BMP41
BMP41
    BRADY
    BMP41 LABEL PRINTER
BMP41 数据手册
BMP®41 Label Printer Specifications Sheet BradyID.com/bmp41 BMP®41 Label Printer The portable BMP®41 Label Printer is the go-to tool for mid-range handheld label printing. A wide range of label cartridges are available for this printer, so you can print what you need, when you need it. Brady also have a variety of accessories available to enhance the BMP®41 Label Printer functionality. Printer: Power: Printer Name BMP 41 Label Printer Power Supply AC Power, rechargable NiMH battery Print Resolution Thermal transfer, 300 dpi Battery Included Yes Max Lines of Print 25 Battery Life 2,500 1”x2” labels Print Speed 133mm/sec (1.3in/sec) Rechargeable Battery Yes, NiMH (1200mAh) Keyboard Type QWERTY Re-Charge Time (estimated) 3 Hours Dimensions: 11.5" x 3.6" x 6" ( 292 x 91 x 152 mm) Charging Options Internal or external with charging dock Weight 2.6 lbs (1.2 kg) Power Source Voltage 110-240 Warranty 2 Years Auto Shut Off 10 minutes, user configurable Overmold/Rugged Yes Print Functions: Operating Temp 4° to 43° C (40° to 110° F) Wire and Cable Wrap Mode Yes Humidity 20% to 90% (non-condensing) Cable Flag Mode Yes Storage Temp -18° to 43° C (0° to 110° F) Terminal Block Mode Yes Continuous or Die Cut Labels Continuous and die cut Patch Panel Mode Yes Portability Yes, handheld Circuit Breaker Mode Yes Banner (Landscape) Yes ® Features: Memory 48 MB / Up to 25,000 Labels Banner (Portrait) Yes User Profiles No Print Preview Yes Cutter Type Manual Multi-Label View No Cut Options Cut between labels or at end of print job Customizable Library No Label Retention After Cut Yes Serialization Yes Labels Per Day (Average) 250 Barcoding 39 & 128 Battery Life Indicator Yes Label Odometer (Supply Remaining) Yes Yes Date/Time Stamp (Real Time Clock) Fixed Length Yes Wearability Options Magnet attachment Mirror Print Yes, via software Drop Test Drop Tested: Four foot drop Vertical Print Yes Languages 11: Danish, Dutch, English, Finnish, French, German, Italian, Norwegian, Portuguese, Spanish, Swedish Reverse Print Yes Rotate Print Yes Auto Format Yes Text Justification Horizontal: left, center or right Vertical: top, middle, bottom Units Inches or Millimeters Specifications subject to change without notice. BMP®41 Label Printer Specifications (continued) Print Functions: (continued) Multi-Copy Printing Up to 99 Copies Multi-Line Print Yes Frame Feature Yes Save Files Yes Display: Included Media MC1-1000-595-WT-BK 1.00" (25.4mm) Black on White Vinyl Tape Number of Stock Parts 100+ Color Print Capability Single print color on a label Available Media Colors Black on: White, Clear, Yellow, Orange, Silver White on: Clear, Red, Blue, Green, or Black Red on: White LCD Type / Size Custom LCD, 2.1" x 1.4" (53.34 mm x 35.56 mm) Cartridge Width Detection Yes LCD Resolution 240 x 160 pixels Cartridge Setting Detection Yes LCD Characters Font size dependent Custom Labels Available Yes LCD Backlight Yes, user adjustable Compliance Communication and Interface Connectivity: Yes PC Connectivity USB Import Data Yes - with Labelmark® Software Import Manufacturer Templates / Graphics No Software Compatibility Optional through USB Media: Agency Approvals FCC Class A, ICES003 RoHS compatibility Pass Patents One or more patents apply including: US 6929415, 5951177, 591898 Trade Harmonization Code (HTS Schedule A or B) / 844.39.9000; Country of Origin: Malaysia (printer); ECCN: EAR99 MSDS For Battery MSDS visit www.BradyID.com Fonts, Graphics, Symbols Type Cartridge Load Labels Location Top Label Output Location Right Side Compatible Media M-, MC-, MC1- Series Cartridges (1.00" and 0.75" height only) Memory in Cartridge Yes Maximum Print Width 0.96" (24.4 mm) Maximum Print Length 39.00" (990 mm) Maximum Liner Width 1.31" (33.3 mm) Media Widths Various sizes from 0.235" to 1.0" (5.969mm to 25.4mm) Text Sizes 4 to 103pt + autosizing Number of Fonts (2) Brady Alpine and Brady Fixed Width Number of Symbols 450 Special Characters 123 Symbol Categories Arrows, Datacomm, Electrical, Exit, Fire, First Aid, CLP/GHS, Greek, Home Electrical, HSID, International, Laboratory, Mandatory, Misc, Packaging, PPE, Prohibition, Public Info, Safety, Warning, WHMIS Compatible Media: M-, MC-, MC1Series Cartridges BMP®41 Label Printer Media Offering B-422 Adhesive Polyester 4 B-342 Permasleeve® Heat Shrinking Tube 4 B-412 Polypropylene Tag 4 B-427 Self Laminating Vinyl 4 B-428 Metalized Polyester 4 B-483 Ultra Aggressive Polyester 4 B-498 Repositionable Vinyl Cloth 4 B-499 Nylon Cloth 4 B-584 Reflective Tape 4 B-595 Indoor/Outdoor Vinyl 4 For more information on the ® BMP 41 Label Printer and media, visit: BradyID.com/bmp41 Specifications subject to change without notice. © 2014 Brady Worldwide Inc. ALL RIGHTS RESERVED (1.00" and 0.75" height only) 1.00" (25.4mm) height 0.75" (19.05mm) height USA Customer Service: 1-888-272-3946 Inside Sales: 1-888-311-0775 www.BradyID.com Canada Customer Service: 1-800-263-6179 www.BradyCanada.ca Mexico 1-800-262-7777 Inside Sales: 1-800-262-7777 ext 177 www.BradyLatinAmerica.com
BMP41 价格&库存
很抱歉,暂时无法提供与“BMP41”相匹配的价格&库存,您可以联系我们找货
