B30C-1125-595-BL
B30C-1125-595-BL
    BRADY
    LABEL 1.125" W X 100' L BLUE
B30C-1125-595-BL 数据手册
BradyID.com/bbp31 Fast. Simple. Powerfully Versatile. The way label making should be. NEW Expanded Range ofLabels! Fast. Simple. Powe The way label making should be. Two powerful printers that take on ALL your labeling needs with unprecedented ease! No more tedious, time-consuming setups. No more difficult-to-load materials. No more wasted labels. No more hassles. These printers are so simple to use and so incredibly fast to set up that most of our customers don’t even believe us the first time we show them. But believe it, because it is really is that easy, and you really will be that fast, and you really will avoid wasted labels. Industrial label printing that’s simple, powerful and brilliantly fast. Exactly the way label making should be. Automatic label setup with no calibration The printer “reads” critical information from your cartridges and automatically sets up the label correctly in the printer or your Brady software. ■■ No sensor adjustment or calibration (or wasted labels!) ■■ No print speed or burn temp trials and errors (or wasted labels!) ■■ No scrolling through lists searching for label part ■■ No need to set up label dimensions in software The printer does all this for you! 20-second material changeovers ■■ ■■ ■■ ■■ ■■ ■■ Foolproof “drop-in” ribbon and label cartridges (anyone can do it!) Drop in the cartridge, lock it and start typing – that’s all you need to do! No threading the ribbon around spools and printheads No need to assemble spindles or mount rolls Ink side of ribbon always faces the right way Easy-to-handle cartridges that won’t roll away or get damaged BBP®31 Printer - stand-alone printing & ultimate ease of use Still the easiest! Just walk up and print. Literally. The best choice for facility and safety and lean/5S “Kaizen event” labeling with a printer that operates stand alone or from your PC. ■■ ■■ ■■ ■■ Safety, facility and lean/5S applications – 275 parts, 12 materials Stand-alone operation ideal for mobile use and “lean events” Intuitive, simple to learn, very approachable – ideal for multi-user situations and events Compatible with powerful MarkWare™ PC software, plus has Windows® based driver for 3rd party software use (ex: print from MSWord) BBP®33 Printer - PC-only printing with expanded material options Never-before-seen supply changeover speed and waste-free set-up in a PC-only printer. Full ranges of facility, safety & lean/5S label materials as well as die cut labels for, wire ID, lab ID and product ID. ■■ ■■ ■■ ■■ Safety, facility and lean/5S applications – 275 parts, 12 materials Wire ID, lab ID & general ID die cuts – 310 parts, 31 materials, plus custom sizes available! Ideal facility-wide printer where mobile use multi-user event labeling are not as important Compatible with LabelMark™, CodeSoft™ and MarkWare™ PC software, plus Windows® based driver for 3rd party software use (ex: print from MSWord) rfully Versatile. Stand alone printing, ultimate ease of use for multi-user “event” labeling. When you see this... BBP31 and BBP33 It’s letting you know which printer model each supply part can be used with. PC only printer with expanded material options. Table of Contents Facility & Safety ID Arc Flash & Sign Header Supply.......................... BradyGlo Photoluminescent Tape...................... Cold Temperature Material.................................. GHS Labels........................................................... Indoor/Outdoor Vinyl............................................. Low-Halide Polyester............................................ Non-Adhesive Pre-Printed Safety Tags................. Non-Adhesive Tag Stock...................................... Printable Magnetic Supply.................................. Repositionable Vinyl........................................... Retro Reflective Tape.......................................... Right-To-Know Labels......................................... ToughWash Washdown Resistant Labels............. Electrical / Automation ID 8 10 12 5 6 7 8 9 11 11 10 12 9 Patch Panel Adhesive Strips............................... PermaSleeve FR Wire Marking Sleeves.............. PermaSleeve HT Wire Marking Sleeves............. PermaSleeve HX Wire Marking Sleeves............. PermaSleeve PS Wire Marking Sleeves.............. Polyimide High Temp Adhesive Labels.............. Raised Profile Push Button Labels...................... Self-Laminating Labels....................................... Tedlar Adhesive Labels...................................... Terminal Block Adhesive Strips.......................... Vinyl Cloth Adhesive Labels............................... BradyID.com/bbp31 PC Board ID 20 25 24 24 22 21 13 20 21 19 19 Standard Polyimide Labels .........................18 Static Dissipative Polyimide Labels ...............18 Product & General Purpose ID General ID Labels for Lean 5S .....................15 Metallized Polyester Labels ........................17 Paper Labels ..........................................12 Polyester Labels ......................................16 Polypropylene Labels ................................11 Print Ribbons ..................................... 26 3 Brady Materials Are Made To Impress. Brady labels last the longest, period. Brady labels stick and stay stuck, plain and simple. In fact, some last up to 10 years outdoors. You only need to make these labels once! Options. Lots of options. We make labels for specific applications. That’s why we have hundreds of label types and sizes to choose from. And if you don’t see the label you need we’ll custom-produce it to your size and shape requirements. We want you to be 100% confident that you have the right label for your exact application. We set the bar high. Brady materials lead the industry in durability and performance because we design and manufacture every label ourselves in our own facilities. We put our materials through rigorous, painstaking tests and trials – and nothing leaves our doors until it passes with flying colors. With label printing like this, the possibilities are endless. When you see this... BBP31 and BBP33 It’s letting you know which printer model each supply part can be used with. 4 BBP®31 and BBP®33 Materials Pre-Printed GHS / CLP Chemical Labels (B-7569) • Blank labels with pre-printed red diamonds allow printer to produce 2-color GHS / CLP labels in one print pass • 3 sizes of labels, each with 6 diamond layouts that match templates in MarkWare™ Software • Indoor/outdoor vinyl material withstands exposure to moisture, chemicals and handling • MarkWare Software v3.9.1 or higher required (upgrades available for current MarkWare owners) Service temp: -4ºF to 180ºF Application temp: 50ºF to 180ºF Average Outdoor Durability: 3-5 years Fits Printer Model(s) Catalog # B# Material Label Height Inch (mm) Label Width Inch (mm) Labels Labels Rec. Per Row Per Roll Ribbon BBP31, BBP33 B30-260-7569-CLP1 B-7569 Vinyl L1 Diamond + Text 2.170 (55.0) 3.350 (85.0) 1 340 B30-R10000 BBP31, BBP33 B30-261-7569-CLP1 B-7569 Vinyl L1 Diamond + Text 2.950 (75.0) 4.330 (110.0) 1 270 B30-R10000 BBP31, BBP33 B30-262-7569-CLP1 B-7569 Vinyl L1 Diamond + Text 4.130 (105.0) 6.100 (155.0) 1 200 B30-R10000 BBP31, BBP33 B30-260-7569-CLP2 B-7569 Vinyl L2 Diamond + Text 2.170 (55.0) 3.350 (85.0) 1 340 B30-R10000 BBP31, BBP33 B30-261-7569-CLP2 B-7569 Vinyl L2 Diamond + Text 2.950 (75.0) 4.330 (110.0) 1 270 B30-R10000 BBP31, BBP33 B30-262-7569-CLP2 B-7569 Vinyl L2 Diamond + Text 4.130 (105.0) 6.100 (155.0) 1 200 B30-R10000 BBP31, BBP33 B30-260-7569-CLP3A B-7569 Vinyl L3A Diamond + Text 2.170 (55.0) 3.350 (85.0) 1 340 B30-R10000 BBP31, BBP33 B30-261-7569-CLP3A B-7569 Vinyl L3A Diamond + Text 2.950 (75.0) 4.330 (110.0) 1 270 B30-R10000 BBP31, BBP33 B30-262-7569-CLP3A B-7569 Vinyl L3A Diamond + Text 4.130 (105.0) 6.100 (155.0) 1 200 B30-R10000 BBP31, BBP33 B30-260-7569-CLP3B B-7569 Vinyl L3B Diamond + Text 2.170 (55.0) 3.350 (85.0) 1 340 B30-R10000 BBP31, BBP33 B30-261-7569-CLP3B B-7569 Vinyl L3B Diamond + Text 2.950 (75.0) 4.330 (110.0) 1 270 B30-R10000 BBP31, BBP33 B30-262-7569-CLP3B B-7569 Vinyl L3B Diamond + Text 4.130 (105.0) 6.100 (155.0) 1 200 B30-R10000 BBP31, BBP33 B30-260-7569-CLP4A B-7569 Vinyl L4A Diamond + Text 2.170 (55.0) 3.350 (85.0) 1 340 B30-R10000 BBP31, BBP33 B30-261-7569-CLP4A B-7569 Vinyl L4A Diamond + Text 2.950 (75.0) 4.330 (110.0) 1 270 B30-R10000 BBP31, BBP33 B30-262-7569-CLP4A B-7569 Vinyl L4A Diamond + Text 4.130 (105.0) 6.100 (155.0) 1 200 B30-R10000 BBP31, BBP33 B30-260-7569-CLP4B B-7569 Vinyl L4B Diamond + Text 2.170 (55.0) 3.350 (85.0) 1 340 B30-R10000 BBP31, BBP33 B30-261-7569-CLP4B B-7569 Vinyl L4B Diamond + Text 2.950 (75.0) 4.330 (110.0) 1 270 B30-R10000 Vinyl L4B Diamond + Text 4.130 (105.0) 6.100 (155.0) 1 200 B30-R10000 BBP31, BBP33 B30-262-7569-CLP4B B-7569 Legend MarkWare™ Software now includes a GHS / CLP Label Module • 18 pre-formatted label layouts and approved GHS symbols are built-in • User selects approved pre-worded hazard statements and GHS symbols which then automatically populates into layout – no need to type everything in • Prompts for additional variable data which then auto-populates into layout • Indoor/outdoor vinyl material withstands exposure to moisture, chemicals and handling • Choose a second language and MarkWare auto-populates in the second language Catalog # Descripion 20700 MarkWare ™ Software Already own MarkWare Software? Go to BradyID.com/markware to upgrade your current MarkWare to v3.9.1 for the GHS / CLP Label Module. BradyID.com/bbp31 5 BBP®31 and BBP®33 Materials Indoor/Outdoor Vinyl (B-595) • For general facility and safety identification: Our best industrial vinyl yet • Durable, low-shrink vinyl with our most aggressive adhesive • Conforms to irregular, curved, rough and highly textured surfaces (painted cinder blocks, uneven wood, textured plastics, paper-jacketed pipes, powder-coated surfaces) A B Figure 33 • Adheres to “difficult” low-surface energy items (PVC piping, blow-molded equipment cases, ABS plastics, recycled plastics) Facility and Safety Applications: - 5S Labels - Equipment & Panel Labels - Pipe Markers - Arc Flash & Chemical Labels - Safety & Warning Labels - And More! Service temp: -40ºF to 180ºF Application temp: 0ºF to 180ºF Average Outdoor Durability: 8-10 year outdoor vinyl label durability. Agency approvals: Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Labels Per Roll Rec. Ribbon BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 B30C-500-595-WT B30C-1125-595-WT B30C-2250-595-WT B30C-3000-595-WT B30C-4000-595-WT B30C-500-595-YL B30C-1125-595-YL B30C-2250-595-YL B30C-3000-595-YL B30C-4000-595-YL B30C-500-595-RD B30C-1125-595-RD B30C-2250-595-RD B30C-4000-595-RD B30C-500-595-BL B30C-1125-595-BL B30C-2250-595-BL B30C-4000-595-BL B30C-500-595-GN B30C-1125-595-GN B30C-2250-595-GN B30C-4000-595-GN B30C-500-595-OR B30C-1125-595-OR B30C-2250-595-OR B30C-4000-595-OR B30C-500-595-BK B30C-1125-595-BK B30C-2250-595-BK B30C-4000-595-BK B30C-500-595-BR B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 White White White White White Yellow Yellow Yellow Yellow Yellow Red Red Red Red Blue Blue Blue Blue Green Green Green Green Orange Orange Orange Orange Black Black Black Black Brown 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 3.000 (76.2) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 3.000 (76.2) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125(28.6) 2.250(57.5) 4.000(101.6) 0.500(12.7) 1.125(28.6) 2.250(57.5) 4.000(101.6) 0.500(12.7) 1.125(28.6) 2.250(57.5) 4.000(101.6) 0.500(12.7) 1.125(28.6) 2.250(57.5) 4.000(101.6) 0.500(12.7) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT BBP31, BBP33 Fig. 33 B30C-1125-595-BR B-595 Brown 1.125(28.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000-WT BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 B30C-2250-595-BR B30C-4000-595-BR B30C-500-595-GD B30C-1125-595-GD B30C-2250-595-GD B30C-4000-595-GD B30C-500-595-GY B30C-1125-595-GY B30C-2250-595-GY B30C-4000-595-GY B30C-500-595-PL B30C-1125-595-PL B30C-2250-595-PL B30C-4000-595-PL B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 Brown Brown Gold Gold Gold Gold Gray Gray Gray Gray Purple Purple Purple Purple 2.250(57.5) 4.000(101.6) 0.500(12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R10000-WT B30-R10000-WT B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT BBP31, BBP31, BBP31, BBP31, Fig. 33 Fig. 33 Fig. 33 Fig. 33 B30C-500-595-CL B30C-1125-595-CL B30C-2250-595-CL B30C-4000-595-CL B-595 B-595 B-595 B-595 Clear Clear Clear Clear 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R10000 B30-R10000 B30-R10000 B30-R10000 BBP33 BBP33 BBP33 BBP33 U.S. Patent Nos. 5,823,689; 6,570,602. Additional Patents Pending. 6 BBP®31 and BBP®33 Materials Low-Halide Polyester (B-569) A • Low-halide content for labeling stainless steel pipes and surfaces • Applies best to very smooth surfaces and ideal for mounting to rigid panels Service temp: -40ºF to 212ºF Application temp: 0ºF to 212ºF Average Outdoor Durability: 3-5 years Fits Printer Model(s) B Figure 33 Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Labels Per Roll Rec. Ribbon BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 B30C-500-569-WT B30C-1125-569-WT B30C-2250-569-WT B30C-3000-569-WT B30C-4000-569-WT B30C-500-569-YL B30C-1125-569-YL B30C-2250-569-YL B30C-4000-569-YL B30C-500-569-RD B30C-1125-569-RD B30C-2250-569-RD B30C-4000-569-RD B30C-500-569-BL B30C-1125-569-BL B30C-2250-569-BL B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 White White White White White Yellow Yellow Yellow Yellow Red Red Red Red Blue Blue Blue 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 3.000 (76.2) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 B30C-4000-569-BL B30C-500-569-LB B30C-1125-569-LB B30C-2250-569-LB B30C-4000-569-LB B30C-500-569-SB B30C-1125-569-SB B30C-2250-569-SB B30C-4000-569-SB B30C-500-569-GN B30C-1125-569-GN B30C-2250-569-GN B30C-4000-569-GN B30C-500-569-OR B30C-1125-569-OR B30C-2250-569-OR B30C-4000-569-OR B30C-500-569-BK B30C-1125-569-BK B30C-2250-569-BK B30C-4000-569-BK B30C-500-569-BR B30C-1125-569-BR B30C-2250-569-BR B30C-4000-569-BR B30C-500-569-OC B30C-1125-569-OC B30C-2250-569-OC B30C-4000-569-OC B30C-500-569-TN B30C-1125-569-TN B30C-2250-569-TN B30C-4000-569-TN B30C-500-569-GY B30C-1125-569-GY B30C-2250-569-GY B30C-4000-569-GY B30C-500-569-PL B30C-1125-569-PL B30C-2250-569-PL B30C-4000-569-PL B30C-500-569-PK B30C-1125-569-PK B30C-2250-569-PK B30C-4000-569-PK B30C-500-569-CL B30C-1125-569-CL B30C-2250-569-CL B30C-4000-569-CL B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 B-569 Blue Light Blue Light Blue Light Blue Light Blue Sky Blue Sky Blue Sky Blue Sky Blue Green Green Green Green Orange Orange Orange Orange Black Black Black Black Brown Brown Brown Brown Ochre Ochre Ochre Ochre Tan Tan Tan Tan Gray Gray Gray Gray Purple Purple Purple Purple Pink Pink Pink Pink Clear Clear Clear Clear 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 0.500 (12.7) 1.125 (28.6) 2.250 (57.5) 4.000 (101.6) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 100ft. (30.5m) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R10000-WT B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000-WT B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 B30-R10000 BradyID.com/bbp31 7 BBP®31 and BBP®33 Materials Pre-Printed Pre-Cut Blank Sign Headers (B-595) A • Allows printer to create multicolor signs fast - in a single print pass • Headers meet NFPA 70E, OSHA 1910.145 and ASME/ANSI Z535 standards B DER • Indoor/outdoor grade material conforms to rough, highly textured, and “difficult to adhere to” surfaces HEADER Service temp: -40ºF to 180ºF Application temp: 0ºF to 180ºF Average Outdoor Durability: 8-10 years Agency approvals: Figure 70 Use these supplies with templates in the BBP®33 printer & MarkWare™ Software for arc flash labels and safety warning labels Fits Printer Model(s) Label Height A Inch (mm) Label Width B Inch (mm) Labels Labels Per Row Per Roll Rec. Ribbon Vinyl 2.250 (57.5) 3.000 (76.2) 1 300 B30-R10000 Vinyl 4.000 (101.6) 6.000 (152.4) 1 175 B30-R10000 B-595 B-595 Vinyl Vinyl 2.250 (57.5) 4.000 (101.6) 3.000 (76.2) 6.000 (152.4) 1 1 300 175 B30-R10000 B30-R10000 B30-241-595-ANSICA B-595 Vinyl 2.250 (57.5) 3.000 (76.2) 1 300 B30-R10000 B30-25-595-ANSICA B-595 Vinyl 4.000 (101.6) 6.000 (152.4) 1 175 B30-R10000 BBP31, BBP33 Fig. 70 B30-241-595-ANSIDA B-595 Vinyl 2.250 (57.5) 3.000 (76.2) 1 300 B30-R10000 BBP31, BBP33 Fig. 70 B30-25-595-ANSIDA B-595 Vinyl 4.000 (101.6) 6.000 (152.4) 1 175 B30-R10000 BBP31, BBP33 Fig. 70 B30-241-595-ANSIWA B-595 Vinyl 2.250 (57.5) 3.000 (76.2) 1 300 B30-R10000 BBP31, BBP33 Fig. 70 B30-25-595-ANSIWA B-595 Vinyl 4.000 (101.6) 6.000 (152.4) 1 175 B30-R10000 BBP31, BBP33 Fig. 70 B30-241-595-ANSINO B-595 Vinyl 2.250 (57.5) 3.000 (76.2) 1 300 B30-R10000 BBP31, BBP33 Fig. 70 B30-25-595-ANSINO B-595 Vinyl 4.000 (101.6) 6.000 (152.4) 1 175 B30-R10000 BBP31, BBP33 Fig. 70 BBP31, BBP33 Fig. 70 BBP31, BBP33 Fig. 70 B30-242-595-BLNKWT B30-241-595-BLNKWT B30-219-595-BLNKWT B-595 B-595 B-595 Vinyl Vinyl Vinyl 1.125 (28.6) * 2.250 (57.5) 2.250 (57.5) * 2.850 (72.4) 3.000 (76.2) 3.850 (97.8) 1 1 1 300 300 250 B30-R10000 B30-R10000 B30-R10000 BBP31, BBP33 Fig. 70 BBP31, BBP33 Fig. 70 BBP31, BBP33 Fig. 70 B30-25-595-BLNKWT B30-241-595-BLNKYL B30-25-595-BLNKYL B-595 B-595 B-595 Vinyl Vinyl Vinyl 4.000 (101.6) 2.250 (57.5) 4.000 (101.6) 6.000 (152.4) 3.000 (76.2) 6.000 (152.4) 1 1 1 175 300 175 B30-R10000 B30-R10000 B30-R10000 Diagram Catalog # B# Material BBP31, BBP33 Fig. 70 B30-241-595-OSHADA B-595 BBP31, BBP33 Fig. 70 B30-25-595-OSHADA B-595 BBP31, BBP33 Fig. 70 BBP31, BBP33 Fig. 70 B30-241-595-OSHACA B30-25-595-OSHACA BBP31, BBP33 Fig. 70 BBP31, BBP33 Fig. 70 Header *Label pre-sized to fit blank rigid valve tags, but can also be used on its own as general purpose label. Visit www.BradyID.com for information on Valve Tags. Non-Adhesive Pre-Printed & Pre-Cut Safety Tags (B-551) • Non-adhesive semi rigid card stock A • Tags are pre-cut with hole and chamfered corners • Micro-perforated between tags to separate cleanly HEADER B • Snap-in plastic grommets available for extra strength around mounting hole Service temp: -40ºF to 180ºF Application temp: 0ºF to 180ºF Average Outdoor Durability: 8-10 years Figure 69 8 Fits Printer Model(s) Diagram Catalog # B# Tag Width A Inch (mm) Tag Height B Inch (mm) Tags Per Row Tags Per Roll Rec. Ribbon BBP31, BBP33 Fig. 69 B30-255-551-ANSIDA B-551 3.250 (82.6) 5.750 (146.1) 1 100 B30-R10000 BBP31, BBP33 Fig. 69 B30-255-551-OSHADA B-551 3.250 (82.6) 5.750 (146.1) 1 100 B30-R10000 BBP31, BBP33 Fig. 69 B30-255-551-ANSICA B-551 3.250 (82.6) 5.750 (146.1) 1 100 B30-R10000 BBP31, BBP33 Fig. 69 B30-255-551-WHT B-551 3.250 (82.6) 5.750 (146.1) 1 100 B30-R10000 Header BBP®31 and BBP®33 Materials ToughWash™ Washdown Resistant Labels (B-854, B-855) • Withstands pressures of high heat, harsh chemicals and numerous washdown cycles • B-854 offers metal detectable layer to detect foreign debris in food stream H E A HEA DER A • Legible and long-lasting for even the toughest washdown cycles B B DER • Ideal for use in the Food & Beverage industry Service temp: -40ºF to 230ºF Agency approvals: Figure 33 Fits Printer Model(s) Diagram Catalog # B-854 ToughWash™ Metal Detectable Material B# BBP31, BBP33 Fig. 33 B30C-4000-854-WT BBP31, BBP33 Fig. 33 BBP31, BBP33 Figure 73 Label Width A Inch (mm) Length B Inch (mm) Labels Per Roll Rec. Ribbon B-854 4.000 (101.06) 50ft. (15.2 m) 1 roll (cont.) B30-R6000 B30C-4000-854-YL B-854 4.000 (101.06) 50ft. (15.2 m) 1 roll (cont.) B30-R6000 Fig. 73 B30C-4000-854-WARN B-854 4.000 (101.06) 6.250 (158.8) 100 B30-R6000 BBP31, BBP33 Fig. 73 B30C-4000-854-DANG B-854 4.000 (101.06) 6.250 (158.8) 100 B30-R6000 BBP31, BBP33 Fig. 73 B30C-4000-854-CAUT B-854 4.000 (101.06) 6.250 (158.8) 100 B30-R6000 Color B-855 ToughWash™ Material BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 Fig. 33 B30C-1125-855-WT B30C-2250-855-WT B30C-4000-855-WT B30C-1125-855-YL B30C-2250-855-YL B30C-4000-855-YL B-855 B-855 B-855 B-855 B-855 B-855 1.125 (28.6) 2.250 (57.5) 4.000 (101.06) 1.125 (28.6) 2.250 (57.5) 4.000 (101.06) 50ft. (15.2 m) 50ft. (15.2 m) 50ft. (15.2 m) 50ft. (15.2 m) 50ft. (15.2 m) 50ft. (15.2 m) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 BBP31, BBP33 Fig. 73 B30C-4000-855-WARN B-855 4.000 (101.06) 6.250 (158.8) 100 B30-R6000 BBP31, BBP33 Fig. 73 B30C-4000-855-DANG B-855 4.000 (101.06) 6.250 (158.8) 100 B30-R6000 BBP31, BBP33 Fig. 73 B30C-4000-855-CAUT B-855 4.000 (101.06) 6.250 (158.8) 100 B30-R6000 Non-Adhesive Continuous Tag Stock (B-551) • For safety, lockout and general purpose hang-tagging • Non-adhesive, semi-rigid tag stock A • Easy to hole-punch; optional snap-in grommets available • Meets OSHA 50 lb. pullout spec for lockout tags B Service temp: -40ºF to 193ºF Average Outdoor Durability: up to 2 years Thickness: 0.35mm Figure 33 Fits Printer Model(s) Diagram Catalog # B# Color Tag Width A Inch (mm) Roll Length B Feet (m) Tags Per Roll Rec. Ribbon BBP31, BBP33 Fig. 33 B30C-2500-551-WT B-551 White 2.500 (63.5) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-3250-551-WT B-551 White 3.250 (82.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4250-551-WT B-551 White 4.250 (107.9) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BradyID.com/bbp31 9 BBP®31 and BBP®33 Materials Retro Reflective Tape (B-584) • Highly reflective material shines back brightly when struck by light • Ideal for labeling outdoor utility poles and pedestals, hard hats, jobsite equipment and roof-top equipment A • Recommended for low light or inclement weather conditions B Service temp: -40ºF to 158ºF Application temp: 0ºF to 158ºF (yellow & orange), 50ºF to 158ºF (silver) Average Outdoor Durability: 4 to 6 years Figure 33 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Labels Per Roll BBP31, BBP33 Fig. 33 B30C-1125-584-SL B-584 Silver 1.125 (28.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2250-584-SL B-584 Silver 2.250 (57.5) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4000-584-SL B-584 Silver 4.000 (101.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-1125-584-YL B-584 Yellow 1.125 (28.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2250-584-YL B-584 Yellow 2.250 (57.5) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4000-584-YL B-584 Yellow 4.000 (101.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-1125-584-OR B-584 Orange 1.125 (28.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2250-584-OR B-584 Orange 2.250 (57.5) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4000-584-OR B-584 Orange 4.000 (101.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 Rec. Ribbon BradyGlo™ High-Intensity Photoluminescent Tape (B-526) • For glow-in-the-dark identification up to 10 hours • Designed for directional and evacuation marking and equipment marking • Ideal for marking emergency utility shut-offs, fire extinguishers, alarm pulls, and vital equipment controls • Complies with indoor use requirements specified in RS 6-1 and 6-1A of New York Local Law 26 A B Service temp: -40ºF to 140ºF Application temp: 40ºF to 140ºF Figure 33 10 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Labels Per Roll Rec. Ribbon BBP31, BBP33 Fig. 33 B30C-1125-526 B-526 Luminous Green 1.125 (28.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2250-526 B-526 Luminous Green 2.250 (57.5) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4000-526 B-526 Luminous Green 4.000 (101.6) 50ft. (15.2m) 1 roll (cont.) B30-R10000 BBP®31 and BBP®33 Materials Printable Magnetic Supply (B-509) • Easiest and quickest material for removing and repositioning. • Non-adhesive magnetic material that can be printed on directly A • Ideal for reusable, repositionable, and lean / 5S identification applications B Service temp: 0ºF to 158ºF Average Outdoor Durability: 3 to 5 years Figure 33 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Labels Per Roll Rec. Ribbon BBP31, BBP33 Fig. 33 B30C-2500-509-WT B-509 White 2.500 (63.5) 25ft (7.62m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4250-509-WT B-509 White 4.250 (107.8) 25ft (7.62m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2500-509-YL B-509 Yellow 2.500 (63.5) 25ft (7.62m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4250-509-YL B-509 Yellow 4.250 (107.8) 25ft (7.62m) 1 roll (cont.) B30-R10000 Repositionable Vinyl (B-581) • Aggressive adhesive stays in place but removes cleanly without leaving adhesive residue A • Ideal for temporary, removable, and repositionable labels, like 5S and lean inventory labels B Service temp: -40ºF to 180ºF Application temp: 50ºF to 180ºF Average Outdoor Durability: 5 years Figure 33 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Labels Per Roll Rec. Ribbon BBP31, BBP33 Fig. 33 B30C-500-581-WT B-581 White 0.500 (12.7) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-1125-581-WT B-581 White 1.125 (28.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2250-581-WT B-581 White 2.250 (57.5) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4000-581-WT B-581 White 4.000 (101.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-500-581-YL B-581 Yellow 0.500 (12.7) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-1125-581-YL B-581 Yellow 1.125 (28.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2250-581-YL B-581 Yellow 2.250 (57.5) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4000-581-YL B-581 Yellow 4.000 (101.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000 Polypropylene Labels (B-425) A • General labeling material for indoor use • Outstanding chemical and solvent resistance and print performance C A B D • Not recommended for prolonged outdoor use E (use B-595 material for 8-10 year outdoor use) E Figure 1 Service temp: -94°F to 212°F Agency approvals: c B D Figure 2 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Label Height B Inch (mm) Horiz. Repeat C Vert. Repeat D Inch (mm) Inch (mm) Web Width E Inch (mm) Labels Labels Per Row Per Roll Rec. Ribbon BBP33 only BBP33 only BBP33 only BBP33 only B33-5-425 B33-17-425 B33-18-425 B33-19-425 B-425 B-425 B-425 B-425 White White White White 1.000 (25.4) 2.000 (50.8) 3.000 (76.2) 3.000 (76.2) 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 2.000 (50.8) 1.075 (27.3) - 3.350 (85.1) 2.200 (55.9) 3.200 (81.3) 3.200 (81.3) 3 1 1 1 Fig. 1 Fig. 2 Fig. 2 Fig. 2 BradyID.com/bbp31 0.600 (15.2) 1.125 (28.6) 1.125 (28.6) 2.125 (54.0) 5000 1500 1500 500 B30-R4300 B30-R4300 B30-R4300 B30-R4300 11 BBP®31 and BBP®33 Materials Pre-Printed Right-To-Know Chemical Labels (B-595) • Allows printer to produce 5-color chemical labels in a single print pass • Indoor/outdoor grade material withstands exposure to moisture, chemicals and handling Service temp: -40ºF to 180ºF Application temp: 0ºF to 180ºF Average Outdoor Durability: 8 to 10 years Agency approvals: Label Height Inch (mm) Label Width Inch (mm) Labels Per Row Labels Per Roll Rec. Ribbon Diamond + Text 2.250 (57.5) 2.250 (57.5) 1 365 B30-R10000 B-595 Diamond + Text 2.250 (57.5) 4.000 (101.6) 1 240 B30-R10000 B30-263-595-NFPA B-595 Diamond + Text 4.000 (101.6) 6.250 (158.8) 1 170 B30-R10000 BBP31, BBP33 B30-244-595-DIAM B-595 Diamond Only 2.250 (57.5) 2.250 (57.5) 1 365 B30-R10000 BBP31, BBP33 B30-161-595-DIAM B-595 Diamond Only 4.000 (101.6) 4.000 (101.6) 1 240 B30-R10000 BBP31, BBP33 B30-246-595-NFR B-595 Diamond NFR 1.125 (28.6) 3.000 (76.2) 1 300 B30-R10000 BBP31, BBP33 B30-244-595-CB B-595 Color Bar + Text 2.250 (57.5) 2.250 (57.5) 1 365 B30-R10000 BBP31, BBP33 B30-245-595-CB B-595 Color Bar + Text 2.250 (57.5) 4.000 (101.6) 1 240 B30-R10000 BBP31, BBP33 B30-263-595-CB B-595 Color Bar + Text 4.000 (101.6) 6.250 (158.8) 1 170 B30-R10000 BBP31, BBP33 B30-244-595-HMIG B-595 Color Bar Only 2.250 (57.5) 2.250 (57.5) 1 365 B30-R10000 BBP31, BBP33 B30-246-595-HMIG B-595 Color Bar HMIG 1.125 (28.6) 3.000 (76.2) 1 300 B30-R10000 Fits Printer Model(s) Catalog # B# BBP31, BBP33 B30-244-595-NFPA B-595 BBP31, BBP33 B30-245-595-NFPA BBP31, BBP33 Legend Paper Labels (B-424) A • Economical choice for light duty general ID • White finish and matte topcoat • Excellent contrast and smear resistance for bar code printing D Service temp: -40°F to 124°F Agency approvals: B E Figure 2 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Label Height B Horiz. Repeat C Inch (mm) Inch (mm) Inch (mm) Vert. Repeat D Web Width E Labels Labels Inch (mm) Inch (mm) Per Row Per Roll Rec. Ribbon BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only B-424 B-424 B-424 B-424 B-424 B-424 B-424 B-424 White White White White White White White White 2.000 (50.8) 2.000 (50.8) 2.750 (69.9) 3.000 (76.2) 3.000 (76.2) 3.000 (76.2) 4.000 (101.6) 4.000 (101.6) 0.600 (15.2) 2.200 (55.9) 1.375 (34.9) 3.200 (81.3) 3.200 (81.3) 5.125 (130.2) 2.125 (54.0) 4.200 (106.7) Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-53-424 B33-17-424 B33-7-424 B33-18-424 B33-19-424 B33-20-424 B33-55-424 B33-25-424 0.500 (12.7) 1.000 (25.4) 1.250 (31.8) 1.000 (25.4) 2.000 (50.8) 5.000 (127) 2.000 (50.8) 6.000 (152.4) 1.125 (28.6) 1.125 (28.6) 2.125 (54.0) 6.125 (155.6) 2.200 (55.9) 2.950 (74.9) 3.200 (81.3) 4.200 (106.7) - 1 1 1 1 1 1 1 1 2500 1500 1000 1500 500 250 750 350 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 Cold Temperature Application Material (B-549) 12 A • Special adhesive permanently adheres to extremely cold surfaces • Can be applied in -10ºF and lasts in -40ºF • Ideal for cold storage warehouses, coolers, freezers, and short-term winter outdoor use B Service temp: -40ºF to 212ºF Application temp: -10ºF to 212ºF Average Outdoor Durability: Up to 1 year Figure 33 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Labels Per Roll Rec. Ribbon BBP31, BBP33 Fig. 33 B30C-1125-549-WT B-549 White 1.125 (28.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2250-549-WT B-549 White 2.250 (57.5) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4000-549-WT B-549 White 4.000 (101.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-4000-549-YL B-549 Yellow 1.125 (28.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-2250-549-YL B-549 Yellow 2.250 (57.5) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP31, BBP33 Fig. 33 B30C-1125-549-YL B-549 Yellow 4.000 (101.6) 100ft. (30.5m) 1 roll (cont.) B30-R10000 BBP®31 and BBP®33 Materials Raised Profile Labels - Engraved Plate Substitutes - Push Button Style (B-593) Costs up to 80% less than engraved legend plates. • High gloss, polyester label with thick raised profile and ultra-aggressive adhesive (0.70mm thick) • High performance, low cost substitute to engraved plates • 10-year outdoor durability rating • On-demand labeling: labels print out in less than 4 seconds • 5 push button sizes (including keyed and non-keyed 22.5mm, and 30.5mm hole diameter keyed) B B D C D C E E Figure 18a Figure 18b (Without key hole) Service temp: -4ºF to 212ºF Application temp: 50ºF to 212ºF Average Outdoor Durability: Up to 10 years Agency approvals: c Note: BBP®31 printers purchased prior to 2012 require a free mechanical rework and firmware upgrade in order to be compatible with the following B-595 Raised Panel Labels. Please contact Technical Support at 1-800-643-8766 for details. Color Label Height A Inch (mm) Label Width B Inch (mm) Hole Vert. Diameter C Repeat D Inch (mm) Inch (mm) Web Width E Inch (mm) Labels Labels Per Per Row Roll Rec. Ribbon White 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R6000 White 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R6000 B-593 White 1.800 (45.7) 1.800 (45.7) 1.200 (30.5) 2.000 (50.8) 2.500 (63.5) 1 190 B30-R6000 B30EP-168-593-WT B-593 White 1.900 (48.3) 1.200 (30.5) 0.885 (22.5) 2.125 (54.0) 2.500 (63.5) 1 180 B30-R6000 BBP31, BBP33 Fig. 18a B30EP-170-593-WT B-593 White 2.400 (60.9) 2.400 (60.9) 1.200 (30.5) 2.625 (66.7) 3.250 (82.6) 1 145 B30-R6000 BBP31, BBP33 Fig. 18a B30EP-167-593-YL B-593 Yellow 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R6000 BBP31, BBP33 Fig. 18b B30EP-167U-593-YL B-593 Yellow 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R6000 BBP31, BBP33 Fig. 18a B30EP-169-593-YL B-593 Yellow 1.800 (45.7) 1.800 (45.7) 1.200 (30.5) 2.000 (50.8) 2.500 (63.5) 1 190 B30-R6000 BBP31, BBP33 Fig. 18a B30EP-168-593-YL B-593 Yellow 1.900 (48.3) 1.200 (30.5) 0.885 (22.5) 2.125 (54.0) 2.500 (63.5) 1 180 B30-R6000 BBP31, BBP33 Fig. 18a B30EP-170-593-YL B-593 Yellow 2.400 (60.9) 2.400 (60.9) 1.200 (30.5) 2.625 (66.7) 3.250 (82.6) 1 145 B30-R6000 BBP31, BBP33 Fig. 18a B30EP-167-593-BK B-593 Black 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R4400-WT BBP31, BBP33 Fig. 18b B30EP-167U-593-BK B-593 Black 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-169-593-BK B-593 Black 1.800 (45.7) 1.800 (45.7) 1.200 (30.5) 2.000 (50.8) 2.500 (63.5) 1 190 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-168-593-BK B-593 Black 1.900 (48.3) 1.200 (30.5) 0.885 (22.5) 2.125 (54.0) 2.500 (63.5) 1 180 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-170-593-BK B-593 Black 2.400 (60.9) 2.400 (60.9) 1.200 (30.5) 2.625 (66.7) 3.250 (82.6) 1 145 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-167-593-GN B-593 Green 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R4400-WT BBP31, BBP33 Fig. 18b B30EP-167U-593-GN B-593 Green 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-169-593-GN B-593 Green 1.800 (45.7) 1.800 (45.7) 1.200 (30.5) 2.000 (50.8) 2.500 (63.5) 1 190 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-168-593-GN B-593 Green 1.900 (48.3) 1.200 (30.5) 0.885 (22.5) 2.125 (54.0) 2.500 (63.5) 1 180 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-170-593-GN B-593 Green 2.400 (60.9) 2.400 (60.9) 1.200 (30.5) 2.625 (66.7) 3.250 (82.6) 1 145 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-167-593-RD B-593 Red 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R4400-WT BBP31, BBP33 Fig. 18b B30EP-167U-593-RD B-593 Red 1.500 (38.1) 1.200 (30.5) 0.885 (22.5) 1.750 (44.5) 2.500 (63.5) 1 200 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-169-593-RD B-593 Red 1.800 (45.7) 1.800 (45.7) 1.200 (30.5) 2.000 (50.8) 2.500 (63.5) 1 190 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-168-593-RD B-593 Red 1.900 (48.3) 1.200 (30.5) 0.885 (22.5) 2.125 (54.0) 2.500 (63.5) 1 180 B30-R4400-WT BBP31, BBP33 Fig. 18a B30EP-170-593-RD B-593 Red 2.400 (60.9) 2.400 (60.9) 1.200 (30.5) 2.625 (66.7) 3.250 (82.6) 1 145 B30-R4400-WT Fits Printer Model(s) Diagram Catalog # B# BBP31, BBP33 Fig. 18a B30EP-167-593-WT B-593 BBP31, BBP33 Fig. 18b B30EP-167U-593-WT B-593 BBP31, BBP33 Fig. 18a B30EP-169-593-WT BBP31, BBP33 Fig. 18a BradyID.com/bbp31 13 BBP®31 and BBP®33 Materials Raised Profile Labels - Engraved Plate Substitutes - Rectangular Style (B-593) Costs up to 80% less than engraved legend plates. • High gloss, polyester label with thick raised profile and ultra-aggressive adhesive (0.70mm thick) • Ideal for inside-panel backer board labels and front-of-enclosure labeling • Up to 80% less than engraved plates and print out in about 4 seconds • 10-year outdoor durability rating • 6 colors, 7 rectangular sizes B Service temp: -4ºF to 212ºF Application temp: 50ºF to 212ºF Average Outdoor Durability: Up to 10 years Agency approvals: c D Note: BBP®31 printers purchased prior to 2012 require a free mechanical rework and firmware upgrade in order to be compatible with the following B-595 Raised Panel Labels. Please contact Technical Support at 1-800-643-8766 for details. 14 Fits Printer Model(s) Diagram Catalog # B# BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c Fig. 18c B30EP-171-593-WT B30EP-172-593-WT B30EP-175-593-WT B30EP-173-593-WT B30EP-174-593-WT B30EP-176-593-WT B30EP-177-593-WT B30EP-171-593-YL B30EP-172-593-YL B30EP-175-593-YL B30EP-173-593-YL B30EP-174-593-YL B30EP-176-593-YL B30EP-177-593-YL B30EP-171-593-BK B30EP-172-593-BK B30EP-175-593-BK B30EP-173-593-BK B30EP-174-593-BK B30EP-176-593-BK B30EP-177-593-BK B30EP-171-593-GN B30EP-172-593-GN B30EP-175-593-GN B30EP-173-593-GN B30EP-174-593-GN B30EP-176-593-GN B30EP-177-593-GN B30EP-171-593-RD B30EP-172-593-RD B30EP-173-593-RD B30EP-174-593-RD B30EP-171-593-SL B30EP-172-593-SL B30EP-173-593-SL B30EP-174-593-SL B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 B-593 E Figure 18c Color Label Height A Inch (mm) Label Width B Inch (mm) Vert. Repeat D Inch (mm) Web Width E Inch (mm) Labels Labels Per Per Row Roll Rec. Ribbon White White White White White White White Yellow Yellow Yellow Yellow Yellow Yellow Yellow Black Black Black Black Black Black Black Green Green Green Green Green Green Green Red Red Red Red Silver Silver Silver Silver 0.490 (12.5) 0.590 (15.0) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 2.500 (63.5) 0.490 (12.5) 0.590 (15.0) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 2.500 (63.5) 0.490 (12.5) 0.590 (15.0) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 2.500 (63.5) 0.490 (12.5) 0.590 (15.0) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 2.500 (63.5) 0.490 (12.5) 0.590 (15.0) 1.000 (25.4) 1.000 (25.4) 0.490 (12.5) 0.590 (15.0) 1.000 (25.4) 1.000 (25.4) 1.060 (26.9) 1.770 (45.0) 3.000 (76.2) 2.000 (50.8) 4.000 (101.6) 3.000 (76.2) 3.000 (76.2) 1.060 (26.9) 1.770 (45.0) 3.000 (76.2) 2.000 (50.8) 4.000 (101.6) 3.000 (76.2) 3.000 (76.2) 1.060 (26.9) 1.770 (45.0) 3.000 (76.2) 2.000 (50.8) 4.000 (101.6) 3.000 (76.2) 3.000 (76.2) 1.060 (26.9) 1.770 (45.0) 3.000 (76.2) 2.000 (50.8) 4.000 (101.6) 3.000 (76.2) 3.000 (76.2) 1.060 (26.9) 1.770 (45.0) 2.000 (50.8) 4.000 (101.6) 1.060 (26.9) 1.770 (45.0) 2.000 (50.8) 4.000 (101.6) 0.750 (19.1) 0.850 (21.6) 1.000 (25.4) 1.250 (31.8) 1.250 (31.8) 1.250 (31.8) 2.750 (69.9) 0.750 (19.1) 0.850 (21.6) 1.000 (25.4) 1.250 (31.8) 1.250 (31.8) 1.250 (31.8) 2.750 (69.9) 0.750 (19.1) 0.850 (21.6) 1.000 (25.4) 1.250 (31.8) 1.250 (31.8) 1.250 (31.8) 2.750 (69.9) 0.750 (19.1) 0.850 (21.6) 1.000 (25.4) 1.250 (31.8) 1.250 (31.8) 1.250 (31.8) 2.750 (69.9) 0.750 (19.1) 0.850 (21.6) 1.250 (31.8) 1.250 (31.8) 0.750 (19.1) 0.850 (21.6) 1.250 (31.8) 1.250 (31.8) 1.375 (34.9) 2.500 (63.5) 3.250 (82.6) 2.500 (63.5) 4.250 (108.0) 3.250 (82.6) 3.250 (82.6) 1.375 (34.9) 2.500 (63.5) 3.250 (82.6) 2.500 (63.5) 4.250 (108.0) 3.250 (82.6) 3.250 (82.6) 1.375 (34.9) 2.500 (63.5) 3.250 (82.6) 2.500 (63.5) 4.250 (108.0) 3.250 (82.6) 3.250 (82.6) 1.375 (34.9) 2.500 (63.5) 3.250 (82.6) 2.500 (63.5) 4.250 (108.0) 3.250 (82.6) 3.250 (82.6) 1.375 (34.9) 2.500 (63.5) 2.500 (63.5) 4.250 (108.0) 1.375 (34.9) 2.500 (63.5) 2.500 (63.5) 4.250 (108.0) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 500 450 375 300 300 300 125 500 450 375 300 300 300 125 500 450 375 300 300 300 125 500 450 375 300 300 300 125 500 450 300 300 500 450 300 300 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R6000 B30-R6000 B30-R6000 B30-R6000 BBP®31 and BBP®33 Materials General ID Labels for Lean 5S, Bins and Production Areas (B-483, B-484, B-498, B-499, B-593, B-595) • Various sizes in several durable material types • Also ideal for marking backer board, DIN rail, relays, PLCs, switches, solenoids, drive motors and other components inside panels • All recommended materials are flexible and have high-tack adhesives for adhesion to wide variety of surfaces and components B-483: Service temp: -40°F to 248°F B-484: Service temp: -40°F to 240°F B-498: Service temp: -40°F to 175°F B-499: Service temp: -40°F to 193°F B-593: Service temp: -4°F to 212°F B-595: Service temp: -40°F to 180°F, 8-10 years average outdoor durability Agency approvals: Agency approvals: Agency approvals: Agency approvals: Agency approvals: c Agency approvals: A C A B D B B D E B D A E E Figure 1 Figure 2 E Figure 3 Figure 5 Figure 18c Label Fits Printer Width A Model(s) Diagram Catalog # B# Color Inch (mm) Vinyl Cloth - Aggressive but repositionable adhesive (B-498): Label Height B Inch (mm) Horiz. Repeat C Inch (mm) Vert. Repeat D Inch (mm) Web Width E Inch (mm) BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only 1.437 (36.5) 0.750 (19.1) 1.437 (36.5) 0.250 (6.4) 1.437 (36.5) 0.500 (12.7) 0.750 (19.1) 1.437 (36.5) 0.350 (8.9) 0.600 (15.2) 0.600 (15.2) 0.800 (20.3) 0.900 (22.9) 1.075 (27.3) 1.100 (27.9) 1.100 (27.9) 1.562 (39.7) 0.875 (22.2) 1.562 (39.7) 0.350 (8.9) 1.562 (39.7) 0.600 (15.2) 0.875 (22.2) 1.562 (39.7) 2.200 (55.9) 2.500 (63.5) 3.700 (94.0) 3.350 (85.1) 2.800 (71.1) 3.350 (85.1) 2.300 (58.4) 3.400 (86.4) 6 4 6 4 3 3 2 3 2500 5000 2500 5000 2300 5000 2500 2300 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 0.475 (12.1) 0.600 (15.2) 0.600 (15.2) 0.900 (22.9) - 0.500 (12.7) 0.625 (15.9) 0.875 (22.2) 1.562 (39.7) 0.875 (22.2) 1.125 (28.6) 2.000 (50.8) 1.900 (48.3) 2.500 (63.5) 3.700 (94.0) 1.770 (45.0) 2.200 (55.9) 4 3 4 4 1 1 1500 1500 1500 2500 1500 1100 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 0.600 (15.2) 0.600 (15.2) 1.125 (28.6) 1.375 (34.9) 1.125 (28.6) 2.125 (54.0) 2.125 (54.0) 2.500(63.5) 3.350(85.1) 2.200(55.9) 2.950(74.9) 3.200(81.3) 3.200(81.3) 4.200(106.7) 4 3 1 1 1 1 1 5000 5000 1500 1000 1500 500 750 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 B33-90-498 B33-68-498 B33-87-498 B33-1-498 B33-95-498 B33-5-498 B33-88-498 B33-89-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 White White White White White White White White 0.250(6.4) 0.500(12.7) 0.500(12.7) 0.750(19.1) 0.800(20.3) 1.000(25.4) 1.000(25.4) 1.000(25.4) White White White White White White 0.375(9.5 dia) 0.500(12.7) 0.500(12.7) 0.800(20.3) 1.500(38.1) 2.000(50.8) Labels Labels Per Per Row Roll Rec. Ribbon Nylon Cloth - Permanent adhesive (B-499): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 5 Fig. 1 Fig. 1 Fig. 1 Fig. 2 Fig. 2 B33-143-499 B33-144-499 B33-68-499 B33-165-499 B33-136-499 B33-137-499 B-499 B-499 B-499 B-499 B-499 B-499 0.500 (12.7) 0.750 (19.1) 1.437 (36.5) 0.750 (19.1) 1.000 (25.4) Polyester - Ultra aggressive adhesive for highly textured and low surface energy surfaces (B-483): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 1 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-149-483 B33-5-483 B33-17-483 B33-7-483 B33-18-483 B33-19-483 B33-55-483 B-483 B-483 B-483 B-483 B-483 B-483 B-483 White White White White White White White 0.500(12.7) 1.000(25.4) 2.000(50.8) 2.750(69.9) 3.000(76.2) 3.000(76.2) 4.000(101.6) 0.500 (12.7) 0.500 (12.7) 1.000 (25.4) 1.250 (31.8) 1.000 (25.4) 2.000 (50.8) 2.000 (50.8) 0.600 (15.2) 1.075 (27.3) - Polyester - Ultra-aggressive adhesive and pliable for conforming to angular surfaces (B-484): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 2 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-125-484 B33-5-484 B33-136-484 B33-17-484 B33-18-484 B33-19-484 B-484 B-484 B-484 B-484 B-484 B-484 White White White White White White 0.900 (22.9) 1.000 (25.4) 1.500 (38.1) 2.000 (50.8) 3.000 (76.2) 3.000 (76.2) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 2.000 (50.8) 1.075 (27.3) - 0.600 (15.2) 0.600 (15.2) 0.875 (22.2) 1.125 (28.6) 1.125 (28.6) 2.125 (54.0) 1.100 (27.9) 3.350 (85.1) 1.700 (43.2) 2.200 (55.9) 3.200 (81.3) 3.200 (81.3) 1 3 1 1 1 1 1500 5000 1500 1500 1500 500 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 1.060 (26.9) 1.060 (26.9) 1.060 (26.9) - 0.750 (19.1) 0.750 (19.1) 0.750 (19.1) 1.375 (34.9) 1.375 (34.9) 1.375 (34.9) 1 1 1 500 500 500 B30-R6000 B30-R6000 B30-R4400-WT - 0.700 (17.8) 1.375 (34.9) 0.700 (17.8) 1.375 (34.9) Raised Profile Labels - Engraved plate substitute labels (B-593*): BBP31, BBP33 Fig. 18c B30EP-171-593-WT B-593 White BBP31, BBP33 Fig. 18c B30EP-171-593-SL B-593 Silver BBP31, BBP33 Fig. 18c B30EP-171-593-BK B-593 Black 0.490 (12.5) 0.490 (12.5) 0.490 (12.5) Continuous cut-to-length vinyl - Permanent adhesive, conformable; indoor/outdoor grade (B-595*): BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 BBP31, BBP33 Fig. 3 Fig. 3 Fig. 3 Fig. 3 B30C-500-595-WT B30C-1125-595-WT B30C-500-595-YL B30C-1125-595-YL B-595 B-595 B-595 B-595 White White Yellow Yellow 0.500 (12.7) 1.125 (28.6) 0.500 (12.7) 1.125 (28.6) 100 ft. (30.5m) 100 ft. (30.5m) 100 ft. (30.5m) 100 ft. (30.5m) - 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R10000 B30-R10000 B30-R10000 B30-R10000 * 58 additional sizes and colors available for B-593 (page 13). 46 additional sizes and colors availalbe for B-595 (page 6). BradyID.com/bbp31 15 BBP®33 Materials Polyester General ID Labels (B-422, B-423, B430, B-432, B483, B-484, B-489) • For general purpose industrial ID applications, bin and shelf labeling in prodution ares, and PC board component ID A C A B-423, B-483, B-489: Service temp: -94°F to 248°F Agency approvals: B D D B B-430, B-432: Service temp: -40°F to 212°F Agency approvals: B-484: Service temp: -40°F to 240°F Agency approvals: E E Figure 1 Figure 2 Fits Printer Model(s) Diagram Catalog # B# Standard adhesive (B-423 gloss white): Color Label Width A Inch (mm) Label Height B Inch (mm) Horiz. Repeat C Vert. Repeat D Web Width E Inch (mm) Inch (mm) Inch (mm) Labels Labels Rec. Per Row Per Roll Ribbon BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 B-423 Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 0.900 (22.9) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.250 (31.8) 1.250 (31.8) 1.500 (38.1) 1.750 (44.5) 2.000 (50.8) 2.000 (50.8) 3.000 (76.2) 3.000 (76.2) 4.000 (101.6) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.250 (6.4) 0.375 (9.5) 0.250 (6.4) 0.250 (6.4) 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 2.000 (50.8) 2.000 (50.8) 0.250 (6.4) 0.438 (11.1) 0.600 (15.2) 0.800 (20.3) 1.075 (27.3) 1.075 (27.3) 1.300 (33.0) - 0.375 (9.5) 0.475 (12.1) 0.600 (15.2) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.475 (12.1) 0.600 (15.2) 0.350 (8.9) 0.475 (12.1) 0.350 (8.9) 0.350 (8.9) 0.600 (15.2) 1.125 (28.6) 1.125 (28.6) 2.125 (54.0) 2.125 (54.0) 3.200 (81.3) 3.200 (81.3) 2.500 (63.5) 3.350 (85.1) 0.950 (24.1) 1.100 (27.9) 1.200 (30.5) 3.350 (85.1) 3.350 (85.1) 1.450 (36.8) 2.750 (69.9) 1.700 (43.2) 1.950 (49.5) 2.200 (55.9) 2.200 (55.9) 3.200 (81.3) 3.200 (81.3) 4.200 (106.7) 12 9 4 4 1 1 1 3 3 1 2 1 1 1 1 1 1 1 15000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 2500 1500 1500 500 750 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B-430 B-430 B-430 Clear Clear Clear 1.000 (25.4) 2.000 (50.8) 3.000 (76.2) 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 1.075 (27.3) - 0.625 (15.9) 1.125 (28.6) 1.125 (28.6) 3.350 (85.1) 2.200 (55.9) 3.200 (81.3) 3 1 1 5000 1500 1500 B30-R6000 B30-R6000 B30-R6000 0.500 (12.7) 1.000 (25.4) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 2.000 (50.8) 3.000 (76.2) 3.000 (76.2) 4.000 (101.6) 0.500 (12.7) 0.500 (12.7) 0.375 (9.5) 0.375 (9.5) 0.750 (19.) 1.000 (25.4) 1.000 (25.4) 2.000 (50.8) 3.000 (76.2) 0.600 (15.2) 1.075 (27.3) 1.650 (41.9) - 0.600 (15.2) 0.600 (15.2) 0.475 (12.1) 0.500 (12.7) 0.875 (22.2) 1.125 (28.6) 1.125 (28.6) 2.125 (54.0) 3.125 (79.4) 2.500 (63.5) 3.350 (85.1) 3.350 (85.1) 1.700 (43.2) 1.700 (43.2) 2.200 (55.9) 3.200 (81.3) 3.200 (81.3) 4.200 (106.7) 4 3 2 1 1 1 1 1 1 5000 5000 2500 2500 1500 1500 1500 500 500 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 0.500 (12.7) 1.000 (25.4) 2.000 (50.8) 3.000 (76.2) 3.000 (76.2) 0.500 (12.7) 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 2.000 (50.8) 0.600 (15.2) 1.075 (27.3) - 0.625 (15.9) 0.600 (15.2) 1.125 (28.6) 1.125 (28.6) 2.125 (54.0) 2.500 (63.5) 3.350 (85.1) 2.200 (55.9) 3.200 (81.3) 3.200 (81.3) 4 3 1 1 1 5000 5000 1500 1500 500 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 0.600 (15.2) 1.075 (27.3) - 0.600 (15.2) 0.600 (15.2) 1.125 (28.6) 1.375 (34.9) 1.125 (28.6) 2.125 (54.0) 2.125 (54.0) 2.500 (63.5) 3.350 (85.1) 2.200 (55.9) 2.950 (74.9) 3.200 (81.3) 3.200 (81.3) 4.200 (106.7) 4 3 1 1 1 1 1 5000 5000 1500 1000 1500 500 750 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 1.075 (27.3) - 0.600 (15.2) 1.125 (28.6) 1.125 (28.6) 2.125 (54.0) 3.350 (85.1) 2.200 (55.9) 3.200 (81.3) 3.200 (81.3) 3 1 1 1 5000 1500 1500 500 B30-R4300 B30-R4300 B30-R4300 B30-R4300 0.600 (15.2) 0.600 (15.2) 0.875 (22.2) 1.125 (28.6) 1.125 (28.6) 2.125 (54.0) 1.100 (27.9) 3.350 (85.1) 1.700 (43.2) 2.200 (55.9) 3.200 (81.3) 3.200 (81.3) 1 3 1 1 1 1 1500 5000 1500 1500 1500 500 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 Fig. 4 Fig. 1 Fig. 1 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 1 Fig. 1 Fig. 2 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-11-423 B33-38-423 B33-149-423 B33-1-423 B33-46-423 B33-49-423 B33-103-423 B33-3-423 B33-5-423 B33-43-423 B33-29-423 B33-45-423 B33-72-423 B33-53-423 B33-17-423 B33-18-423 B33-19-423 B33-55-423 Standard adhesive (B-430 clear): BBP33 only Fig. 1 BBP33 only Fig. 2 BBP33 only Fig. 2 B33-5-430 B33-17-430 B33-18-430 Stronger adhesive for textured sufaces (B-422 gloss white): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 1 Fig. 1 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-149-422 B33-5-422 B33-147-422 B33-102-422 B33-136-422 B33-17-422 B33-18-422 B33-19-422 B33-76-422 B-422 B-422 B-422 B-422 B-422 B-422 B-422 B-422 B-422 White White White White White White White White White Stronger adhesive for textured surfaces (B-432 clear): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 1 Fig. 1 Fig. 2 Fig. 2 Fig. 2 B33-149-432 B33-5-432 B33-17-432 B33-18-432 B33-19-432 B-432 B-432 B-432 B-432 B-432 Clear Clear Clear Clear Clear Ultra aggressive adhesive for highly textured surfaces (B-483 gloss white): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 1 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-149-483 B33-5-483 B33-17-483 B33-7-483 B33-18-483 B33-19-483 B33-55-483 B-483 B-483 B-483 B-483 B-483 B-483 B-483 Gloss White 0.500 (12.7) Gloss White 1.000 (25.4) Gloss White 2.000 (50.8) Gloss White 2.750 (69.9) Gloss White 3.000 (76.2) Gloss White 3.000 (76.2) Gloss White 4.000 (101.6) 0.500 (12.7) 0.500 (12.7) 1.000 (25.4) 1.250 (31.8) 1.000 (25.4) 2.000 (50.8) 2.000 (50.8) Ultra aggressive adhesive for highly textured surfaces (B-489 matte white): BBP33 only BBP33 only BBP33 only BBP33 only Fig. 1 Fig. 2 Fig. 2 Fig. 2 B33-5-489 B33-17-489 B33-18-489 B33-19-489 B-489 B-489 B-489 B-489 Matte White Matte White Matte White Matte White 1.000 (25.4) 2.000 (50.8) 3.000 (76.2) 3.000 (76.2) 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 2.000 (50.8) Polyester - Ultra-aggressive adhesive and pliable for conforming to angular surfaces (B-484): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only 16 Fig. 2 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-125-484 B33-5-484 B33-136-484 B33-17-484 B33-18-484 B33-19-484 B-484 B-484 B-484 B-484 B-484 B-484 White White White White White White 0.900 (22.9) 1.000 (25.4) 1.500 (38.1) 2.000 (50.8) 3.000 (76.2) 3.000 (76.2) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 2.000 (50.8) 1.075 (27.3) - BBP®31 and BBP®33 Materials Metallized Polyester Labels (B-428, B434, B-435, B-438, B-486, B-565) • For product labeling, asset tracking and general industrial ID • Silver metallic label withstands solvents and variable temperatures • Ideal for serial number plates and rating plates with name-plate quality and metal-looking finish • 3 adhesive strengths/gloss configurations to meet your needs B-428: Service temp: -40°F to 293°F B-434: Service temp: -40°F to 194°F B-435: Service temp: -40°F to 194°F B-438: Service temp: -40°F to 104°F B-486: Service temp: -40°F to 248°F B-565: Service temp: -40°F to 240°F Agency approvals: Agency approvals: Agency approvals: Agency approvals: Agency approvals: Agency approvals: A C A B D D B A E E Figure 1 Fits Printer Model(s) Diagram Catalog # B# Color Standard adhesive for smooth surfaces (B-428 matte): B E Figure 2 Label Width A Label Height B Inch (mm) Inch (mm) Figure 3 Horiz. Repeat C Vert. Repeat D Web Width E Inch (mm) Inch (mm) Inch (mm) Labels Labels Rec. Per Row Per Roll Ribbon BBP33 only Fig. 1 B33-5-428 B-428 Matte Silver 1.000 (25.4) 0.500 (12.7) 1.075 (27.3) 0.600 (15.2) 3.350 (85.1) 3 5000 B30-R4300 BBP33 only Fig. 2 B33-53-428 B-428 Matte Silver 2.000 (50.8) 0.500 (12.7) - 0.600 (15.2) 2.200 (55.9) 1 2500 B30-R4300 BBP33 only Fig. 2 B33-17-428 B-428 Matte Silver 2.000 (50.8) 1.000 (25.4) 1.125 (28.6) 2.200 (55.9) 1 1500 B30-R4300 BBP33 only Fig. 2 B33-18-428 B-428 Matte Silver 3.000 (76.2) 1.000 (25.4) 1.125 (28.6) 3.200 (81.3) 1 1500 B30-R4300 BBP33 only Fig. 2 B33-19-428 B-428 Matte Silver 3.000 (76.2) 2.000 (50.8) - 2.125 (54.0) 3.200 (81.3) 1 500 B30-R4300 BBP33 only Fig. 3 B33C-3000-428 B-428 Matte Silver 3.000 (76.2) 85 ft (25.9m) - - 3.400 (86.4) 1 roll (cont.) B30-R4300 Standard adhesive for smooth surfaces. Material compatible in BBP31 Printer (B-565 matte): BBP31, BBP33 Fig. 3 B30C-1125-565-SL B-565 Matte Silver 1.125 (28.6) 100 ft. (30.5m) - - 1.375 (34.9) 1 roll (cont.) B30-R4300 BBP31, BBP33 Fig. 3 B30C-2250-565-SL B-565 Matte Silver 2.250 (57.5) 100ft. (30.5m) - - 2.500 (63.5) 1 roll (cont.) B30-R4300 BBP31, BBP33 Fig. 3 B30C-4000-565-SL B-565 Matte Silver 4.000 (101.6) 100ft. (30.5m) - - 4.200 (106.7) 1 roll (cont.) B30-R4300 Standard adhesive for smooth surfaces (B-435 glossy): BBP33 only Fig. 2 B33-18-435 B-435 Gloss Silver 3.000 (76.2) 1.000 (25.4) - 1.125 (28.6) 3.200 (81.3) 1 1500 B30-R6000 BBP33 only Fig. 2 B33-19-435 B-435 Gloss Silver 3.000 (76.2) 2.000 (50.8) - 2.125 (54.0) 3.200 (81.3) 1 500 B30-R6000 BBP33 only Fig. 2 B33-55-435 B-435 Gloss Silver 4.000 (101.6) 2.000 (50.8) - 2.125 (54.0) 4.200 (106.7) 1 750 B30-R6000 Stronger adhesive for rougher surfaces (B-434 glossy): BBP33 only Fig. 1 B33-5-434 B-434 Gloss Silver 1.000 (25.4) 0.500 (12.7) 1.075 (27.3) 0.600 (15.2) 3.350 (85.1) 3 5000 B30-R6000 BBP33 only Fig. 2 B33-136-434 B-434 Gloss Silver 1.500 (38.1) 0.750 (19.1) - 0.875 (22.2) 1.700 (43.2) 1 1500 B30-R6000 BBP33 only Fig. 2 B33-17-434 B-434 Gloss Silver 2.000 (50.8) 1.000 (25.4) 1.125 (28.6) 2.200 (55.9) 1 1500 B30-R6000 BBP33 only Fig. 2 B33-18-434 B-434 Gloss Silver 3.000 (76.2) 1.000 (25.4) 1.125 (28.6) 3.200 (81.3) 1 1500 B30-R6000 BBP33 only Fig. 2 B33-19-434 B-434 Gloss Silver 3.000 (76.2) 2.000 (50.8) 2.125 (54.0) 3.200 (81.3) 1 500 B30-R6000 BBP33 only Fig. 2 B33-55-434 B-434 Gloss Silver 4.000 (101.6) 2.000 (50.8) 2.125 (54.0) 4.200 (106.7) 1 750 B30-R6000 - Ultra aggressive adhesive for highly textured, powder coated and low surface energy surfaces (B-486 matte): BBP33 only Fig. 2 B33-59-486 B-486 Matte Silver 1.000 (25.4) 0.500 (12.7) - 0.600 (15.2) 1.200 (30.5) 1 2500 B30-R4300 BBP33 only Fig. 1 B33-5-486 B-486 Matte Silver 1.000 (25.4) 0.500 (12.7) 1.075 (27.3) 0.600 (15.2) 3.350 (85.1) 3 5000 B30-R4300 BBP33 only Fig. 2 B33-53-486 B-486 Matte Silver 2.000 (50.8) 0.500 (12.7) - 0.600 (15.2) 2.200 (55.9) 1 2500 B30-R4300 BBP33 only Fig. 2 B33-17-486 B-486 Matte Silver 2.000 (50.8) 1.000 (25.4) 1.125 (28.6) 2.200 (55.9) 1 1300 B30-R4300 BBP33 only Fig. 2 B33-7-486 B-486 Matte Silver 2.750 (69.9) 1.250 (31.8) 1.375 (34.9) 2.950 (74.9) 1 1000 B30-R4300 BBP33 only Fig. 2 B33-18-486 B-486 Matte Silver 3.000 (76.2) 1.000 (25.4) 1.125 (28.6) 3.200 (81.3) 1 1300 B30-R4300 BBP33 only Fig. 2 B33-19-486 B-486 Matte Silver 3.000 (76.2) 2.000 (50.8) 2.125 (54.0) 3.200 (81.3) 1 500 B30-R4300 BBP33 only Fig. 2 B33-76-486 B-486 Matte Silver 4.000 (101.6) 3.000 (76.2) - 3.125 (79.4) 4.200 (106.7) 1 500 B30-R4300 BBP33 only Fig. 2 B33-161-486 B-486 Matte Silver 4.000 (101.6) 4.000 (101.6) - 4.125 (104.8) 4.200 (106.7) 1 250 B30-R4300 - Tamper-Evident - Leaves checkerboard footprint on surface and on label if removed to prevent re-use (B-438 matte): BBP31, BBP33 Fig. 2 B30-17-438 B-438 Matte Silver 2.000 (50.8) 1.000 (25.4) 2.500 (63.5) 1.125 (28.6) 1 1225 B30-R4300 BBP31, BBP33 Fig. 2 B30-18-438 B-438 Matte Silver 3.000 (76.2) 1.000 (25.4) 3.250 (82.6) 1.250 (31.8) 1 1225 B30-R4300 BBP31, BBP33 Fig. 2 B30-222-438 B-438 Matte Silver 3.000 (76.2) 2.000 (50.8) 3.250 (82.6) 2.250 (57.2) 1 650 B30-R4300 BBP31, BBP33 Fig. 3 B30C-3000-438-SL B-438 Matte Silver 3.000 (76.2) 100 ft. (30.5m) BradyID.com/bbp31 3.250 (82.6) 1 roll (cont.) B30-R4300 17 BBP®33 Materials Standard Polyimide Labels (B-724, B-727) • Top or bottom-side component ID or board ID labels that withstand the various processes, fluxes and cleaning solvents encountered in the manufacture of printed circuit boards A B-727: Service temp: -94°F to 212°F (short burst max temp: 80 sec at 572°F, 5 min at 500°F, 2 hrs at 338°F) Agency approvals: A C B D B-724: Service temp: -94°F to 518°F (short burst max temp: D B E 80 sec at 626°F, 5 min at 536°F) E Figure 1 Agency approvals: Figure 2 Fits Printer Model(s) Diagram Catalog # B# Color Standard temperature (B-727 gloss white): Label Width A Label Height B Horiz. Repeat C Vert. Repeat D Inch (mm) Inch (mm) Inch (mm) Inch (mm) Web Width E Inch (mm) Labels Labels Rec. Per Row Per Roll Ribbon BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only 0.250 (6.35) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 0.900 (22.9) 0.900 (22.9) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.250 (31.8) 1.375 (34.9) 1.500 (38.1) 1.750 (44.5) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.25 (6.4) 0.438 (11.1) 0.600 (15.2) 0.800 (20.3) 1.125 (28.6) - 0.375 (9.5) 0.475 (12.1) 0.600 (15.2) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.475 (12.1) 0.600 (15.2) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 3.200 (81.3) 3.200 (81.3) 2.500 (63.5) 0.950 (24.1) 3.350 (85.1) 1.100 (27.9) 3.350 (85.1) 1.200 (30.5) 1.200 (30.5) 1.200 (30.5) 1.450 (36.8) 1.600 (40.6) 1.700 (43.2) 1.950 (49.5) 12 9 4 1 4 1 3 1 1 1 1 1 1 1 5000 5000 5000 5000 5000 5000 5000 5000 5000 2500 5000 5000 5000 5000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 0.900 (22.9) 1.250 (31.8) 1.500 (38.1) 0.500 (12.7) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.600 (15.2) 0.800 (20.3) 1.125 (28.6) - 0.600 (15.2) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 2.500 (63.5) 0.950 (24.1) 3.350 (85.1) 3.350 (85.1) 1.450 (36.8) 3.350 (85.1) 4 1 4 3 1 2 5000 5000 5000 5000 5000 5000 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 Fig. 1 Fig. 1 Fig. 1 Fig. 2 Fig. 1 Fig. 2 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-11-727 B33-38-727 B33-149-727 B33-46-727 B33-1-727 B33-49-727 B33-2-727 B33-103-727 B33-58-727 B33-59-727 B33-43-727 B33-44-727 B33-45-727 B33-72-727 B-727 B-727 B-727 B-727 B-727 B-727 B-727 B-727 B-727 B-727 B-727 B-727 B-727 B-727 Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Extremely high temperature (B-724 matte amber): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 1 Fig. 2 Fig. 1 Fig. 1 Fig. 2 Fig. 1 B33-149-724 B33-46-724 B33-1-724 B33-2-724 B33-43-724 B33-4-724 B-724 B-724 B-724 B-724 B-724 B-724 Matte Amber Matte Amber Matte Amber Matte Amber Matte Amber Matte Amber Static Dissipative Polyimide Labels (B-717, B-718, B-719) • Circuit board and electronic component ID with static dissipative adhesive and release liner with surface resistivity values recommended for dissipative ESD packaging A • Complies with EIA-541 Packaging Material Standards for ESD Sensitive Items C A B B D D • For top or bottom-side component or board identification E E All: Service temp: -94°F to 212°F (short burst max temp: 80 sec at 572°F, 5 min at 500°F, 2 hrs at 338°F) Agency approvals: Figure 2 Figure 1 Fits Printer Model(s) Diagram Catalog # B# Standard thickness (B-717 gloss white): Color Label Width A Inch (mm) Label Height B Horiz. Repeat C Inch (mm) Inch (mm) Vert. Repeat D Web Width E Labels Labels Rec. Inch (mm) Inch (mm) Per Row Per Roll Ribbon BBP33 only BBP33 only BBP33 only BBP33 only Gloss White Gloss White Gloss White Gloss White 0.750 (19.1) 1.000 (25.4) 1.250 (31.8) 1.500 (38.1) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.950 (24.1) 1.200 (30.5) 1.450 (36.8) 1.700 (43.2) 1 1 1 1 5000 5000 5000 5000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White Gloss White 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 0.900 (22.9) 1.250 (31.8) 1.500 (38.1) 1.750 (44.5) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.438 (11.1) 0.600 (15.2) 0.800 (20.3) - 0.375 (9.5) 0.475 (12.1) 0.600 (15.2) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 0.350 (8.9) 3.200 (81.3) 3.200 (81.3) 2.500 (63.5) 3.350 (85.1) 0.950 (24.1) 1.100 (27.9) 1.450 (36.8) 1.700 (43.2) 1.950 (49.5) 12 9 4 4 1 1 1 1 1 15000 5000 5000 5000 5000 5000 5000 5000 5000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 0.438 (11.1) 1.125 (28.6) - 0.475 (12.1) 0.350 (8.9) 0.350 (8.9) 0.288 (7.3) 0.350 (8.9) 3.200 (81.3) 0.950 (24.1) 3.350 (85.1) 1.200 (30.5) 1.450 (36.8) 9 1 3 1 1 5000 5000 5000 5000 5000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-46-717 B33-103-717 B33-43-717 B33-45-717 B-717 B-717 B-717 B-717 - Low profile label (B-718 gloss white): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 4 Fig. 1 Fig. 1 Fig. 1 Fig. 2 Fig. 2 Fig. 2 Fig. 2 Fig. 2 B33-11-718 B33-38-718 B33-149-718 B33-1-718 B33-46-718 B33-49-718 B33-43-718 B33-45-718 B33-72-718 B-718 B-718 B-718 B-718 B-718 B-718 B-718 B-718 B-718 Low profile label - Matte white to prevent sticking of solder balls (B-719 matte white): BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only 18 Fig. 1 Fig. 2 Fig. 1 Fig. 2 Fig. 2 B33-38-719 B33-46-719 B33-2-719 B33-42-719 B33-43-719 B-719 B-719 B-719 B-719 B-719 Matte White Matte White Matte White Matte White Matte White 0.375 0.750 0.900 1.000 1.250 (9.5) (19.1) (22.9) (25.4) (31.8) 0.375 (9.5) 0.250 (6.4) 0.250 (6.4) 0.188 (4.8) 0.250 (6.4) BBP®33 Materials Vinyl Cloth Adhesive Wire & Cable Labels (B-498) • A vinyl cloth label for marking wires, cables and inside-panel components • Repositionable! A highly unique adhesive and cloth construction gives excellent holding power and still allows for clean removal and reapplication • Ideal choice for marking both ends of a wire that you may need to cut shorter before final termination A Service temp: -40°F to 175°F Agency Approvals: C B D E Figure 1 Fits Printer Model(s) Diagram Catalog # B# BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only B33-90-498 B33-68-498 B33-87-498 B33-1-498 B33-91-498 B33-165-498 B33-95-498 B33-5-498 B33-88-498 B33-89-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Color Label Width A Inch (mm) Label Height B Inch (mm) Horiz. Repeat C Inch (mm) Vert. Repeat D Inch (mm) Web Width E Inch (mm) Labels Labels Per Row Per Roll Rec. Ribbon White White White White White White White White White White 0.250 (6.4) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 0.800 (20.3) 0.800 (20.3) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.437 (36.5) 0.750 (19.1) 1.437 (36.5) 0.250 (6.4) 0.937 (23.8) 1.437 (36.5) 1.437 (36.5) 0.500 (12.7) 0.750 (19.1) 1.437 (36.5) 0.350 (8.9) 0.600 (15.2) 0.600 (15.2) 0.800 (20.3) 0.850 (21.6) 0.900 (22.9) 0.900 (22.9) 1.075 (27.3) 1.100 (27.9) 1.100 (27.9) 1.562 (39.7) 0.875 (22.2) 1.562 (39.7) 0.350 (8.9) 1.062 (27.0) 1.562 (39.7) 1.562 (39.7) 0.600 (15.2) 0.875 (22.2) 1.562 (39.7) 2.200 (55.9) 2.500 (63.5) 3.700 (94) 3.350 (85.1) 3.500 (88.9) 3.700 (94.0) 2.800 (71.1) 3.350 (85.1) 2.300 (58.4) 3.400 (86.4) 6 4 6 4 4 4 3 3 2 3 2500 5000 2500 5000 2500 2500 2300 5000 2500 2300 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 Terminal Block Adhesive Strips (B-498) • Specially designed narrow-width continuous label for alignment on terminal blocks and patch panels • Highly unique adhesive and vinyl cloth construction gives excellent holding power and still allows for clean removal and reapplication Service temp: -40°F to 175°F B Agency Approvals: A E Figure 3 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Web Width E Inch (mm) Labels Per Roll Rec. Ribbon BBP33 only BBP33 only BBP33 only B33C-240-498 B33C-312-498 B33C-375-498 B-498 B-498 B-498 White White White 0.240 (6.1) 0.312 (7.9) 0.375 (9.5) 85 ft. (25.9m) 85 ft. (25.9m) 85 ft. (25.9m) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R6200 B30-R6200 B30-R6200 Fig. 3 Fig. 3 Fig. 3 BradyID.com/bbp31 19 BBP®33 Materials Self-Laminating Wire & Cable Labels (B-427) • Brady’s most popular wire marker! • Features white printable area with clear “tail” that wraps around marker to protect text • Superior resistance to abrasion, handling, solvents, water, oil and dirt • Vinyl with permanent acrylic adhesive designed specifically for tightly curved surfaces Service temp: -40°F to 158°F Agency Approvals: A B C A A F F D B B D BD E E Figure 9a BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 15 Fig. 12 Fig. 12 Fig. 9a Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 9a Fig. 14 Fig. 14 Fig. 14 B33-80-427 B33-113-427 B33-8-427 B33-56-427 B33-73-427 B33-74-427 B33-115-427 B33-116-427 B33-9-427 B33-75-427 B33-131-427 B33-10-427 B33-81-427 B33-135-427AW B33-118-427 B33-119-427 B33-272-427 B33-120-427 B33-121-427 B33-273-427 B33-137-427AW B33-27-427 B33-26-427 B33-82-427 F E Figure 12 Label Fits Printer Model(s) Diagram Catalog # D Figure 14 B# Width A Color Inch (mm) Label Height B Inch (mm) B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 White White White White White White White White White White White White White White White White White White White White White White White White 0.750 (19.1) 1.000 (25.4) 1.437 (36.5) 0.937 (23.8) 1.750 (44.6) 1.437 (36.5) 0.750 (19.1) 1.000 (25.4) 1.437 (36.5) 2.250 (57.2) 2.625 (66.7) 3.750 (95.3) 6.000 (152.4) 0.750 (19.1) 1.000 (25.4) 1.500 (38.1) 2.250 (57.2) 1.000 (25.4) 1.500 (38.1) 2.250 (57.2) 1.000 (25.4) 3.750 (95.3) 2.250 (57.2) 6.000 (152.4) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 0.800 (20.3) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.750 (44.5) 1.750 (44.5) 1.750 (44.5) 2.000 (50.8) 2.000 (50.8) 2.500 (63.5) 2.000 (50.8) E Figure 15 Horiz. Vert. Web Print Area Repeat C Repeat D Width E Height F Per Inch (mm) Inch (mm) Inch (mm) Inch (mm) Row 0.600 (15.2) 0.600 (15.2) 0.662 (16.8) 0.800 (20.3) 0.800 (20.3) 0.800 (20.3) 1.100 (27.9) 1.100 (27.9) 1.075 (27.3) 1.100 (27.9) 1.075 (27.3) 1.100 (27.9) - 0.950 (24.1) 0.950 (24.1) 1.625 (41.3) 1.125 (28.6) 1.875 (47.6) 1.625 (41.3) 0.875 (22.2) 1.125 (28.6) 1.625 (41.3) 2.375 (60.3) 1.125 (28.6) 4.000 (101.6) 6.187 (157.1) 0.875 (22.2) 1.125 (28.6) 1.750 (44.5) 2.500 (63.5) 1.125 (28.6) 1.750 (44.5) 2.500 (63.5) 1.125 (28.6) 4.000 (101.6) 2.438 (61.9) 6.187 (157.1) 2.500 (63.5) 2.500 (63.5) 3.350 (85.1) 3.350 (85.1) 3.350 (85.1) 3.400 (86.4) 2.300 (58.4) 2.300 (58.4) 3.350 (85.1) 2.300 (58.4) 2.825 (71.8) 3.350 (85.1) 2.300 (58.4) 1.700 (43.2) 1.700 (43.2) 1.700 (43.2) 1.700 (43.2) 1.950 (49.5) 1.950 (49.5) 1.950 (49.5) 2.200 (55.9) 2.200 (55.9) 2.700 (68.8) 2.200 (55.9) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.500 (38.1) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 0.750 (19.1) 1.500 (38.1) 4 4 5 4 4 4 2 2 3 2 1 3 2 1 1 1 1 1 1 1 1 1 1 1 Labels Labels Per Rec. Roll Ribbon 2500 2500 5000 5000 3500 4000 2500 2500 2500 1400 1500 1200 500 1500 1250 1000 700 1250 1000 500 1500 400 500 200 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 Patch Panel Adhesive Strips (B-422) • Continuous supply in 3 widths to make labeling patch panels and other datacomm components quick and easy B • Aggressive adhesive suitable for rough, highly textured and powder-coated surfaces as well as smooth surfaces A E Figure 3 Service temp: -40°F to 212°F Agency Approvals: 20 Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Web Width E Inch (mm) Labels Per Roll Rec. Ribbon BBP33 only BBP33 only BBP33 only Fig. 3 Fig. 3 Fig. 3 B33C-240-422 B33C-312-422 B33C-375-422 B-422 B-422 B-422 White White White 0.240 (6.1) 0.312 (7.9) 0.375 (9.5) 85ft (25.9m) 85ft (25.9m) 85ft (25.9m) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R6000 B30-R6000 B30-R6000 BBP®33 Materials Tedlar® Adhesive Wire & Cable Labels (B-437) • Topcoated Polyvinylflouride label for wire & cable marking where high temperature and self-extinguishing features are required • Heavy duty performance with excellent resistance to water, oil and other fluids • Meets MIL–M-87958 Standard A Service temp: -94°F to 275°F Agency Approvals: A B C B D D B A E Figure 1 C E E Figure 3 Fits Printer Model(s) Diagram Catalog # B# BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only B33-11-437 B33-1-437 B33-2-437 B33-5-437 B33-29-437 B33-5-437YL B33-29-437YL B-437 B-437 B-437 B-437 B-437 B-437 B-437 B33C-1000-437 B33C-1500-437 B33C-2000-437 B33C-3000-437 B33C-1000-437YL B33C-1500-437YL B33C-2000-437YL B33C-3000-437YL B-437 B-437 B-437 B-437 B-437 B-437 B-437 B-437 Fig. 4 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Figure 4 Color Label Width A Inch (mm) Label Height B Inch (mm) Horiz. Repeat C Inch (mm) Vert. Repeat D Inch (mm) Web Width E Inch (mm) Labels Labels Per Per Row Roll Rec. Ribbon White White White White White Yellow Yellow 0.250 (6.4) 0.750 (19.1) 0.900 (22.9) 1.000 (25.4) 1.250 (31.8) 1.000 (25.4) 1.250 (31.8) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.500 (12.7) 0.375 (9.5) 0.500 (12.7) 0.375 (9.5) 0.250 (6.4) 0.800 (20.3) 1.125 (28.6) 1.075 (27.3) 1.300 (33.0) 1.075 (27.3) 1.300 (33.0) 0.375 (9.5) 0.350 (8.9) 0.350 (8.9) 0.600 (15.2) 0.475 (12.1) 0.600 (15.2) 0.475 (12.1) 3.200 (81.3) 3.350 (85.1) 3.350 (85.1) 3.350 (85.1) 2.750 (69.9) 3.350 (85.1) 2.750 (69.9) 12 4 3 3 2 3 2 White White White White Yellow Yellow Yellow Yellow 1.000 (25.4) 1.500 (38.1) 2.000 (50.8) 3.000 (76.2) 1.000 (25.4) 1.500 (38.1) 2.000 (50.8) 3.000 (76.2) 85ft. (25.9m) 85ft. (25.9m) 85ft. (25.9m) 85ft. (25.9m) 85ft. (25.9m) 85ft. (25.9m) 85ft. (25.9m) 85ft. (25.9m) - - 1.200 (30.5) 1.900 (48.3) 2.200 (55.9) 3.400 (86.4) 1.200 (30.5) 1.900 (48.3) 2.200 (55.9) 3.400 (86.4) 15000 5000 5000 5000 5000 5000 5000 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 Continuous Rolls BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 3 Fig. 3 Fig. 3 Fig. 3 Fig. 3 Fig. 3 Fig. 3 Fig. 3 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 Polyimide High Temp Adhesive Wire & Cable Labels (B-472) • Topcoated Polyimide label for wire & cable marking where high temperature and self-extinguishing features are required • Heavy duty performance with excellent resistance to water, oil and other fluids Service temp: -94°F to 320°F Agency Approvals: A A C B D B B D A E C E Figure 1 E Figure 3 Fits Printer Model(s) Diagram Catalog # B# BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only B33-11-472 B33-1-472 B33-2-472 B33-5-472 B33-29-472 B33-5-472YL B33-29-472YL B-472 B-472 B-472 B-472 B-472 B-472 B-472 B33C-1000-472 B33C-1500-472 B33C-2000-472 B33C-3000-472 B33C-1000-472YL B33C-1500-472YL B33C-2000-472YL B33C-3000-472YL B-472 B-472 B-472 B-472 B-472 B-472 B-472 B-472 Fig. 4 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Figure 4 Color Label Width A Inch (mm) Label Height B Inch (mm) Horiz. Repeat C Inch (mm) Vert. Repeat D Inch (mm) Web Width E Inch (mm) White White White White White Yellow Yellow 0.250 (6.4) 0.750 (19.1) 0.900 (22.9) 1.000 (25.4) 1.250 (31.8) 1.000 (25.4) 1.250 (31.8) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.500 (12.7) 0.375 (9.5) 0.500 (12.7) 0.375 (9.5) 0.250 (6.4) 0.800 (20.3) 1.125 (28.6) 1.075 (27.3) 1.300 (33.0) 1.075 (27.3) 1.300 (33.0) 0.375 (9.5) 3.200 (81.3) 0.350 (8.9) 3.350 (85.1) 0.350 (8.9) 3.350 (85.1) 0.600 (15.2) 3.350 (85.1) 0.475 (12.1) 2.750 (69.9) 0.600 (15.2) 3.350 (85.1) 0.475 (12.1) 2.750 (69.9) White White White White Yellow Yellow Yellow Yellow 1.000 (25.4) 1.500 (38.1) 2.000 (50.8) 3.000 (76.2) 1.000 (25.4) 1.500 (38.1) 2.000 (50.8) 3.000 (76.2) 85ft (25.9m) 85ft (25.9m) 85ft (25.9m) 85ft (25.9m) 85ft (25.9m) 85ft (25.9m) 85ft (25.9m) 85ft (25.9m) - - Labels Labels Per Per Row Roll Rec. Ribbon 12 4 3 3 2 3 2 15000 5000 5000 5000 5000 5000 5000 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 Continuous Rolls BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only BBP33 only Fig. 3 Fig. 3 Fig. 3 Fig. 3 Fig. 3 Fig. 3 Fig. 3 Fig. 3 BradyID.com/bbp31 1.200 (30.5) 1.900 (48.3) 2.200 (55.9) 3.400 (86.4) 1.200 (30.5) 1.900 (48.3) 2.200 (55.9) 3.400 (86.4) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 21 BBP®33 Materials PermaSleeve® PS Polyolefin Wire Marking Sleeves (B-342) Standard Military/Industrial Grade. 3:1 Shrink ratio. • • • • A 3:1 heat shrinkable wire marker sleeve that fits snugly around wires Can be used for identification or wire protection Fade-resistant and flame-retardant Meets the following insulating and physical property specifications: - SAE-AMS-DTL-23053/5C (class 1) - SAE-AS-81531 - MIL-STD-202 - Tested per ASTM E162, ASTM E662 A A Service temp: -40°F to 267°F (short burst max temp: 5 min at 500°F, 24 hrs at 350°F) Agency Approvals: B B (Ø diameter) (Ø diameter) Figure 20 Fits Printer Model Diagram Catalog # Material Color For Wire Gauge (approx.) Figure 20-2 For Wire Diameters Supplied Inch (mm) Diameter B Min. Max. Inch (mm) Recovered Diameter Inch (mm) Recovered Wall Thickness Inch (mm) Sleeves Per Per Rec. Row Roll Ribbon 3:1 Shrink ratio single-side printable, 2” sleeve width (dimension A): BBP33 Fig. 20 B33-94-2-342 B-342 White 28 to 20 0.023(0.6) - 0.080 (2.0) 0.094 (2.4) 0.024 (0.6) .024 (0.6) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33-125-2-342 B-342 White 22 to 16 0.046(1.2) - 1.110 (2.8) 0.125 (3.2) 0.047 (1.2) .020 (0.5) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33-187-2-342 B-342 White 20 to 10 0.062(1.6) - 0.150 (3.8) 0.187 (4.7) 0.062 (1.6) .020 (0.5) +/- .003 (0.07) 1 750 B30-R4300 BBP33 Fig. 20 B33-250-2-342 B-342 White 16 to 8 0.094(2.4) - 0.215 (5.5) 0.250 (6.4) 0.093 (2.4) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4300 BBP33 Fig. 20 B33-375-2-342 B-342 White 12 to 4 0.125(3.2) - 0.320 (8.1) 0.375 (9.5) 0.125 (3.1) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4300 BBP33 Fig. 20 B33-500-2-342 B-342 White 8 to 1 0.187(4.8) - 0.450 (11.4) 0.500 (12.7) 1.187 (4.7) .025 (0.6) +/- .003 (0.07) 1 350 B30-R4300 BBP33 Fig. 20 B33-750-2-342 B-342 White 6 to 4/0 0.250(6.4) - 0.700 (17.8) 0.750 (19.0) 0.250 (6.4) .025 (0.6) +/- .003 (0.07) 1 250 B30-R4300 BBP33 Fig. 20 B33-1000-2-342 B-342 White 2 to 0.950 dia 0.333(8.5) - 0.950 (24.1) 1.000 (25.4) 0.375 (9.5) .036 (0.9) +/- .003 (0.07) 1 250 B30-R4300 BBP33 Fig. 20 B33-1500-2-342 B-342 White n/a 0.500(12.7) - 1.400 (35.6) 1.500 (38.1) 0.500 (12.7) .035 (0.9) +/- .003 (0.07) 1 150 B30-R4300 BBP33 Fig. 20 B33-94-2-342YL B-342 Yellow 28 to 20 0.023(0.6) - 0.080 (2.0) 0.094 (2.4) 0.024 (0.6) .024 (0.6) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33-125-2-342YL B-342 Yellow 22 to 16 0.046(1.2) - 1.110 (2.8) 0.125 (3.2) 0.047 (1.2) .020 (0.5) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33-187-2-342YL B-342 Yellow 20 to 10 0.062(1.6) - 0.150 (3.8) 0.187 (4.7) 0.062 (1.6) .020 (0.5) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33-250-2-342YL B-342 Yellow 16 to 8 0.094(2.4) - 0.215 (5.5) 0.250 (6.4) 0.093 (2.4) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4300 BBP33 Fig. 20 B33-375-2-342YL B-342 Yellow 12 to 4 0.125(3.2) - 0.320 (8.1) 0.375 (9.5) 0.125 (3.1) .025 (0.6) +/- .003 (0.07) 1 250 B30-R4300 BBP33 Fig. 20 B33-500-2-342YL B-342 Yellow 8 to 1 0.187(4.8) - 0.450 (11.4) 0.500 (12.7) 1.187 (4.7) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4300 BBP33 Fig. 20 B33-750-2-342YL B-342 Yellow 6 to 4/0 0.250(6.4) - 0.700 (17.8) 0.750 (19.0) 0.250 (6.4) .025 (0.6) +/- .003 (0.07) 1 350 B30-R4300 BBP33 Fig. 20 B33-1000-2-342YL B-342 Yellow 2 to 0.950 dia 0.333(8.5) - 0.950 (24.1) 1.000 (25.4) 0.375 (9.5) .036 (0.9) +/- .003 (0.07) 1 250 B30-R4300 BBP33 Fig. 20 B33-1500-2-342YL B-342 Yellow n/a 0.500(12.7) - 1.400 (35.6) 1.500 (38.1) 0.500 (12.7) .035 (0.9) +/- .003 (0.07) 1 150 B30-R4300 BBP33 Fig. 20 B33-1500-2-342BK B-342 Black n/a 0.500(12.7) - 1.400 (35.6) 1.500 (38.1) 0.500 (12.7) .035 (0.9) +/- .003 (0.07) 1 150 B30-R4500-SV 3:1 Shrink ratio single-side printable, 1” sleeve width in “2-up pre-cut” configuration (dimension A): 22 BBP33 Fig. 20-2 B33-94-2-342-2 B-342 White 28 to 20 0.023(0.6) - 0.080 (2.0) 0.094 (2.4) 0.024 (0.6) .024 (0.6) +/- .003 (0.07) 2 2000 B30-R4300 BBP33 Fig. 20-2 B33-125-2-342-2 B-342 White 22 to 16 0.046(1.2) - 0.111 (2.8) 0.125 (3.2) 0.047 (1.2) .020 (0.5) +/- .003 (0.07) 2 2000 B30-R4300 BBP33 Fig. 20 B33-187-2-342-2 B-342 White 20 to 10 0.062(1.6) - 0.150 (3.8) 0.187 (4.7) 0.062 (1.6) .020 (0.5) +/- .003 (0.07) 2 1500 B30-R4300 BBP33 Fig. 20 B33-250-2-342-2 B-342 White 16 to 8 0.094(2.4) - 0.215 (5.5) 0.250 (6.4) 0.093 (2.4) .025 (0.6) +/- .003 (0.07) 2 1000 B30-R4300 BBP33 Fig. 20 B33-375-2-342-2 B-342 White 12 to 4 0.125(3.2) - 0.320 (8.1) 0.375 (9.5) 0.125 (3.1) .025 (0.6) +/- .003 (0.07) 2 1000 B30-R4300 BBP33 Fig. 20-2 B33-500-2-342-2 B-342 White 8 to 1 0.187(4.8) - 0.450 (11.4) 0.500 (12.7) 0.119 (3.0) .025 (0.6) +/- .003 (0.07) 2 700 B30-R4300 BBP33 Fig. 20-2 B33-750-2-342-2 B-342 White 6 to 4/0 0.250(6.4) - 0.700 (17.8) 0.750 (19.1) 0.250 (6.35) .025 (0.6) +/- .003 (0.07) 2 500 B30-R4300 BBP33 Fig. 20-2 B33-1000-2-342-2 B-342 White 2 to 0.950 dia 0.333(8.5) - 0.950 (24.1) 1.000 (25.4) 0.375 (9.5) .036 (0.9) +/- .003 (0.07) 2 500 B30-R4300 BBP33 Fig. 20-2 B33-1500-2-342-2 B-342 White n/a 0.500(12.7) - 1.400 (35.6) 1.500 (38.1) 0.500 (12.7) .035 (0.9) +/- .003 (0.07) 2 150 B30-R4300 BBP33 Fig. 20-2 B33-94-2-342YL-2 B-342 Yellow 28 to 20 0.023(0.6) - 0.080 (2.0) 0.094 (2.4) 0.024 (0.6) .024 (0.6) +/- .003 (0.07) 2 2000 B30-R4300 BBP33 Fig. 20-2 B33-125-2-342YL-2 B-342 Yellow 22 to 16 0.046(1.2) - 0.111 (2.8) 0.125 (3.2) 0.047 (1.2) .020 (0.5) +/- .003 (0.07) 2 2000 B30-R4300 BBP33 Fig. 20-2 B33-500-2-342YL-2 B-342 Yellow 8 to 1 0.187(4.8) - 0.450 (11.4) 0.500 (12.7) 0.119 (3.0) .025 (0.6) +/- .003 (0.07) 2 700 B30-R4300 BBP33 Fig. 20-2 B33-750-2-342-YL-2 B-342 Yellow 6 to 4/0 0.250(6.4) - 0.700 (17.8) 0.750 (19.1) 0.250 (6.35) .025 (0.6) +/- .003 (0.07) 2 500 B30-R4300 BBP33 Fig. 20-2 B33-1000-2-342YL-2 B-342 Yellow 2 to 0.950 dia 0.333(8.5) - 0.950 (24.1) 1.000 (25.4) 0.375 (9.5) .036 (0.9) +/- .003 (0.07) 2 500 B30-R4300 BBP33 Fig. 20-2 B33-1500-2-342-YL-2 B-342 Yellow n/a 0.500 (12.7) .035 (0.9) +/- .003 (0.07) 2 300 B30-R4300 0.500(12.7) - 1.400 (35.6) 1.500 (38.1) BBP®33 Materials PermaSleeve® PS Polyolefin Wire Marking Sleeves (Continued) Fits Printer Model Diagram Catalog # Material Color For Wire Gauge (approx.) For Wire Diameters Supplied Inch (mm) Diameter B Min. Max. Inch (mm) Recovered Diameter Inch (mm) Recovered Wall Thickness Inch (mm) Sleeves Per Per Rec. Row Roll Ribbon 3:1 Shrink ratio double-side printable, 2” sleeve width (dimension A): BBP33 Fig. 20 B33D-94-2-342 B-342 White 28 to 20 0.023(0.6) - 0.080 (2.0) 0.094 (2.4) 0.024 (0.6) .024 (0.6) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33D-187-2-342 B-342 White 20 to 10 0.062(1.6) - 0.150 (3.8) 0.187 (4.7) 0.062 (1.6) .020 (0.5) +/- .003 (0.07) 1 750 BBP33 Fig. 20 B33D-125-2-342 B-342 White 22 to 16 0.046(1.2) - 1.110 (2.8) 0.125 (3.2) 0.047 (1.2) .020 (0.5) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33D-250-2-342 B-342 White 16 to 8 0.094(2.4) - 0.215 (5.5) 0.250 (6.4) 0.093 (2.4) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4300 BBP33 Fig. 20 B33D-375-2-342 B-342 White 12 to 4 0.125(3.2) - 0.320 (8.1) 0.375 (9.5) 0.125 (3.1) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4300 BBP33 Fig. 20 B33D-500-2-342 B-342 White 8 to 1 0.187(4.8) - 0.450 (11.4) 0.500 (12.7) 1.187 (4.7) .025 (0.6) +/- .003 (0.07) 1 350 B30-R4300 BBP33 Fig. 20 B33D-750-2-342 B-342 White 6 to 4/0 0.250(6.4) - 0.700 (17.8) 0.750 (19.0) 0.250 (6.4) .025 (0.6) +/- .003 (0.07) 1 250 B30-R4300 BBP33 Fig. 20 B33D-1000-2-342 B-342 White 2 to 0.950 dia 0.333(8.5) - 0.950 (24.1) 1.000 (25.4) 0.375 (9.5) .036 (0.9) +/- .003 (0.07) 1 250 B30-R4300 BBP33 Fig. 20 B33D-1500-2-342 B-342 White n/a 0.500(12.7) - 1.400 (35.6) 1.500 (38.1) 0.500 (12.7) .035 (0.9) +/- .003 (0.07) 1 150 B30-R4300 BBP33 Fig. 20 B33D-94-2-342YL B-342 Yellow 28 to 20 0.023(0.6) - 0.080 (2.0) 0.094 (2.4) 0.024 (0.6) .024 (0.6) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33D-125-2-342YL B-342 Yellow 22 to 16 0.046(1.2) - 1.110 (2.8) 0.125 (3.2) 0.047 (1.2) .020 (0.5) +/- .003 (0.07) 1 1000 B30-R4300 BBP33 Fig. 20 B33D-187-2-342YL B-342 Yellow 20 to 10 0.062(1.6) - 0.150 (3.8) 0.187 (4.7) 0.062 (1.6) .020 (0.5) +/- .003 (0.07) 1 750 B30-R4300 BBP33 Fig. 20 B33D-250-2-342YL B-342 Yellow 16 to 8 0.094(2.4) - 0.215 (5.5) 0.250 (6.4) 0.093 (2.4) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4300 BBP33 Fig. 20 B33D-375-2-342YL B-342 Yellow 12 to 4 0.125(3.2) - 0.320 (8.1) 0.375 (9.5) 0.125 (3.1) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4300 BBP33 Fig. 20 B33D-500-2-342YL B-342 Yellow 8 to 1 0.187(4.8) - 0.450 (11.4) 0.500 (12.7) 1.187 (4.7) .025 (0.6) +/- .003 (0.07) 1 350 B30-R4300 BBP33 Fig. 20 B33D-750-2-342YL B-342 Yellow 6 to 4/0 0.250(6.4) - 0.700 (17.8) 0.750 (19.0) 0.250 (6.4) .025 (0.6) +/- .003 (0.07) 1 250 B30-R4300 BBP33 Fig. 20 B33D-1000-2-342YL B-342 Yellow 2 to 0.950 dia 0.333(8.5) - 0.950 (24.1) 1.000 (25.4) 0.375 (9.5) .036 (0.9) +/- .003 (0.07) 1 250 B30-R4300 BBP33 Fig. 20 B33D-1500-2-342YL B-342 Yellow n/a 0.500(12.7) - 1.400 (35.6) 1.500 (38.1) 0.500 (12.7) .035 (0.9) +/- .003 (0.07) 1 150 B30-R4300 BBP33 Fig. 20 B33D-94-2-342BK B-342 Black 28 to 20 0.023(0.6) - 0.080 (2.0) 0.094 (2.4) 0.024 (0.6) .024 (0.6) +/- .003 (0.07) 1 1000 B30-R4500-SV BBP33 Fig. 20 B33D-125-2-342BK B-342 Black 22 to 16 0.046(1.2) - 1.110 (2.8) 0.125 (3.2) 0.047 (1.2) .020 (0.5) +/- .003 (0.07) 1 1000 B30-R4500-SV BBP33 Fig. 20 B33D-187-2-342BK B-342 Black 20 to 10 0.062(1.6) - 0.150 (3.8) 0.187 (4.7) 0.062 (1.6) .020 (0.5) +/- .003 (0.07) 1 750 B30-R4500-SV BBP33 Fig. 20 B33D-250-2-342BK B-342 Black 16 to 8 0.094(2.4) - 0.215 (5.5) 0.250 (6.4) 0.093 (2.4) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4500-SV BBP33 Fig. 20 B33D-375-2-342BK B-342 Black 12 to 4 0.125(3.2) - 0.320 (8.1) 0.375 (9.5) 0.125 (3.1) .025 (0.6) +/- .003 (0.07) 1 500 B30-R4500-SV BBP33 Fig. 20 B33D-500-2-342BK B-342 Black 8 to 1 0.187(4.8) - 0.450 (11.4) 0.500 (12.7) 1.187 (4.7) .025 (0.6) +/- .003 (0.07) 1 350 B30-R4500-SV BBP33 Fig. 20 B33D-750-2-342BK B-342 Black 6 to 4/0 0.250(6.4) - 0.700 (17.8) 0.750 (19.0) 0.250 (6.4) .025 (0.6) +/- .003 (0.07) 1 250 B30-R4500-SV BBP33 Fig. 20 B33D-1000-2-342BK B-342 Black 2 to 0.950 dia 0.333(8.5) - 0.950 (24.1) 1.000 (25.4) 0.375 (9.5) .036 (0.9) +/- .003 (0.07) 1 250 B30-R4500-SV BBP33 Fig. 20 B33D-1500-2-342BK B-342 Black n/a 0.500 (12.7) .035 (0.9) +/- .003 (0.07) 1 150 B30-R4500-SV 0.500(12.7) - 1.400 (35.6) 1.500 (38.1) B30-R4300 BBP®33 Prints Double-Sided Wire Sleeves! Print double sided sleeves with no wasted labels! Double sided sleeves are fast and easy with the BBP®33 printer. Use the appropriate double sided sleeve part and create your print job using LabelMark ® sofware’s “two-sided print” feature. After the first side of your print job is complete, the software prompts you to cut the media and re-insert it for a second print pass. BradyID.com/bbp31 23 BBP®33 Materials PermaSleeve® HT High Temperature PVDF Wire Marking Sleeves (B-345) High temperature, low outgassing. 2:1 Shrink ratio. • A 2:1 shrink ratio wire marker sleeve specifically designed for high temperature and low vacuum outgassing applications • Made from irridated high-temp Polyvinylidine Fluoride (PVDF) heat shrink tubing • Fade-resistant and flame-retardant • Meets the following industry specifications: A - NASA SP-R-0022A Outgassing Performance B - Tested per ASTM E162, ASTM E662, SAE-AMS-DTL-23053/18 (class 2) - MIL-STD-202 (Ø diam eter) - SAE-AS-81531 Service temp: -67°F to 437°F Agency Approvals for HT and HX Sleeves: Figure 20 Fits For Wire Diameters Printer Diagram For Wire Gauge Inch (mm) Catalog # Model Material Color (approx.) Min. Max. 3:1 Shrink ratio double-side printable, 2” sleeve width (dimension A): Supplied Diameter B Inch (mm) Recovered Diameter Inch (mm) BBP33 Fig. 20 B33D-94-2-345 BBP33 Fig. 20 B33D-94-2-345BK 0.094 (2.4) 0.094 (2.4) 0.031 (0.8) 0.031 (0.8) .015 (0.4) +/- .003 (0.07) .015 (0.4) +/- .003 (0.07) 1 1 1000 B30-R6000 1000 B30-R4400-WT 0.125 (3.2) 0.187 (4.7) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.750 (19.0) 1.000 (25.4) 1.500 (38.1) 0.125 (3.2) 0.187 (4.7) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.750 (19.0) 1.000 (25.4) 1.500 (38.1) 0.062 (1.6) 0.093 (2.4) 0.125 (3.2) 0.187 (4.7) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 0.062 (1.6) 0.093 (2.4) 0.125 (3.2) 0.187 (4.7) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) .015 (0.4) .015 (0.4) .015 (0.4) .015 (0.4) .015 (0.4) .015 (0.4) .017 (0.4) .024 (0.6) .015 (0.4) .015 (0.4) .015 (0.4) .015 (0.4) .015 (0.4) .015 (0.4) .017 (0.4) .024 (0.6) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1000 750 500 500 350 250 250 150 1000 750 500 500 350 250 250 150 B-345 B-345 White 26 to 20 Black 26 to 20 0.031 (0.8) - 0.080 (2.0) 0.031 (0.8) - 0.080 (2.0) Recovered Wall Thickness Inch (mm) Sleeves Per Per Rec. Row Roll Ribbon 2:1 Shrink ratio double-side printable, 2” sleeve width (dimension A): BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 B33D-125-2-345 B33D-187-2-345 B33D-250-2-345 B33D-375-2-345 B33D-500-2-345 B33D-750-2-345 B33D-1000-2-345 B33D-1500-2-345 B33D-125-2-345BK B33D-187-2-345BK B33D-250-2-345BK B33D-375-2-345BK B33D-500-2-345BK B33D-750-2-345BK B33D-1000-2-345BK B33D-1500-2-345BK B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 B-345 White White White White White White White White Black Black Black Black Black Black Black Black 20 to 16 16 to 10 12 to 8 8 to 4 6 to 1 2 to 4/0 2/0 to 0.950 dia N/A 20 to 16 16 to 10 12 to 8 8 to 4 6 to 1 3 to 4/0 2/0 to 0.950 dia N/A 0.063 (1.6) - 0.110 (2.8) 0.094 (2.4) - 0.150 (3.8) 0.125 (3.2) - 0.215 (5.5) 0.187 (3.2) - 0.320 (8.1) 0.250 (6.4) - 0.450 (11.4) 0.375 (9.5) - 0.700 (17.8) 0.450 (11.4) - 0.950 (24.1) 0.750 (19.1) - 1.400 (35.6) 0.063 (1.6) - 0.110 (2.8) 0.094 (2.4) - 0.150 (3.8) 0.125 (3.2) - 0.215 (5.5) 0.187 (3.2) - 0.320 (8.1) 0.250 (6.4) - 0.450 (11.4) 0.375 (9.5) - 0.700 (17.8) 0.450 (11.4) - 0.950 (24.1) 0.750 (19.1) - 1.400 (35.6) PermaSleeve® HX Polyolefin Wire Marking Sleeves (B-7642) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .004 (0.1) +/- .004 (0.1) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .004 (0.1) +/- .004 (0.1) B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R6000 B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT B30-R4400-WT A Military/Industrial Grade. 2:1 Shrink ratio. • Flame retardant and high-temp rated but not as high temp as B-345 “HT” sleeves • Meets the following industry specifications: - SAE-AMS-DTL-23053/5 (class 1 and 3) - MIL-STD-202 - SAE-AS-81531 - Tested per ASTM E162, ASTM E662 B (Ø diameter) Figure 20 Service temp: -40°F to 248°F (short burst max temp: 5 min at 464°F, 24 hrs at 320°F) Agency Approval: Fits For Wire Diameters Printer Diagram For Wire Gauge Inch (mm) Catalog # Model Material Color (approx.) Min. Max. 3:1 Shrink ratio single-side printable, 2” sleeve width (dimension A): Supplied Recovered Diameter B Diameter Inch (mm) Inch (mm) BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 0.094(2.4) 0.125(3.2) 0.187(4.8) 0.250(6.4) 0.375(9.5) 0.500(12.7) 0.750(19.0) 1.000(25.4) 1.500(38.1) 2.000(50.8) 0.047 (1.2) 0.063 (1.6) 0.094 (2.4) 0.126 (3.2) 0.189 (4.8) 0.252 (6.4) 0.374 (9.5) 0.500 (12.7) 0.752 (19.1) 1.000 (25.4) .020 (0.5) .020 (0.5) .020 (0.5) .025 (0.6) .025 (0.6) .025 (0.6) .030 (0.8) .035 (0.9) .040 (1.0) .045 (1.1) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .005 (0.1) +/- .006 (0.2) +/- .007 (0.2) 1 1 1 1 1 1 1 1 1 1 500 500 450 400 250 225 150 150 50 50 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 0.094(2.4) 0.125(3.2) 0.187(4.8) 0.250(6.4) 0.375(9.5) 0.500(12.7) 0.750(19.0) 1.000(25.4) 1.500(38.1) 2.000(50.8) 0.047 (1.2) 0.063 (1.6) 0.094 (2.4) 0.126 (3.2) 0.189 (4.8) 0.252 (6.4) 0.374 (9.5) 0.500 (12.7) 0.752 (19.1) 1.000 (25.4) .020 (0.5) .020 (0.5) .020 (0.5) .025 (0.6) .025 (0.6) .025 (0.6) .030 (0.8) .035 (0.9) .040 (1.0) .045 (1.1) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .003 (0.07) +/- .005 (0.1) +/- .006 (0.2) +/- .007 (0.2) 1 1 1 1 1 1 1 1 1 1 500 500 450 400 250 225 150 150 50 50 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 B33-94-2-7642 B33-125-2-7642 B33-187-2-7642 B33-250-2-7642 B33-375-2-7642 B33-500-2-7642 B33-750-2-7642 B33-1000-2-7642 B33-1500-2-7642 B33-2000-2-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 White White White White White White White White White White 24 to 20 20 to 16 16 to 10 12 to 8 8 to 4 6 to 1 2 to 4/0 2/0 to 0.950 dia N/A N/A 0.047 (1.2) - 0.080 (2.0) 0.062 (1.6) - 0.110 (2.8) 0.094 (2.4) - 0.151 (3.8) 0.125 (3.2) - 0.215 (5.5) 0.188 (4.8) - .0320 (8.1) 0.250 (6.4) - 0.450 (11.4) 0.375 (9.5) - 0.700 (17.8) 0.450 (11.4) - 0.950 (24.1) 0.750 (19.0) - 1.400 (35.6) 1.000 (25.4) - 1.900 (48.3) Recovered Wall Thickness Inch (mm) Sleeves Per Per Rec. Row Roll Ribbon 3:1 Shrink ratio double-side printable, 2” sleeve width (dimension A): BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 BBP33 24 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 Fig. 20 B33D-94-2-7642 B33D-125-2-7642 B33D-187-2-7642 B33D-250-2-7642 B33D-375-2-7642 B33D-500-2-7642 B33D-750-2-7642 B33D-1000-2-7642 B33D-1500-2-7642 B33D-2000-2-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 B-7642 White White White White White White White White White White 24 to 20 20 to 16 16 to 10 12 to 8 8 to 4 6 to 1 2 to 4/0 2/0 to 0.950 dia N/A N/A 0.047 (1.2) - 0.080 (2.0) 0.062 (1.6) - 0.110 (2.8) 0.094 (2.4) - 0.151 (3.8) 0.125 (3.2) - 0.215 (5.5) 0.188 (4.8) - 0.0320 (8.1) 0.250 (6.4) - 0.450 (11.4) 0.375 (9.5) - 0.700 (17.8) 0.450 (11.4) - 0.950 (24.1) 0.750 (19.0) - 1.400 (35.6) 1.000 (25.4) - 1.900 (48.3) BBP®33 Materials PermaSleeve® FR Fluid Resistant Wire Marking Sleeves (B-344) Military/Industrial Grade. 3:1 Shrink ratio. • Designed for labeling wires in applications where they will be exposed to fuels, lubricants and harsh chemicals such as in the installation of hydrogen fuel cells in aerospace • Resistant to harsh chemicals including JP8 Jet Fuel, Skydrol® and DOT 3 brake fluid • Meets the following industry specifications: - SAE-AMS-DTL-23053/6 (class 1) - MIL-STD-202G method 215K A B (Ø diameter) Figure 20 Service temp: -94°F to 267°F Agency Approvals for: Fits For Wire Diameters Printer For Wire Gauge Inch (mm) Diagram Catalog # Model Material Color (approx.) Min. Max. 3:1 Shrink ratio double-side printable, 2” sleeve width (dimension A): Supplied Recovered Diameter B Diameter Inch (mm) Inch (mm) BBP33 Fig. 20 B33D-94-2-344 B-344 White 28 to 20 0.023 (0.6) - 0.080 (2.0) 0.094(2.4) 0.024 (0.6) 0.024 (0.6) +/- 0.003 (0.1) 1 1000 B30-R6600 BBP33 Fig. 20 B33D-125-2-344 B-344 White 22 to 16 0.046 (1.2) - 0.111 (2.8) 0.125(3.1) 0.047 (1.2) 0.020 (0.5) +/- 0.003 (0.1) 1 1000 B30-R6600 BBP33 Fig. 20 B33D-187-2-344 B-344 White 20 to 10 0.062 (1.6) - 0.15 (3.81) 0.187(4.8) 0.062 (1.6) 0.020 (0.5) +/- 0.003 (0.1) 1 750 B30-R6600 BBP33 Fig. 20 B33D-250-2-344 B-344 White 16 to 8 0.094 (2.4) - 0.215 (5.5) 0.250(6.35) 0.093 (2.4) 0.025 (0.6) +/- 0.003 (0.1) 1 500 B30-R6600 BBP33 Fig. 20 B33D-375-2-344 B-344 White 12 to 4 0.125 (3.2) - 0.320 (8.1) 0.375(9.5) 0.125 (3.2) 0.025 (0.6) +/- 0.003 (0.1) 1 500 B30-R6600 BBP33 Fig. 20 B33D-500-2-344 B-344 White 8 to 1 0.187 (4.8) - 0.450 (11.4) 0.500(12.7) 0.119 (3.0) 0.025 (0.6) +/- 0.003 (0.1) 1 350 B30-R6600 BBP33 Fig. 20 B33D-750-2-344 B-344 White 6 to 4/0 0.250 (6.4) - 0.700 (17.8) 0.750(19.05) 0.250 (6.35) 0.025 (0.6) +/- 0.003 (0.1) 1 250 B30-R6600 BBP33 Fig. 20 B33D-1000-2-344 B-344 White 2 to 0.950 dia 0.333 (8.5) - 0.950 (24.1) 1.000(25.4) 0.375 (9.5) 0.036 (0.9) +/- 0.003 (0.1) 1 250 B30-R6600 BBP33 Fig. 20 B33D-1500-2-344 B-344 White n/a 0.500 (12.7) - 1.400 (35.6) 1.500(38.1) 0.500 (12.7) 0.035 (0.9) +/-0 .003 (0.1) 1 150 B30-R6600 BBP33 Fig. 20 B33D-94-2-344YL B-344 Yellow 28 to 20 0.023 (0.6) - 0.080 (2.0) 0.094(2.4) 0.024 (0.6) 0.024 (0.6) +/- 0.003 (0.1) 1 1000 B30-R6600 BBP33 Fig. 20 B33D-125-2-344YL B-344 Yellow 22 to 16 0.046 (1.2) - 0.111 (2.8) 0.125(3.1) 0.047 (1.2) 0.020 (0.5) +/- 0.003 (0.1) 1 1000 B30-R6600 BBP33 Fig. 20 B33D-187-2-344YL B-344 Yellow 20 to 10 0.062 (1.6) - 0.15 (3.81) 0.187(4.8) 0.062 (1.6) 0.020 (0.5) +/- 0.003 (0.1) 1 750 B30-R6600 BBP33 Fig. 20 B33D-250-2-344YL B-344 Yellow 16 to 8 0.094 (2.4) - 0.215 (5.5) 0.250(6.35) 0.093 (2.4) 0.025 (0.6) +/- 0.003 (0.1) 1 500 B30-R6600 BBP33 Fig. 20 B33D-375-2-344YL B-344 Yellow 12 to 4 0.125 (3.2) - 0.320 (8.1) 0.375(9.5) 0.125 (3.2) 0.025 (0.6) +/- 0.003 (0.1) 1 500 B30-R6600 BBP33 Fig. 20 B33D-500-2-344YL B-344 Yellow 8 to 1 0.187 (4.8) - 0.450 (11.4) 0.500(12.7) 0.119 (3.0) 0.025 (0.6) +/- 0.003 (0.1) 1 350 B30-R6600 BBP33 Fig. 20 B33D-750-2-344YL B-344 Yellow 6 to 4/0 0.250 (6.4) - 0.700 (17.8) 0.750(19.05) 0.250 (6.35) 0.025 (0.6) +/- 0.003 (0.1) 1 250 B30-R6600 BBP33 Fig. 20 B33D-1000-2-344YL B-344 Yellow 2 to 0.950 dia 0.333 (8.5) - 0.950 (24.1) 1.000(25.4) 0.375 (9.5) 0.036 (0.9) +/- 0.003 (0.1) 1 250 B30-R6600 BBP33 Fig. 20 B33D-1500-2-344YL B-344 Yellow n/a 0.500 (12.7) - 1.400 (35.6) 1.500(38.1) 0.500 (12.7) 0.035 (0.9) +/-0 .003 (0.1) 1 150 B30-R6600 BBP33 Fig. 20 B33D-94-2-344BK B-344 Black 28 to 20 0.023 (0.6) - 0.080 (2.0) 0.094(2.4) 0.024 (0.6) 0.024 (0.6) +/- 0.003 (0.1) 1 1000 B30-R6700-WT BBP33 Fig. 20 B33D-125-2-344BK B-344 Black 22 to 16 0.046 (1.2) - 0.111 (2.8) 0.125(3.1) 0.047 (1.2) 0.020 (0.5) +/- 0.003 (0.1) 1 1000 B30-R6700-WT BBP33 Fig. 20 B33D-187-2-344BK B-344 Black 20 to 10 0.062 (1.6) - 0.15 (3.81) 0.187(4.8) 0.062 (1.6) 0.020 (0.5) +/- 0.003 (0.1) 1 750 B30-R6700-WT BBP33 Fig. 20 B33D-250-2-344BK B-344 Black 16 to 8 0.094 (2.4) - 0.215 (5.5) 0.250(6.35) 0.093 (2.4) 0.025 (0.6) +/- 0.003 (0.1) 1 500 B30-R6700-WT BBP33 Fig. 20 B33D-375-2-344BK B-344 Black 12 to 4 0.125 (3.2) - 0.320 (8.1) 0.375(9.5) 0.125 (3.2) 0.025 (0.6) +/- 0.003 (0.1) 1 500 B30-R6700-WT BBP33 Fig. 20 B33D-500-2-344BK B-344 Black 8 to 1 0.187 (4.8) - 0.450 (11.4) 0.500(12.7) 0.119 (3.0) 0.025 (0.6) +/- 0.003 (0.1) 1 350 B30-R6700-WT BBP33 Fig. 20 B33D-750-2-344BK B-344 Black 6 to 4/0 0.250 (6.4) - 0.700 (17.8) 0.750(19.05) 0.250 (6.35) 0.025 (0.6) +/- 0.003 (0.1) 1 250 B30-R6700-WT BBP33 Fig. 20 B33D-1000-2-344BK B-344 Black 2 to 0.950 dia 0.333 (8.5) - 0.950 (24.1) 1.000(25.4) 0.375 (9.5) 0.036 (0.9) +/- 0.003 (0.1) 1 250 B30-R6700-WT BBP33 Fig. 20 B33D-1500-2-344BK B-344 Black n/a 0.500 (12.7) 0.035 (0.9) +/-0 .003 (0.1) 1 150 B30-R6700-WT 0.500 (12.7) - 1.400 (35.6) 1.500(38.1) BradyID.com/bbp31 Recovered Wall Thickness Inch (mm) Sleeves Per Per Rec. Row Roll Ribbon 25 BBP®31 and BBP®33 Print Ribbones Print Ribbons Catalog # “Drop & Click” print ribbons for 5 second ribbon supply changes. • Tough, smear-proof ribbons that produce long-lasting printed text and can withstand years in industrial areas and outdoor conditions Installs in 5 seconds and the ink always faces the right direction! Catalog # Color 4.330” x 200’ Heavy-duty ribbons for outdoor & harsh facility materials: B30-R10000 Black B30-R10000-WT White B30-R10000-RD Red B30-R10000-GN Green B30-R10000-BL Blue • Self-contained cartridges drop straight into printer with a “click” B30-R10000-YL B30-R10000-YL2 B30-R10000-OR B30-R10000-MA • No calibrating, no threading, no wasted feeding, no hassles, and the Color 4.330” x 200’ Industrial grade print ribbons: B30-R4300 B30-R6000 B30-R6200 B30-R6400 B30-R6600 B30-R4400-WT B30-R6700-WT B30-R4500-SV Yellow*** Yellow*** Orange Black Black Black Black Black White White Silver* Magenta ink will always be facing the right * B30-R4500-SV for use with B-342 black PermaSleeves only. direction! *** For printing yellow onto white B-595 use B30-R10000YL. For printing yellow onto other colors of B-595 use B30-R10000-YL2. • Printer notifies user if installed ribbon is not recommended for installed labels BBP®31 & BBP®33 Print Ribbon / Material Compatibility (Updated September 2014) Update your BBP®33 printer firmware. Recommendations below assume current firmware version. Visit www.BradyID.com/bbp33 for free upgrade via download. YL WT - R4300 - R6000 - R6200 - R6400 - R6600 - - R10000 - WT - R4400 R10000 WT - R6700 - - R10000 - - - R10000 - YL2 - R10000 - R4500 SV - B-# Material B30 B-342 PermaSleeve® PS Wire Markers B-344 PermaSleeve® FR Wire Markers B-345 PermaSleeve® HT Wire Markers B-422 Glossy White Polyester B-423 Glossy White Polyester B-424 Matte White Paper B-425 Matte White Polypropylene B-426 Matte Amber Polyimide B-427 Vinyl Self-Laminating B-428 Metallized Polyester B-430 Glossy Clear Polyester B-432 Glossy Clear Polyester B-434 Glossy Metallized Polyester B-435 Glossy Metallized Polyester B-437 Tedlar® B-438 Tamper Evident Metallized Polyester B-457 Glossy White Polyimide B-472 Topcoated Polyimide B-483 Glossy White Polyester B-484 Glossy White Polyester B-486 Matte Metallized Polyester B-489 Matte White Polyester B-498 Repositionable Coated Vinyl Cloth B-499 Coated Nylon Cloth B-509 Printable Magnetic B-526 Photoluminescent Polyester B-549 Cold Temp Polyester B-551 Non-Adhesive Tag B-565 Metallized Polyester B-569 Low-Halide Polyester B-581 Repositionable Vinyl B-584 Retro Reflective B-593 Raised Panel Engraved Plate Substitute B-595 Outdoor Vinyl B-854 Toughwash™ Metal Detectable B-855 Toughwash™ B-717 Glossy Static Dissipative Polyimide B-718 Glossy Low Profile Static Dissipative Polyimide B-719 Matte Low Profile Static Dissipative Polyimide B-7642 PermaSleeve® HX Wire Markers (Bl ack) B30 (Bl ack) B30 (Bl ack) B30 (Bl ack) B30 (Bl ack) B30 l – – – – l l l l l – – – – l l – l – – l l l – – – – – l – – – – – – – – – – – – l l l – – – – – l l l l – – l – l l – – – l l l l l – l l l l l l l l l l – – – – l – – – – – l – – – – – – – – – – – l – – – – – – – – – – – – – – – – – – – – – – l – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – l l l – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – l l l l – l l l – l – – – – – l – – l – – (Bl ack) (White) B30 (W hit e) B30 – – – l* – – – – – – – l l – – – – – – – – – – – – – – – – – – – – l – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – l – – l l – – l – – – – B30 (W hit e) l – – – – – – – – Refer to the corresponding Tech Data Sheets for complete material information at www.BradyID.com/techdata. *B30-R4500-SV ribbon for use with B-342 black PermaSleeves® only; B30-R4400-WT ribbon for use with B-345 black PermaSleeves® only. **Colored ribbons optimized for use on white material. Test use on other material colors for suitability to your application. ***For printing yellow onto white B-595 use B30-R10000-YL. For printing yellow onto other colors of B-595 use B30-R10000-YL2. 26 B30 (Y ellow ) (Yello w) B30 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – l *** – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – l *** – – – – – – – (Colors) B30 B30 – – – – – – – – – – – – – – – – – – – – – – – – l ** l ** l ** l ** – l ** l ** l ** – l ** – – – – – l* – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – (Sil ver) All labels were created using the BBP®31 & BBP®33 Printers and are shown in their actual size. B30C-1125-595-YL B33-75-427 B33-75-427 B33-187-2-342 B33-9-427 B30-222-438 B30EP-174-593-BK B30EP-173-593-SV B30EP-173-593-SL B30EP-177-593-YL Create multicolor signs and chemical labels in 1 print pass by using supplies with pre-printed color headers, diamonds and color bars. B30-245-595-NFPA B30-261-7569-CLP4A B30-25-595-ANSIWA B30EP-167-593-WT Raised profile engraved plate B30EP-168-593-BK substitute labels are pre-cut for common sizes, last 10 years outdoors and cost up to 80% less than engraved. B30C-2250-595-OR BradyID.com/bbp31 B30C-1125-595-WT B30-241-595-ANSIDA B30C-4000-595-YL B-595 vinyl is our most aggressive ever - it sticks to pipes and extremely rough surfaces and lasts up to 10 years outdoors. B30C-2250-595-GN B30C-2250-595-GN B30C-1125-595-BL B30C-2500-509-WT B33-18-434 B33-164-481 B33-68-498 B33-103-457 B33-17-438 B30C-4250-551-WT BBP®31 Sign & Label Printer Specifications BBP®33 Label Printer Specifications Produces Facility & Safety labels for indoor and up to 10-year outdoor use. Built-in auto-tape cut-off and full smart chip enabled supplies for Description hassle-free drop lock and print loading. Label rolls and ribbons drop & snap into place for 20-second total changeover time. For facility ID such as signs, pipe markers, lean/5S, GHS labels, arc flash labels, equipment labels, reflective and glowin-dark ID, tags, magnetic and panel labels. Widest selection of colored labels, colored ribbons and outdoor grade labels. Applications & Other Comments Recommended Throughput & Operational Hours* Print Technology Print Resolution Max Print Speed Max Print Width Media Widths Minimum Label Dimension Color Capabilities PC Connect or Stand Alone Connectivity Options Compatible Software 600 2”x4” labels per day, 300 larger labels per day, 3 hrs / 5 days Thermal Transfer 300 dpi 3" per sec 4.000” 0.500” to 4.250” 0.500” Monocolor PC Connect and Stand Alone Standard: USB MarkWare™ Software, Windows® based driver for 3rd party software use * Not a guarantee of performance. Depends on specific label size, text printed and other factors. Specialty Material Recommendations B-593 Raised Panel Labels PermaSleeve ® Wire Marking Sleeves Double-Sided PermaSleeve® Custom Labels Yes (Recommended) No No No High performance “full hassle-free” printing where smart chip supplies automatically set up label eliminating calibration steps and label waste. Prints on the first label! Label rolls and ribbons drop & snap into place for 20-second total changeover time. Applications & Multi-application printer with complete range of supplies for Wire, Cable, Other Comments Product and Electronics applications as well as Safety, Facility and Lean/5S. Recommended Wire ID & Small OEM labels Safety labels Throughput & 1000 labels per day 600 2” x 4” labels per day Operational Hours* 8 hours / 5 days 300 larger labels per day Print Technology Thermal Transfer Print Resolution 300 dpi Auto Cutter Standard (Built-in) Max Print Speed 4” per sec Max Print Width 4.000” Media Widths 0.500” to 4.250” Minimum Label 0.240” Dimension Color Capabilities Monocolor PC Connect or PC Connect only Stand Alone Connectivity Standard: USB, Ethernet Options Optional: WiFi, WiFi Direct Printer Language BPL (Brady Programming Language) Compatible Labelmark™ Software, MarkWare™ Software, Codesoft™ Software, Windows® Software based driver for 3rd party software use Description * Not a guarantee of performance. Depends on specific label size, text printed and other factors. Specialty Material Recommendations B-593 Raised Panel Labels PermaSleeve® PS, HT, HX and FR Wire Marking Sleeves Double-Sided PermaSleeve® Custom Labels Yes Yes Yes (with 2-pass reinsert of media) Yes (in approved Brady B numbers) Software-Printer compatability. Brady Software The powerful and easy-to-use Brady software takes your label-making muscle to even higher levels. Compatible with BBP®31 and BBP®33 printers. Brady360® 5-Year Warranty ■■ Create custom safety signs & labels including pipe markers, We have you Covered. MarkWare™ Facility Identification Software ANSI signs, Lockout tags, GHS labels, RTK chemical labels and custom labels with bar codes and graphics. ■■ Template wizard walks you through label creation process. ■■ Pre-formatted GHS label templates. ■■ Printer automatically reads supply and sets up label part for full hassle-free use when using Brady’s MarkWare software. For additional information visit BradyID.com/markware Labelmark™ Labeling Software Compatible with BBP®33 printer only. ■■ Written specifically for wire and data comm ID, ADM labeling and general industrial applications. We always stand behind our products to make sure they exceed your expectations and to deliver you an unrivaled customer experience — that’s why there is the Brady 360® program. We’ve strengthened our commitment to you with a 5-year printer warranty standard and free of charge on our benchtop printer models.* With a team of 30 certified tech support and repair technicians and our 5-year warranty backing you up, you can rest assured you’ll have the support you need — every step of the way. Compatible with BBP®33 printer only. This 5-year warranty covers repair parts & labor, one print head replacement, a free loaner printer, a stress-free printer setup session, and much more. You also have access to additional fee-based support, including an onsite repair service, custom programming and advanced integrations services. ■■ Available separately, this powerful enterprise level label *Excludes repairs due to negligence, Wraptor™ model and handheld models. ■■ Printer automatically reads installed supply and sets up label part for full hassle-free use when using Brady’s Labelmark software. For additional information visit BradyID.com/labelmark CodeSoft™ Label Design Software creation software features more extensive capabilities for integration with 3rd party software applications. See BradyID.com/brady360 for full coverage details & restrictions. For additional information visit BradyID.com/codesoft BradyID.com/bbp31 BBP®31 Sign & Label Printer, Software and Tape Starter Packs Catalog Number Description BBP31 BBP31 Sign & Label Maker* BBP31-MWS BBP31 Printer and MarkWare™ Std Software BBP31-MWL BBP31 Printer and MarkWare™ Lean Software BBP31 Printer and Tape Starter Pack BBP31-ARCFLASH KIT BBP31 Printer w/ Arc Flash Supply Kit BBP31-SFTY KIT BBP31 Printer w/ Safety & Compliance Supply Kit BBP31-LEANVW KIT BBP31 Printer w/ 5S Visual Workplace Supply Kit BBP31-PIPE KIT BBP31 Printer w/ Pipe ID Supply Kit BBP31-GENIND KIT BBP31 Printer w/ General Industrial 5S Supply Kit * BBP31 Sign & Label Printer ships with printer, power cord, USB cable, drivers CD, stylus, cleaning kit, cutter cleaning tool, quick start guide, documentation holder and 5-year warranty. Current MarkWare owners: Markware v3.8.1 required for use with BBP31. MarkWare v3.7 or higher required to upgrade to v3.8.1. Both upgrades are free and available at www.BradyID.com. BBP®33 Label Printer and Software Catalog Number Description BBP33-C BBP33-C-LMP BBP33-C-MWS BBP®33 Label Printer w/ Auto cutter BBP®33 Label Printer w/ Auto cutter and LabelMark ™5 Software BBP®33 Label Printer w/ Auto cutter and MarkWare™ Software BBP®33 Label Printer w/ Auto cutter, LabelMark ™5 Software and MarkWare™ Software BBP33-C-LMP-MWS * BBP33 Label Printer ships with printer, power cord, USB cable, drivers CD, stylus, cleaning kit, cutter cleaning tool, quick start guide and 5-year warranty. Current MarkWare owners: Markware v3.9.1 required for use with BBP33 Printer. MarkWare v3.7 or higher required to upgrade to v3.9.1. Both upgrades are free and available at www.BradyID.com. Current LabelMark owners: The current version of LabelMark 5 or higher is required for use with BBP33 Printer. If you already own a prior version of LabelMark 5, a free upgrade is available from Brady Tech Support or click “update” from within your LabelMark program. Current CodeSoft owners: CodeSoft v9.0 or higher and the current CodeSoft driver file are both required for use with BBP33 Printer. Visit www.teklynx.com for more info. BBP®31 & BBP®33 Label Printer Accessories Catalog Number Description 120994 Rolling case w/ handle and supplies pockets for benchtop printers B31-WIPER 5 pack of extra media wipers B31-CCT 1 pack of extra cutter cleaning tools Scan the QR code for more information Learn more now about the BBP®31 Label Printer at www.BradyID.com/bbp31. USA Customer Service: 1-888-272-3946 Inside Sales: 1-888-3110775 www.BradyID.com Canada Customer Service: 1-800-2636179 www.BradyCanada.ca Mexico Customer Service: 1-800-262-7777 Inside Sales: 1-800-262-7777 ext 177 www.BradyLatinAmerica.com Y1244494 MS1244494 U.S. Patent Nos. 5,823,689; 6,570,602; 8,542,155; 8,648,891. Additional Patents Pending. © 2014 Brady Worldwide Inc. ALL RIGHTS RESERVED Windows® is a registered trademark of Microsoft Corp. CodeSoft™ is a registered trademark of Teklynx Corp.
B30C-1125-595-BL
- 物料型号:文档列出了多种不同型号的物料,例如B-342、B-344、B-345等,每种物料都有其特定的应用和特性。 - 器件简介:文档提供了各种标签材料的简介,包括它们的设计目的和主要应用场景。 - 引脚分配:虽然文档中没有直接提到“引脚分配”,但是提供了不同标签材料的尺寸和规格,如宽度、高度、重复间隔等。 - 参数特性:详细列出了每种材料的参数,包括适用温度范围、颜色、材质、以及特定应用下的特性,如耐化学腐蚀、耐磨、耐高温等。 - 功能详解:文档对每种材料的功能进行了详细解释,如适用于电线标识的B-344 FR Fluid Resistant Wire Marking Sleeves,以及适用于极端温度环境的B-345 HT High Temperature PVDF Wire Marking Sleeves。 - 应用信息:提供了材料的推荐应用,例如B-342 PermaSleeve PS Wire Markers适用于多种工业应用,而B-345则特别适用于需要高耐温和低挥发性的应用。 - 封装信息:文档提供了标签材料的封装信息,包括每卷标签的数量和推荐的色带类型。
B30C-1125-595-BL 价格&库存
很抱歉,暂时无法提供与“B30C-1125-595-BL”相匹配的价格&库存,您可以联系我们找货
B30C-1125-595-BL
    • 1+1501.533751+192.58784
    库存:3
