CMC-3750
CMC-3750
    BRADY
    n/a
CMC-3750 数据手册
CUSTOM AND SPECIALTY PRODUCTS Die-Cut Overlaminates Die-cut overlaminate labels are sized to fit popular dot matrix, thermal transfer and laser label sizes. Liners are backslit for easy overlaminate removal. Die-cut overlaminates are produced in B-103 clear polyester, a good generalpurpose and PC board overlaminate that withstands high temperatures, dirt, oil and cleaning solvents while displaying excellent clarity. Packaged in rolls of 5,000 or 2,000 depending on label size. General-Purpose Clear Polyester (B-103) DIE-CUT OVERLAMINATES / CIRCULAR MASKS CUSTOM AND SPECIALTY PRODUCTS 240 B-103 Clear Polyester LAM-1-103 LAM-2-103 LAM-3-103 LAM-5-103 LAM-6-103 LAM-7-103 Pieces Per Roll 5,000 5,000 5,000 2,000 2,000 2,000 Label Size Inch (mm) 0.650 x 0.200 1.000 x 0.250 1.500 x 0.250 1.000 x 0.500 1.500 x 0.750 2.000 x 1.000 Label Repeat Inch (mm) 0.262 (6.65) 0.312 (7.92) 0.312 (7.92) 0.562 (14.27) 0.812 (20.62) 1.062 (26.97) (16.51 x 5.08) (25.40 x 6.35) (38.10 x 6.35) (25.40 x 12.70) (38.10 x 19.05) (50.80 x 25.40) Overlaminates protect bar codes from dirt, oil and abrasion without affecting readability. Circular Masks  ROLL - FORM MASKS Beige Creped Masking Tape (B-540) Part Number LMC-1000 LMC-1125 LMC-1250 LMC-1375 LMC-1500 LMC-2000 LMC-3000  CARD - MOUNTED Masks Per Package 1,000 1,000 1,000 1,000 1,000 500 500 Diameter of Circle Inch (mm) 1.000 (25.40) 1.125 (28.58) 1.250 (31.75) 1.375 (34.93) 1.500 (38.10) 2.000 (50.80) 3.000 (76.20) Designed for production line applications, the masks are produced in roll form for convenient use. MASKS Beige Creped Masking Tape (B-540) Part Number CMC-1250* CMC-1875* CMC-2500* CMC-3125* CMC-3750* CMC-4375* CMC-5000* CMC-5625* CMC-6250* CMC-6875* CMC-7500* CMC-8125** CMC-8750** CMC-9375** CMC-1000** Masks Per Card 180 144 144 112 72 60 54 32 28 24 24 20 20 16 16 Diameter of Circle Inch (mm) 0.125 (3.18) 0.187 (4.75) 0.250 (6.35) 0.312 (7.92) 0.375 (9.53) 0.437 (11.10) 0.500 (12.70) 0.562 (14.27) 0.625 (15.88) 0.687 (17.45) 0.750 (19.05) 0.812 (20.62) 0.875 (22.23) 0.937 (23.80) 1.000 (25.40) * CMC-1250 - CMC-7500 furnished on 2.000" x 9.000" (5.08 cm x 22.90 cm) dispenser cards. **CMC-8125 - CMC-1000 furnished on 2.750" x 9.000" (6.99 cm x 22.90 cm) dispenser cards. www.bradyid.com Mounted on Blue Streak dispenser cards for easy handling and quick application.
CMC-3750 价格&库存
很抱歉,暂时无法提供与“CMC-3750”相匹配的价格&库存,您可以联系我们找货
