DAT-39-292-1
DAT-39-292-1
    BRADY
DAT-39-292-1 数据手册
3/15/2016 TDSDetails ­ BRADY    1­855­395­5693   Welcome to Brady Contact Us   Login / Register The Brady Advantage  | Find a Brady Distributor   0 item(s) | $0.00 All Categories Products   Markets   Standards and Compliance   Customer Support   Technical Support   Client Services   News and Events Home  >  TDSDetails Close | Print TDS Technical Data Sheet BRADY B­292 DOT MATRIX PRINTABLE TRANSLUCENT VINYL TAPE TDS No. B­292 Effective Date: 06/27/2012  Description:   GENERAL Print Technology: Dot Matrix  Material Type: Translucent vinyl  Finish: Provided in a self­laminated format with a white printable zone and a translucent overlaminating area. Adhesive: Permanent acrylic APPLICATIONS  B­292 is an excellent material for wire and cable identification. This material has good clarity, conformability and is self­extinguishing. B­292 has outstanding water and oil resistance. RECOMMENDED RIBBONS Brady Series R2000, R5000 and R7300 black for dot matrix printing. REGULATORY/AGENCY APPROVALS  B­292 is UL Recognized to UL969 Labeling and Marking Standard when printed with the Brady Series R2000, R5000, and R7300 dot matrix ribbons. See UL files MH10939 for specific details. Brady B­292 is RoHS compliant to 2005/618/EC MCV amendment to RoHS Directive 2002/95/EC.   Details:   PHYSICAL PROPERTIES TEST METHODS AVERAGE RESULTS Thickness ASTM D 1000 ­Total Thickness   0.0040 inch (0.102 mm) Adhesion to: ASTM D 1000 ­Stainless Steel 20 minute dwell 24 hour dwell     38 oz/in (42 N/100 mm) 49 oz/in (54 N/100 mm) ­Polypropylene 20 minute dwell 24 hour dwell 25 oz/in (28 N/100 mm) 33 oz/in (36 N/100 mm) Tack ASTM D 2979 Polyken™ Probe Tack  (1 second dwell, 1 cm/sec separation)   13.3 oz (378 g) Drop Shear PSTC­7 (except use 1/2" x 1" sample) 3.3 hours Tensile Strength and Elongation ASTM D 1000 ­Machine ­Cross https://www.bradyid.com/en­us/tdsdetails?id=B292   12 lbs/in (210 N/100 mm), 152% 11 lbs/in (193 N/100 mm), 195% 1/4 3/15/2016 TDSDetails ­ BRADY Flammability   ABT less than 10 seconds ASTM D 1000 Average Burn Time Performance properties tested with white printable zone of B­292 printed with Brady Series R2000 and R5000 dot matrix ribbon inks. Samples wrapped around 0.080” OD TFE wire in a self­laminating format. PERFORMANCE PROPERTIES TEST METHODS TYPICAL RESULTS High Service Temperature 30 days at 158°F (70°C) No visible effect Low Service Temperature 30 days at ­40°F (­40°C) No visible effect Humidity Resistance 30 days at 100°F (37°C), 95% R.H. No visible effect Weatherability ASTM G155, Cycle 1 30 days in Xenon Arc Weatherometer No visible effect PERFORMANCE PROPERTIES CHEMICAL RESISTANCE White printable zone of B­292 was printed with Brady Series R2000 and R5000 dot matrix ribbon inks.  Samples wrapped around 0.080” OD TFE wire in a self­ laminating format.  Except where noted, testing was conducted at room temperature after 24 hour dwell. Testing consisted of 5 cycles of a 10 minute immersion in the specified test fluid followed by a 30 minute recovery period.   CHEMICAL REAGENT SUBJECTIVE OBSERVATION OF VISUAL CHANGE SUBSTRATE/ADHESIVE SERIES R2000 INK SERIES R5000 INK Cleaners and Solvents     Isopropyl Alcohol No visible effect No visible effect Mineral Spirits No visible effect No visible effect Northwoods™ Buzz Saw Terpene Cleaner No visible effect No visible effect Formula 409® No visible effect No visible effect Deionized Water No visible effect No visible effect Fuels, Oils and Lubricants     Gasoline Moderate unwrap No visible effect Brake Fluid No visible effect No visible effect SAE 30 WT Oil at 70°C No visible effect No visible effect Yellow 77® Wire Pulling Lubricant No visible effect No visible effect Aerospace Related Fluids     JP­8 Jet Fuel No visible effect No visible effect https://www.bradyid.com/en­us/tdsdetails?id=B292 2/4 3/15/2016 TDSDetails ­ BRADY Skydrol® 500B­4 Material destroyed NA MIL­H­ 5606 Oil No visible effect No visible effect B­292 is not recommended for use in harsh organic solvents such as methyl ethyl ketone, acetone, or 1,1,1­trichloroethane.   Product testing, customer feedback, and history of similar products, support a customerperformance expectation of at least two years from the date of receipt for this product as long as this product is stored in its original packaging in an environment b elow 80 degrees F (27 degrees C) and 60% RH . We are confident that our product will perform well beyond this time frame. However, it remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional testing protocols that will qualify a product's fitness for use, in their actual applications. Trademarks:  ASTM: American Society for Testing and Materials (U.S.A.)  Formula 409® is a registered trademark of the Chlorox Company Northwoods™ is a trademark of the Superior Chemical Corporation PSTC: Pressure Sensitive Tape Council (U.S.A.)  Polyken™ is a trademark of Testing Machines Inc.  SAE: Society of Automotive Engineers (U.S.A.) Skydrol® is a registered trademark of the Monsanto Company UL: Underwriters Laboratories Inc. (U.S.A.) Yellow 77® is a registered trademark of Ideal Industries, Inc.  Note: All values shown are averages and should not be used for specification purposes.  Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY  Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2015 Brady Worldw ide, Inc. | All Rights Reserved  Material may not be reproduced or distributed in any form w ithout w ritten permission.   Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414­358­6600 | Fax: 800­292­2289 CONTACT US DISTRIBUTION PARTNERS CORPORATE INFORMATION SUPPORT Contact Us Find a Distributor Email Subscription Brady International Sites Brady Mobile Site Bradyserve.com Distributor.com Minimum Advertised Price Policy About Brady Environmental Policy Bradycorp.com ISO Certified Legal Email Customer Support Email Technical Support Submit Website Feedback Warranty Sitemap ©2016 Brady Worldw ide, Inc BradyID.com Privacy Policy  Terms of Use  Terms and Conditions of Sale       Brady identifies and protects products, people, and premises with high performance labels, industrial label printers, software, safety & facility identification, spill control, Lockout Tagout solutions and more. Brady helps you create and maintain safer work environments and comply with regulatory standards. Our high­performance materials clearly identify products, components and other assets, even in the most extreme conditions. https://www.bradyid.com/en­us/tdsdetails?id=B292 3/4 3/15/2016 https://www.bradyid.com/en­us/tdsdetails?id=B292 TDSDetails ­ BRADY 4/4
DAT-39-292-1 价格&库存
很抱歉,暂时无法提供与“DAT-39-292-1”相匹配的价格&库存,您可以联系我们找货
