DAT-75-292-1
DAT-75-292-1
    BRADY
DAT-75-292-1 数据手册
Technical Data Sheet BRADY B­292 DOT MATRIX PRINTABLE TRANSLUCENT VINYL TAPE TDS No. B­292 Effective Date: 06/27/2012 Description:   GENERAL Print Technology: Dot Matrix Material Type: Translucent vinyl Finish: Provided in a self­laminated format with a white printable zone and a translucent overlaminating area. Adhesive: Permanent acrylic APPLICATIONS B­292 is an excellent material for wire and cable identification. This material has good clarity, conformability and is self­ extinguishing. B­292 has outstanding water and oil resistance. RECOMMENDED RIBBONS Brady Series R2000, R5000 and R7300 black for dot matrix printing. REGULATORY/AGENCY APPROVALS B­292 is UL Recognized to UL969 Labeling and Marking Standard when printed with the Brady Series R2000, R5000, and R7300 dot matrix ribbons. See UL files MH10939 for specific details. Brady B­292 is RoHS compliant to 2005/618/EC MCV amendment to RoHS Directive 2002/95/EC.   Details:   PHYSICAL PROPERTIES Thickness Adhesion to: TEST METHODS ASTM D 1000 ­Total Thickness ASTM D 1000 ­Stainless Steel 20 minute dwell 24 hour dwell ­Polypropylene 20 minute dwell 24 hour dwell ASTM D 2979 Polyken™ Probe Tack (1 second dwell, 1 cm/sec separation) PSTC­7 (except use 1/2" x 1" sample) ASTM D 1000 ­Machine ­Cross ASTM D 1000 Average Burn Time Tack Drop Shear Tensile Strength and Elongation Flammability AVERAGE RESULTS   0.0040 inch (0.102 mm)     38 oz/in (42 N/100 mm) 49 oz/in (54 N/100 mm) 25 oz/in (28 N/100 mm) 33 oz/in (36 N/100 mm)   13.3 oz (378 g) 3.3 hours   12 lbs/in (210 N/100 mm), 152% 11 lbs/in (193 N/100 mm), 195%   ABT less than 10 seconds Performance properties tested with white printable zone of B­292 printed with Brady Series R2000 and R5000 dot matrix ribbon inks. Samples wrapped around 0.080” OD TFE wire in a self­laminating format. PERFORMANCE PROPERTIES High Service Temperature Low Service Temperature Humidity Resistance Weatherability TEST METHODS 30 days at 158°F (70°C) 30 days at ­40°F (­40°C) 30 days at 100°F (37°C), 95% R.H. ASTM G155, Cycle 1 30 days in Xenon Arc Weatherometer PERFORMANCE PROPERTIES TYPICAL RESULTS No visible effect No visible effect No visible effect No visible effect CHEMICAL RESISTANCE White printable zone of B­292 was printed with Brady Series R2000 and R5000 dot matrix ribbon inks.  Samples wrapped around 0.080” OD TFE wire in a self­laminating format.  Except where noted, testing was conducted at room temperature after 24 hour dwell. Testing consisted of 5 cycles of a 10 minute immersion in the specified test fluid followed by a 30 minute recovery period.   CHEMICAL REAGENT SUBJECTIVE OBSERVATION OF VISUAL CHANGE SUBSTRATE/ADHESIVE SERIES R2000 INK SERIES R5000 INK Cleaners and Solvents     Isopropyl Alcohol No visible effect No visible effect Mineral Spirits No visible effect No visible effect Northwoods™ Buzz Saw Terpene Cleaner No visible effect No visible effect Formula 409® No visible effect No visible effect Deionized Water No visible effect No visible effect Fuels, Oils and Lubricants     Gasoline Moderate unwrap No visible effect Brake Fluid No visible effect No visible effect SAE 30 WT Oil at 70°C No visible effect No visible effect Yellow 77® Wire Pulling Lubricant No visible effect No visible effect Aerospace Related Fluids     JP­8 Jet Fuel No visible effect No visible effect Skydrol® 500B­4 Material destroyed NA MIL­H­ 5606 Oil No visible effect No visible effect B­292 is not recommended for use in harsh organic solvents such as methyl ethyl ketone, acetone, or 1,1,1­trichloroethane.   Product testing, customer feedback, and history of similar products, support a customerperformance expectation of at least two years from the date of receipt for this product as long as this product is stored in its original packaging in an environment below 80 degrees F (27 degrees C) and 60% RH . We are confident that our product will perform well beyond this time frame. However, it remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional testing protocols that will qualify a product's fitness for use, in their actual applications. Trademarks: ASTM: American Society for Testing and Materials (U.S.A.) Formula 409® is a registered trademark of the Chlorox Company Northwoods™ is a trademark of the Superior Chemical Corporation PSTC: Pressure Sensitive Tape Council (U.S.A.) Polyken™ is a trademark of Testing Machines Inc. SAE: Society of Automotive Engineers (U.S.A.) Skydrol® is a registered trademark of the Monsanto Company UL: Underwriters Laboratories Inc. (U.S.A.) Yellow 77® is a registered trademark of Ideal Industries, Inc. Note: All values shown are averages and should not be used for specification purposes.  Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2016 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414­358­6600 | Fax: 800­292­2289
DAT-75-292-1 价格&库存
很抱歉,暂时无法提供与“DAT-75-292-1”相匹配的价格&库存,您可以联系我们找货
