Technical Data Sheet
BRADY B-388 STANDARD TEMPERATURE CABLE MARKER
TDS No. B-388
Effective Date: 3/31/19
GENERAL PRODUCT DESCRIPTION:
Print Technology: Thermal Transfer
Material Type: Polyolefin
Available Colors: White
APPLICATIONS:
B-388 cable markers are designed as a high performance wire bundle and cable identification tag. This standard
temperature cable marker is meant for areas with continuous operating temperature up to 135°C.
RECOMMENDED RIBBON
Brady R6600 series black ribbon
REGULATORY APPROVALS
B-388 is compliant to RoHS Directive 2011/65/EU and Amendment 2015/863. The product does not contain
substances on the REACH Candidate List dated January 15, 2019 at a concentration >0.1%
SPECIAL FEATURES
B-388 cable markers are supplied in roll form designed for use with thermal transfer printers. The unique design has
smooth edges which minimize risk of abrasion to wire and cable jackets.
Details:
PHYSICAL PROPERTIES
Thickness
Tensile Strength
Ultimate Elongation
Specific Gravity
PERFORMANCE PROPERTIES
Heat Shock
Heat Aging
Low Temperature Flexibility
Operating Temperature
Copper Mirror Corrosion
Weatherability
UV Light Resistance
Humidity Resistance
Salt Fog
TEST METHODS
ASTM D882, 20”/min speed
ASTM D792 Method A
TEST METHODS
4 hours @ 250°C, bend over 10x
thickness mandrel
168 hours @ 175°C bend over
10x thickness mandrel
4 hours @ -55°C, bend over 10x
thickness mandrel
ASTM D 2671, Procedure A
ASTM G155 Cycle 1, 1000 hours
ASTM G155 Cycle 1 dry, 1000
hours
1000 hours at 100°F/95% RH
1000 hours at 5% Salt Spray
TYPICAL RESULTS
0.020 +/- 0.003 inches
> 1500 psi
> 200 %
≤ 1.48
TYPICAL RESULTS
Tag darkens but is legible, no
cracking when bent over mandrel
Tag darkens slightly but is
legible, no cracking when bent
over mandrel
No visible effect, no cracking
-55°C to 135°C
No corrosion
Tag darkens slightly but is legible
No visible effect
No visible effect
B-388 Standard Temperature Cable Markers exhibit the following performance when printed using the Brady i7100
(300 dpi) with R6600 black ribbon.
PERFORMANCE PROPERTY
Print Adherence per
SAE-AS5942 (sec 4.1)
TEST METHODS
20 eraser rubs with 2 lb pressure
TYPICAL RESULTS
Print legible, no visible effect
Solvent Resistance per
SAE-AS5942
(Sec 3.4.2)
MIL-STD-202-215 Method 215
Chemical resistance
Samples were thermal transfer printed with Brady R6600 series black ribbon. Tests were conducted at room
temperature after 24 hour dwell. Testing consisted of 5 cycles of 10 minute immersions in the specified chemical
reagent followed by 30 minute recovery periods. After the final immersion, the samples were removed from the test
fluid and the printed image was rubbed 20 (10 double rubs) times with a cotton swab saturated with the test fluid.
CHEMICAL REAGENT
R6600 PRINTING WITHOUT RUB
Isopropyl alcohol
Methyl Ethyl Ketone
Gasoline
Diesel Fuel
MIL 5606 Oil
20W Oil
Skydrol ® 500 B-4
JP-8 Jet Fuel
10% NaCl
Deionized Water
*Swelling of the tag was observed
1
1
1
1
1*
1
1
1
1
1
R6600 PRINTING WITH RUB
1
3
3
2
1
1
2
1
2
1
PRINT EFFECT
1 = No visible effect
2 = Slight smear or print removal, detectable but minimal smear
3 = Moderate smear or print removal (print still legible)
4 = Severe smear or print removal (print illegible or just barely legible)
5 = Complete print removal
NP = print removed prior to rub
Shelf life is five years from the date of receipt for this product as long as this product is stored in its original packaging
in an environment at 32-95 degrees F (0-35 degrees C). It remains the responsibility of the user to assess the risk of
using this product. We encourage customers to develop testing protocols that will qualify a product's fitness for use in
their actual applications.
Trademarks:
ASTM: American Society for Testing and Materials (U.S.A.)
Skydrol® is a registered trademark of Monsanto Company
Note: All values shown are typical and should not be used for specification purposes. Test data and test results
contained in this document are for general information only and shall not be relied upon by Brady customers for
designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop
specifications or performance criteria for specific product applications should contact Brady for further information.
Product compliance information is based upon information provided by suppliers of the raw materials used by Brady
to manufacture this product or based on results of testing using recognized analytical methods performed by a third
party, independent laboratory. As such, Brady makes no independent representations or warranties, express or
implied, and assumes no liability in connection with the use of this information.
WARRANTY
Brady products are sold with the understanding that the buyers will test them in actual use and determine for
themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free
from defects in material and workmanship, but limits its obligation under this warranty to replacement of the
product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does
not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other
warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness
for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will
Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection
with the use, or inability to use, Brady's products.
Copyright 2018 Brady Worldwide, Inc. | All Rights Reserved
Material may not be reproduced or distributed in any form without written permission.
Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414-358-6600 | Fax:
800-292-2289
很抱歉,暂时无法提供与“HSCMST-410-2-W-1.5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+18629.606021+2390.38905
