Technical Data Sheet
Brady B-543 Floor Marking Tape
TDS No. B-543
Effective Date: 08/17/2018
Description:
Brady B-543 is an extruded polyvinyl chloride tape used for industrial floor marking.
Details:
Use:
Brady B-543 is used to mark aisles, passageways, storage locations, point out safety equipment and exits, and
enforce protective equipment requirements. It is designed for high-traffic environments where durability is highly
valued.
Adhesive Type:
Acrylic
Substrate Type:
Polyvinyl chloride
Standard Material Colors:
Solid: White, Red, Green, Blue, Yellow, Orange
Striped Print: Yellow/Black
Thickness:
0.050 in. (1.27 mm)
Adhesive Properties:
Adhesion to Stainless Steel (PSTC-101)
15 Minute Dwell (Avg.) – 150 oz/in (16.3 N/10 mm)
Tack (ASTM D2979-16) (Avg.) = greater than 1500 g
Abrasion Resistance (ASTM D4060-14):
Solid: S-35 Tungsten Carbide Wheels, 1000g wts.
Material withstands up to 3500 cycles at nominal thickness
Striped print: CS-10 Wheels, 500g wts.
Black stripe withstands up to 1200 cycles at nominal thickness
Gloss (60°):
40 - 70 units
Minimum Application Temperature:
50°F (10°C)
Service Temperature:
0°F to 140°F (-18°C to 60°C)
Average Outdoor Durability:
Not recommended for outdoor use.
Chemical Resistance:
Reagent
25% Sulfuric Acid
10% Sulfuric Acid
30% Hydrochloric Acid
10% Hydrochloric Acid
Glacial Acetic Acid
10% Acetic Acid
50% Sodium Hydroxide
10% Sodium Hydroxide
10% Ammonia
5% Sodium Hypochlorite
10% Sodium Chloride
Methyl Ethyl Ketone
Acetone
Toluene
Methanol
Isopropyl Alcohol
Heptane
Mineral Spirits
Turpentine
Diesel Fuel
Kerosene
Gasoline
ASTM # 3 Oil
SAE 20 Oil
Alconox® Detergent
Deionized Water
7 day Immersion
Impact to Print
7 day Immersion
Impact to Adhesive
7 day Immersion
Impact to Film
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
F
F
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
F
NE
NE
NE
NE
NE
NE
F
F
F
NE
NE
F
NE
F
NE
NE
F
NE
NE
F
NE
NE
NE
NE
NE
F
NE
NE
NE
NE
NE
NE
F
F
F
F
F
F
F
F
F
F
F
NE
NE
NE
NE
NE = No Effect
F = Failed (affected Sample)
Shelf life is two years from the date of receipt for this product as long as this product is stored in its original packaging
in an environment below 80° F (27° C) and 60% RH. It remains the responsibility of the user to assess the risk of
using this product. We encourage customers to develop testing protocols that will qualify a product's fitness for use in
their actual application.
Trademarks:
ASTM: American Society for Testing and Materials (U.S.A.)
Alconox® is a registered trademark of Alconox Co.
All S.I. Units (metric) are mathematically derived from the U.S. Conventional Units
PSTC: Pressure Sensitive Tape Council (U.S.A.)
SAE: Society of Automotive Engineers
Note: All values shown are averages and should not be used for specification purposes.
Test data and test results contained in this document are for general information only and shall not be relied upon by
Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers
desiring to develop specifications or performance criteria for specific product applications should contact Brady for
further information.
Product compliance information is based upon information provided by suppliers of the raw materials used by Brady
to manufacture this product or based on results of testing using recognized analytical methods performed by a third
party, independent laboratory. As such, Brady makes no independent representations or warranties, express or
implied, and assumes no liability in connection with the use of this information.
WARRANTY
Brady products are sold with the understanding that the buyers will test them in actual use and determine for
themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from
defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown
to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons
obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but
not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations
or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or
consequential damages of any kind arising in connection with the use, or inability to use, Brady's products.
Copyright 2018 Brady Worldwide, Inc. | All Rights Reserved
Material may not be reproduced or distributed in any form without written permission.
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414-358-6600 | Fax: 800-292-2289
很抱歉,暂时无法提供与“170033”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1691.418211+219.09782
