Technical Data Sheet
BRADY B-724 THERMAL TRANSFER PRINTABLE POLYIMIDE LABEL STOCK
TDS No. B-724
Effective Date: 02/27/2023
Description:
GENERAL
Print Technology: Thermal Transfer
Material Type: Greenish/Amber Polyimide
Finish: Matte
Adhesive: Permanent Acrylic
APPLICATIONS
Printed circuit board and electronic component pre-process labeling
RECOMMENDED RIBBONS
Brady Series R4300
REGULATORY APPROVALS
For information on the Weee-RoHS compliance status for a Brady Product go to one of the following websites:
In Canada: www.bradycanada.ca/weee-rohs
In Europe: www.bradyeurope.com/rohs
In Japan: www.brady.co.jp/products/labelsuse/rohs
All other regions: www.bradyid.com/weee-rohs
SPECIAL FEATURES
B-724 in combination with the Series R4300 ribbon passes the requirements of:
MIL-STD-202G, Method 215K
SAE AS81531 Marking of Electrical Insulating Material
Preheat can be employed to further enhance print permanence in the case of extreme solvent and/or abrasion
exposure.
B-724 is designed to withstand multiple cycles of harsh condition washes for printed circuit boards. Degradation of
topcoat may be seen in certain aqueous chemistries.
Details:
PHYSICAL PROPERTIES
Thickness
TEST METHODS
ASTM D1000
-Substrate
-Adhesive
-Total (excluding liner)
AVERAGE RESULTS
0.0028 inch (0.072 mm)
0.0016 inch (0.039 mm)
0.0044 inch (0.111 mm)
Adhesion to:
-Stainless Steel
ASTM D1000
20 minute dwell
24 hour dwell
45 oz/inch (49 N/100 mm)
47 oz/inch (51 (N/100 mm)
-Epoxy PC Board
20 minute dwell
24 hour dwell
33 oz/inch (36 N/100 mm)
48 oz/inch (53 N/100 mm)
Tack
ASTM D2979
Polyken™ Probe Tack
(1 second dwell, 1 cm/sec
separation)
66 oz (1883 grams)
Drop Shear
PSTC-7 (except use ½” x 1”
sample)
Over 100 hours
Dielectric Strength
ASTM D1000
10000 volts
Flammability
ASTM D1000
Average Burn Time
Less than 5 seconds
Performance properties were tested on B-724 printed with the Brady Series R4300 thermal transfer ribbon.
Printed samples of B-724 were laminated to aluminum and allowed to dwell 24 hours before exposure to the
indicated environmental conditions.
PERFORMANCE PROPERTIES
Short Term High Service
Temperature
TEST METHODS
TYPICAL RESULTS
80 seconds at various temperatures
No visible effect to label at 626°F
(330°C), label discolors slightly at
644°F (340°C), but still functional, at
662°F (350°C) label still functional but
slightly discolored and adhesive
discolored at label edge.
5 minutes at various temperatures
No visible effect to label at 536°F
(280°C),label discolors slightly at
572°F (300°C) but still functional, at
608°F (320°C) label still functional but
discolored at edge.
2 hours at various temperatures
No visible effect to label at 500°F
(260°C), adhesive brown at edge of
label at 536°F(280°C).
Long Term High Service Temperature 1000 hours at various temperatures
No visible effect to label at 356°F at
(180°C) label still functional but
brown at edge.
Low Service Temperature
1000 hours at -94°F (-70°C)
No visible effect
ASTM G155, Cycle 1
1000 hours in Xenon Arc
Weather-Ometer®
1000 hours at 100°F, 95% RH
Topcoat degraded
Weatherability
1
Humidity Resistance
UV Light Resistance
Abrasion Resistance
Salt Fog Resistance
Chemical Vapor Phase Resistance
No visible effect
ASTM G155, cycle 1, dry
Topcoat fades to off-white,
1000 hours in Q-Sun Xenon Test
Chamber
Taber Abraser, CS-10 grinding wheels, Print legible after 100 cycles
500 g/arm (Fed. Std. 191A, Method
5306)
ASTM B117
Slight discoloration of topcoat, no
1000 hours in 5% salt fog solution
visible effect to print
chamber
Label adhered to epoxy PC board and
exposed to the vapor of the boiling
chemical for 10 minutes and then
rubbed with a wetted cotton swab for
10 rubs.
Test samples were baked 4 minutes at
160°C prior to testing.
Ionox® 3955
Slight print smear
Micronox® MX 2501
Slight print smear
Label adhered to epoxy PC board and No visible effect
exposed to 10 second dip at 249°C
Wave Solder
1
B-724 is not recommended for outdoor use.
PERFORMANCE PROPERTY
CHEMICAL RESISTANCE
Samples were printed with the Brady Series R4300 thermal transfer ribbon. Labels were adhered to epoxy PC
board. Test samples were exposed to indicated environments. Test samples were baked 4 minutes at 160°C
before testing. All test samples were immersed in the test fluids for 10 minutes prior to rub with cotton swab ten
times.
CHEMICAL REAGENT
SUBJECTIVE OBSERVATION TO VISUAL CHANGE
EFFECT TO LABEL
R4300
WITHOUT RUB
1
WITH RUB
1
Kyzen Corp. 15% Aquanox®
A4625 at 140°F (60°C)
No visible
effect
Kyzen Corp. 17% Aquanox®
A4620 at 140°F (60°C)
No visible
effect
1
2
Kyzen Corp. 10% Aquanox®
A4638 at 150°F (65°C)
No visible
effect
1
1
Kyzen Corp. 20% Aquanox®
A4703 at 145°F (63°C)
No visible
effect
1
1
Zestron 15% Atron ® AC205 at
150°F (65°C)
No visible
effect
1
2
Zestron 15% Atron ® AC207 at
150°F (65°C)
No visible
effect
1
2
Zestron 15% Vigon® A201 at
150°F (65°C)
No visible
effect
1
2
Zestron 15% Vigon® N600 at
150°F (65°C)
No visible
effect
1
2
99% Isopropyl Alcohol at 180°F
(82°C)
No visible
effect
1
1
Deionized water at 212°F
(100°C)
No visible
effect
1
1
Rating Scale:
1=no visible effect
2=slight smear or print removal, detectable but minimal smear
3=moderate smear or print removal (print still legible)
4=severe smear or print removal (print illegible or just barely legible
5=complete print removal
SOLVENT RESISTANCE
TEST METHOD
MIL-STD-202G, Method 215 K
Test samples were printed with the Brady Series R4300 thermal transfer ribbon. Labels were printed with
alphanumerics and barcodes. Test samples were subjected to 3 cycles of 3 minute immersions immediately followed
by a toothbrush rub after each immersion.
TEST FLUID
Solvent A
1 part IPA, 3 parts Mineral Spirits
RESULTS R4300
Meets requirement
Solvent C,
Terpene defluxer
Meets requirement
Solvent D,
Saponifier @ 70°C
Meets requirement
Shelf Life:
Shelf life is two years from the date of receiptfor this product as long as this product is stored in its original packaging
in an environment below 80° F (27° C) and 60% RH. It remains the responsibility of the user to assess the risk of
using this product. We encourage customers to develop testing protocols that will qualify a product's fitness for use in
their actual application.
Trademarks:
ANSI: American National Standards Institute (U.S.A.)
ASTM: American Society for Testing and Materials (U.S.A.)
Aquanox® is a registered trademark of the Kyzen Corporation
Atron® is a registered trademark of the Zestron Corporation
Ionox® is a registered trademark of the Kyzen Corporation
Micronox® is a registered trademark of the Kyzen Corporation
PSTC: Pressure Sensitive Tape Council (U.S.A.)
Polyken™ is a trademark of Testing Machines Inc.
Vigon® is the registered trademark of Zestron Corporation
Weather-Ometer® is a registered trademark of Atlas Material Testing Technology LLC
Note: All values shown are averages and should not be used for specification purposes.
Test data and test results contained in this document are for general information only and shall not be relied upon by
Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers
desiring to develop specifications or performance criteria for specific product applications should contact Brady for
further information.
Product compliance information is based upon information provided by suppliers of the raw materials used by Brady
to manufacture this product or based on results of testing using recognized analytical methods performed by a third
party, independent laboratory. As such, Brady makes no independent representations or warranties, express or
implied, and assumes no liability in connection with the use of this information.
WARRANTY
Brady products are sold with the understanding that the buyers will test them in actual use and determine for
themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from
defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown
to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons
obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but
not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations
or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or
consequential damages of any kind arising in connection with the use, or inability to use, Brady's products.
Copyright 2023 Brady Worldwide, Inc. | All Rights Reserved
Material may not be reproduced or distributed in any form without written permission.
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414-358-6600 | Fax: 800-292-2289
很抱歉,暂时无法提供与“B33-2-724”相匹配的价格&库存,您可以联系我们找货
