Technical Data Sheet
Compact Safety Padlocks
TDS No. LOTO9
Effective Date: 11/20/2012
Description:
Design
Compact, lightweight, and enhanced impact
resistance.
Superior corrosion and chemical resistance
Nonconductive, spark resistant lock body
Insulated key chamber protects workers from
shock when the key is inserted
Key won’t release until the padlock shackle is
securely closed
Material
Lock body made from Polyamide Nylon 66
Color: Lock Body
Black
Chemical
Green
Blue
Violet
Red
White
Yellow
Brown
Orange
Grey
Shackle made from Aluminum
Color: Shackle – Black
UL Rating UL 94 – HB (Plastic Components
Only)
Temperature Range
Service Temperature: 20° to 120°C (0° to
250°F)
Chemical Resistance
All approved chemicals listed are based on the
manufactures specified chemical resistance chart for
plastic material only.
Dimensions
“A”
“B”
“C”
“D”
“ØE”
1.26” [32mm]
1.38” [35mm]
0.63” [16mm]
1.00” [25.5mm]
1.50” [38mm]
2.00” [50mm]
3.00” [25.5mm]
ø0.19” [4.74]
Chemical
Nickel salt solns. (chloride,
sulfate)
Acetone
15 – 60
Ammonia soln.
15 – 30 Petroleum
°C
15 – 30
15 – 30
Ammonia soln.
48
Silicone oils
Fuel, engine: Gasoline (Leaded
& Unleaded)
48
Toluene
15 – 30
Fuel, Diesel
85
Water (including seawater)
15 – 30
Heptane
°C
Water (including seawater),
15 – 30
chlorinated (
很抱歉,暂时无法提供与“120886”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+993.172561+129.10922
