (12.7) 0.200 (5.1) 1 750 M61-R6010 Fig. 53 PTL-6-423 B-423 Polyester White 0.500 (12.7) 0.275 (7.0) 1 750 M61-R6010 Fig. 29 PTL-7-423 B-423 Polyester White 0.500 (12.7) 0.500 (12.7) 1 500 M61-R6010 Fig. 33 PTL-8-423 B-423 Polyester White 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 29 PTL-9-423 B-423 Polyester White 0.650 (16.5) 0.200 (5.1) 1 750 M61-R6010 Fig. 29 PTL-10-423 B-423 Polyester White 0.750 (19.1) 0.250 (6.4) 1 750 M61-R6010 Fig. 29 PTL-13-423 B-423 Polyester White 0.900 (22.9) 0.250 (6.4) 1 750 M61-R6010 Fig. 29 PTL-14-423 B-423 Polyester White 1.000 (25.4) 0.187 (4.8) 1 750 M61-R6010 Fig. 29 PTL-15-423 B-423 Polyester White 1.000 (25.4) 0.275 (7.0) 1 750 M61-R6010 Fig. 29 BM71-16-423 B-423 Polyester White 1.000 (25.4) 0.375 (9.5) 1 5000 M61-R6010 Fig. 29 PTL-16-423 B-423 Polyester White 1.000 (25.4) 0.375 (9.5) 1 500 M61-R6010 Fig. 29 BM71-17-423 B-423 Polyester White 1.000 (25.4) 0.500 (12.7) 1 5000 M61-R6010 Fig. 29 PTL-17-423 B-423 Polyester White 1.000 (25.4) 0.500 (12.7) 1 500 M61-R6010 Fig. 29 BM71-19-423 B-423 Polyester White 1.000 (25.4) 1.000 (25.4) 1 2500 M61-R6010 Fig. 29 PTL-19-423 B-423 Polyester White 1.000 (25.4) 1.000 (25.4) 1 250 M61-R6010 Fig. 29 BM71-20-423 B-423 Polyester White 1.000 (25.4) 2.000 (50.8) 1 1000 M61-R6010 Fig. 46 PTL-24-423-BK B-423 Polyester White 1.130 (28.7) 0.500 (12.7) 1 500 M61-R6010 Fig. 29 PTL-25-423 B-423 Polyester White 1.250 (31.8) 0.250 (6.4) 1 750 M61-R6010 Fig. 29 PTL-27-423 B-423 Polyester White 1.500 (38.1) 0.125 (3.2) 1 750 M61-R6010 Fig. 29 PTL-28-423 B-423 Polyester White 1.500 (38.1) 0.250 (6.4) 1 750 M61-R6010 Fig. 29 PTL-29-423 B-423 Polyester White 1.500 (38.1) 0.500 (12.7) 1 500 M61-R6010 Fig. 51 PTL-30-423-CALI B-423 Polyester White 1.500 (38.1) 0.750 (19.1) 1 250 M61-R6010 Fig. 53 PTL-30-423-INSP B-423 Polyester Black on White 1.500 (38.1) 0.750 (19.1) 1 250 M61-R6010 Fig. 52 PTL-30-423-TEST B-423 Polyester White 1.500 (38.1) 0.750 (19.1) 1 250 M61-R6010 Fig. 29 PTL-31-423 B-423 Polyester White 1.500 (38.1) 1.000 (25.4) 1 250 M61-R6010 Fig. 29 PTL-32-423 B-423 Polyester White 1.500 (38.1) 1.500 (38.1) 1 250 M61-R6010 Fig. 54 PTL-35-423-PROP B-423 Polyester Black on Silver 1.630 (41.4) 0.750 (19.1) 1 250 M61-R6010 Fig. 29 PTL-2-423 B-423 Polyester White 2.000 (50.8) 0.250 (6.4) 1 100 M61-R6010 Fig. 29 PTL-20-423 B-423 Polyester White 2.000 (50.8) 1.000 (25.4) 1 100 M61-R6010 Fig. 29 PTL-26-423 B-423 Polyester White 2.750 (69.9) 1.250 (31.8) 1 100 M61-R6010 Fig. 29 PTL-22-423 B-423 Polyester White 3.000 (76.2) 1.000 (25.4) 1 100 M61-R6010 Fig. 29 PTL-37-423 B-423 Polyester White 3.000 (76.2) 1.900 (48.3) 1 100 M61-R6010 Fig. 29 PTL-23-423 B-423 Polyester White 4.000 (101.6) 1.000 (25.4) 1 100 M61-R6010 Fig. 29 PTL-38-423 B-423 Polyester White 4.000 (101.6) 1.900 (48.3) 1 100 M61-R6010 General ID Materials Vinyl B-439 General Purpose Vinyl Material Colored vinyl material for thermal transfer printing. Ideal for rating plates, finished product identification and general purpose labeling. A B Figure 33 Diagram Catalog Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Labels Per Row Labels Per Pkg Rec. Ribbon Fig. 33 PTL-8-439 B-439 Vinyl White 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-42-439 B-439 Vinyl White 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-43-439 B-439 Vinyl White 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-8-439-YL B-439 Vinyl Yellow 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-42-439-YL B-439 Vinyl Yellow 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-43-439-YL B-439 Vinyl Yellow 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-8-439-BK B-439 Vinyl Black 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410-WT Fig. 33 PTL-42-439-BK B-439 Vinyl Black 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410-WT Fig. 33 PTL-43-439-BK B-439 Vinyl Black 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410-WT Fig. 33 PTL-8-439-BL B-439 Vinyl Blue 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410-WT M61-R4410-WT Fig. 33 PTL-42-439-BL B-439 Vinyl Blue 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. Fig. 33 PTL-43-439-BL B-439 Vinyl Blue 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R4410-WT Fig. 33 PTL-8-439-GR B-439 Vinyl Green 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-42-439-GR B-439 Vinyl Green 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-43-439-GR B-439 Vinyl Green 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-8-439-OR B-439 Vinyl Orange 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-42-439-OR B-439 Vinyl Orange 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-43-439-OR B-439 Vinyl Orange 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-8-439-RD B-439 Vinyl Red 0.500 (12.7) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-42-439-RD B-439 Vinyl Red 1.000 (25.4) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Fig. 33 PTL-43-439-RD B-439 Vinyl Red 1.900 (48.3) 50 ft. (15.2 m) 1 1 Roll Cont. M61-R6010 Bulk Parts for High Volume Printing Bulk label parts offer a cost-effective solution for high volume printing with the BMP®61printer*. Look for material catalog numbers that begin with “BM71-” or “BPTL”. *Bulk label printing requires the media feeder and smart cell spool which are included in the bulk material packaging, and LabelMark™ Software. BradyID.com/bmp61 1-888-272-3946 17 LabelMark™ 6 Labeling Software LabelMark 6 Labeling Software features a unique app environment to provide access to what you need, right when you need it. It offers label creation solutions from basic labeling to advanced data import on labels, allowing users to: ■■ Integrate data sources, label designs and batch printing into one cohesive system ■■ Easily make copies of imported data by defining number of copies ■■ Print text vertically on continuous tapes Printer, Accessories and Ribbons Printer Catalog Numbers Catalog Number Description BMP61-W BMP61 Label Printer* with WiFi BMP61 BMP61 Label Printer* Printer Accessories BMP-HC-1 Hardcase Accessory BMP-STRAP-1 Carrying Strap BMP-MAGNET-1 Magnet Accessory BMP41-AC AC Adapter / Battery Charger BMP41-QC External Battery Quick Charger BMP41-BATT Rechargeable NiHM Battery BMP61-BATCOV Battery Cover BMP61-CUTTER Cutter Accessory PCK-5 Cleaning Kit 5-Pack * Printer ships with AC adapter/battery charger, NiMH rechargeable battery, USB cord, utility strap, hardcase, PTL-19-423 label material, M61-R6010 ribbon, Quick Start Guide and Driver Disks. Printer Ribbons All materials in the printer will work with a new series of M61 ribbons that easily fit into the printer. Catalog Number 18 Description Size M61-R6610 Black R6600 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R6010 Black R6000 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R6410 Black R6410 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R4310 Black R4300 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R6210 Black R6200 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R4410-WT White R4400 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R6810-WT White R6800 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R6710-WT White R6710 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R4410-RD Red R4400 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) M61-R4410-BL Blue R4400 Series Ribbon 2” x 75’ (50.8 mm x 22.85 m) ■■ Use QR codes and barcodes ■■ Import data and serialization in a few clicks with “check error” function ■■ Create jobs to simultaneously manage multiple print projects and printers Printer Specifications Printer: Text Justification Horizontal: left, center or right Vertical: top, middle, bottom List Function Yes Graphic Download Yes Printer Name BMP®61 Label Printer Print Resolution Thermal transfer, 300 dpi Max Lines of Print 25 Print Speed 1.33"/sec (33.8mm/sec) Keyboard Type* QWERTY, AZERTY, QWERTZ, CYRILLIC Multi-Copy Printing Up to 999 Copies Dimensions: 12.93" L x 4.22" W x 4.19" H (328.5 x 107.2 x 106.5 mm) Multi-Line Print Yes Frame Feature Yes Weight 3.212 lbs (equipped with supplied media & ribbon) Save Files Yes Warranty 2 Year Display: Overmold/Rugged Yes LCD Type / Size Custom LCD, Color, 2.8” QVGA Operating Temp 40° to 120° F (5° to 49° C) LCD Resolution 320 x 240 pixels Humidity 10% to 90% (non-condensing) LCD Characters Font Size Dependent Storage Temp -24° to 140° F (-30° to 60° C) LCD Backlight Yes Continuous or Die Cut Labels Continuous and die cut Communication and Interface: Portability Yes, via grip or strap Connectivity: USB 2.0, USB Flash drive, Wi-Fi* PC Connectivity USB/Wifi Import Data Yes, via USB Flash drive Software Compatibility Labelmark® Software version 6.0 or higher, Brady Mobile Apps Print Functions: (continued) Features: Memory 512 MB RAM / 256 MB Flash User Profiles No Cutter Type Manual Cut Options Cut between labels or at end of print job Media: Label Retention After Cut No, dispensed upright Type Ribbon and Tape separate, also bulk rolls Labels Per Day (Average) 750 Load Labels Location Top Battery Life Indicator Yes Label Output Location Top Label Odometer (Supply Remaining) Yes Compatible Media Wearability Options Yes, via strap BPTL, BPTDS, BPSPT, BPTLTB, PTL, PSHT, PTLEP, PTS, PTLFP, PSPT, PTPSL, PSFR, PTPS, PTLSL, BM71, M61, M61C, BM61C, Custom available Drop Test Drop Tested to spec MIL-STD-810G: Four foot drop Memory in Cartridge Yes 1.92" (48.76 mm) Languages* 22: Bulgarian, Croatian, Czech, Danish, Dutch, English, Estonian, Finnish, French, German, Hungarian, Italian, Norwegian, Polish, Portuguese, Romanian, Russian, Slovak, Slovenian, Spanish, Swedish, Turkish Maximum Print Width Maximum Print Length 40.00" (1016 mm) Maximum Liner Width 2.25" (57 mm) with liner Media Widths Various sizes from 0.235" to 2.00" (6.4mm to 50.8mm) Minimum Media Width 0.235" (6.4mm) Minimum Label Height 0.236" (5.99mm) Liner Width 0.812", 1.062", 1.312", 1.562", 1.812", 2.250" Included Media M61-R6010 PTL-19-423 (1.0" x 1.0"/25.4mm x 25.4mm) Power: Power Supply Rechargable NiMH battery, AC Power/battery changer Battery Included Yes Battery Life 1000 labels Rechargeable Battery Yes NiMH (1200mAh) Re-Charge Time (estimated) 4 hours Number of Stock Parts* 600+ Charging Options Internal or External with quick charger Color Print Capability Single print color on a label Power Source Voltage 110-240 Auto Shut Off User configurable 5-30 minutes Available Media Colors Wire and Cable Wrap Mode Yes Ribbons Compatible ribbons begin with M61-Rxxx Cable Flag Mode Yes Cartridge Width Detection Yes Terminal Block Mode Yes Cartridge Setting Detection Yes Patch Panel Mode Yes Custom Labels Available Yes Circuit Breaker Mode Yes Compliance: Banner (Landscape) Yes Banner (Portrait) Yes Print Preview Yes Multi-Label View No Serialization Yes, multiple and linked Barcoding 39 & 128 Date/Time Stamp (Real Time Clock) Yes Font Points or Millimeters History Yes, last 10 print jobs Text Sizes 4-174pt + autosizing Fixed Length Yes Number of Fonts (2) Brady Alpine, Brady Fixed Width Mirror Print Yes, via software Number of Symbols 450 Vertical Print Yes Special Characters Depends upon Regional Keypad, see manual Reverse Print Yes, via software Rotate Print Yes Auto Format Yes Symbols Arrows, Datacomm, Electrical, Exit, Fire Safety, First Aid, CLP/GHS, HSID, Greek, Home Electrical, International, Laboratory, Mandatory, Packaging, Miscellaneous, Personal Protective Equipment, Prohibition, Public Info, Safety, Warning, WHMIS Print Functions: Media: White, Yellow, Gray, Green, Orange, Red, Clear, Silver, Blue, Brown, Purple, Clear Ribbon: Black, White, Blue and Red Agency Approvals* FCC Class A, UL-BMP61 WLAN 1EEE 802.11 b/g/n-BMP61-W Trade Harmonizaiton Code: (HTS Schedule A or B) /844.39.9000, Country of Origin: Malaysia (printer), ECCN: EAR99 MSDS For battery MSDS visit www.BradyID.com Fonts, Graphics, Symbols: *Available in select countries. Specifications subject to change without notice. BradyID.com/bmp61 1-888-272-3946 19 USA Customer Service: 1-888-272-3946 Inside Sales: 1-888-311-0775 BradyID.com Canada Customer Service: 1-800-263-6179 BradyCanada.ca Mexico Customer Service: 1-800-262-7777 Inside Sales: 1-800-262-7777 ext 177 BradyLatinAmerica.com © 2016 Brady Worldwide Inc. ALL RIGHTS RESERVED
BMP61-CUTTER 价格&库存
很抱歉,暂时无法提供与“BMP61-CUTTER”相匹配的价格&库存,您可以联系我们找货
BMP61-CUTTER
    • 1+957.739991+123.84907
