170045
170045
    BRADY
    BRADY - 170045 - FLOOR MARKING TAPE, 2" X 100FT, BLACK
170045 数据手册
Technical Data Sheet Brady B-543 Floor Marking Tape TDS No. B-543 Effective Date: ​08/17/2018 Description: Brady B-543 is an extruded polyvinyl chloride tape used for industrial floor marking. Details: Use: Brady B-543 is used to mark aisles, passageways, storage locations, point out safety equipment and exits, and enforce protective equipment requirements. It is designed for high-traffic environments where durability is highly valued. Adhesive Type: Acrylic Substrate Type: Polyvinyl chloride Standard Material Colors: Solid: White, Red, Green, Blue, Yellow, Orange Striped Print: Yellow/Black Thickness: 0.050 in. (1.27 mm) Adhesive Properties: Adhesion to Stainless Steel (PSTC-101) 15 Minute Dwell (Avg.) – 150 oz/in (16.3 N/10 mm) Tack (ASTM D2979-16) (Avg.) = greater than 1500 g Abrasion Resistance (ASTM D4060-14): Solid: S-35 Tungsten Carbide Wheels, 1000g wts. Material withstands up to 3500 cycles at nominal thickness Striped print: CS-10 Wheels, 500g wts. Black stripe withstands up to 1200 cycles at nominal thickness Gloss (60°): 40 - 70 units Minimum Application Temperature: 50°F (10°C) Service Temperature: 0°F to 140°F (-18°C to 60°C) Average Outdoor Durability: Not recommended for outdoor use. Chemical Resistance: Reagent 25% Sulfuric Acid 10% Sulfuric Acid 30% Hydrochloric Acid 10% Hydrochloric Acid Glacial Acetic Acid 10% Acetic Acid 50% Sodium Hydroxide 10% Sodium Hydroxide 10% Ammonia 5% Sodium Hypochlorite 10% Sodium Chloride Methyl Ethyl Ketone Acetone Toluene Methanol Isopropyl Alcohol Heptane Mineral Spirits Turpentine Diesel Fuel Kerosene Gasoline ASTM # 3 Oil SAE 20 Oil Alconox® Detergent Deionized Water 7 day Immersion Impact to Print 7 day Immersion Impact to Adhesive 7 day Immersion Impact to Film NE NE NE NE NE NE NE NE NE NE NE F F NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE F NE NE NE NE NE NE F F F NE NE F NE F NE NE F NE NE F NE NE NE NE NE F NE NE NE NE NE NE F F F F F F F F F F F NE NE NE NE NE = No Effect F = Failed (affected Sample) Shelf life is ​two years from the date of receipt​ for this product as long as this product is stored in its original packaging in an environment below 80° F (27° C) and 60% RH. It remains the responsibility of the user to assess the risk of using this product. We encourage customers to develop testing protocols that will qualify a product's fitness for use in their actual application. Trademarks: ASTM: American Society for Testing and Materials (U.S.A.) Alconox® is a registered trademark of Alconox Co. All S.I. Units (metric) are mathematically derived from the U.S. Conventional Units PSTC: Pressure Sensitive Tape Council (U.S.A.) SAE: Society of Automotive Engineers Note: ​All values shown are averages and should not be used for specification purposes. Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2018 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414-358-6600 | Fax: 800-292-2289
170045 价格&库存
很抱歉,暂时无法提供与“170045”相匹配的价格&库存,您可以联系我们找货
