DAT-42-292-2.5
DAT-42-292-2.5
    BRADY
DAT-42-292-2.5 数据手册
Dot Matrix Materials - Benchtops BradyID.com Dot Matrix / Laser / Ink Jet Wire & Cable Tags Non Adhesive Fig. D23 Fig. D26 Diagram Part Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Vertical Repeat C Inch (mm) Web Width D Inch (mm) Holes Per Tag Labels Labels Per Row Per Pkg D23 BT-109-WT-3060-1 B-109 Polyethylene White 3.000 (76.20) 6.000 (152.40) 6.000 (152.40) 4.000 (101.60) - 1 100 D23 BT-109-WT-3060-2 B-109 Polyethylene White 3.000 (76.20) 6.000 (152.40) 6.000 (152.40) 4.000 (101.60) - 2 100 D23 BT-109-WT-2037 B-109 Polyethylene White 3.750 (95.25) 2.000 (50.80) 2.000 (50.80) 4.750 (120.65) - 1 100 D23 BT-109-WT-2547 B-109 Polyethylene White 4.750 (120.65) 2.500 (63.50) 2.500 (63.50) 5.750 (146.05) - 1 100 D26 BT-508-WT-2050 B-508 Nomex White 2.000 (50.80) 0.500 (12.70) 0.500 (12.70) 3.000 (76.2) 4 1 2,500 D26 BT-508-WT-2075 B-508 Nomex White 2.000 (50.80) 0.750 (19.05) 0.750 (19.05) 3.000 (76.2) 6 1 2,500 D26 BT-508-YL-2050 B-508 Nomex Yellow 2.000 (50.80) 0.500 (12.70) 0.500 (12.70) 3.000 (76.2) 4 1 2,500 D26 BT-508-YL-2075 B-508 Nomex Yellow 2.000 (50.80) 0.750 (19.05) 0.750 (19.05) 3.000 (76.2) 6 1 2,500 BRADYWRAP™ Wire & Cable Tape Continuous Strip / Cut-To-Length Fig. D20 Dot Matrix - Benchtops Diagram Part Number B-# Material Color Label Width A Inch (mm) Label Height B Inch (mm) Web Width C Inch (mm) Labels Labels Per Row Per Pkg Max. Characters Across 5 CPI 10 CPI 17.1 CPI D20 RCM-637-1.0-WT B-637 Tedlar White 1.000 (25.40) 100 ft (30.48 m) 3.600 (91.44) 1 1 cont. 4 9 15 D20 RCM-637-1.5-WT B-637 Tedlar White 1.500 (38.10) 100 ft (30.48 m) 3.600 (91.44) 1 1 cont. 7 14 23 D20 RCM-330-2.0-WT B-330 Polyolefin White 2.000 (50.80) 100 ft (30.48 m) 3.600 (91.44) 1 1 cont. 9 19 32 D20 RCM-637-2.0-WT B-637 Tedlar White 2.000 (50.80) 100 ft (30.48 m) 3.600 (91.44) 1 1 cont. 9 19 32 D20 RCM-637-1.0-YL B-637 Tedlar Yellow 1.000 (25.40) 100 ft (30.48 m) 3.600 (91.44) 1 1 cont. 4 9 15 D20 RCM-637-1.5-YL B-637 Tedlar Yellow 1.500 (38.10) 100 ft (30.48 m) 3.600 (91.44) 1 1 cont. 7 14 23 D20 RCM-637-2.0-YL B-637 Tedlar Yellow 2.000 (50.80) 100 ft (30.48 m) 3.600 (91.44) 1 1 cont. 9 19 32 Self-Laminating Wire & Cable Markers Fig. D17 Diagram Material Label Color Width A Inch (mm) Label Height B Inch (mm) Print-Area C Inch (mm) Horizontal Repeat C Inch (mm) Vertical Repeat D Inch (mm) Web Width E Inch (mm) Labels Labels Per Per Row Pkg Part Number B-# D17 DAT-71-642-10 B-642 Polyvinylfluoride White 0.500 (12.7) 0.750 (19.05) 0.375 (9.53) 0.600 (15.24) 1.000 (25.40) 8.100 (205.74) 12 10,000 D17 * DAT-55-642-10 B-642 Polyvinylfluoride White 0.500 (12.7) 0.750 (19.05) 0.375 (9.53) 0.600 (15.24) 1.000 (25.40) 9.300 (236.22) 14 10,000 D17 DAT-52-642-10 B-642 Polyvinylfluoride White 0.800 (20.32) 1.437 (36.50) 0.500 (12.70) 0.900 (22.86) 1.500 (38.10) 6.300 (160.02) 6 10,000 D17 * DAT-41-292-1 B-292 Vinyl White 1.000 (25.40) 5.937 (150.80) 1.500 (38.10) 1.100 (27.94) 6.000 (152.40) 9.500 (241.30) 8 1,000 D17 * DAT-41-292-2.5 B-292 Vinyl White 1.000 (25.40) 5.937 (150.80) 1.500 (38.10) 1.100 (27.94) 6.000 (152.40) 9.500 (241.30) 8 2,500 D17 * DAT-42-292-1 B-292 Vinyl White 1.000 (25.40) 7.437 (188.90) 1.500 (38.10) 1.100 (27.94) 7.500 (190.50) 9.500 (241.30) 8 1,000 D17 * DAT-42-292-2.5 B-292 Vinyl White 1.000 (25.40) 7.437 (188.90) 1.500 (38.10) 1.100 (27.94) 7.500 (190.50) 9.500 (241.30) 8 2,500 D17 DAT-69-292-GY B-292 Vinyl Gray 1.000 (25.4) 5.937 (150.80) 1.500 (38.10) 1.100 (27.94) 6.000 (152.40) 8.400 (213.36) 7 2,500 D17 DAT-75-292-BL B-292 Vinyl Blue 2.000 (50.80) 5.937 (150.80) 1.500 (38.10) 2.100 (53.34) 6.000 (152.40) 7.000 (177.80) 3 2,500 D17 DAT-75-292-RD B-292 Vinyl Red 2.000 (50.80) 5.937 (150.80) 1.500 (38.10) 2.100 (53.34) 6.000 (152.40) 7.000 (177.80) 3 2,500 D17 DAT-69-292-YL B-292 Vinyl Yellow 1.000 (25.4) 5.937 (150.80) 1.500 (38.10) 1.100 (27.94) 6.000 (152.40) 8.400 (213.36) 7 2,500 D17 DAT-159-292-YL B-292 Vinyl Yellow 2.000 (50.80) 8.437 (214.30) 1.500 (38.10) 2.100 (53.34) 8.500 (215.90) 7.200 (182.88) 3 2,500 * Does not fit narrow carriage (80-column) printers. Full Material Properties on page 237. 212
DAT-42-292-2.5 价格&库存
很抱歉,暂时无法提供与“DAT-42-292-2.5”相匹配的价格&库存,您可以联系我们找货
DAT-42-292-2.5
