113231
113231
    BRADY
    Valve Access Plug Valve Lockout
113231 数据手册
Technical Data Sheet Plug Valve Lockout TDS No. LOTO­52 Effective Date: 11/20/2012 Description: Design     Available in four sizes to accommodate a wide range of plug valves Effective fit for difficult­to­secure plug valves Durable and tamper­resistant Compact in size and easy to use Material Body, base: polypropylene Color: Red (PMS1805C) Hose Clamp: Steel   Temperature Range Polypropylene : ­20° to 80°C (0° to 175°F)   Chemical Chemical Resistance All approved chemicals listed are based on the manufactures specified chemical resistance chart for plastic material only Dimensions   7/8”     [22.2mm] 3.21” A ­ [81.4mm] 0.37” B ­ [9.3mm] 0.88” C ­ [22.2mm] 3.00” D ­ [76.2mm] 0.39” E ­ [10mm]     1­3/8” [35mm] 3.21” [81.4mm] 0.37” [9.3mm] 1.38” [34.9mm] 3.00” [76.2mm] 0.39” [10mm] 2­1/8” [54mm] 4.71” [119.6mm] 0.37” [9.3mm] 2.13” [54.1mm] 4.00” [101.6mm] 0.39” [10mm] 2­½” [63.5mm] 4.71” [119.6mm] 0.37” [9.3mm] 2.50” [63.5mm] 4.00” [101.6mm] 0.39” [10mm] °C Chemical °C Acetone 25 Petroleum 25 Acetone 60 Turpentine oil 25 Chlorine, chlorine water 25 Turpentine substitute (white spirit) 25 Fuel, engine: Gasoline (normal & premium grade) 85 Trichloroethane 1,1,1 45 Lubrication oil: gear oil Lubricating oil: HD engine
113231 价格&库存
很抱歉,暂时无法提供与“113231”相匹配的价格&库存,您可以联系我们找货
