Technical Data Sheet
BRADY B-427 THERMAL TRANSFER PRINTABLE TRANSLUCENT VINYL TAPE
TDS No. B-427
Effective Date: 10/20/2022
Description:
GENERAL
Print Technology: Thermal Transfer
Material Type: Translucent vinyl
Finish: Provided in a self-laminated format with a white printable zone and a translucent overlaminating area.
Adhesive: Permanent acrylic
APPLICATIONS
B-427 is an excellent material for wire and cable identification. This material has good clarity, conformability and is
self-extinguishing. B-427 has outstanding water and oil resistance.
RECOMMENDED RIBBONS
Brady Series R4300 black
Brady Series R4400
Brady Series R4500 colored (red, blue, green)
Brady Series R6200
Brady Series R6700
REGULATORY/AGENCY APPROVALS
B-427 is UL Recognized to UL969A Labeling and Marking Standard when printed with the Brady Series R4300 and R7950
ribbons. See UL files MH64936 (Brady Worldwide, INC.) and MH9997 (W H Brady NV) for specific details. Brady customers
should specify at purchase if they require UL969A Recognized B-427 labels. Brady sells both UL969 Recognized B-427
labels and non-approved labels depending on customer requirements.
B-427 is UL Recognized to UL2238 Cable Assemblies and Fittings for Industrial Control and Signal Distribution Standard,
Section 37.16 “Tests for permanence of wrap around cord or cable label” when printed with the Brady Series R4300 and
R7950 ribbons. See UL files MH62024 (Brady Worldwide, Inc.) or MH62052 (W H Brady NV) for specific details.
Brady customers should specify at purchase if they require UL2238, Section 37.16 Recognized B-427 labels. Brady sells both
UL2238, Section 37.16 Recognized B-427 labels and non-approved labels depending on customer requirements.
For information on the Weee-RoHS compliance status for a Brady Product go to one of the following websites:
In Canada: www.bradycanada.ca/weee-rohs
In Europe: www.bradyeurope.com/rohs
In Japan: www.brady.co.jp/products/labelsuse/rohs
All other regions: www.bradyid.com/weee-rohs
Details:
PHYSICAL PROPERTIES
Thickness
TEST METHODS
ASTM D 1000
-Total Thickness
AVERAGE RESULTS
0.0040 inch (0.102mm)
Adhesion to:
ASTM D 1000
-Stainless Steel
20 minute dwell
24 hour dwell
38 oz/in (42 N/100 mm)
49 oz/in (54 N/100 mm)
-Polypropylene
20 minute dwell
24 hour dwell
25 oz/in (28 N/100 mm)
33 oz/in (36 N/100 mm)
Tack
ASTM D 2979
PolykenTM Probe Tack
(1 second dwell, 1 cm/sec separation)
Tensile Strength and Elongation
Flammability
13.3 oz (378 g)
ASTM D 1000
-Machine
-Cross
12 lbs/in (210 N/100 mm), 152%
11 lbs/in (193 N/100 mm), 195%
ASTM D 1000
Average Burn Time
ABT less than 10 seconds
Performance properties tested with white printable zone of B-427 printed with Brady Series R4300 black thermal transfer ribbon.
Samples wrapped around 0.080” OD TFE wire in a self-laminating format.
PERFORMANCE PROPERTIES
TEST METHODS
TYPICAL RESULTS
High Service Temperature
30 days at 158°F (70°C)
No visible effect at 158°F (70°C).
Moderate discoloration at 212°F 100°C)
but still functional.
Low Service Temperature
30 days at -94°F (-70°C)
No visible effect
Humidity Resistance
30 days at 100°F (37°C), 95% R.H.
No visible effect
UV Light Resistance
ASTM G155, cycle 1, Dry
30 days in Q-Sun Xenon Test Chamber
No visible effect
Weatherability
ASTM G155, Cycle 1
30 days in Xenon arc Weather-Ometer®
No visible effect
CHEMICAL RESISTANCE
White printable zone of B-427 was printed with Brady Series R4300 black thermal transfer ribbon. Samples wrapped around
0.080” OD TFE wire in a self-laminating format. Except where noted, testing was conducted at room temperature after 24
hour dwell. Testing consisted of 5 cycles of a 10 minute immersion in the specified test fluid followed by a 30 minute recovery
period.
CHEMICAL REAGENT
SUBJECTIVE OBSERVATION OF VISUAL CHANGE
SUBSTRATE/ADHESIVE
SERIES R4300 RIBBON
Cleaners and Solvents
No visible effect
No visible effect
Isopropyl Alcohol
No visible effect
No visible effect
Mineral Spirits
No visible effect
No visible effect
NorthwoodsTM Buzz Saw Terpene
Cleaner
No visible effect
No visible effect
Formula 409®
No visible effect
No visible effect
Deionized Water
No visible effect
No visible effect
Gasoline
Moderate unwrap
No visible effect
Brake Fluid
No visible effect
No visible effect
SAE 30 WT Oil at 70°C
No visible effect
No visible effect
Yellow 77® Wire Pulling Lubricant
No visible effect
No visible effect
Fuels, Oils and Lubricants
Aerospace Related Fluids
JP-8 Jet Fuel
No visible effect
No visible effect
Skydrol® 500B-4
Material destroyed
NA
MIL-H-5606 Oil
No visible effect
No visible effect
B-427 is not recommended for use in harsh organic solvents such as methyl ethyl ketone, acetone, or 1,1,1-trichloroethane.
Shelf Life and Fitness for Use: Product testing, customer feedback, and history of similar products, support a customer performance
expectation of one year from the date of receipt for this product as long as this product is stored in its original packaging in an
environment below 80°F (27°C) and 60% RH. However, it remains the responsibility of the user to assess the risk of using such
product. We encourage customers to develop functional testing protocols that will qualify a product's fitness for use, in their actual
applications.
Trademarks:
ASTM: American Society for Testing and Materials (U.S.A)
Formula 409® is a registered trademark of the Clorox Company
NorthwoodsTM is a trademark of the Superior Chemical Corporation
PolykenTM is a trademark of Testing Machines Inc.
SAE: Society of Automotive Engineers (U.S.A.)
Skydrol® is a registered trademark of the Monsanto Company
UL: Underwriters Laboratories Inc. (U.S.A.)
Weather-Ometer® is a registered trademark of Atlas Material Testing Technology LLC
Yellow 77® is a registered trademark of Ideal Industries, Inc.
Note: All values shown are averages and should not be used for specification purposes.
Test data and test results contained in this document are for general information only and shall not be relied upon by Brady
customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop
specifications or performance criteria for specific product applications should contact Brady for further information.
WARRANTY
Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their
adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and
workmanship, but limits its obligations under this warranty to replacement of the product shown to Brady’s satisfaction to have been
defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This
warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or
fitness for a particular purpose, and any other obligations or liability on Brady’s part. Under no circumstances will Brady be liable for
any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady’s
products.
Copyright 2019 Brady Worldwide, Inc.│ All Rights Reserved
Material may not be reproduced or distributed in any form without written permission
________________________________________________________________________________________________________
Brady North America │6555 W. Good Hope Road │Milwaukee, WI 53223 │USA │Tel: 414-358-6600│ Fax: 800-292-2289
很抱歉,暂时无法提供与“B33-56-427”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1944.286361+252.01653
