B33-119-427
B33-119-427
    BRADY
    LABEL 1.5" HX1.5"W WHT 1=1000PCS
B33-119-427 数据手册
SAFETY, FACILITY & EQUIPMENT IDENTIFICATION BradyID.com/s35 Your experts for safety, facility and equipment identification. B30 & B33 Series Materials BradyID.com/s35 ‹‚<  ? ~‚~ ‹ˆ#Q • • • • Brady’s most popular wire marker! Features white printable area with clear “tail” that wraps around marker to protect text Superior resistance to abrasion, handling, solvents, water, oil and dirt Vinyl with permanent acrylic adhesive designed specifically for tightly curved surfaces Service temp: -40°F to 158°F Agency Approvals: ®   A       Figure 9a   B   D F   Figure 12 Figure 14 E Figure 15 Benchtop Printers Fits Printer Diagram Catalog # Model(s) B# Label Color Width A Inch (mm) Label Height B Inch (mm) Horiz. Repeat C Inch (mm) Vert. Repeat D Inch (mm) Web Width E Inch (mm) Print Area Height F Inch (mm) Labels Labels Rec. Per Per Ribbon Row Roll BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 B-427 White White White White White White White White White White White White White White White White White White White White White White White White 0.750 (19.1) 1.000 (25.4) 1.437 (36.5) 0.937 (23.8) 1.750 (44.6) 1.437 (36.5) 0.750 (19.1) 1.000 (25.4) 1.437 (36.5) 2.250 (57.2) 2.625 (66.7) 3.750 (95.3) 6.000 (152.4) 0.750 (19.1) 1.000 (25.4) 1.500 (38.1) 2.250 (57.2) 1.000 (25.4) 1.500 (38.1) 2.250 (57.2) 1.000 (25.4) 3.750 (95.3) 2.250 (57.2) 6.000 (152.4) 0.600 (15.2) 0.600 (15.2) 0.662 (16.8) 0.800 (20.3) 0.800 (20.3) 0.800 (20.3) 1.100 (27.9) 1.100 (27.9) 1.075 (27.3) 1.100 (27.9) 1.075 (27.3) 1.100 (27.9) - 0.950 (24.1) 0.950 (24.1) 1.625 (41.3) 1.125 (28.6) 1.875 (47.6) 1.625 (41.3) 0.875 (22.2) 1.125 (28.6) 1.625 (41.3) 2.375 (60.3) 1.125 (28.6) 4.000 (101.6) 6.187 (157.1) 0.875 (22.2) 1.125 (28.6) 1.750 (44.5) 2.500 (63.5) 1.125 (28.6) 1.750 (44.5) 2.500 (63.5) 1.125 (28.6) 4.000 (101.6) 2.438 (61.9) 6.187 (157.1) 2.500 (63.5) 2.500 (63.5) 3.350 (85.1) 3.350 (85.1) 3.350 (85.1) 3.400 (86.4) 2.300 (58.4) 2.300 (58.4) 3.350 (85.1) 2.300 (58.4) 2.825 (71.8) 3.350 (85.1) 2.300 (58.4) 1.700 (43.2) 1.700 (43.2) 1.700 (43.2) 1.700 (43.2) 1.950 (49.5) 1.950 (49.5) 1.950 (49.5) 2.200 (55.9) 2.200 (55.9) 2.700 (68.8) 2.200 (55.9) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.500 (38.1) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 0.750 (19.1) 1.500 (38.1) 4 4 5 4 4 4 2 2 3 2 1 3 2 1 1 1 1 1 1 1 1 1 1 1 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 12 Fig. 15 Fig. 12 Fig. 12 Fig. 9a Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 14 Fig. 9a Fig. 14 Fig. 14 Fig. 14 B33-80-427 B33-113-427 B33-8-427 B33-56-427 B33-73-427 B33-74-427 B33-115-427 B33-116-427 B33-9-427 B33-75-427 B33-131-427 B33-10-427 B33-81-427 B33-135-427AW B33-118-427 B33-119-427 B33-272-427 B33-120-427 B33-121-427 B33-273-427 B33-137-427AW B33-27-427 B33-26-427 B33-82-427 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 0.800 (20.3) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.750 (44.5) 1.750 (44.5) 1.750 (44.5) 2.000 (50.8) 2.000 (50.8) 2.500 (63.5) 2.000 (50.8) 2500 2500 5000 5000 3500 4000 2500 2500 2500 1400 1500 1200 500 1500 1250 1000 700 1250 1000 500 1500 400 500 200 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30 Series  >    ‹ˆ## • Continuous supply in 3 widths to make labeling patch panels and other datacomm components quick and easy • Aggressive adhesive suitable for rough, highly textured and powder-coated surfaces as well as smooth surfaces  Service temp: -40°F to 212°F Agency Approvals:   Figure 3 ® Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Web Width E Inch (mm) Labels Per Roll Rec. Ribbon BBP33 Only BBP33 Only Fig. 3 Fig. 3 B33C-312-422 B33C-375-422 B-422 B-422 White White 0.312 (7.9) 0.375 (9.5) 85ft (25.9m) 85ft (25.9m) 1.000 (25.4) 1.000 (25.4) 1 roll (cont.) 1 roll (cont.) B30-R6000 B30-R6000 404 11b_BBP30-37_Materials.indd 404 7/6/17 4:55 PM B30 & B33 Series Materials BradyID.com/s35 K '> ? ~‚~ ‹ˆ_ • A vinyl cloth label for marking wires, cables and inside-panel components • Repositionable! A highly unique adhesive and cloth construction gives excellent holding power and still allows for clean removal and reapplication • Ideal choice for marking both ends of a wire that you may need to cut shorter before final termination Service temp: -40°F to 175°F Agency Approvals:  ®     Fits Printer Diagram Model(s) Catalog # B# Color Label Width A Inch (mm) Label Height B Inch (mm) Horiz. Repeat C Inch (mm) Vert. Repeat D Inch (mm) Web Width E Inch (mm) Labels Labels Per Row Per Roll Rec. Ribbon BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only BBP33 Only B33-90-498 B33-68-498 B33-87-498 B33-1-498 B33-91-498 B33-95-498 B33-5-498 B33-88-498 B33-89-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 B-498 White White White White White White White White White 0.250 (6.4) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 0.750 (19.1) 0.800 (20.3) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.437 (36.5) 0.750 (19.1) 1.437 (36.5) 0.250 (6.4) 0.937 (23.8) 1.437 (36.5) 0.500 (12.7) 0.750 (19.1) 1.437 (36.5) 0.350 (8.9) 0.600 (15.2) 0.600 (15.2) 0.800 (20.3) 0.850 (21.6) 0.900 (22.9) 1.075 (27.3) 1.100 (27.9) 1.100 (27.9) 1.562 (39.7) 0.875 (22.2) 1.562 (39.7) 0.350 (8.9) 1.062 (27.0) 1.562 (39.7) 0.600 (15.2) 0.875 (22.2) 1.562 (39.7) 2.200 (55.9) 2.500 (63.5) 3.700 (94) 3.350 (85.1) 3.500 (88.9) 2.800 (71.1) 3.350 (85.1) 2.300 (58.4) 3.400 (86.4) 6 4 6 4 4 3 3 2 3 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 B30-R6200 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 Fig. 1 2500 5000 2500 5000 2500 2300 5000 2500 2300 < >    ‹ˆ_ • Specially designed narrow-width continuous label for alignment on terminal blocks and patch panels • Highly unique adhesive and vinyl cloth construction gives excellent holding power and still allows for clean removal and reapplication Benchtop Printers Figure 1 Service temp: -40°F to 175°F Agency Approvals: ®    Fits Printer Model(s) Diagram Catalog # B# Color Label Width A Inch (mm) Roll Length B Feet (m) Web Width E Inch (mm) Labels Per Roll Rec. Ribbon BBP33 Only BBP33 Only Fig. 3 Fig. 3 B33C-312-498 B33C-375-498 B-498 B-498 White White 0.312 (7.9) 0.375 (9.5) 85 ft. (25.9m) 85 ft. (25.9m) 1.000 (25.4) 1.000 (25.4) 1 roll (cont.) 1 roll (cont.) B30-R6200 B30-R6200 1-888-272-3946 11b_BBP30-37_Materials.indd 405 BradyID.com/s35 B30 Series Figure 3 405 7/6/17 4:55 PM
B33-119-427 价格&库存
很抱歉,暂时无法提供与“B33-119-427”相匹配的价格&库存,您可以联系我们找货
B33-119-427
    • 1+1198.403051+155.78852
    库存:15
