3PS-1000-2-WT-S
3PS-1000-2-WT-S
    BRADY
    Cable Markers Printable Heat Shrink Polyolefin White PermaSleeve® Roll
3PS-1000-2-WT-S 数据手册
HELP  888-250-3082 US - ENGLISH  0 SIGN IN  SEARCH  Printer Labels / Bradyprinter PR Plus Printer Labels / 3" Core Double Sided PermaSleeve Polyolefin Wire Marking Sleeves 3" Core Double Sided PermaSleeve Polyolefin Wire Marking Sleeves Part Number: 3PS-1000-2-WT-S Material: Polyolefin For Use with Printer: BRADY IP® Series Label Printer, BradyPrinter i5100, BradyPrinter i7100, BRADYPRINTER PR Plus Series Label Printer Material Number: B-342 Color: White Quantity per Roll: 100 ADD TO CART 1 Add To Favorites PEOPLE ALSO VIEWED OVERVIEW PermaSleeve® PS Heat-Shrink Polyolefin (B-342) wire marking sleeves combine speed, ease of use, and permanence to create long-lasting, high quality identification. 3:1 heat shrinkable sleeve fit snugly around wires for maximum insulation protection and permanent identification Fade-resistant and smudge-proof for superior aesthetic appearance Cold resistant and flame-retardant with an operating temperature of -67°F to 275°F (-55°C to 135°C) Meets SAE-AMS-DTL-23053/5C (Class 1), SAE-AS-81531, MIL-STD-202; RoHS Compliant; and UL  Recognized SPECIFICATIONS Material Number B-342 Diameter as Supplied 1 in Dimensions 1.66 in H UOM Roll Finish Matte Maximum Service Temperature °F 275 °F Maximum Wire Diameter 0.95 in Minimum Service Temperature °F -67 °F Minimum Wire Diameter 0.375 in Minimum Wire Gauge 2 AWG Printable Sides Double-Side Printable Product Number 130088 UPC 662820575658 Quantity per Roll 100 Quantity per Row 1 Recovered Diameter 0.375 in Roll Width 2 in Shrink Ratio 3:1 Sleeve Size 1 in Dia x 2 in W Sleeve Size(m) 25.4 mm Dia x 50.8 mm W Sleeve Width 2 in Applications Cable & Wire Marking Color White For Use with Printer BRADY IP® Series Label Printer, BradyPrinter i5100, BradyPrinter i7100, BRADYPRINTER PR Plus Series Label Printer Label/Media Format Roll Label Properties Heat Shrink Sleeves Material Polyolefin Material Properties Flame-retardant, Heat-Shrinkable Print Technology Thermal Transfer Resistance Properties Chemical-Resistant, Corrosion-Resistant, Humidity-Resistant, Smear-Resistant, UV-Resistant, Weather-Resistant Suggested Ribbon Series R2000, R4300, R4502S, R5000, R6600, R6700 Solutions Services Help Resources Floor Marking Guide Lockout Tagout Services Contact Us Find a Distributor GHS Label Compliance Arc Flash Services Knowledge Center Lockout Tagout Compliance Confined Space Services Printer Drivers & Firmware Design Custom Safety Signs Visual Workplace Services Brady Software Updates Hazcom GHS Services Safety Data Sheets Software Programming & Integration Technical Data Sheets Arc Flash Labeling Requirements Cable and Wire Label Options Product and Barcode Labeling Label Template & File Conversion Brand Protection Solutions Printer Use & Training Label Selection Tool WEEE-RoHS Compliance Product Certification Printer Registration Printer Selection Tool Digital Catalog Request a Catalog Interactive Facility Map EPA e-Manifest Update Printer Preventative Maintenance Toll and Custom Coating Authentication & Tracking Services Corporate Other BradyContact Brady (NYSE:BRC) is a Sites manufacturer of complete 6555 W. About Careers Distributor Good Hope Investors Portal Privacy Milwaukee, International Policy Sites Rd. WI 53223 Terms and Safety Phone: 888- Conditions Services & 250-3082 Terms of Software Use Smart ID ISO Brand Certificates Protection Solutions Hours: 7am6pm CT Monday Thursday; Friday 7am5pm CT solutions that identify and protect people, products and places. Brady’s products help customers increase safety, security, productivity and performance and include highperformance labels, signs, safety devices, printing systems and software. 2018 © Brady Worldwide, Inc.
3PS-1000-2-WT-S
物料型号:3PS-1000-2-WT-S 器件简介:PermaSleeve® PS Heat-Shrink Polyolefin (B-342) wire marking sleeves,结合速度、易用性和永久性,创造持久、高质量的标识。 引脚分配:无相关信息 参数特性: - 材料编号:B-342 - 直径:1英寸 - 尺寸:1.66英寸高 - 单位:卷 - 表面处理:哑光 - 最大工作温度:275°F - 最大线径:0.95英寸 - 最小工作温度:-67°F - 最小线径:0.375英寸 - 最小线规:2AWG - 可打印面:双面可打印 - 产品编号:130088 - UPC:662820575658 - 每卷数量:100 - 每行数量:1 - 收缩直径:0.375英寸 - 卷宽:2英寸 - 收缩比:3:1 - 套管尺寸:1英寸直径x2英寸宽 - 套管尺寸(毫米):25.4毫米直径x50.8毫米宽 - 套管宽度:2英寸 功能详解:适用于电缆和电线标识,耐褪色、耐污迹,具有化学抗性、耐腐蚀性、耐湿性、耐污迹、耐UV和耐候性。 应用信息:用于电缆和电线标识 封装信息:使用Brady IP®系列标签打印机、BradyPrinter i5100、BradyPrinter i7100、BRADYPRINTER PR Plus系列标签打印机。
3PS-1000-2-WT-S 价格&库存
很抱歉,暂时无法提供与“3PS-1000-2-WT-S”相匹配的价格&库存,您可以联系我们找货
