BMP51 PRINTER EU
BMP51 PRINTER EU
    BRADY
    BRADY - BMP51 PRINTER EU - LABEL PRINTER, PORTABLE, 300DBI, EU
BMP51 PRINTER EU 数据手册
Designed to get the job done BMP51 Label printer Designed to get the job done The Brady Advantage Table of contents When it comes to identification, safety and compliance, there’s a clear advantage to working with Brady. We put our customers first in everything we do. Our goal is to give you an unrivalled customer experience. We are relentlessly committed to performance and excellence - in our products, services and people. Our products and solutions perform in ways that others simply can’t match. Our people perform in ways that regularly exceed your expectations, and our focus and discipline work toward solid, long-term performance for our customers. In short, Brady is the company you trust when performance matters most. 3 6 10 12 18 20 29 31 32 33 34 35 BMP51 Label Printer Applications BMP51 Media offering Electrical, voice/datacom identification General & industrial identification Laboratory identification Master material index Software Printer specifications BMP51 Printer, kits and accessories Brady technical service Brady support Learn more about the Brady Advantage at: www.bradyeurope.com Brady products are sold on the condition that the purchaser will test them in actual use and determine for himself/herself their suitability to his/her intended purpose. Brady warrants to the purchaser that Brady products are free from defects in material and workmanship but limits its obligation under this warranty to the replacement of the product which has been shown to Brady’s satisfaction to have been defective at the time of its purchase. The warranty does not extend to any persons who have acquired the product from the purchaser. It is in lieu of any other warranty, including every warranty of sale-ability, marketability or suitability for the intended purpose, and is also in lieu of any other obligation or liability on the part of Brady. Under no circumstances will Brady be liable for losses, damage, costs or subsequent damage of whatever nature which may arise in connection with the use of, or inability to use, Brady’s products. 2 Designed to get the job done When you need clear, durable labels on the spot, you need the BMP51 Label Printer from Brady. It offers crisp printing, easy formatting, convenient label sizes, and portability required for electrical and datacom installations, laboratory identification, facility and safety labelling. Get the job done FASTER. Change supplies in seconds. Hassle free drop-in cartridges have both the label material & ribbon inside! Automatic label formatting. Cartridges feature smart cell technology that tells the printer how to correctly format your label. You just drop in a cartridge and the printer calibrates the rest. Quick to print. Prints 25.40 mm per second – which means no more waiting around for labels to print. Durable built-in cutter. There’s a self-cleaning cutter that can cut through any material with ease, and it even grips the label until you need it. Get the job done EASIER. Battery options for portability. Use with the AC power supply, AA-batteries or simply with the rechargeable Li-Ion battery which allows you to print over 3,000 labels on a single charge. Wireless capabilities. Built-in Bluetooth® technology and the optional Wi-Fi card provide wireless printing options. Robust software. Labelling Software enables the printer to print: bar code symbologies, time/date stamps, imported graphics, automatic data serialisation, and more. Continuous & die-cut label materials. Whether you need to label wires, cables, panels or equipment, you can do it all with this one printer. There are 20 material types and more than 200 label parts to choose from. Labels up to 38.10 mm wide. Make large labels that can easily be identified from a distance (or make continuous labels up to 1m long!). Magnet. Keep your printer handy, use the magnet to hold your printer on panel doors, metal ladders or any metal surface. Get the job done WITH CONFIDENCE. Label for the long haul. Our labels won’t fade, smear or fall off – so you only need to label something once. A rugged printer you can rely on. This printer can survive in all kinds of harsh environments, temperatures and has a rugged, drop tested construction. www.bradyeurope.com 3 BMP51 at a glance 68.58 x 43.18 mm Backlight Display Font size, with Auto size Indicator Label part number Label size Degree of rotation Number of areas on current label Power key Feed key Media remaining Indicates CAPS Lock is on (default) Battery charge remaining 6.4 to 38.1 mm Label Widths AC Adaptor Port Thumb Drive-Port USB port Function keys Brady Network Card port Print key Navigation keys with ENTER button Rechargeable Li-Ion Battery 2 YEAR WARRANTY 4 BMP51 Top 3 features Connectivity Built-in Bluetooth card, optional wifi card for wireless printing via a network: making it quick & easy to print without being physically connected to multiple PCs. Battery options 3 power options: AA batteries, AC adaptor or rechargeable Li-Ion battery The printer can be powered through a designated AC power adapter. When the adapter is plugging in, it will also charge the BMP Lithium Ion Battery Pack if one is inserted in the battery compartiment (it will not charge AA rechargeable batteries). Hassle-free drop-in cartridges Ribbon and label materials in ONE cartridge! • • Install or remove ribbon and material in one easy step No need to worry about having the right ribbon for your materials • Ribbon and material runs out at the same time (less waste!) Easy-to-load cartridges with “No Jam” technology. • Top-loading cartridge that snaps into place (you can’t load it wrong!) • Easy access to cartridge for quick changes • Locking mechanism prevents labels from retracting into cartridge www.bradyeurope.com 5 Applications Electrical, voice/datacom identification Wire & cable marking for twisted pair data cables (UTP, FTP...), fibre optic cables, conductors, computer wires, electrical installation wires & cables, power & ground cables, energy cables... Wrap-around labels Flags Tags Self-lams Sleeves Component marking for patch panels, control panels, punch blocks, terminal blocks, breaker boxes, face-plates... Punch block & patch panel labels Terminal block labels General & industrial identification Asset & component marking to be used on all kind of surfaces (smooth, rough, textured, low energy...). Rating & name plate labels 6 Overlaminate labels Pre-printed labels Applications Facility & safety identification Lean warehouse identification Laboratory identification Specimen tracking identification for sample tracking within histology labs: utilize barcode technology to prevent misdiagnosis. Straws & rods Conical & large tube labels Specimen process marking supporting microscopic analysis of cells and tissues within pathology and clinical labs. Centrifuge, eppendorf & PCR labels Slide labels Tissue cassettes Specimen storage identification supporting specimen collection and handling such as blood samples, cryo-samples etc. Well plate labels Cryo labels Lean lab identification for general supplies marking. General lab equipment labels Removable labels for glassware www.bradyeurope.com Bottle tamper seal labels 7 Advantages of labelling Ever lost time figuring out where each wire goes? Durable professional labels that remain legible and stay attached in harsh conditions are extremely important to keep power, network, voice and data cables and components organised and running effectively. Professional identification on wires, cables and components enables you to: • • • • immediately recognise what needs checking during troubleshooting clearly mark parts for upcoming maintenance upgrades trace history, lifespan and supplier add safety warnings or precautions Ask yourself how much time or money you lose while trying to trace an unidentified faulty cable,wire or component. Ask yourself how fast pressure builds when machinery, production lines, servers and services are impacted. This is when professional labelling pays off big time. 8 What is a professional label? The combination of label liner, adhesive, substrate and topcoat provide a professional label’s features, resistances, capabilities and durability. 1 The topcoat gives the label its colour and finish, receives the print, and increases resistance against weathering, flames, chemicals or heat. 2 The substrate gives the label its form and provides tensile properties such as strength and flexibility and physical properties such as chemical and temperature resistance. 3 The adhesive attaches the label to a chosen surface type and ensures resistance against a set of environmental contexts. 4 The label liner is a very thin carrier that releases the self-adhesive label. 1 2 3 4 Which label suits your needs best? Request your Electrical, Tele- & Datacom Identification guide book to help you choose the optimal Brady label material for your application at www.bradyeurope.com/cableID. www.bradyeurope.com 9 BMP51 media offering We continuously try to improve & extend our label material offering, therefore make sure to check for firmware upgrades regularly, in order to make sure you always have access to the newest materials. Material B-109 B-145 B-342 B-351 B-403 B-412 B-422 B-425A B-427 B-428 B-432 B-461 Polyethylene Tag Polyethylene Tag Heat-shrink Polyolefin Sleeve Tamper-resistant Vinyl Paper Polypropylene Tag Polyester Polypropylene Self-laminating Vinyl Metallised Polyester Polyester Self-laminating Polyester Material B-481 B-482 B-483 B-488 B-490 B-492 B-498 B-499 B-584 B-595 B-7425 B-7641 StainerBondz™ Polyester Polyester Polyester Polyester Freezerbondz™ Polyester Freezerbondz™ Polyester Vinyl Cloth Nylon Cloth Reflective Tape Vinyl Polypropylene Heat-shrink Polyolefin Sleeve Compatible Media: M-, MC-, MC1- Series Cartridges (All sizes) 19.05 mm height 38.1 mm height 25.4 mm height Smart-Cell Technology With smart-cell technology built into label rolls and ribbons, the printers are able to automatically format the label and place objects so that there is no guess work on your part. If the label material & ribbon are not compatible, the screen will show an error message. 10 Font Sizes & Symbol Library Variable Font Sizes Barcode Types Font sizes range from 4 to 103 point. The maximum font size available depends on factors such as label size, number of characters, numer of lines, as well as font sizes in other lines. Point Size 4 6 7 9 10 14 16 20 26 32 40 45 51 55 60 65 70 76 102 Print Sample CODE 39 • • CODE 128 Code 39 and Code 128 Other barcodes supported in combination with LabelMark or Brady Workstation ABC 12345 ABC 12345 Symbol Library ABC 12345 ABC 12345 • • • ABC 12345 ABC 12345 ABC 12345 ABC 12345 Standard electrical and datacom symbols Over 450 built in graphics Built in time/date stamp ABC 12345 ABC 12345 ABC 12345 Arrows Datacom Electrical Exit Fire First aid CLP/GHS Home electrical International Mandatory Packaging Prohibition Public info Warning WHMIS ABC 1234 ABC 123 ABC 123 ABC 123 ABC 12 ABC 12 AB 12 AB 12 www.bradyeurope.com ...and many more 11 Electrical, voice/datacom identicifation Wire & cable marking Cable flags Pre-formatted with two printable areas, allowing label to be easily folded around wires to create a two-sided, printed flag. Information is still legible on smaller diameter wires and the flag permits you to handle and view labels without touching the wires. Diagram Order Reference B-425: Polypropylene MFT-01-425 B-499: Nylon Cloth M-141-499 M-152-499 Colour Label Width A (mm) Label Height B (mm) Printable Area Height PH (mm) Labels per Roll Additional Features Printer Compatibility Black on White 30.00 20.00 10.00 200 BMP51; BMP53 Black on White 25.40 57.15 25.40 90 Black on White 38.10 31.75 Ideal for Fibre Optic Labelling BMP41; BMP51; BMP53 160 Low profile; High adhesion BMP51; BMP53 Tags for communications cables Multi-purpose tag that can be used for a variety of applications including identification of multiconductor cables, inventory, equipment, lockout, safety warning repair and work-in-progress. Extremely tear resistant. Diagram Order Reference B-109: Polyethylene Tag M-12-109 B-145: Polyethylene Tag M-111-145FR-GY Label Height Printable Area Printable Area B (mm) Width PW (mm) Height PH (mm) Labels per Roll Additional Features Black on White 19.05 76.20 19.05 56.00 80 Good cold-weather tag BMP51; BMP53 Black on Grey 19.25 20.62 19.25 65 Flame Retardant Colour Label Width A (mm) 30.63 Wrap around wire & cable markers Durable vinyl cloth wrap around wire and cable markers made with an adhesive that allows the markers to be removed cleanly and reapplied if necessary. Order Diagram Reference B-498: Vinyl Cloth M-7-498 M-11-498 M-48-498 M-49-498 M-91-498 M-131-498 B-499: Nylon Cloth 12 Colour Label Width Label Height Label Length Max. Wire A (mm) B (mm) B (m) Diameter (mm) Labels per Roll Printer Compatibility Black on White Black on White Black on White Black on White Black on White Black on White 12.70 19.05 25.40 25.40 25.40 12.70 12.70 12.70 19.05 25.40 38.10 25.40 - 2.80 4.00 5.10 5.10 7.10 5.10 240 220 180 160 120 180 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 MC-375-499 Black on White 9.53 - 4.88 - 1 BMP41; BMP51; BMP53 MC-500-499 Black on White 12.70 - 4.88 - 1 BMP41; BMP51; BMP53 MC-1000-499 Black on White 25.40 - 4.88 - 1 BMP51; BMP53 MC-750-499 Black on White 19.05 - 4.88 - 1 BMP41; BMP51; BMP53 >> Printer Compatibility BMP51; BMP53 Electrical, voice/datacom identification Wire & cable marking How to read an order reference: example M-31-427-YL M 31 427 YL M: Die cut label Label size code MC: Continuous label Brady material Optional colour number (B-number) Self-laminating cable markers Features a clear, non-printable area that wraps around the cable and serves as an overlaminate to the printed text. Offers superior resistance to abrasion, dirt, oils, solvents, and water. Order Diagram Reference Colour B-427: Self-laminating Vinyl M-89-427 Black on White/Transparent Label Width A (mm) Label Height Label B Length (mm) B (m) Printable Area Width PW (mm) Printable Area Labels Max. Wire Height per Diameter PH (mm) Roll (mm) For Data Cables Sized to Fit 12.70 38.10 12.70 12.70 180 8.10 mm M-11-427 Black on White/Transparent 12.70 19.05 12.70 9.53 360 3.00 mm M-102-427 Black on White/Transparent 12.70 31.75 12.70 9.53 200 7.10 mm CAT 6; 4 pair UTP Copper M-90-427 Black on White/Transparent 19.05 38.10 19.05 12.70 180 8.10 mm CAT 6; 4 pair UTP Copper M-91-427 Black on White/Transparent 25.40 38.10 25.40 12.70 180 8.10 mm CAT 6; 4 pair UTP Copper M-143-427 Black on White/Transparent 25.40 31.75 25.40 12.70 200 6.10 mm CAT 6; 4 pair UTP Copper M-91-427-YL Black on Yellow/Transparent 25.40 38.10 25.40 12.70 180 8.10 mm CAT 6; 4 pair UTP Copper M-51-427 Black on White/Transparent 25.40 63.50 25.40 19.05 110 M-49-427 Black on White/Transparent 25.40 25.40 25.40 9.53 260 M-51-427-YL Black on Yellow/Transparent 25.40 63.50 25.40 19.05 110 M-53-427 Black on White/Transparent 25.40 101.60 25.40 25.40 70 M-53-427-YL Black on Yellow/Transparent 25.40 101.60 25.40 25.40 70 M-115-427 Black on White/Transparent 38.10 31.75 38.10 12.70 200 14.20 mm 25 pair Copper; 4-12 pair Fibre; Coaxial 5.10 mm 2 Pair Fibre/Coaxial; Single/ Multi-Mode 14.20 mm 25 pair Copper; 4-12 pair Fibre; Coaxial 24.30 mm 50 Pair Copper; 24 Pair Fibre; Backbone 24.30 mm 50 Pair Copper; 24 Pair Fibre; Backbone 6.10 mm CAT 6;4 pair UTP Copper BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 M-32-427 Black on White/Transparent 38.10 38.10 38.10 12.70 180 8.10 mm CAT 6;4 pair UTP Copper BMP51; BMP53 M-116-427 Black on White/Transparent 38.10 63.50 38.10 19.05 80 BMP51; BMP53 M-33-427 Black on White/Transparent 38.10 101.60 38.10 25.40 70 M-34-427 Black on White/Transparent 38.10 152.40 38.10 38.10 40 MC-750-427 Black on White/Transparent 19.05 7.62 9.53 1 14.20 mm 25 pair Copper;4-12 pair Fibre;Coaxial 24.30 mm 50 Pair Copper;24 Pair Fibre;Backbone 36.40 mm 100 Pair Copper;36 Pair Fibre;Backbone 3.00 mm CAT 6; 4 pair UTP Copper MC-1000-427 Black on White/Transparent 25.40 7.62 9.53 1 5.10 mm CAT 6;4 pair UTP Copper BMP41; BMP51; BMP53 BMP51; BMP53 MC-1500-427 Black on White/Transparent 38.10 7.62 12.70 1 8.10 mm CAT 6;4 pair UTP Copper BMP51; BMP53 www.bradyeurope.com CAT 6; 4 pair UTP Copper Printer Compatibility BMP51; BMP53 BMP51; BMP53 13 Electrical, voice/datacom identification Wire & cable marking PermaSleeve PS wire marking sleeves These heat-shrink sleeves are the ultimate in marker durability, permanence and aesthetic appearance. Fast shrink rate saves time and costs during installation. Available as individual die-cut markers or continuous cut-to-length tubing. Diagram Order Reference Colour B-342: Heat-shrink Polyolefin Sleeve Label Width A (mm) Label Height B (mm) Label Length B (m) Min. Wire Diameter (mm) Max. Wire Diameter (mm) Labels per Roll Printer Compatibility 19.05 19.05 19.05 19.05 25.78 25.78 25.78 25.78 8.50 11.15 6.00 16.40 6.00 8.50 11.15 16.40 – – – – – – – – 1.57 mm 2.39 mm 1.17 mm 3.18 mm 1.17 mm 1.57 mm 2.39 mm 3.18 mm 3.81 mm 5.46 mm 2.79 mm 8.13 mm 2.79 mm 3.81 mm 5.46 mm 8.13 mm 80 80 80 80 80 80 80 80 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 M-187-075-342 M-250-075-342 M-125-075-342 M-375-075-342 M-125-1-342 M-187-1-342 M-250-1-342 M-375-1-342 Black on White Black on White Black on White Black on White Black on White Black on White Black on White Black on White MC-187-342 Black on White 8.50 2.13 1.57 mm 3.81 mm 1 BMP41; BMP51; BMP53 MC-125-342 Black on White 6.00 2.13 1.17 mm 2.79 mm 1 BMP41; BMP51; BMP53 MC-250-342 Black on White 11.15 2.13 2.39 mm 5.46 mm 1 BMP41; BMP51; BMP53 MC1-375-342 Black on White 16.40 2.13 3.18 mm 8.13 mm 1 BMP41; BMP51; BMP53 MC-187-342-YL Black on Yellow 8.50 2.13 1.57 mm 3.81 mm 1 BMP41; BMP51; BMP53 MC-125-342-YL Black on Yellow 6.00 2.13 1.17 mm 2.79 mm 1 BMP41; BMP51; BMP53 MC-250-342-YL Black on Yellow 11.15 2.13 2.39 mm 5.46 mm 1 BMP41; BMP51; BMP53 PermaSleeve heat-shrink sleeve markers These heat-shrink sleeves are the ultimate in marker identification, protection, durability and aesthetic appearance. Fast shrink rate saves time and costs during installation. Low smoke zero halogen wire marking sleeves (B-7641) offer outstanding fire safety properties and minimal smoke emission. Diagram Order Reference Colour B-7641: Heat-shrink Polyolefin Sleeve MC1-125-7641 Black on White MC1-125-7641-YL Black on Yellow MC1-187-7641 Black on White MC1-187-7641-YL Black on Yellow MC1-250-7641 Black on White MC1-250-7641-YL Black on Yellow MC1-375-7641 Black on White MC1-375-7641-YL Black on Yellow Label Width A (mm) Label Length B (m) Min. Wire Diameter (mm) Max. Wire Diameter (mm) Labels per Roll Printer Compatibility 6.00 6.00 8.50 8.50 11.15 11.15 16.40 16.40 2.13 2.13 2.13 2.13 2.13 2.13 2.13 2.13 1.17 mm 1.17 mm 1.57 mm 1.57 mm 2.39 mm 2.39 mm 3.18 mm 3.18 mm 2.79 mm 2.79 mm 3.81 mm 3.81 mm 5.46 mm 5.46 mm 8.13 mm 8.13 mm 1 1 1 1 1 1 1 1 BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 Did you know? The BMP51 Label Maker has a built-in label retention feature, that grips the label until you need it. Paired with the magnet accessory, this is the ultimate answer to your “on the job” labelling requirements. 14 Electrical, voice/datacom identification Component marking Punch block & patch panel labels Make fully-formatted punch block strips or labels in one easy process. Labelling software allows you to easily create serialised punch block labels with or without grid lines to fit your equipment. Order Diagram Reference B-412: Polypropylene Tag MC-375-412 Colour Label Width A (mm) Label Height B (mm) Label Length B (m) Labels per Roll Additional Features Printer Compatibility Black on White 9.53 6.10 1 Non-Adhesive Slide-in Strips BMP41; BMP51; BMP53 MC-475-412 Black on White 12.07 6.10 1 Non-Adhesive Slide-in Strips BMP41; BMP51; BMP53 MC-625-412 Black on White 15.88 6.10 1 Non-Adhesive Slide-in Strips BMP41; BMP51; BMP53 B-422: Polyester M-7-422 MC-375-422 Black on White Black on White 12.70 9.53 7.62 280 1 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 MC-475-422 Black on White 12.07 7.62 1 MC-625-422 Black on White 15.88 7.62 1 Port Labels Adhesive Stick-on Strips: Outlet, Patch Panel, Cont. Tape, Cut to Size Adhesive Stick-on Strips: Outlet, Patch Panel, Cont. Tape, Cut to Size Adhesive Stick-on Strips: Outlet, Patch Panel, Cont. Tape, Cut to Size 12.70 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 Terminal block markers Specially-designed narrow-width markers. Labelling Software can auto-serialise these labels to save you time. Diagram Order Reference B-498: Vinyl Cloth MC-240-498 Colour Label Width A (mm) Label Length B (m) Labels per Roll Printer Compatibility Black on White 6.10 4.88 1 BMP41; BMP51; BMP53 MC-318-498 Black on White 8.08 4.88 1 BMP41; BMP51; BMP53 MC-375-498 Black on White 9.53 6.10 1 BMP41; BMP51; BMP53 www.bradyeurope.com 15 Electrical, voice/datacom identification Component Marking General datacom identification Durable materials with permanent adhesive. Available in a variety of sizes and colours for marking racks, bays, frames, slots, and other voice/data hardware. Diagram Order Reference B-422: Polyester M-89-422 M-7-422 MC1-1000-422 Colour Label Width A (mm) Black on White Black on White Black on White 12.70 12.70 25.40 38.10 12.70 M-49-422 B-483: Polyester M-61-483 Black on White 25.40 25.40 260 Black on White 12.70 50.80 80 M-60-483 Black on White 25.40 50.80 140 M-47-483 Black on White 25.40 12.70 480 Black on White B-595: Vinyl MC-375-595-WT-BK Label Height B (mm) Label Length Labels B (m) per Roll 7.62 180 280 1 Additional Features Printer Compatibility Stick-on Individual Labels Port Labels Adhesive Stick-on Strips: Outlet, Patch Panel, Cont. Tape, Cut to Size Adhesive Stick-on individual labels BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 Ultra-aggressive adhesive; Designed for powder coated surfaces Ultra-aggressive adhesive; Designed for powder coated surfaces Ultra-aggressive adhesive; Designed for powder coated surfaces BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 9.53 7.62 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 MC-375-595-YL-BK Black on Yellow 9.53 7.62 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 MC-500-595-YL-BK Black on Yellow 12.70 7.62 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 MC-750-595-YL-BK Black on Yellow 19.05 7.62 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 MC1-1000-595-YL-BK Black on Yellow 25.40 7.62 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 MC-1500-595-YL-BK Black on Yellow 38.10 7.62 1 Adhesive Stick on Strips, Cut to Size BMP51; BMP53 MC-500-595-CL-WT White on Clear 12.70 6.10 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 MC-750-595-CL-WT White on Clear 19.05 6.10 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 MC1-1000-595-CL-WT White on Clear 25.40 6.10 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 MC-1500-595-CL-WT White on Clear 38.10 6.10 1 Adhesive Stick on Strips, Cut to Size BMP51; BMP53 MC-375-595-RD-WT White on Red 9.53 7.62 1 Adhesive Stick on Strips, Cut to Size BMP41; BMP51; BMP53 General electrical component marking Various sizes, colours and label types for marking relays, solenoids, switches, drive motors, and other components. Diagram Order Reference B-422: Polyester M-89-422 M-7-422 M-49-422 MC1-1000-422 B-428: Metallised Polyester M-92-428-BB M-47-428 M-60-428 M-30-428 M-29-428 B-483: Polyester M-61-483 M-60-483 B-499: Nylon Cloth M-11-499 M-84-499 M-128-499 M-132-499 B-595: Vinyl MC-375-595-RD-WT 16 Colour Label Width Label Height A (mm) B (mm) Label Length B (m) Labels per Roll Printer Compatibility Black on White Black on White Black on White Black on White 12.70 12.70 25.40 25.40 38.10 12.70 25.40 7.62 180 280 260 1 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 Black on Silver Black on Silver Black on Silver Black on Silver Black on Silver 12.70 25.40 25.40 38.1 38.10 33.02 12.70 50.80 19.05 12.70 239 480 140 260 360 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 Black on White Black on White 12.70 25.40 50.80 50.80 80 140 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 Black on White Black on White Black on White Black on White 19.05 22.86 25.40 38.10 12.70 12.70 48.26 31.75 220 200 100 160 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 White on Red 9.53 7.62 1 BMP41; BMP51; BMP53 MC-500-595-OR-BK Black on Orange 12.70 7.62 1 BMP41; BMP51; BMP53 MC-750-595-OR-BK Black on Orange 19.05 7.62 1 BMP41; BMP51; BMP53 MC1-1000-595-OR-BK Black on Orange 25.40 7.62 1 BMP41; BMP51; BMP53 MC-1500-595-OR-BK 7.62 1 BMP51; BMP53 Black on Orange 38.10 Electrical, voice/datacom identification Component marking Faceplate & outlet labels Label your ports, jacks, and outlets with a variety of adhesive labels or slide-in strips. Order Diagram Reference B-412: Polypropylene Tag MC-475-412 B-422: Polyester M-89-422 M-7-422 Colour Label Width A (mm) Label Height B (mm) Label Length B (m) Labels per Roll Additional Features Printer Compatibility Black on White 12.07 6.10 1 Non-Adhesive Slide-in Strips BMP41; BMP51; BMP53 Black on White Black on White 12.70 12.70 180 280 Stick-on Individual Labels Port Labels Adhesive Stick-on Strips: Outlet, Patch Panel, Cont. Tape, Cut to Size Adhesive Stick-on Strips: Outlet, Patch Panel, Cont. Tape, Cut to Size BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 MC-375-422 Black on White 9.53 7.62 1 MC-475-422 Black on White 12.07 7.62 1 Black on White 12.70 38.10 12.70 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 B-483: Polyester M-61-483 50.80 Ultra-aggressive adhesive; Designed for powder coated surfaces 80 BMP41; BMP51; BMP53 Control panel and electrical panel labels Long-lasting, durable materials to quickly identify control and electrical panels. Diagram Order Reference B-428: Metallised Polyester M-47-428 M-60-428 M-30-428 M-29-428 B-595: Vinyl MC-1500-595-CL-BK Colour Label Width A (mm) Label Height B (mm) Black on Silver Black on Silver Black on Silver Black on Silver 25.40 25.40 38.1 38.10 12.70 50.80 19.05 12.70 Label Length B (m) Labels per Roll Printer Compatibility 480 140 260 360 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 Black on Clear 38.10 6.10 1 BMP51; BMP53 MC-1500-595-CL-WT White on Clear 38.10 6.10 1 BMP51; BMP53 MC-375-595-RD-WT 9.53 7.62 1 BMP41; BMP51; BMP53 38.10 7.62 1 BMP51; BMP53 MC-1500-595-WT-BK White on Red Black on Orange Black on White 38.10 7.62 1 BMP51; BMP53 MC-1500-595-YL-BK Black on Yellow 38.10 7.62 1 BMP51; BMP53 MC-1500-595-WT-RD Red on White 38.10 7.62 1 BMP51; BMP53 MC-1500-595-BK-WT White on Black 38.10 7.62 1 BMP51; BMP53 MC-1500-595-BL-WT White on Blue 38.10 7.62 1 BMP51; BMP53 MC-1500-595-GN-WT White on Green 38.10 7.62 1 BMP51; BMP53 MC-1500-595-RD-WT White on Red 38.10 7.62 1 BMP51; BMP53 MC-1500-595-OR-BK www.bradyeurope.com 17 General & industrial identification Asset & component marking Tamper-resistant labels Destructible vinyl material prohibits one piece removal of label to indicate if the label has been tampered with. Diagram Order Reference Colour B-351: Tamper-resistant Vinyl M-17-351 Black on White M-20-351 Black on White Label Width A (mm) Label Height Labels per B (mm) Roll Printer Compatibility 25.40 25.40 12.70 50.80 360 160 BMP51; BMP53 BMP51; BMP53 Highly reflective identification Ideal for reading labels in low light conditions. Diagram Order Reference B-584: Reflective Tape MC-500-584 MC-750-584 MC-1000-584 MC-1500-584 MC-500-584-YL MC-750-584-YL MC-1000-584-YL MC-1500-584-YL Colour Label Width A (mm) Label Length Labels per B (m) Roll Printer Compatibility Black on White Black on White Black on White Black on White Black on Yellow Black on Yellow Black on Yellow Black on Yellow 12.70 19.05 25.40 38.10 12.70 19.05 25.40 38.10 6.10 6.10 6.10 6.10 6.10 6.10 6.10 6.10 1 1 1 1 1 1 1 1 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 Name & rating plate labels for rough surfaces Diagram Order Reference B-483: Polyester M-61-483 M-60-483 M-47-483 Colour Label Width A (mm) Label Height Labels per B (mm) Roll Printer Compatibility Black on White Black on White Black on White 12.70 25.40 25.40 50.80 50.80 12.70 80 140 480 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 Name & rating plate labels for smooth, high surface energy surfaces Diagram Order Reference B-428: Metallised Polyester M-92-428-BB M-47-428 M-60-428 M-30-428 M-29-428 18 Colour Label Width A (mm) Label Height Labels per B (mm) Roll Printer Compatibility Black on Silver Black on Silver Black on Silver Black on Silver Black on Silver 12.70 25.40 25.40 38.1 38.10 33.02 12.70 50.80 19.05 12.70 239 480 140 260 360 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 General & industrial identification Asset & Component Marking Name & rating plate labels for smooth, low surface energy & textured surfaces Label Order Width Diagram Reference Colour A (mm) B-422: Polyester MC-375-422 Black on White 9.53 MC-475-422 Black on White 12.07 Label Label Length Height Labels Printer B (m) B (mm) per Roll Compatibility 7.62 1 7.62 1 M-89-422 Black on White 12.70 38.10 180 M-7-422 Black on White 12.70 12.70 280 MC-500-422 Black on White 12.70 7.62 1 MC-625-422 Black on White 15.88 7.62 1 M-90-422 Black on White 19.05 38.10 180 M-47-422 Black on White 25.40 12.70 480 MC1-1000- Black on White 25.40 422 M-49-422 Black on White 25.40 7.62 1 25.40 260 12.70 280 BMP51; BMP53 48.26 100 BMP51; BMP53 B-432: Polyester M-17-432- Black on Clear 25.40 CL-BK M-78-432- Black on Clear 25.40 CL-BK B-499: Nylon Cloth MC-375-499 Black on White 9.53 4.88 1 MC-500-499 Black on White 12.70 4.88 1 M-11-499 12.70 200 1 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP51; BMP53 31.75 160 BMP51; BMP53 6.10 1 6.10 1 6.10 1 6.10 1 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 Black on White 19.05 MC-750-499 Black on White 19.05 M-84-499 Black on White 22.86 MC-1000- Black on White 25.40 499 M-132-499 Black on White 38.10 B-595: Vinyl MC-500-595- Black on Clear 12.70 CL-BK MC-750-595- Black on Clear 19.05 CL-BK MC1-1000- Black on Clear 25.40 595-CL-BK MC-1500- Black on Clear 38.10 595-CL-BK MC-500-595- Black on 12.70 OR-BK Orange MC-750-595- Black on 19.05 OR-BK Orange MC1-1000- Black on 25.40 595-OR-BK Orange MC-1500- Black on 38.10 595-OR-BK Orange MC-375-595- Black on White 9.53 WT-BK MC-500-595- Black on White 12.70 WT-BK MC-750-595- Black on White 19.05 WT-BK MC1-1000- Black on White 25.40 595-WT-BK MC-1500- Black on White 38.10 595-WT-BK MC-375-595- Black on Yellow 9.53 YL-BK MC-500-595- Black on Yellow 12.70 YL-BK BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 12.70 4.88 220 1 4.88 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 Label Order Width Diagram Reference Colour A (mm) B-595: Vinyl MC-750-595- Black on Yellow 19.05 YL-BK MC1-1000- Black on Yellow 25.40 595-YL-BK MC-1500- Black on Yellow 38.10 595-YL-BK MC-500-595- Red on White 12.70 WT-RD MC-750-595- Red on White 19.05 WT-RD MC1-1000- Red on White 25.40 595-WT-RD MC-1500- Red on White 38.10 595-WT-RD MC-500-595- White on 12.70 BK-WT Black MC-750-595- White on 19.05 BK-WT Black MC1-1000- White on 25.40 595-BK-WT Black MC-1500- White on 38.10 595-BK-WT Black MC-500-595- White on 12.70 BL-WT Blue MC-750-595- White on 19.05 BL-WT Blue MC1-1000- White on 25.40 595-BL-WT Blue MC-1500- White on 38.10 595-BL-WT Blue MC-500-595- White on Clear 12.70 CL-WT MC-750-595- White on Clear 19.05 CL-WT MC1-1000- White on Clear 25.40 595-CL-WT MC-1500- White on Clear 38.10 595-CL-WT MC-500-595- White on 12.70 GN-WT Green MC-750-595- White on 19.05 GN-WT Green MC1-1000- White on 25.40 595-GN-WT Green MC-1500- White on 38.10 595-GN-WT Green MC-375-595- White on Red 9.53 RD-WT MC-500-595- White on Red 12.70 RD-WT MC-750-595- White on Red 19.05 RD-WT MC1-1000- White on Red 25.40 595-RD-WT MC-1500- White on Red 38.10 595-RD-WT Label Label Length Height Labels Printer B (m) B (mm) per Roll Compatibility 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 6.10 1 6.10 1 6.10 1 6.10 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 7.62 1 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 BMP51; BMP53 BMP41; BMP51; BMP53 BMP41; BMP51; BMP53 www.bradyeurope.com 19 Laboratory identification Specimen tracking identification Straw and rod labels F N A H S L R • Brady offers a range of labels designed to fit the small surface area of straws and rods and will withstand long-term storage. Freezer environment Liquid nitrogen environment Autoclave environment Hot water bath (100°C) Self-laminating label Low-profile (extremely thin) label Removable The background colours in the Order Reference column represent the material colour. Labels are shown per straw size and in order of label width. Special Properties Label Width Label Height A (mm) B (mm) Printable Area Width PW (mm) Printable Area Height PH (mm) Order Reference Labels Printer Compatibility per Roll Labels per Row F N S 25.40 25.40 25.40 9.53 M-49-427 BMP51, BMP53 260 1 B-427 F N S 25.40 63.50 25.40 19.05 M-51-427 BMP51, BMP53 110 1 B-427 F N S 27.94 6.35 27.94 6.35 M-135-427-AW BMP51, BMP53 240 1 F N S 44.45 25.40 44.45 9.53 M-133-427 BMP51, BMP53 140 1 F N S 44.45 38.10 44.45 12.70 M-134-427 BMP51, BMP53 140 1 Diagram Material 0.25 ml Straw B-427 0.50 ml Straw Straw Rod 0.25 ml Straw B-427 0.50 ml Straw B-427 Vial / tube labels • Brady’s vial and test tube labels are designed to withstand extreme laboratory solvents like Xylene, Ethanol, Alcohol and DMSO, ensuring that the specimen identification is always legible - and will not smear, fade or fall off. The background colours in the Order Reference column represent the material colour. Labels are shown per vial / tube size and in order of label width. Diagram Material Special Properties 0.6 ml B-499 F N A Diameter C (mm) Printable Area Width PW (mm) Order Reference Labels Printer Compatibility per Roll Labels per Row 4.88 – – MC-375-499 BMP51, BMP53 1 1 Label Width A (mm) Label Height B (mm) Label Length B (m) 9.53 – 1.0 - 8.0 ml B-498 F B-492 F N R 25.40 19.05 – – – M-48-498 BMP51, BMP53 180 1 H L 44.45 25.40 – – – M-125-492 BMP51, BMP53 180 1 H L 41.28 15.24 – 9.53 – M-95-492 BMP51, BMP53 200 1 H L 41.91 12.70 – – – M-124-492 BMP51, BMP53 180 1 12.70 – 4.88 – – MC-500-499 BMP51, BMP53 1 1 19.05 – 4.88 – – MC-750-499 BMP51, BMP53 1 1 19.05 – 7.62 – 9.53 MC-750-427 BMP51, BMP53 1 1 25.40 – 4.88 – – MC-1000-499 BMP51, BMP53 1 1 1.5 - 2.0 ml B-492 F B-492 F N B-499 F N A B-499 F N A B-427 F N B-499 F N A B-7425 F N A H 38.10 25.40 – – 38.10 M-31-7425 BMP51, BMP53 250 1 B-7425 F N A H 25.40 9.53 – 9.53 25.40 M-118-7425 BMP51, BMP53 240 1 1.5 ml 2.0 - 50.0 ml S 15.0 ml - 20 Laboratory identification Specimen tracking identification Vial Top Labels Save time by using the Vial and Vial top combination labels - print your information in one go. F A H S L R Freezer environment Autoclave environment Hot water bath (100°C) Self-laminating label Low-profile (extremely thin) label Removable The background colours in the Order Reference column represent the material colour. Labels are shown per vial / tube size and in order of label width. Diagram 0.5 - 1.5 ml Material Special Properties Label Width A (mm) Label Height Diameter B (mm) C (mm) Order Reference Printer Compatibility Labels per Roll Labels per Row B-499 F A – – 9.53 M-82-499 BMP51, BMP53 240 1 B-499 F A – – 9.53 M-82-499-OR-BK BMP51, BMP53 240 1 B-499 F A – – 9.53 M-82-499-RD-BK BMP51, BMP53 240 1 B-499 F A – – 9.53 M-82-499-YL-BK BMP51, BMP53 240 1 B-492 F – – 9.53 M-82-492 BMP51, BMP53 240 1 B-499 F 25.40 9.53 9.53 M-118-499 BMP51, BMP53 240 1 B-492 F 25.40 9.53 9.53 M-118-492 BMP51, BMP53 240 1 B-499 F 25.40 12.70 9.53 M-120-499 BMP51, BMP53 240 1 B-492 F 25.40 12.70 9.53 M-120-492 BMP51, BMP53 240 1 B-499 F 25.40 12.70 11.18 M-117-499 BMP51, BMP53 240 1 B-492 F H L 25.40 12.70 11.18 M-117-492 BMP51, BMP53 240 1 B-492 F H L 41.28 15.24 9.53 M-95-492 BMP51, BMP53 200 1 B-499 F A – – 12.70 M-83-499 BMP51, BMP53 240 1 B-499 F A – – 12.70 M-83-499-OR-BK BMP51, BMP53 240 1 B-499 F A – – 12.70 M-83-499-RD-BK BMP51, BMP53 240 1 B-499 F A – – 12.70 M-83-499-YL-BK BMP51, BMP53 240 1 B-492 F – – 12.70 M-83-492 BMP51, BMP53 240 1 B-7425 F 25.40 9.53 9.53 M-118-7425 BMP51, BMP53 240 1 H L H L H L 1.0 - 2.0 ml A 1.5 - 2.0 ml A A H L N A H www.bradyeurope.com 21 Laboratory identification Specimen tracking identification Conical & large tube labeling • Brady offers several sample identification labels which are perfect to identify conicals. They are easy to handle, have great flexibility and easily wrap around curved sample containers. Your sample identification label will remain attached and legible, even when the sample is stored in a freezer, in liquid nitrogen or heated in an autoclave. Freezer environment Liquid nitrogen environment Autoclave environment Hot water bath (100°C) Self-laminating label Low-profile (extremely thin) label Removable The background colours in the Order Reference column represent the material colour. Labels are shown per vial / tube size and in order of label width. Diagram 0.6 ml F N A H S L R Material Special Properties Label Width A (mm) Label Height B (mm) Label Length B (m) Diameter C (mm) Printable Area Width PW (mm) Printable Area Height PH (mm) Printer Order Reference Compatibility Labels per Roll Labels per Row B-499 F N A 9.53 – 4.88 – – – MC-375-499 BMP51, BMP53 1 1 B-492 F N H L 44.45 25.40 – – – – M-125-492 BMP51, BMP53 180 1 B-492 F N H L 22.86 25.40 – – – – M-156-492 BMP51, BMP53 180 1 B-492 F H L 41.28 15.24 – 9.53 – – M-95-492 BMP51, BMP53 200 1 B-492 F N H L 41.91 12.70 – – – – M-124-492 BMP51, BMP53 180 1 B-499 F N A 12.70 – 4.88 – – – MC-500-499 BMP51, BMP53 1 1 19.05 – 4.88 – – – MC-750-499 BMP51, BMP53 1 1 19.05 – 7.62 – 9.53 – MC-750-427 BMP51, BMP53 1 1 25.40 – 4.88 – – – MC-1000-499 BMP51, BMP53 1 1 25.40 – 7.62 – 9.53 – MC-1000-427 MC-1000-461AW** BMP51, BMP53 1 1 BMP51, BMP53 1 1 1.0 - 8.0 ml 1.0 - 15.0 ml 1.5 - 2.0 ml 1.5 ml 2.0 - 50.0 ml B-499 F N A B-427 F N B-499 F N A B-427 F N B-461 F N A H S L 25.40 – 7.62 – 25.40 – F N A H S L 31.75 – 7.62 – 31.75 – MC-1250-461AW** BMP51, BMP53 1 1 F N 38.10 – 7.62 – 12.70 – MC-1500-427 BMP51, BMP53 1 1 F N A H S L 38.10 95.25 – – 38.10 31.75 M-119-461 BMP51, BMP53 80 1 B-492 F N 25.40 48.26 – – – – M-78-492 BMP51, BMP53 100 1 B-499 F N A 38.10 31.75 – – – – M-132-499 BMP51, BMP53 160 1 S S 4.0 - 50.0 ml B-461 5.0 - 50.0 ml B-427 S 12.0 - 14.0 ml B-461 12.0 - 24.0 ml H L 14.0 - 15.0 ml B-490 F N L 38.10 55.88 – – – – M-113-490 BMP51, BMP53 140 1 B-461 F N A H S L H 38.10 57.15 – – 38.10 31.75 M-129-461 BMP51, BMP53 140 1 B-427 F N S 38.10 63.50 – – 38.10 19.05 M-116-427 BMP51, BMP53 80 1 B-427 F N S 19.05 38.10 – – 19.05 12.70 M-90-427 BMP51, BMP53 180 1 B-427 F N S 25.40 38.10 – – 25.40 12.70 M-91-427 BMP51, BMP53 180 1 B-499 F N A 25.40 48.26 – – – – M-128-499 BMP51, BMP53 100 1 B-490 F N 38.10 98.42 – – – – M-114-490 BMP51, BMP53 80 1 50.0 ml H *AW = All White / no transparent area. 22 L Laboratory identification Specimen process marking Centrifuge / microcentrifuge labels • Brady offers a wide range of Centrifuge, Eppendorf and PCR Labels. When applying a self-laminating label, we recommend you avoid touching the adhesive side of the label when wrapping it around a vial or tube, to ensure maximum adhesion. The background colours in the Order Reference column represent the material colour. Labels are shown per vial / tube size and in order of label width. Special Properties Label Width A (mm) Label Height B (mm) Label Length Diameter B (m) C (mm) Printable Area Width PW (mm) Printable Area Height PH (mm) Order Reference Printer Compatibility Labels per Roll Labels per Row B-461 F N A H S L 9.53 28.58 – – 9.53 19.05 M-123-461 BMP51, BMP53 360 1 B-461 F N A H S L 12.70 28.58 – – 12.70 19.05 M-122-461 BMP51, BMP53 360 1 B-461 F N A H S L 12.70 44.45 – – 12.70 19.05 M-72-461 BMP51, BMP53 180 1 B-499 F N A 19.05 12.70 – – – – M-11-499 BMP51, BMP53 220 1 B-490 F N H L 31.75 9.53 – – – – M-112-490 BMP51, BMP53 360 1 B-492 F N H L 31.75 9.53 – – – – M-112-492 BMP51, BMP53 360 1 H L – – – 9.53 – – M-82-492 BMP51, BMP53 240 1 – – – 9.53 – – M-82-499-RD-BK BMP51, BMP53 240 1 Diagram Material 0.5 - 0.7 ml 0.5 - 1.5 ml B-492 F B-499 F B-492 F N 9.53 20.96 – – – – M-130-492 BMP51, BMP53 220 1 B-499 F N A 9.53 20.96 – – – – M-130-499 BMP51, BMP53 220 1 B-499 F N A 9.53 – 4.88 – – – MC-375-499 BMP51, BMP53 1 1 B-499 F N A 22.86 12.70 – – – – M-84-499 BMP51, BMP53 200 1 B-492 F N A 0.6 ml H L H L 31.75 6.35 – – – – M-155-492 BMP51, BMP53 180 1 H L 25.40 9.53 – 9.53 – – M-118-492 BMP51, BMP53 240 1 25.40 9.53 – 9.53 – – M-118-499 BMP51, BMP53 240 1 1.0 - 2.0 ml B-492 F B-499 F A 1.0 - 8.0 ml B-492 F N 12.70 25.40 – – – – M-131-492 BMP51, BMP53 180 1 B-499 F N A H L 12.70 25.40 – – – – M-131-499 BMP51, BMP53 180 1 B-461 F N A H S L 12.70 55.88 – – 12.70 19.05 M-74-461 BMP51, BMP53 140 1 B-461 F N A H S L 15.24 45.72 – – 15.24 25.40 M-126-461 BMP51, BMP53 180 1 B-490 F N L 15.24 45.72 – – – – M-126-490 BMP51, BMP53 180 1 B-461 F N A H S L 15.24 66.68 – – 15.24 25.40 M-86-461 BMP51, BMP53 120 1 B-461 F N A H S L 12.70 41.91 – – 12.70 19.05 M-124-461 BMP51, BMP53 180 1 B-490 F N H L 12.70 41.91 – – – – M-124-490 BMP51, BMP53 180 1 B-492 F H L 25.40 12.70 – 9.53 – – M-120-492 BMP51, BMP53 240 1 B-499 F 25.40 12.70 – 9.53 – – M-120-499 BMP51, BMP53 240 1 B-492 F 25.40 12.70 – 11.18 – – M-117-492 BMP51, BMP53 240 1 B-499 F 25.40 12.70 – 11.18 – – M-117-499 BMP51, BMP53 240 1 B-492 F N H L 41.91 12.70 – – – – M-124-492 BMP51, BMP53 180 1 B-492 F H L – – – 12.70 – – M-83-492 BMP51, BMP53 240 1 B-499 F A – – – 12.70 – – M-83-499-OR-BK BMP51, BMP53 240 1 B-499 F A – – – 12.70 – – M-83-499-RD-BK BMP51, BMP53 240 1 B-499 F N A 12.70 – 4.88 – – – MC-500-499 BMP51, BMP53 1 1 B-461 F N A H S L 12.70 – 7.62 – 12.70 – MC-500-461-AW BMP51, BMP53 1 1 B-492 F N 12.70 – 7.62 – – – MC-500-492 BMP51, BMP53 1 1 19.05 – 4.88 – – – MC-750-499 BMP51, BMP53 1 1 19.05 – 7.62 – 9.53 – MC-750-427 BMP51, BMP53 1 1 25.40 – 4.88 – – – MC-1000-499 BMP51, BMP53 1 1 H 1.5 - 2.0 ml A H L A 1.5 ml H L 2.0 - 50.0 ml B-499 F N A B-427 F N B-499 F N A S www.bradyeurope.com 23 Laboratory identification Specimen process marking Slide labels F N A H S L R • Brady offers labels specifically designed to identify slides and to resist exposure to harsh chemicals during the slide staining process. They perform well in the hematoxilin and eosin slide staining process and offer superior chemical resistance also useful in other laboratory contexts. Labels are shown in order of label width. Freezer environment Liquid nitrogen environment Autoclave environment Hot water bath (100°C) Self-laminating label Low-profile (extremely thin) label Removable The background colours in the Order Reference column represent the material colour. Special Properties F A Label Width Label Height Order A (mm) B (mm) Reference 6.35 48.26 M-81-488 Printer Compatibility BMP51, BMP53 Labels per Roll 160 Labels per Row 1 B-481 F 22.86 19.05 M-194-481 BMP51, BMP53 320 1 B-488 F 22.86 22.86 M-97-488 BMP51, BMP53 280 1 B-481 F H 22.86 22.86 M-97-481 BMP51, BMP53 280 1 B-481 F H 25.40 9.53 M-195-481 BMP51, BMP53 320 1 B-7425 F H 38.10 25.40 M-31-7425 BMP51, BMP53 250 1 Diagram Material B-488 H A N A Tissue Cassette Labels Specifically designed to identify tissue cassettes, Brady’s B-482 label withstands a temperature range from -80°C to 121°C and offers superior resistance to chemicals used in tissue processing enabling it to retain barcode legibility. The label must be used in combination with Brady’s BSP31 Label Attachment System for pre-process tissue cassette identification and complements the use of StainerBondz slide labels as part of a complete histology process. F N A H S L R Freezer environment Liquid nitrogen environment Autoclave environment Hot water bath (100°C) Self-laminating label Low-profile (extremely thin) label Removable Labels are shown in order of label width. Diagram The background colours in the Order Reference column represent the material colour. Material B-498 Special Properties F R Label Width A (mm) 19.05 Label Height B (mm) 12.70 Order Reference M-11-498 Printer Compatibility BMP51, BMP53 Labels per Roll 220 Labels per Row 1 B-482 F 26.67 6.35 M-127-482 BMP51, BMP53 360 1 H B-498 Re-Identify Tissue Cassettes Labels Tissue cassettes are often re-identified when labs collect samples from various biorepositories. Typically, each laboratory has its own unique way of identifying samples, which creates a need to re-identify samples in a common way. Brady B-498 post-process labels offer customers the optimal way to organise these specimens and conduct further studies. These labels can be applied directly onto the cassettes, on pure paraffin wax and on top of another label or identifier. This is not the same as Brady’s B-482 tissue cassette solution. B-498 Re-identify labels are applied after processing and are never used with the BSP31 label attachment system. 24 Laboratory identification Specimen storage Identification F N A H S L R Freezer environment Liquid nitrogen environment Autoclave environment Hot water bath (100°C) Self-laminating label Low-profile (extremely thin) label Removable Well plate labels • When total tracking of all sample collections is required then Brady has a solution for Well plate identification. Our well plate labels guarantee crystal clear text and barcoding for most lab environments. Labels are shown in order of label width. Diagram Material B-488 B-499 B-595 B-595 B-499 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-427 B-499 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-432 B-427 B-499 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 Special Properties F A F N A F F F N A F F F F F F F F F F F N S F N A F F F F F F F F F F F A F N S F N A F F F F F F F F F F Label Width A (mm) 6.35 9.53 9.53 9.53 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 The background colours in the Order Reference column represent the material colour. Label Height B (mm) 48.26 – – – – – – – – – – – – – – 38.10 – – – – – – – – – – – 12.70 38.10 – – – – – – – – – – – Label Length B (m) – 4.88 7.62 7.62 4.88 6.10 6.10 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 – 4.88 6.10 6.10 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 – – 4.88 6.10 6.10 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 Printable Area Height PH (mm) – – – – – – – – – – – – – – – 12.70 – – – – – – – – – – – – 12.70 – – – – – – – – – – – Printable Area Width PW (mm) – – – – – – – – – – – – – – – 19.05 – – – – – – – – – – – – 25.40 – – – – – – – – – – – www.bradyeurope.com Order Reference M-81-488 MC-375-499 MC-375-595-WT-BK MC-375-595-YL-BK MC-500-499 MC-500-595-CL-BK MC-500-595-CL-WT MC-500-595-BK-WT MC-500-595-BL-WT MC-500-595-GN-WT MC-500-595-OR-BK MC-500-595-RD-WT MC-500-595-WT-BK MC-500-595-WT-RD MC-500-595-YL-BK M-90-427 MC-750-499 MC-750-595-CL-BK MC-750-595-CL-WT MC-750-595-BK-WT MC-750-595-BL-WT MC-750-595-GN-WT MC-750-595-OR-BK MC-750-595-RD-WT MC-750-595-WT-BK MC-750-595-WT-RD MC-750-595-YL-BK M-17-432-CL-BK M-91-427 MC-1000-499 MC1-1000-595-CL-BK MC1-1000-595-CL-WT MC1-1000-595-BK-WT MC1-1000-595-BL-WT MC1-1000-595-GN-WT MC1-1000-595-OR-BK MC1-1000-595-RD-WT MC1-1000-595-WT-BK MC1-1000-595-WT-RD MC1-1000-595-YL-BK Printer Compatibility BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 Labels per Roll 160 1 1 1 1 1 1 1 1 1 1 1 1 1 1 180 1 1 1 1 1 1 1 1 1 1 1 280 180 1 1 1 1 1 1 1 1 1 1 1 Labels per Row 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 25 Laboratory identification Specimen storage identification Cryo preservation • Brady offers a range of labels designed specifically to identify laboratory samples for cryo storage. These labels can be applied to room temperature or to already frozen samples, albeit with a small overlap. The label will remain legible and will stick to the sample container during processing, even when exposed to extreme heat or chemicals like DMSO, Xylene and Ethanol, ensuring secure sample identification in the most challenging laboratory conditions. The background colours in the Order Reference column represent the material colour. Labels are shown per vial / tube size and in order of label width. Special Properties Label Width A (mm) Label Height B (mm) Label Length B (m) Printable Area Width PW (mm) Printable Area Height PH (mm) Printer Order Reference Compatibility B-461 F N A H S L 9.53 28.58 – 9.53 19.05 M-123-461 BMP51, BMP53 360 1 B-461 F N A H S L 12.70 28.58 – 12.70 19.05 M-122-461 BMP51, BMP53 360 1 B-461 F N A H S L 12.70 44.45 – 12.70 19.05 M-72-461 BMP51, BMP53 180 1 B-499 F N A 19.05 12.70 – – – M-11-499 BMP51, BMP53 220 1 B-490 F N 31.75 9.53 – – – M-112-490 BMP51, BMP53 360 1 B-499 F N A 9.53 20.96 – – – M-130-499 BMP51, BMP53 220 1 B-492 F N 9.53 20.96 – – – M-130-492 BMP51, BMP53 220 1 B-499 F N A 9.53 – 4.88 – – MC-375-499 BMP51, BMP53 1 1 B-461 F N A H S L 9.53 – 7.62 9.53 – MC-375-461-AW BMP51, BMP53 1 1 B-499 F N A 22.86 12.70 – – – M-84-499 BMP51, BMP53 200 1 B-499 F N A 12.70 25.40 – – – M-131-499 BMP51, BMP53 180 1 B-492 F N L 12.70 25.40 – – – M-131-492 BMP51, BMP53 180 1 B-461 F N A H S L 12.70 55.88 – 12.70 19.05 M-74-461 BMP51, BMP53 140 1 B-461 F N A H S L 15.24 45.72 – 15.24 25.40 M-126-461 BMP51, BMP53 180 1 B-490 F N L 15.24 45.72 – – – M-126-490 BMP51, BMP53 180 1 B-461 F N A H S L 15.24 66.68 – 15.24 25.40 M-86-461 BMP51, BMP53 120 1 B-461 F N A H S L 25.40 44.45 – 25.40 25.40 M-125-461 BMP51, BMP53 180 1 B-490 F N L 25.40 44.45 – – – M-125-490 BMP51, BMP53 180 1 B-461 F N A H S L 25.40 66.68 – 25.40 25.40 M-75-461 BMP51, BMP53 120 1 B-492 F N 22.86 25.40 – – – M-156-492 BMP51, BMP53 180 1 B-499 F N A 12.70 – 4.88 – – MC-500-499 BMP51, BMP53 1 1 B-461 F N A H S L 12.70 – 7.62 12.70 – MC-500-461-AW BMP51, BMP53 1 1 B-499 F N A 19.05 – 4.88 – – MC-750-499 BMP51, BMP53 1 1 B-499 F N A 25.40 – 4.88 – – BMP51, BMP53 1 1 B-461 F N A H S L 25.40 – 7.62 25.40 – MC-1000-499 MC-1000-461AW BMP51, BMP53 1 1 F N A H S L 31.75 – 7.62 31.75 – MC-1250-461AW BMP51, BMP53 1 1 F N A H S L 38.10 95.25 – 38.10 31.75 M-119-461 BMP51, BMP53 80 1 B-492 F N 25.40 48.26 – – – M-78-492 BMP51, BMP53 100 1 B-499 F N A 38.10 31.75 – – – M-132-499 BMP51, BMP53 160 1 Diagram Material 0.5 - 0.7 ml H L H L Labels per Roll Labels per Row 0.6 ml 1.0 - 8.0 ml H H H 1.0 - 15.0 ml H L 1.5 ml 2.0 - 50.0 ml 4.0 - 50.0 ml B-461 12.0 - 14.0 ml B-461 12.0 - 24.0 ml 26 H L Laboratory identification Lean lab identification Bottles / flasks & dishes • Brady’s labels for bottles, flasks and dishes are easy to handle and flexible. This enables the labels to be placed on curved containers and remain attached and legible, even after being subjected to freezing, liquid nitrogen and heat. Labels are shown in order of label width. Diagram Material B-499 B-499 B-499 B-498 B-499 B-427 B-499 B-498 B-427 B-498 B-499 B-499 Special Properties F N A F N A F N A F R F N A F N S F N A F R F N S F R F N A F N A Label Width A (mm) 9.53 9.53 12.70 12.70 12.70 19.05 19.05 25.40 25.40 25.40 25.40 38.10 The background colours in the Order Reference column represent the material colour. Label Height B (mm) 20.96 – 25.40 25.40 – 38.10 – 31.75 38.10 48.26 – 31.75 Label Length B (m) – 4.88 – – 4.88 – 4.88 – – – 4.88 – Printable Area Width PW (mm) – – – – – 19.05 – – 25.40 – – – Printable Area Height PH (mm) – – – – – 12.70 – – 12.70 – – – Order Reference M-130-499 MC-375-499 M-131-499 M-131-498 MC-500-499 M-90-427 MC-750-499 M-103-498 M-91-427 M-128-498 MC-1000-499 M-132-499 Printer Compatibility BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 Labels per Roll 220 1 180 180 1 180 1 160 180 100 1 160 Labels per Row 1 1 1 1 1 1 1 1 1 1 1 1 Water dissolvable labels The B-403 water dissolvable paper label is self-adhesive and extremely easy to apply. Exposing the label to warm water will completely dissolve it within 30 seconds, without damage to the surface it was applied to, and without leaving any residue. The water dissolvable label adheres well to most surfaces, including glass, stainless steel, aluminium, plastic and others. This makes the label a great solution to enable short term The background colours in identification for containers, crates and the Order Reference column represent the material colour. glassware with a minimum of waste. Diagram Special Material Properties B-403 R R B-403 Label Width Label Length Order A (mm) B (m) Reference Printer Compatibility 48.25 7.62 MC-1500-403 BMP51; BMP53 48.25 7.62 MC-750-403 Printer Ribbon Series R6400 BMP41; BMP51; BMP53 R6400 Labels per Roll 1 1 Bottle tamper seal labels Brady’s bottle seal identification provides tracking information with the added feature of security. These labelling materials are designed to fracture easily in order to show signs of sample tampering and to prevent one-piece label removal. Labels are shown in order of label width. Diagram Material Special Properties B-351 F B-351 F The background colours in the Order Reference column represent the material colour. Label Width A (mm) 25.40 Label Height B (mm) 12.70 Order Reference M-17-351 Printer Compatibility BMP51, BMP53 Labels per Roll 360 Labels per Row 1 25.40 50.80 M-20-351 BMP51, BMP53 160 1 www.bradyeurope.com 27 Laboratory identification Lean lab identification General lab identification Just like a durable sample label lets you know which sample you are holding, a cabinet or drawer label can inform you of the cabinet’s content. With proper identification, time spent looking for the right sample or tool can be invested in what really matters. Brady offers a range of materials suitable for identifying drawers, cabinets, shelves, storage units and laboratory equipment. Labels are shown in order of label width. Diagram 28 Material B-499 B-499 B-595 B-595 B-499 B-498 B-499 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-499 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-432 B-498 B-498 B-432 B-499 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-595 B-499 Special Properties F N A F N A F F F N A F R F N A F F F F F F F F F F F N A F F F F F F F F F F F A F R F R F A F N A F F F F F F F F F F F N A Label Width A (mm) 9.53 9.53 9.53 9.53 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 38.10 F N A H S L R Freezer environment Liquid nitrogen environment Autoclave environment Hot water bath (100°C) Self-laminating label Low-profile (extremely thin) label Removable The background colours in the Order Reference column represent the material colour Label Height B (mm) 20.96 – – – 25.40 25.40 – – – – – – – – – – – – – – – – – – – – – – 12.70 31.75 48.26 48.26 – – – – – – – – – – – 31.75 Label Length B (m) – 4.88 7.62 7.62 – – 4.88 6.10 6.10 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 4.88 6.10 6.10 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 – – – – 4.88 6.10 6.10 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 – Order Reference M-130-499 MC-375-499 MC-375-595-WT-BK MC-375-595-YL-BK M-131-499 M-131-498 MC-500-499 MC-500-595-CL-BK MC-500-595-CL-WT MC-500-595-BK-WT MC-500-595-BL-WT MC-500-595-GN-WT MC-500-595-OR-BK MC-500-595-RD-WT MC-500-595-WT-BK MC-500-595-WT-RD MC-500-595-YL-BK MC-750-499 MC-750-595-CL-BK MC-750-595-CL-WT MC-750-595-BK-WT MC-750-595-BL-WT MC-750-595-GN-WT MC-750-595-OR-BK MC-750-595-RD-WT MC-750-595-WT-BK MC-750-595-WT-RD MC-750-595-YL-BK M-17-432-CL-BK M-103-498 M-128-498 M-78-432-CL-BK MC-1000-499 MC1-1000-595-CL-BK MC1-1000-595-CL-WT MC1-1000-595-BK-WT MC1-1000-595-BL-WT MC1-1000-595-GN-WT MC1-1000-595-OR-BK MC1-1000-595-RD-WT MC1-1000-595-WT-BK MC1-1000-595-WT-RD MC1-1000-595-YL-BK M-132-499 Printer Compatibility BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 BMP51, BMP53 Labels per Roll 220 1 1 1 180 180 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 280 160 100 100 1 1 1 1 1 1 1 1 1 1 1 160 Labels per Row 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Master material index This section provides a quick reference to Brady materials listed throughout this catalogue, including basic attributes, applications and regulatory compliance where applicable. For more detailed material attribute and performance information, please refer to the material’s Technical Data Sheet, listed at www.bradyeurope.com/tds. Brady Material No. Material Finish Colour Temp (°C) Performance (Tested for 30 days) Attributes Min. Max. B-109 Polyethylene Tag Matt White -40 °C 49 °C B-145 Polyethylene Tag Matt Grey -40 °C 100 °C B-342 Heat-shrink Polyolefin Sleeve Matt White -55 °C 130.6 °C B-351 Tamper-resistant Vinyl Matt White -40 °C 80 °C B-403 Paper Matt Black on White -40 °C 78 °C B-412 Polypropylene Tag Matt White -40 °C 100 °C B-422 Polyester Gloss White -40 °C 100 °C B-425 Polypropylene Matt White -70 °C 80 °C B-427 Self-laminating Vinyl B-428 Metallised Polyester Matt Silver -70 °C 120 °C B-432 Polyester Gloss Clear -40 °C 100 °C B-461 Self-laminating Polyester Matt White/Transparent -196 °C 110 °C B-7425 Polypropylene Matt Black on White -80 °C 70 °C Matt White/Transparent -40 °C 60 °C Properties & Applications White polyethylene tag material with matt finish. Excellent multi-purpose tag for identifying multiconductor cables, inventory, safety warning repair and work-in-processing manufacturing. Good weatherability, humidity resistance and legibility after solvent exposure. This multipurpose material can be used for a variety of tag applications including identification of multiconductor cables, equipment, safety warning repair and workinprogress. 3:1 ratio heat shrinkable wire marking sleeve that fits snugly around wires for identification and protection. Fade-resistant and flame retardant. Also available in yellow, black, blue, brown, green, gray, orange, pink, red, violet. White vinyl material with matt finish. Tamper evident material fractures to show signs of product tampering and prevent one-piece removal. White dissolvable paper. Dissolves completely in water leaving no adhesive residue, ideal for temporary labeling applications. White polypropylene tag material with matt finish. Offers high print legibility and high tensile strength. White material stock with glossy finish and 2 mils of adhesive for rough surface applications, including low surface energy plastics. Designed to withstand solvent exposure. UL rated for surfaces commonly used in solar panel manufacturing. Also used for component identification, barcoding, asset and inventory tracking. White polypropylene material stock with matt finish for thermal transfer printing or write-on applications. Excellent solvent resistance and print performance; not recommended for long-term outdoor use. Thermal transfer printable, self-laminating material. These labels have a printable area with a clear “tail” that wraps around the marker. The “tail” serves as overlaminate to protect the print. Superior resistance to abrasion, solvents, water, oil and dirt. Also available in grey, brown, green, yellow, blue, red, purple, orange Thermal transfer printable metallised polyester with matt finish. Withstands solvents and variable temperatures. Excellent for serial and rating plate applications with name-plate quality and a metal-looking finish. Translucent, high performance polyester material with a glossy finish. Thermal transfer printable. Very similar to B-430, but has a thicker layer of acrylic adhesive for better adherence to rough surface applications. Permanent adhesive; suitable for liquid nitrogen application if material is wrapped around itself, as in self-lamination; write-on capabilities. Temperature range increases to 121°C when used in autoclave process White Polypropylene material. Ideal for laboratory identification such as vials, centrifuge tubes and test tubes. For freezer or liquid nitrogen applications, B-7425 must be applied prior to being frozen. www.bradyeurope.com Approval/Compliance – – UL Recognised to UL224; SAE-AMS-DTL-23053/5 C (Class 1); SAEAS-81531 – – – UL Recognised; CSA Accepted UL Recognised; CSA Accepted; Halogen Free (DIN VDE 0472/part 815) UL Recognised to UL969 Labelling and Marking Standard when printed with the Brady Series R4300 and R6200 ribbons. See UL files MH17154 for specific details. Brady customers should specify at purchase if they require UL Recognised B-427 labels. Brady sells both UL Recognised B-427 labels and non-approved labels depending on customer requirements. UL Recognised; CSA Accepted; Halogen Free (DIN VDE 0472/part 815) UL Recognised; CSA Accepted – – 29 Master material index Brady Material No. Material Finish Colour Temp (°C) Performance (Tested for 30 days) Attributes Min. Max. B-481 StainerBondz™ Polyester Matt White -80 °C B-482 Polyester Matt White B-483 Polyester White -40 °C Matt White -40 °C 145 °C B-490 Freezerbondz™ Polyester Matt White -196 °C 130 °C B-492 Freezerbondz™ Polyester Matt White -196 °C 110 °C B-498 Vinyl Cloth Semigloss White -40 °C 80 °C B-499 Nylon Cloth Matt White -40 °C 90 °C B-584 Reflective Tape Gloss Orange -40 °C 70 °C B-595 Vinyl Gloss White -40 °C 82 °C B-7641 Heat-shrink Polyolefin Sleeve Matt White -55 °C 105 °C Abrasion resistance Electrostatic dissipative Fuel/oil resistance ToughBond™ Series High heat resistance White polyester thermal transfer printable material with glossy finish and aggressive adhesive specifically designed for powder coated surfaces. 120 °C Polyester MetaLabel™ Series White polyester will remain resistant when exposed to xylene and other chemicals that are commonly used in the slide staining process The B-482 label material, combined with Brady’s R6400 ribbon, provides the durability and print quality that histology and anatomic pathology labs need for accurate, identifiable specimen labelling. Paraffin and solvent resistant. 130 °C B-488 WorkHorse™ Labels 30 Gloss Properties & Applications Low temperature resistance White polyester thermal transfer printable material, similar to B-423, but with matt finish. Widely used for component identification, barcoding, asset and inventory tracking. Can be applied to frozen surfaces including glass and polypropylene stored in liquid nitrogen, except for Vial Tops. Material must slightly overlap itself. Ultra thin; can label frosted/frozen (with overlap) or room temperature labels and lasts in liquid nitrogen and hot water baths White vinyl cloth label material with glossy finish. The adhesive and cloth backing give excellent holding power, while being repositionable and removing cleanly. Approval/Compliance – – UL Recognised; CSA Accepted UL Recognised; CSA Accepted – – UL Recognised UL Recognised; CSA Nylon cloth material with matt finish. The Accepted; Halogen Free adhesive allows labelling in environments with (DIN VDE 0472/part heat, cold, oil and dirt. Also available in orange, 815) Approvals are for red and yellow. White material only Suitable for outdoor use. Also available in silver – and yellow. Durable, low-shrink vinyl with our most aggressive adhesive. Conforms to irregular, curved, rough and highly textured surfaces (painted cinder blocks, uneven wood, textured BS5609:1986 Section 2 plastics, paper-jacketed pipes, powder-coated and section 3 surfaces). Adheres to “difficult” low-surface energy items (PVC piping, blow-moulded equipment cases, ABS plastics, recycled plastics). Available in a wide range of colours. 2:1 ratio heat shrinkable, zero halogen wire BS-6853 (1999) Vehicle marking sleeves. The wire marking sleeves Category 1A; ENoffer outstanding fire safety properties and 45545-2, requirement minimal smoke emission. Also available in 24, Vehicle Category yellow. HL3; Zero Halogen Defender™ Series Removable CleanLift™ Series Solvent/chemical resistance Tamper-indicating UltraTemp™ Series Ultra-aggressive adhesive Software solutions Brady Workstation Brady Workstation offers professional, intuitive apps to design quality product and cable labels and safety signs. Label design becomes easier, faster and quickly adaptable to new label norms thanks to centralised updates. Select the apps you need Simply select the apps you need, download the 30-day trial and purchase when satisfied. Available product, cable, safety and facility identification apps enable you to: • • • • • • • • • design and edit custom labels and signs design label templates and lock elements for consistency create text-only cable labels automate label creation easily import data easily set up complex label sequences easily design CLP-chemical labels print lockout procedures, tags and energy source labels design safety and facility signs. Available in multiple languages Brady Workstation apps are available in more than 20 languages, including English, French, German, Russian, Spanish, Italian, Polish and Dutch. Select your language before downloading from the drop down menu. Easily connect to your printer Brady Workstation works seamlessly with a range of Brady desktop and portable printers. Brady’s high-end label printers also offer bi-directional communication with Brady Workstation and will inform users if they have to switch label materials to print specific label designs. Printer compatibility is shown in Brady Workstation on an app by app basis. Try it today! Discover Brady Workstation at www.bradyeurope.com/workstation or download at workstation.bradyid.com. Suite du logiciel Conception de base de Brady Workstation Rendez vos ressources internes rapidement opérationnelles sur autant d’ordinateurs que vous le souhaitez grâce à ce logiciel gratuit de création d’étiquettes ! Vous bénéficierez d’une conception de base, d’une fonctionnalité de mise en forme, d’illustrations et de bibliothèques de codes-barres simples pour créer des étiquettes de qualité professionnelle ! Cette suite de base est fournie avec chaque imprimante. Il vous suffit de la télécharger. Workstation.BradyID.com/Free Suite du logiciel Identification de produits et fils de Brady Workstation Identifiez rapidement vos produits et fils à l’aide d’étiquettes de texte ou illustrées personnalisées, en utilisant des données sérialisées ou importées. Workstation.BradyID.com/ProductandWire www.bradyeurope.com 31 Printer specifications PRINTER FONTS/GRAPHICS/SYMBOLOGIES Description BMP51 Label Printer Text Sizes (pt) 4 - 102 pt Includes This printer ships in a hard case with a Rechargeable Lithium Ion Battery, USB Cable, AC adaptor, power cord, Product CD, Brady Printer Drivers CD, Quick Start Guide, a Bluetooth network card and an MC1-1000-422 cartridge. Built-in Fonts Brady Alpine Brady Fixed Width Built-in Symbols 450 symbols included Applications Wire & Cable Marking; Patch Panel Identification; Control Panel & Component Marking; Terminal Block Marking; Voice & Data Communication; Electrical Component Marking; General & Industrial Marking; Laboratory Identification Symbol Categories Print Speed (mm/sec) 25.40 Internal Memory Capacity 48 MB - up to 25.000 labels Cutter Manual cut Between labels or at end of print job With label retention Keyboard Type QWERTY Colour Capability Monocolour Language Support Danish, Dutch, English, Finnish, French, German, Italian, Norwegian (Bokmål), Portuguese, Spanish, Swedish Arrows Electrical Exit Datacom Fire Safety First Aid GHS/CLP Laboratory Mandatory Packaging Miscellaneous Personal Protective Equipment Prohibition Public Information Safety Warning WHIMIS Bar Code Capability Yes Portability Yes Bar Code Type Code 39 and 128, other via software Weight (kg) 1.20 Size W x D x L (mm) 107 x 106 x 328 Drop Test up to 1.8 metres DISPLAY Operating Temperature 5°C - 40°C Display Monocolour LCD Screen Operating Humidity 20%-90% (non-condensing) Display Resolution 320 x 240 px Warranty 2 years Display Size 68.58 mm x 43.18 mm MEDIA SUPPORTED PRINTING FUNCTIONS Materials Supported 200+ standard parts: continuous tapes and die cut labels Format Media supplied in Cartridge with Ribbon Compatible Media M-, MC-, MC1- Continuous vs Die-cut Labels Continuous Tape & Die Cut Labels Custom Labels No Smart Cell Yes Calibration Automated through Smart Cell Max. Label Width (mm) 38.10 mm Min. Label Width (mm) 6.40 mm Recommended Usage per Day 500 POWER SUPPLY Printing Functions Banner Serialisation Mirror Rotate Reverse Auto Format Justification Vertical Fixed Length Multi-copy Print Preview Date/Time Stamp Frame Feature Serialisation Simple & Simultaneous & Single Advanced & Multiple Advanced Printing Modes Flags Terminal Block Patch Panel Wire Wrap Print Resolution (dpi) 300 SOFTWARE & CONNECTIVITY Auto Shut Off Yes Connectivity Options USB, Bluetooth. Optional: Ethernet, WiFi Battery Type Lithium Ion Battery Software Compatibility Brady Workstation, LabelMark, CodeSoft Power Supply AC Adaptor, 8 AA Batteries, Rechargeable Battery COMPLIANCE Approval/Compliance 32 CE, WEEE, RoHS BMP51 Printer, kits and accessories Printers Order Reference BMP51 PRINTER EU BMP51-EU-PWID BMP51 PRINTER KIT UK BMP51-UK-PWID Art. No. 710894 198630 710898 198631 Description BMP51 Label Printer - EU BMP51 Label Printer - EU with Brady Workstation PWID Suite BMP51 Label Printer - UK BMP51 Label Printer - UK with Brady Workstation PWID Suite The Basic Suite is included with every printer, all you need to do is download it. Workstation.BradyID.com/Free Quickly identify your products and wires with customised text or graphical labels, using serialised or imported data. Workstation.BradyID.com/ProductandWire Printer Kits Order Reference BMP51-EU-ELEC* BMP51-UK-ELEC* BMP51-EU-LAB*** BMP51-UK-LAB*** BMP51-EU-DATA** BMP51-UK-DATA** Art. No. 198654 198657 198655 198658 198653 198656 Description BMP51 Electrical Kit EU BMP51 Electrical Kit UK BMP51 Laboratory Kit EU BMP51 Laboratory Kit UK BMP51 TeleDatacom Kit EU BMP51 TeleDatacom Kit UK *Freezerbondz Polyester; Heat-shrink Polyolefin Sleeve; Metallised Polyester; Nylon Cloth; Polyester; Polyethylene Tag; Polypropylene; Polypropylene Tag; Reflective Tape; Self-laminating Polyester; Self-laminating Vinyl; StainerBondz Polyester; Tamper-resistant Vinyl; Vinyl; Vinyl Cloth **This printer ships in a hard case with a Rechargeable Lithium Ion Battery, USB Cable, AC adaptor with power cord, Magnet accessory, Product CD, Brady Printer Drivers CD, Quick Start Guide, a Bluetooth network card, a Brady Workstation Product & Wire Identification Suite, M-132-499, M1-115-427 and an MC1-1000422 cartridge. ***This printer ships in a hard case with a Rechargeable Lithium Ion Battery, USB Cable, AC adaptor with power cord, Product CD, Brady Printer Drivers CD, Quick Start Guide, a Bluetooth network card, a Brady Workstation Product & Wire Identification Suite, M-122-461, M-131-499 and an MC1-1000-422 cartridge. Accessories Art. No. Order Reference 142261 UBP-Li-ION-AC-120v 710902 UBP-Li-ION-AC-EUR 710903 UBP-Li-ION-AC-UK 114883 710612 710613 M41/50/61/71/611-ACBC-NA M41/50/61/71/611-ACBC-EU M41/50/61/71/611-ACBC-UK 142260 BMP-UBP 12V 143115 M50-BATT-TRAY 143109 121423 143108 142265 142267 142266 M50-HC M50-SC M50-MAGNET NET-BT NET-LAN NET-WIFI Description Univeral Li-ion Battery Pack with AC Adaptor/ Battery Pack US Univeral Li-ion Battery Pack with AC Adaptor/ Battery Pack EU Univeral Li-ion Battery Pack with AC Adaptor/ Battery Pack UK AC Adaptor - USA 120V AC Adaptor - Europe 220V AC Adaptor - UK 240V Rechargeable Lithium Ion battery for the BMP51 printer BMP50 Series Spare Battery Tray for 8 AA batteries BMP50 Series Hard Carry Case BMP50 Series Soft Carry Case BMP50 Series Magnet Accessory Bluetooth Network Card LAN Network Card WiFi Network Card www.bradyeurope.com Magnet 33 Brady technical service 2 year warranty on all Brady portable printers Brady offers a 2 year warranty on every Brady Mobile Printer sold. This manufacturer’s warranty is completely free and highlights Brady’s commitment to quality and on-the-job reliability. Flash this QR Code to access to all the details about the Brady warranty. What if you want more extensive support ? Brady offers Assist Base, Assist Field and Assist Custom service contracts which include priority assistance for 1, 3 or 5 years to guarantee continued support and the ultimate printer reliability, even in demanding working environments. These agreements also include many great extras versus our free, standard 2 year warranty, such as: spare parts, a solution within 2 business days, free annual preventative maintenance, repair transportation costs, priority access to the technical service team or even a specialist at your premises. Get all of these extra assurances at the cost of just 1 flat fee repair! Our training and setup service • Brady Setup Base : Stress free installation of your Brady printer and software by screensharing. We help you produce your first labels. • Brady Setup Field : Stress free installation of your Brady printer and software by a Brady specialist at your premises. We help you produce your first labels. • Brady Training Half/Whole day : Hands-on training by a Brady specialist at your premises. Please contact us for additional information! 34 Brady support Register your Product After registering your product you will have access to: • Technical support • Notification of updates • Special offers and product announcements www.bradyeurope.com/registration Reliable identification and safety solutions When temperature, chemicals, pressure or friction make durable identification difficult, and when identification is critical for traceability, production efficiency or workplace safety, Brady responds with expertise, material science knowledge and hassle free label printing solutions to answer your identification challenges. Laboratory identification EUR-M-513-EN Product & wire identification EUR-0-501-EN Safety and facility identification EUR-M-801-EN Enter the EUR-number of the catalogues above in the website’s search engine to get the most recent updates. Discover more reliable identification - and safety solutions in the Brady catalogues on www.bradyeurope.com/catalogues! www.bradyeurope.com 35 Africa Hungary Spain & Portugal Randburg, South Africa Tel.: +27 11 704 3295 Email: africa@bradycorp.com Budaörs Tel.: +36 23 500 275 Email: central_europe@bradycorp.com Madrid, Spain Tel.: +34 900 902 993 Email: spain@bradycorp.com, portugal@bradycorp.com Benelux Italy Zele, Belgium Tel.: +32 (0) 52 45 78 11 Email: benelux@bradycorp.com Gorgonzola Tel.: +39 02 26 00 00 22 Email: italy@bradycorp.com Central & Eastern Europe Middle East FZE Bratislava, Slovakia Tel.: +421 2 3300 4800 Email: central_europe@bradycorp.com Dubai, UAE Tel.: +971 4881 2524 Email: me@bradycorp.com Denmark Norway Odense Tel.: +45 66 14 44 00 Email: denmark@bradycorp.com Kjeller Tel.: +47 70 13 40 00 Email: norway@bradycorp.com France Romania Roncq Tel.: +33 (0) 3 20 76 94 48 Email: france@bradycorp.com Bucharest Tel.: +40 21 202 3032 Email: central_europe@bradycorp.com Germany, Austria & Switzerland Russia Egelsbach, Germany Tel.: +49 (0) 6103 7598 660 Email: germany@bradycorp.com Moscow Tel.: +7 495 269 47 87 Email: central_europe@bradycorp.com Sweden, Finland, Baltic states Kista, Sweden Tel.: +46 (0) 8 590 057 30 Email: sweden@bradyeurope.com Turkey Istanbul Tel.: +90 212 264 02 20 / 264 02 21 Email: turkey@bradycorp.com UK & Ireland Banbury, UK Tel.: +44 (0) 1295 228 288 Email: uk@bradycorp.com Our mission is to identify and protect people, products and places Your distributor To help minimise our impact on the environment, Brady limits its number of reprints. Search for: EUR-M-409-EN Y1863893 © 2019 Brady Worldwide Inc. ALL RIGHTS RESERVED. 25/11/2019 Updated versions are always available for download on www.bradyeurope.com.
BMP51 PRINTER EU 价格&库存
很抱歉,暂时无法提供与“BMP51 PRINTER EU”相匹配的价格&库存,您可以联系我们找货
