18551
18551
    BRADY
18551 数据手册
The NEW TLS 2200® Thermal Labeling System gives you even more power. The TLS 2200 ® printer features increased processing power and enhanced functionality! Version 4.0 TLS 2200® Version 4.0 printer delivers the power to create custom labels in seconds. The new TLS 2200 ® Thermal Labeling System v4.0 offers a rugged, portable, and easy-to-use labeling solution – now with even more features. With crisp, thermal-transfer quality printing and a variety of durable materials, you can create custom labels for the most demanding applications including product bar code ID, electrical and datacomm marking, laboratory ID, security ID, and more. Print labels faster Version 4.0 features increased processing speed with nearly 100% faster data processing. Clearer graphical display Even in low light conditions, the increased screen resolution and contrast make on-screen text easier to read. New Sleep Mode Extends battery life and increases productivity by allowing users to set the printer to “sleep” after 1, 3 or 5 minutes of non-use. More bar code symbologies Version 4.0 now includes Code 128, IFT 25, and Codabar. Rugged Industrial Design Tough, drop-tested construction PC connectivity With Brady LabelMark™ Labeling Software, users can design labels on a PC and print directly to a TLS 2200 printer. Table of Contents: TLS 2200® Thermal Labeling System 2-3 TLS 2200 and TLS-PC Link Thermal Labeling Systems Part Number: TLS2200 Printing Options and Font Sizing n 4 5 Labeling Software 6-7 Printing Applications 8-9 Materials Chart and Ribbon Cross-Reference Guide Printer (system includes hard case, R6210 ribbon, battery pack, battery charger, Quick Start Guide, manual, communications cable, test labels (PTL-19-423), one cleaning card) n n n n n 10 Label Ordering Guide 10-26 Label Product Charts n n n n n n n 27 More Brady Printers n n Prints over 500 labels between battery charges Weight 2.75 lbs (1.25 kg) Thermal transfer print mechanism 203 dpi (8 dots/mm) Labels up to 2" wide (50.8 mm) Print length up to 54" (1371 mm) FCC Class A approved Adjustable for 6 different widths of labels Built-in industrial label cutter Patent numbers D409,230; 5,918,989; 5,951,177; 6,113,293 and 6,142,686 Custom TrueType font Print width 1.81" (46 mm) Two line liquid crystal display (LCD) 16 characters wide Operating temperature range: 40ºF to 120ºF (4ºC to 49ºC) UL and CUL listed battery charger: 120 V/60 hz input 9 VDC 183 mA output 6 month warranty, extended to 12 months with online product registration TLS 2200 Thermal Labeling System Accessories Part TLS2200-AC TLS2200-BC TLS2200-BP TLS2200-DC TLS2200-HC TLSHM-QUICKCH TLS-AC-QC 2 Description AC adapter Battery charger Battery pack Dust cover Hard side carrying case Quick charger for battery TLS 2200 Printer, Quick Charger, and AC Adapter 1-888-272-3946 • www.bradyid.com/tls2200 Part TLS2200-SC TLS2200-CABLE TLS2200-UPDISKS TLS2200-UPKIT PCK-5 81701 Description Soft side users case Communications cable Upgrade disks (includes 3.5" disks) Upgrade kit (includes 3.5" disks and cables) Cleaning kit (includes 5 cleaning cards) USB to DB9 Serial Adapter Cable Make the connection to more powerful labeling options with the TLS-PC Link™ Printer. The TLS-PC Link ™ Thermal Labeling System is a rugged portable/desktop solution. Use the power of your PC for more versatile labeling options. Versatile label options Uses all of the available TLS 2200 printer materials and ribbons, including bulk roll material. Easy-to-use label design software Brady LabelMarkTM Labeling Software is included with your TLS-PC Link, and BradySoftTM 8 Label Design Software is also available for use with this system. WindowsTM driver included This driver allows you to easily print labels from either Brady labeling software solution. ™ ™ TLS-PC LINK Thermal Labeling System TLS-PC Link Thermal Labeling System Part Number: TLSPC Printer (system includes LabelMark™ Labeling Software, rechargeable battery pack, power supply/battery charger, R6210 ribbon, sample labels (PTL-19-423), Quick Start Guide, manual, communications cable, and Windows drivers) n n n n n n n Prints over 500 labels between battery charges Weight 2.50 lbs (1.14 kg) Thermal Transfer print mechanism 203 dpi (8 dots/mm) Labels up to 2" wide (50.8 mm) Print length up to 6" (152.4 mm) FCC Class A approved Adjustable for 6 different widths of labels n n n n n n Built-in industrial label cutter Patent numbers 5,918,989; 5,951,177; 6,113,293 and 6,142,686 Custom TrueType font Print width 1.81" (46 mm) Operating temperature range: 40ºF to 120ºF (4ºC to 49ºC) UL and CUL listed AC adapter/battery charger: 120 V/60 hz input 12 VDC 3000 mA output TLS-PC Link Thermal Labeling System Accessories Part TLSPC-AC TLSPC-BP TLSPC-CABLE PCK-5 Description Replacement power supply/battery charger Rechargeable battery pack Communications cable Cleaning kit (includes 5 cleaning cards) 1-888-272-3946 • www.bradyid.com/tls2200 3 Easily Create Your Own Custom Labels. TLS 2200® Thermal Labeling System Variable Font Sizes* Variable font sizes range from 1 (4 point) to 19 (72 point). The maximum font size available depends on factors such as label size, number of characters, number of lines, as well as font sizes in other lines. Autotext Sizing The TLS 2200 Thermal Labeling System uses an automatic font sizing feature called autotext sizing. As you enter characters on the LCD, it instantly reads your label style, selects the most suitable type size, and registers it for printing. Overriding Autotext If you wish to select a specific font size for your label, the autotext feature can easily be overridden on a line-by-line basis. Symbols Standard electrical and telecommunications symbols are included. Banner Printing Continuous tape available in many different sizes, colors, and materials. 4 1-888-272-3946 • www.bradyid.com/tls2200 * An alternative electrical/datacomm font size set (1/8", 3/16", 1/4", 3/8", 7/16", 1/2", 3/4", and 1.0") can be downloaded for free from the www.bradyid.com website. Expand Your Functionality LabelMark™ Labeling Software (included with TLS-PC Link™ Thermal Labeling System) LabelMark Labeling Software allows users to design, edit, and print their Brady labels. Brady LabelMark software is best suited for applications in telecomm, electrical, and industrial markets. Can also be used with TLS 2200 ® Thermal Labeling System. Easy to Use Graphical Interface Label Design n Option for line-edit or free-form mode for label design n Several common barcode symbologies available n Ability to import graphical images n ASCII and ODBC data import capabilities Label Editing Easy to use single screen editing n Multiple document interface for working with different labels at the same time n n Ability to flip/flop data on label (i.e. flip/flop “to”/“from” order) Label Printing n Works with all Brady media, stock and custom formats n Works with a variety of different printers to suit various applications n Direct printing to Brady’s TLS 2200 ® and TLS-PC Link™ printers BradySoft™ 8 Label Design Software With BradySoft 8 Label Design Software, you can create labels that help your organization manage assets and resources, control distribution channels and stock levels, track documents, or manage data records – all with one powerful labeling program. Design tools for fast label design No special training required with these intuitive, easy-to-use features: n Organize data from external data sources n Import data from multiple database connections n Switch from TrueType fonts to printer resident fonts For use with the TLS-PC Link System Don’t re-type — import for faster, more accurate labels Easily import information from spreadsheets and data tables right onto your labels with fewer errors. n Database Connection Wizard n Label Design Wizard that’s intuitive and easy to use n Database tables can be easily created, modified, or deleted n Database Manager Tool lets you print directly from the database n Label preview No-hassle, automated label printing BradySoft 8 Label Design Software makes label printing faster and easier with these flexible options: n Simplify printing with five different print dialog options n Customize parameters for exporting data n Print directly from “Find Record” results n Encode complicated labels for trouble-free printing 1-888-272-3946 • www.bradyid.com/tls2200 5 Printing Applications 6 PATCH PANEL WIRE AND CABLE WRAP AROUND LABELS FACE PLATE ID WIRE AND CABLE SELF-LAMINATING LABELS TERMINAL BLOCK WIRE AND CABLE SLEEVES DESI-STRIP INSERT FLAG LABELS 1-888-272-3946 • www.bradyid.com/tls2200 TAG PRINTING CIRCUIT BOARD & COMPONENT LABELING ELECTRICAL PANEL ID LABORATORY ID INDUSTRIAL BAR CODE LABELING SECURITY ID ASSET IDENTIFICATION CUSTOM LABELING 1-888-272-3946 • www.bradyid.com/tls2200 7 Materials and Ribbon Cross Reference Chart Brady Material Number Material Description Ribbon Color Finish Max. Service Temp. F°, (C°) Application Special Properties Agency Approval(s)/ Compliance B-109 BradyTag® Polyethylene Tag R4310, R6210 White Matte 120 (49) 30 days Wire & Cable Marking, Panel ID, Voice/Data ID Tear resistant, Excellent cold-weather performance B-145 Polyethylene Tag R6210 Gray Matte 212 (100) 30 days Voice/Data ID Tear resistant, 2-Side Printable B-321 BradySleeveTM Heat Shrink Polyolefin Sleeves R6210 White Matte 221 (105) 30 days Panel ID, Wire & Cable Marking Heat-shrinkable B-342 PermaSleeveTM Heat Shrink Polyolefin Sleeves R4310 White, Yellow Matte 267 (130) 30 days Wire & Cable Marking, Panel ID Heat-shrinkable, Self-Extinguishing B-351 Vinyl with permanent acrylic adhesive R6010, R6210 White Matte 212 (100) 30 days Tamper Indicating Fractures easily, prevents one-piece removal B-352 Vinyl with permanent acrylic adhesive R4410*, R6010 Silver Matte 212 (100) 30 days Tamper Indicating Fractures easily, prevents one-piece removal B-390 DuraSleeve® Polypropylene Inserts R6010 White Matte 212 (100) 1000 hrs. Wire & Cable Marking, Panel ID Rigid Inserts B-412 Polypropylene Tag R4310, R6210 White Matte 212 (100) 30 days Voice/Data ID PermaShield Polyester with permanent acrylic adhesive R4410*, R6010 White Gloss 212 (100) 30 days Circuit Board & Component ID Polyester with permanent acrylic adhesive R4410*, R6010, R6210 White B-424 PermaShieldTM Paper with permanent acrylic adhesive R4310 White Matte 122 (50) General & Industrial ID, Panel ID Good contrast and smear resistance B-425 Polypropylene with acrylic adhesive R4310, R6210 White Matte 248 (120) 5 mins. General & Industrial ID Excellent solvent resistance B-426 Polyimide with permanent adhesive R4310 Amber Matte 662 (350) 80 sec. Circuit Board & Component ID Withstands extremely high temperatures B-427 Self-laminating vinyl with permanent acrylic adhesive R4310, R6210 White and various colors Matte 158 (70) 30 days General & Industrial ID, Laboratory ID, Panel ID Self-Laminating, SelfExtinguishing, Excellent water & oil resistance, Excellent abrasion and smudge resistance Silver Matte B-422 B-423 TM PermaShieldTM Polyester with permanent acrylic adhesive R4310 Polyester with permanent acrylic adhesive R4410*, R6010 Polyester with permanent acrylic adhesive R4410*, R6010 Polyester with permanent acrylic adhesive R6010 B-437 Tedlar® with permanent acrylic adhesive R4310, R6210 B-439 Vinyl with permanent acrylic adhesive R6010 B-449 Polypropylene with removable acrylic adhesive R4310, R6210 B-428 B-430 B-432 B-435 Clear Clear Silver Gloss Gloss Gloss Gloss 248 (120) 30 days 176 (80) 30 days 212 (100) 30 days 212 (100) 30 days 194 (90) 30 days ® Circuit Board & Component ID, Panel ID ® Circuit Board & Component ID, Panel ID General & Industrial ID ® ® ® Translucent, High adhesion General & Industrial ID, Voice/Data ID, Panel ID High adhesion General & Industrial ID, Panel ID Excellent solvent resistance ® ® White, Yellow Matte 275 (135) 30 days Circuit Board & Component ID, Panel ID Self-Extinguishing White and various colors Matte 104 (40) 30 days General & Industrial ID, Laboratory ID, Panel ID, Voice/Data ID Various colors available White Matte 194 (90) 30 days Laboratory ID Ideal for temporary labeling applications ® continued on page 9 ® These materials have static dissipative adhesives. These materials are AGA approved. These materials are UL approved. These materials are Halogen-Free (DIN VDE 0472/parts 815) These materials are CSA approved. 8 1-888-272-3946 • www.bradyid.com/tls2200 Items in color red are acceptable ribbons for use with respective materials *R4410 is available in blue, red, and white. Materials and Ribbon Cross-Reference Chart Brady Material Number B-451 Material Description Vinyl with permanent acrylic adhesive Ribbon R4310 Color Finish Max. Service Temp. F°, (C°) Application Special Properties White/ Translucent Matte 158 (70) 30 days General & Industrial ID, Panel ID, Voice/Data ID, Wire & Cable Marking Self-Laminating, SelfExtinguishing, Excellent water & oil resistance, Excellent abrasion and smudge resistance Circuit Board & Component ID Good contrast and smear resistance Gloss 662 (350) 80 sec. Polyimide with permanent acrylic adhesive R6010 Polyester with permanent acrylic adhesive R4410*, R6010 B-461 Self-laminating polyester film with permanent acrylic adhesive R4310 White/ Translucent, Yellow Matte 212 (100) 30 days Laboratory ID Self-Laminating, Excellent abrasion and smudge resistance B-473 Polyester with permanent acrylic adhesive R6010 White, Yellow Gloss 248 (120) 30 days Circuit Board & Component ID, Panel ID Static dissipative adhesive & liner B-477 Polyimide with static dissipative permanent acrylic adhesive R6010 White Gloss 662 (350) 80 sec. Circuit Board & Component ID Static Dissipative Adhesive & Liner Polyimide with static dissipative permanent acrylic adhesive R6010 Circuit Board & Component ID Static dissipative adhesive & liner, Low profile Polyimide with static dissipative permanent acrylic adhesive R6010 Circuit Board & Component ID Static dissipative adhesive & liner, Low profile (1 mil) Polyester with permanent rubber adhesive R4410*, R6010 Panel ID, Voice/Data ID Ultra-aggressive adhesive, Designed for powder coated surfaces Polyester with permanent rubber adhesive R4310, R6010 B-488 Polyester with permanent acrylic adhesive R4310, R6010 White Matte 320 (160) 30 days General & Industrial ID, Laboratory ID, Panel ID B-489 Polyester with permanent rubber adhesive R4310, R6010 White Matte 248 (120) 30 days General & Industrial ID, Panel ID Ultra-aggressive adhesive, Designed for powder coated surfaces FreezerBondzTM Polyester with permanent acrylic adhesive R4310, R6210 Laboratory ID Can be applied to frozen surfaces including glass and polypropylene stored in liquid nitrogen Polyethylene Napthalate with permanent adhesive R6010 Vinyl Cloth with repositionable rubber based adhesive R6210, R4310, R6010 White Nylon Cloth with permanent acrylic pressure sensitive adhesive R4310, R6010, R6210 B-642 Tedlar® with permanent acrylic adhesive B-7546 Tamper evident polyester B-457 B-459 B-478 B-479 B-483 B-486 B-490 B-495 B-498 B-499 White White White White Gloss Matte Gloss Matte Matte Gloss 662 (350) 80 sec. 662 (350) 80 sec. 248 (120) 30 days 248 (120) 30 days 266 (130) 30 days 464 (240) 5 min. General & Industrial ID, Panel ID Circuit Board & Component ID Good contrast and smear resistance Circuit Board & Component ID, Panel ID Repositionable General & Industrial ID, Panel ID Low profile, High adhesion R4310, R6210 White Matte 275 (135) 30 days Panel ID, Voice/Data ID, Wire & Cable Marking Self-Extinguishing, Self-Laminating R6010 White Gloss 175 (80) 30 days Tamper Indicating Leaves “void” footprint when removed R6010 Silver White ® ® ® ® ® ® ® 175 (80) 30 days General & Industrial ID, Tamper Indicating Leaves “void” footprint when removed Matte 212 (100) 30 days Tamper Indicating Leaves “void” footprint when removed 194 (90) 30 days ® ® Gloss Gloss ® Ultra-aggressive adhesive, Designed for powder coated surfaces 174 (90) 30 days R6010, R4410* ® ® Matte Tamper evident polyester ® Circuit Board & Component ID White, Yellow B-7576 ® ® General & Industrial ID ® These materials have static dissipative adhesives. These materials are AGA approved. These materials are UL approved. These materials are Halogen-Free (DIN VDE 0472/parts 815) These materials are CSA approved. 212 (100) 30 days 175 (80) 30 days R4410*, R6010 ® Silver Matte SemiGloss Tamper evident polyester Polypropylene with permanent acrylic adhesive White White B-7566 B-8425 White Agency Approval(s)/ Compliance Items in color red are acceptable ribbons for use with respective materials *R4410 is available in blue, red, and white. 1-888-272-3946 • www.bradyid.com/tls2200 9 Label Ordering Guide Wire and Cable Labels Wire and Cable Labels Page 10 11-12 13 13 14 14 14 14 Ribbon Chart Description Pre-Cut General Labels Self-Laminating Wire and Cable Labels Continuous Tapes Specialty Markers – PermaSleeve Specialty Markers – DuraSleeve Specialty Markers – BradySleeve Specialty Markers – BradyTag Specialty Markers – Terminal Block Markers Part # R4310 R6010 R6210 R4410-BL R4410-RD R4410-WT General Purpose Labels 15-16 16 16 17 17 17-18 Description R4310 Black Ribbon R6010 Black Ribbon R6210 Black Ribbon R4410 Blue Ribbon R4410 Red Ribbon R4410 White Ribbon General Pre-Cut Labels PermaShield Labels Pre-Printed Labels Black Bordered Labels Tamper Indicating Labels Continuous Tapes Circuit Board and Component Labels 18-20 20-21 22 Pre-Cut to Size Labels Polyimide Labels Tedlar Labels Datacomm Labels 22-23 23 24 24 25 25 Communications Labeling Patch Panel Labels Patch Panel Continuous Tapes and Strips Power and Ground Cable Labels Workstation Labels Fiber Optic Labels/Flags Laboratory Labels 26 26 FreezerBondz™ Labels General Self-Laminating Labels for Vials Tubes, Straws and More Catalog numbers beginning with "B" indicate bulk roll. Wire and Cable Marking Pre-Cut General Labels Catalog Number Diagram Permanent Adhesive (B-499) PTL-28-499 PTL-29-499 PTL-30-499 PTL-31-499 PTL-16-499 PTL-18-499 PTL-19-499 PTL-11-499 BPTL-11-499 PTL-7-499 PTL-21-499 PTL-23-499 Removable Adhesive (B-498) PTL-28-498 PTL-29-498 BPTL-29-498 PTL-30-498 PTL-31-498 PTL-32-498 PTL-16-498 PTL-18-498 BPTL-18-498 PTL-19-498 BPTL-19-498 PTL-17-498 PTL-10-498 PTL-11-498 BPTL-11-498 PTL-7-498 PTL-15-498 PTL-21-498 PTL-23-498 PTL-33-498 PTL-34-498 10 1-888-272-3946 • Labels per Roll Dimensions - inches A B Dimensions - mm A B Wire Gauge 750 500 250 250 500 250 250 500 5000 500 100 100 0.250 0.500 0.750 1.000 0.375 0.750 1.000 0.500 0.500 0.500 1.000 1.000 1.500 1.500 1.500 1.500 1.000 1.000 1.000 0.750 0.750 0.500 2.500 4.000 6.35 12.70 19.05 25.40 9.53 19.05 25.40 12.70 12.70 12.70 25.40 25.40 38.10 38.10 38.10 38.10 25.40 25.40 25.40 19.05 19.05 12.70 63.50 101.60 10 to 4 10 to 4 10 to 4 10 to 4 12 to 10 12 to 10 12 to 10 16 to 10 16 to 10 22 to 16 Cables Cables 750 500 5000 250 250 250 500 250 2500 250 2500 500 750 500 5000 500 750 100 100 100 50 0.250 0.500 0.500 0.750 1.000 1.500 0.375 0.750 0.750 1.000 1.000 1.000 0.250 0.500 0.500 0.500 1.000 1.000 1.000 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.000 1.000 1.000 1.000 1.000 0.500 0.750 0.750 0.750 0.500 0.275 2.500 4.000 4.000 6.000 6.35 12.70 12.70 19.05 25.40 38.10 9.53 19.05 19.05 25.40 25.40 25.40 6.35 12.70 12.70 12.70 25.40 25.40 25.40 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 25.40 25.40 25.40 25.40 25.40 12.70 19.05 19.05 19.05 12.70 6.99 63.50 101.60 101.60 152.40 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 16 to 10 16 to 10 16 to 10 22 to 16 22 to 16 Cables Cables Cables Cables www.bradyid.com/tls2200 Length 75ft (22.9m) 75ft (22.9m) 75ft (22.9m) 75ft (22.9m) 75ft (22.9m) 75ft (22.9m) Wire and Cable Marking Self-Laminating Wire and Cable Labels (B-427) Diagram = Catalog Number PTL-102-427 PTL-18-427 BPTL-18-427 PTL-18-427-YL PTL-28-427 PTL-28-427-BL PTL-28-427-BR PTL-28-427-GR PTL-28-427-GY PTL-28-427-OR PTL-28-427-PL PTL-28-427-RD PTL-28-427-YL PTL-29-427 BPTL-29-427 PTL-29-427-BL PTL-29-427-BR PTL-29-427-GR PTL-29-427-GY PTL-29-427-OR PTL-29-427-PL PTL-29-427-RD PTL-29-427-YL PTL-30-427 BPTL-30-427 PTL-30-427-BL PTL-30-427-BR PTL-30-427-GR PTL-30-427-GY PTL-30-427-OR PTL-30-427-PL PTL-30-427-RD PTL-30-427-YL PTL-103-427 PTL-31-427 BPTL-31-427 PTL-31-427-BL PTL-31-427-BR PTL-31-427-GR PTL-31-427-GY PTL-31-427-OR PTL-31-427-PL PTL-31-427-RD PTL-31-427-YL PTL-31-642 PTL-32-427 BPTL-32-427 PTL-32-427-BL PTL-32-427-BR PTL-32-427-GR PTL-32-427-GY PTL-32-427-OR PTL-32-427-PL PTL-32-427-RD PTL-32-427-YL PTL-88-427 PTL-107-427 BPTL-107-427 PTL-17-427 BPTL-17-427 PTL-17-427-YL PTL-19-427 BPTL-19-427 Labels per Roll Color A 250 250 2500 250 750 750 750 750 750 750 750 750 750 500 5000 500 500 500 500 500 500 500 500 250 2500 250 250 250 250 250 250 250 250 250 250 2500 250 250 250 250 250 250 250 250 250 250 1000 250 250 250 250 250 250 250 250 250 100 1000 500 5000 500 250 2500 White White White Yellow White Blue Brown Green Gray Orange Purple Red Yellow White White Blue Brown Green Gray Orange Purple Red Yellow White White Blue Brown Green Gray Orange Purple Red Yellow White White White Blue Brown Green Gray Orange Purple Red Yellow White White White Blue Brown Green Gray Orange Purple Red Yellow White White White White White Yellow White White 0.500 0.750 0.750 0.750 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.750 0.750 0.750 0.750 0.750 0.750 0.750 0.750 0.750 0.750 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.750 2.000 2.000 0.500 0.500 0.500 1.000 1.000 Dimensions - inches B 1.250 1.000 1.000 1.000 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.250 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.000 1.000 1.000 1.000 1.000 C A 0.375 0.375 0.375 0.375 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.375 0.375 0.375 0.375 0.375 12.70 19.05 19.05 19.05 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 19.05 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 44.45 50.80 50.80 12.70 12.70 12.70 25.40 25.40 Dimensions - mm B C 31.75 25.40 25.40 25.40 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 31.75 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 25.40 25.40 25.40 25.40 25.40 Wire Gauge 9.53 9.53 9.53 9.53 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 9.53 9.53 9.53 9.53 9.53 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 10 to 4 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 continued on page 12 Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. 1-888-272-3946 • www.bradyid.com/tls2200 11 Wire and Cable Marking Self-Laminating Wire and Cable Labels (B-427) Diagram = Catalog Number PTL-19-427-BL PTL-19-427-BR PTL-19-427-GR PTL-19-427-GY PTL-19-427-OR PTL-19-427-PL PTL-19-427-RD PTL-19-427-YL PTL-19-642 PTL-104-427 PTL-87-427 PTL-10-427 PTL-10-427-YL PTL-11-427 BPTL-11-427 PTL-11-427-YL PTL-96-427 PTL-21-427 BPTL-21-427 PTL-21-427-BL PTL-21-427-BR PTL-21-427-GR PTL-21-427-GY PTL-21-427-OR PTL-21-427-PL PTL-21-427-RD PTL-21-427-YL PTL-21-642 PTL-157-427 PTL-23-427 BPTL-23-427 PTL-23-427-BL PTL-23-427-BR PTL-23-427-GR PTL-23-427-GY PTL-23-427-OR PTL-23-427-PL PTL-23-427-RD PTL-23-427-YL PTL-33-427 BPTL-33-427 PTL-33-427-BL PTL-33-427-BR PTL-33-427-GR PTL-33-427-GY PTL-33-427-OR PTL-33-427-PL PTL-33-427-RD PTL-33-427-YL PTL-66-427 PTL-77-461 PTL-109-427 BPTL-109-427 PTL-34-427 BPTL-34-427 PTL-34-427-BL PTL-34-427-BR PTL-34-427-GR PTL-34-427-GY PTL-34-427-OR PTL-34-427-PL PTL-34-427-RD PTL-34-427-YL 12 Labels per Roll 250 250 250 250 250 250 250 250 250 250 250 750 750 500 5000 500 250 100 1000 100 100 100 100 100 100 100 100 100 100 100 1000 100 100 100 100 100 100 100 100 100 500 100 100 100 100 100 100 100 100 100 100 100 500 50 500 50 50 50 50 50 50 50 50 1-888-272-3946 • Color Blue Brown Green Gray Orange Purple Red Yellow White White White White Yellow White White Yellow White White White Blue Brown Green Gray Orange Purple Red Yellow White White White White Blue Brown Green Gray Orange Purple Red Yellow White White Blue Brown Green Gray Orange Purple Red Yellow White White White White White White Blue Brown Green Gray Orange Purple Red Yellow A 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.500 1.750 0.250 0.250 0.500 0.500 0.500 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.500 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.938 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 Dimensions - inches B 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 0.750 0.750 0.750 0.750 0.750 0.750 2.500 2.500 2.500 2.500 2.500 2.500 2.500 2.500 2.500 2.500 2.500 2.500 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 3.150 3.500 4.000 4.000 6.000 6.000 6.000 6.000 6.000 6.000 6.000 6.000 6.000 6.000 www.bradyid.com/tls2200 C 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.750 0.750 0.750 0.750 0.750 0.750 0.750 0.750 0.750 0.750 0.750 0.750 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.250 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 continued from page 11 A 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 38.10 44.45 6.35 6.35 12.70 12.70 12.70 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 38.10 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 49.23 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 Dimensions - mm B C 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 19.05 9.53 19.05 9.53 19.05 9.53 19.05 9.53 19.05 9.53 19.05 9.53 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 63.50 19.05 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 101.60 25.40 80.00 25.40 88.90 31.75 101.60 38.10 101.60 38.10 152.40 38.10 152.40 38.10 152.40 38.10 152.40 38.10 152.40 38.10 152.40 38.10 152.40 38.10 152.40 38.10 152.40 38.10 152.40 38.10 Wire Gauge 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 12 to 10 16 to 10 16 to 10 16 to 10 16 to 10 16 to 10 16 to 10 Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Cables Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. Wire and Cable Marking Continuous Tapes (B-437) Catalog Number Diagram PTLCM-41-437W PTLCM-41-437Y PTL-8-498 PTL-106-427 Material Color B-437 B-437 B-437 B-437 White Yellow White White/Translucent Dimensions - inches A B 1.500 1.500 0.500 50 ft. Write-On Width - inches C 50 ft. 50 ft. 30 ft. 1.500 N/A N/A N/A 0.500 Dimensions - mm A B 38.10 38.10 12.70 15.24 m Write-On Width - mm C 15.24 m 15.24 m 9.14 m 38.10 N/A N/A N/A 12.70 Specialty Markers: PermaSleeve™ Heat-Shrink Sleeve Markers (B-342) Diagram = Catalog Number Sleeves per Roll 1.015” Marker Width, White 3:1 Shrink Ratio PSPT-094-1WT 100 BPSPT-094-1WT 2500 PSPT-125-1WT 100 BPSPT-125-1WT 1000 PSPT-187-1WT 100 BPSPT-187-1WT 1000 PSPT-250-1WT 100 BPSPT-250-1WT 1000 PSPT-375-1WT 100 BPSPT-375-1WT 1000 PSPT-500-1WT 100 BPSPT-500-1WT 1000 PSPT-1000-1WT 50 Yellow 3:1 Shrink Ratio PSPT-094-1YL 100 PSPT-125-1YL 100 PSPT-187-1YL 100 PSPT-250-1YL 100 PSPT-375-1YL 100 PSPT-500-1YL 100 PSPT-1000-1YL 50 1.765" Marker Width, White 3:1 Shrink Ratio PSPT-094-175WT 100 BPSPT-094-175WT 2500 PSPT-125-175WT 100 BPSPT-125-175WT 1000 PSPT-187-175WT 100 BPSPT-187-175WT 1000 PSPT-250-175WT 100 BPSPT-250-175WT 1000 PSPT-375-175WT 100 BPSPT-375-175WT 1000 PSPT-500-175WT 100 BPSPT-500-175WT 1000 PSPT-1000-175WT 50 BPSPT-1000-175WT 500 Yellow 3:1 Shrink Ratio PSPT-094-175YL 100 PSPT-125-175YL 100 PSPT-187-175YL 100 PSPT-250-175YL 100 PSPT-375-175YL 100 PSPT-500-175YL 100 PSPT-1000-175YL 50 A Dimensions - inches B A Dimensions - mm B Approx. Wire Gauge 1.015 1.015 1.015 1.015 1.015 1.015 1.015 1.015 1.015 1.015 1.015 1.015 1.015 0.182 0.182 0.235 0.235 0.335 0.335 0.439 0.439 0.645 0.645 0.851 0.851 1.660 25.78 25.78 25.78 25.78 25.78 25.78 25.78 25.78 25.78 25.78 25.78 25.78 25.78 4.62 4.62 5.96 5.96 8.50 8.50 11.15 11.15 16.38 16.38 21.61 21.61 42.16 28-18 28-18 22-16 22-16 18-12 18-12 16-10 16-10 12-6 12-6 8-1 8-1 1-500 1.015 1.015 1.015 1.015 1.015 1.015 1.015 0.182 0.235 0.335 0.439 0.645 0.851 1.660 25.78 25.78 25.78 25.78 25.78 25.78 25.78 4.62 5.96 8.50 11.15 16.38 21.61 42.16 28-18 22-16 18-12 16-10 12-6 8-1 1-500 1.765 1.765 1.765 1.765 1.765 1.765 1.765 1.765 1.765 1.765 1.765 1.765 1.765 1.765 0.182 0.182 0.235 0.235 0.335 0.335 0.439 0.439 0.645 0.645 0.851 0.851 1.660 1.660 44.83 44.83 44.83 44.83 44.83 44.83 44.83 44.83 44.83 44.83 44.83 44.83 44.83 44.83 4.62 4.62 5.96 5.96 8.50 8.50 11.15 11.15 16.38 16.38 21.61 21.61 42.16 42.16 28-18 28-18 22-16 22-16 18-12 18-12 16-10 16-10 12-6 12-6 8-1 8-1 1-500 1-500 1.765 1.765 1.765 1.765 1.765 1.765 1.765 0.182 0.235 0.335 0.439 0.645 0.851 1.660 44.83 44.83 44.83 44.83 44.83 44.83 44.83 4.62 5.96 8.50 11.15 16.38 21.61 42.16 28-18 22-16 18-12 16-10 12-6 8-1 1-500 1-888-272-3946 • www.bradyid.com/tls2200 13 Wire and Cable Marking Specialty Markers: DuraSleeve® Wire Marker Inserts (B-390) Diagram = Catalog Number Sleeves per Roll A Dimensions - inches B A Dimensions - mm B PTDS-15-390 BPTDS-15-390 PTDS-30-390 BPTDS-30-390 300 3000 300 3000 0.590 0.590 1.181 1.181 0.163 0.163 0.163 0.163 15.00 15.00 30.00 30.00 4.14 4.14 4.14 4.14 Specialty Markers: BradySleeve™ Heat-Shrink Sleeve Markers (B-321) Diagram = Catalog Number 0.450" Sleeve Width PTS-0.45-350-321 PTS-0.45-500-321 0.950" Sleeve Width PTS-0.95-350-321 PTS-0.95-500-321 PTS-0.95-750-321 PTS-0.95-1000-321 1.900" Sleeve Width PTS-1.90-350-321 PTS-1.90-500-321 PTS-1.90-750-321 PTS-1.90-1000-321 Sleeve Dimensions Dimensions - inches Sleeve Dimensions Dimensions - mm A B Sleeves per Roll A B Wire Gauge 500 500 0.450 0.450 0.350 0.500 11.43 11.43 8.89 12.70 16-10 10-8 500 500 250 250 0.950 0.950 0.950 0.950 0.350 0.500 0.750 1.000 24.13 24.13 24.13 24.13 8.89 12.70 19.05 25.40 16-10 10-8 4-2 1-00 500 500 250 250 1.900 1.900 1.900 1.900 0.350 0.500 0.750 1.000 48.26 48.26 48.26 48.26 8.89 12.70 19.05 25.40 16-10 10-8 4-2 1-00 Specialty Markers: BradyTag® Tear Resistant Markers (B-109) Catalog Number PTL-12-109 BPTL-12-109 PTL-36-109 Diagram Tags per Roll 100 1000 250 Dimensions - inches A B 3.000 0.750 3.000 0.750 1.125 1.750 Dimensions - mm A 76.20 76.20 28.57 B 19.05 19.05 44.45 Specialty Markers: Terminal Block Repositionable Markers (B-498) Diagram = Catalog Number PTLTB-498-240 BPTLTB-498-240 PTLTB-498-318 BPTLTB-498-318 PTLTB-498-375 BPTLTB-498-375 14 1-888-272-3946 Roll Dimensions - inches A B 0.240 30 ft. 0.240 275 ft. 0.318 30 ft. 0.318 275 ft. 0.375 30 ft. 0.375 275 ft. • www.bradyid.com/tls2200 Roll Dimensions - mm A B 6.09 9.10 m 6.09 83.82 m 8.07 9.10 m 8.07 83.82 m 9.52 9.10 m 9.52 83.82 m Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. General Purpose Labels General Pre-Cut Labels Catalog Number PTL-82-499 PTL-82-499YL PTL-83-499 PTL-83-499YL PTL-7-432 PTL-10-425 PTL-10-432 PTL-10-8425 PTL-11-432 PTL-80-424 PTL-84-499 PTL-16-435 PTL-16-483 PTL-16-486 PTL-16-489 PTL-17-432 PTL-17-435 PTL-17-449 PTL-17-483 PTL-17-486 PTL-17-489 PTL-19-435 PTL-19-483 PTL-19-486 PTL-19-489 PTL-105-427-AW PTL-112-490 PTL-65-483 PTL-29-435 PTL-29-483 PTL-29-486 PTL-29-489 PTL-30-427-AW PTL-30-435 PTL-30-483 PTL-30-486 PTL-30-489 PTL-31-435 PTL-31-483 PTL-31-486 PTL-31-489 PTL-32-435 PTL-32-483 PTL-32-486 PTL-32-489 PTL-113-490 PTL-114-490 PTL-76-490 PTL-81-499 PTL-78-427-AW PTL-78-490 PTL-61-483 PTL-78-499 PTL-20-424 BPTL-20-424 Diagram Labels per Roll 500 500 500 500 500 750 750 750 500 250 500 500 500 500 500 500 500 500 500 500 500 250 250 250 250 750 500 250 500 500 500 500 250 250 250 250 250 250 250 250 250 250 250 250 250 100 100 250 750 250 250 100 250 100 1000 Material B-499 B-499 B-499 B-499 B-432 B-425 B-432 8-425 B-432 B-424 B-499 B-435 B-483 B-486 B-489 B-432 B-435 B-449 B-483 B-486 B-489 B-435 B-483 B-486 B-489 B-427 B-490 B-483 B-435 B-483 B-486 B-489 B-427 B-435 B-483 B-486 B-489 B-435 B-483 B-486 B-489 B-435 B-483 B-486 B-489 B-490 B-490 B-490 B-499 B-427 B-490 B-483 B-499 B-424 B-424 Color White Yellow White Yellow Clear White Clear White Clear White White Silver White Silver White Clear Silver White White White White Silver White Silver White White White White Silver White Silver White White Silver White Silver White Silver White Silver White Silver White Silver White White White White Yellow White White White White White White Dimensions - inches A B 0.000 0.375 Diameter 0.000 0.375 Diameter 0.000 0.500 Diameter 0.000 0.500 Diameter 0.500 0.500 0.750 0.250 0.750 0.250 0.750 0.250 0.750 0.500 0.750 0.900 0.900 0.500 1.000 0.375 1.000 0.375 1.000 0.375 1.000 0.375 1.000 0.500 1.000 0.500 1.000 0.500 1.000 0.500 1.000 0.500 1.000 0.500 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.100 0.250 1.250 0.375 1.375 1.000 1.500 0.500 1.500 0.500 1.500 0.500 1.500 0.500 1.500 0.750 1.500 0.750 1.500 0.750 1.500 0.750 1.500 0.750 1.500 1.000 1.500 1.000 1.500 1.000 1.500 1.000 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 2.200 1.500 3.875 1.625 0.600 1.900 0.250 1.900 1.000 1.900 1.000 2.000 0.500 1.900 1.000 2.000 1.000 2.000 1.000 Dimensions - mm A B 0.00 9.53 Diameter 0.00 9.53 Diameter 0.00 12.70 Diameter 0.00 12.70 Diameter 12.70 12.70 19.05 6.35 19.05 6.35 19.05 6.35 19.05 12.70 19.05 22.86 22.86 12.70 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 12.70 25.40 12.70 25.40 12.70 25.40 12.70 25.40 12.70 25.40 12.70 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 27.94 6.35 31.75 9.53 34.93 25.40 38.10 12.70 38.10 12.70 38.10 12.70 38.10 12.70 38.10 19.05 38.10 19.05 38.10 19.05 38.10 19.05 38.10 19.05 38.10 25.40 38.10 25.40 38.10 25.40 38.10 25.40 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 55.88 38.10 98.43 41.28 15.24 48.26 6.35 48.26 25.40 48.26 25.40 50.80 12.70 48.26 25.40 50.80 25.40 50.80 25.40 continued on page16 1-888-272-3946 • www.bradyid.com/tls2200 15 General Purpose Labels General Pre-Cut Labels Catalog Number PTL-20-435 PTL-20-483 PTL-20-486 PTL-20-489 PTL-22-424 PTL-37-424 PTL-37-435 PTL-37-483 PTL-37-486 PTL-37-489 PTL-62-483 PTL-23-483 PTL-38-424 PTL-38-435 PTL-38-483 PTL-38-486 PTL-38-489 PTL-63-483 Diagram continued from page 15 Labels per Roll 100 100 100 100 100 100 100 100 100 100 50 100 100 100 100 100 100 50 Material B-435 B-483 B-486 B-489 B-424 B-424 B-435 B-483 B-486 B-489 B-483 B-483 B-424 B-435 B-486 B-486 B-489 B-483 Color Silver White Silver White White White Silver White Silver White White White White Silver White Silver White White Dimensions - inches A B 2.000 1.000 2.000 1.000 2.000 1.000 2.000 1.000 3.000 1.000 3.000 1.900 3.000 1.900 3.000 1.900 3.000 1.900 3.000 1.900 4.000 0.750 4.000 1.000 4.000 1.900 4.000 1.900 4.000 1.900 4.000 1.900 4.000 1.900 8.000 0.750 Dimensions - mm A B 50.80 25.40 50.80 25.40 50.80 25.40 50.80 25.40 76.20 25.40 76.20 48.26 76.20 48.26 76.20 48.26 76.20 48.26 76.20 48.26 101.60 19.05 101.60 25.40 101.60 48.26 101.60 48.26 101.60 48.26 101.60 48.26 101.60 48.26 203.20 19.05 PermaShield™ Labels with Overlaminate Diagram = Catalog Number PTPSL-17-428 PTPSL-17-424 PTPSL-17-422 PTPSL-20-428 PTPSL-20-424 PTPSL-20-422 PTPSL-26-428 PTPSL-26-422 PTPSL-50-428 PTPSL-50-422 Labels per Roll 500 500 500 100 100 100 100 100 100 100 Material B-428 B-424 B-422 B-428 B-424 B-422 B-428 B-422 B-428 B-422 Color Silver White White Silver White White Silver White Silver White Dimensions - inches Label Overlaminate A B C D 1.000 0.500 1.250 0.750 1.000 0.500 1.250 0.750 1.000 0.500 1.250 0.750 2.000 1.000 2.250 1.250 2.000 1.000 2.250 1.250 2.000 1.000 2.250 1.250 2.750 1.250 3.000 1.500 2.750 1.250 3.000 1.500 3.000 1.650 3.250 1.900 3.000 1.650 3.250 1.900 Dimensions - mm Label Overlaminate A B C D 25.40 12.70 31.75 19.05 25.40 12.70 31.75 19.05 25.40 12.70 31.75 19.05 50.80 25.40 57.15 31.75 50.80 25.40 57.15 31.75 50.80 25.40 57.15 31.75 69.85 31.75 76.20 38.10 69.85 31.75 76.20 38.10 76.20 41.91 82.55 48.26 76.20 41.91 82.55 48.26 Pre-Printed Labels Catalog Number PTLSL-17-473 PTL-30-423-CALI PTL-30-428-CALI PTL-30-423-TEST PTL-30-428-TEST PTL-30-423-INSP PTL-30-428-INSP PTL-35-422-PROP PTL-35-423-PROP PTL-35-428-PROP PTL-35-435-PROP 16 1-888-272-3946 Diagram • Material B-473 B-423 B-428 B-423 B-428 B-423 B-428 B-422 B-423 B-428 B-435 Labels per Roll 500 250 250 250 250 250 250 250 250 250 250 www.bradyid.com/tls2200 Dimensions - inches A B 1.000 0.500 1.500 0.750 1.500 0.750 1.500 0.750 1.500 0.750 1.500 0.750 1.500 0.750 1.630 0.750 1.630 0.750 1.630 0.750 1.630 0.750 Dimensions - mm A B 25.40 12.70 38.10 19.05 38.10 19.05 38.10 19.05 38.10 19.05 38.10 19.05 38.10 19.05 41.40 19.05 41.40 19.05 41.40 19.05 41.40 19.05 Pre-Printed Legend Description STATIC SENSITIVE CALIBRATION CALIBRATION TESTED TESTED INSPECTED BY INSPECTED BY PROPERTY TAG PROPERTY TAG PROPERTY TAG PROPERTY TAG Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. General Purpose Labels Black Bordered Labels Diagram = Catalog Number PTL-24-423-BK PTL-24-428-BK PTL-24-483-BK PTL-24-486-BK Material B-423 B-428 B-483 B-486 Labels per Roll 500 500 500 500 Color White Silver White Silver Dimensions - inches A B 1.130 0.500 1.130 0.500 1.130 0.500 1.130 0.500 Dimensions - mm A B 28.70 12.70 28.70 12.70 28.70 12.70 28.70 12.70 Color Silver White Silver White Silver White Silver White Silver White Silver White Silver White Silver White Dimensions - inches A B 1.000 0.500 1.000 0.500 1.000 0.500 1.000 0.500 1.500 1.000 1.500 1.000 1.500 1.000 1.500 1.000 2.000 1.000 2.000 1.000 2.000 1.000 2.000 1.000 3.000 1.900 3.000 1.900 3.000 1.900 3.000 1.900 Dimensions - mm A B 25.40 12.70 25.40 12.70 25.40 12.70 25.40 12.70 38.10 25.40 38.10 25.40 38.10 25.40 38.10 25.40 50.80 25.40 50.80 25.40 50.80 25.40 50.80 25.40 76.20 48.26 76.20 48.26 76.20 48.26 76.20 48.26 Tamper Indication Labels Diagram = Catalog Number PTL-17-7576 PTL-17-7546 PTL-17-352 PTL-17-351 PTL-31-7576 PTL-31-7546 PTL-31-352 PTL-31-351 PTL-20-7576 PTL-20-7546 PTL-20-352 PTL-20-351 PTL-37-7576 PTL-37-7546 PTL-37-352 PTL-37-351 Material B-7576 B-7546 B-352 B-351 B-7576 B-7546 B-352 B-351 B-7576 B-7546 B-352 B-351 B-7576 B-7546 B-352 B-351 Labels per Roll 500 500 500 500 250 250 250 250 100 100 100 100 100 100 100 100 Shown: B-351 and B-352 Shown: B-7546 and B-7576 Continuous Tape Diagram = Catalog Number PTL-101-432 PTL-101-483 PTL-101-489 PTL-46-422 PTL-46-430 PTL-8-422 PTL-8-423 PTL-8-428 PTL-8-430 PTL-8-432 PTL-8-439 PTL-8-439-BK PTL-8-439-BL PTL-8-439-GR PTL-8-439-OR PTL-8-439-RD PTL-8-439-YL Material B-432 B-483 B-489 B-422 B-430 B-422 B-423 B-428 B-430 B-432 B-439 B-439 B-439 B-439 B-439 B-439 B-439 Color Clear White White White Clear White White Silver Clear Clear White Black Blue Green Orange Red Yellow Dimensions - inches A B 0.250 50 ft. 0.250 50 ft. 0.250 50 ft. 0.375 50 ft. 0.375 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. 0.500 50 ft. Dimensions - mm A B 6.35 15.24 m 6.35 15.24 m 6.35 15.24 m 9.53 15.24 m 9.53 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m 12.70 15.24 m continued on page 18 1-888-272-3946 • www.bradyid.com/tls2200 17 General Purpose Labels Continuous Tape Diagram = Catalog Number PTL-8-483 PTL-8-489 PTL-42-422 PTL-42-430 PTL-42-432 PTL-42-439 PTL-42-439-BK PTL-42-439-BL PTL-42-439-GR PTL-42-439-OR PTL-42-439-RD PTL-42-439-YL PTL-42-483 PTL-42-489 PTL-100-432 PTL-100-483 PTL-100-489 PTL-43-422 PTL-43-430 PTL-43-432 PTL-43-439 PTL-43-439-BK PTL-43-439-BL PTL-43-439-GR PTL-43-439-OR PTL-43-439-RD PTL-43-439-YL PTL-43-483 PTL-43-489 continued from page 17 Material B-483 B-489 B-422 B-430 B-432 B-439 B-439 B-439 B-439 B-439 B-439 B-439 B-483 B-489 B-432 B-483 B-489 B-422 B-430 B-432 B-439 B-439 B-439 B-439 B-439 B-439 B-439 B-483 B-489 Dimensions - inches A B 0.500 50 ft. 0.500 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.000 50 ft. 1.300 50 ft. 1.300 50 ft. 1.300 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. 1.900 50 ft. Color White White White Clear Clear White Black Blue Green Orange Red Yellow White White Clear White White White Clear Clear White Black Blue Green Orange Red Yellow White White Dimensions - mm A B 12.70 15.24 m 12.70 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 25.40 15.24 m 33.02 15.24 m 33.02 15.24 m 33.02 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m 48.26 15.24 m Circuit Board and Component Labels Through Hole Technology Top or Bottom Pre-Cut Labels Catalog Number Diagram PTL-68-430 PTL-70-430 PTL-1-473 PTL-1-423 PTL-69-430 PTL-71-430 PTL-3-423 PTL-4-423 PTL-5-473 PTL-5-422 PTL-5-423 Material Labels per Roll Color B-430 B-430 B-473 B-423 B-430 B-430 B-423 B-423 B-473 B-422 B-423 750 750 750 750 750 750 500 500 750 750 750 Clear Clear White White Clear Clear White White White White White Surface Mount Technology (SMT) Top or Bottom • Dimensions - inches A B 0.240 0.240 0.250 0.250 0.350 0.350 0.375 0.400 0.500 0.500 0.500 0.150 0.200 0.250 0.250 0.150 0.200 0.375 0.400 0.200 0.200 0.200 Dimensions - mm A B 6.00 6.00 6.35 6.35 8.89 8.89 9.53 10.16 12.70 12.70 12.70 3.81 5.08 6.35 6.35 3.81 5.08 9.53 10.16 5.08 5.08 5.08 Yes, this material will work with this application. X No, this material does not work with this application. s In extreme high temperatures, testing of these materials is recommended. 18 1-888-272-3946 • www.bradyid.com/tls2200 Surface Mount Technology (SMT) X X X X X X X X X X X Through Hole Technology Top s s s s s s s s s s s Through Hole Technology Bottom After Process X X X X X X X X X X X • • • • • • • • • • • continued on page 19 Circuit Board and Component Labels Pre-Cut Labels Catalog Number PTL-6-473 PTL-6-423 PTL-6-430 PTL-44-422 PTL-44-430 PTL-7-422 PTL-7-423 BPTL-7-423 PTL-7-430 PTL-39-422 PTL-39-430 PTL-9-473 PTL-9-423 PTL-85-430 PTL-99-430 PTL-10-473 PTL-10-423 PTL-80-488 PTL-13-423 PTL-97-488 PTL-14-423 PTL-15-423 PTL-15-428 PTL-16-473 PTL-16-422 PTL-16-423 BPTL-16-423 PTL-16-430 PTL-17-473 PTL-17-422 PTL-17-423 BPTL-17-423 PTL-17-428 BPTL-17-428 PTL-17-430 PTL-19-422 PTL-19-423 BPTL-19-423 PTL-25-423 PTL-27-423 PTL-28-473 PTL-28-423 PTL-28-430 PTL-45-422 PTL-45-430 PTL-29-422 PTL-29-423 BPTL-29-423 PTL-29-428 PTL-29-430 PTL-29-459 PTL-30-422 PTL-30-459 PTL-31-423 PTL-32-422 PTL-32-423 PTL-81-488 PTL-78-488 PTL-2-423 PTL-20-422 Through Hole Technology Top or Bottom continued from page 18 Diagram Material Labels per Roll Color B-473 B-423 B-430 B-422 B-430 B-422 B-423 B-423 B-430 B-422 B-430 B-473 B-423 B-430 B-430 B-473 B-423 B-488 B-423 B-488 B-423 B-423 B-428 B-473 B-422 B-423 B-423 B-430 B-473 B-422 B-423 B-423 B-428 B-428 B-430 B-422 B-423 B-423 B-423 B-423 B-473 B-423 B-430 B-422 B-430 B-422 B-423 B-423 B-428 B-430 B-459 B-422 B-459 B-423 B-422 B-423 B-488 B-488 B-423 B-422 750 750 750 500 500 500 500 5000 500 750 750 750 750 750 750 750 750 250 750 250 750 750 750 500 500 500 5000 500 500 500 500 5000 500 5000 500 250 250 2500 750 750 750 750 750 500 500 500 500 5000 500 500 500 250 250 250 250 250 750 250 100 100 White White Clear White Clear White White White Clear White Clear White White Clear Clear White White White White White White White Silver White White White White Clear White White White White Silver Silver Clear White White White White White White White Clear White Clear White White White Silver Clear White White White White White White White White White White Dimensions - inches A B 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.500 0.600 0.600 0.650 0.650 0.740 0.740 0.750 0.750 0.750 0.900 0.900 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.250 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.900 1.900 2.000 2.000 0.275 0.275 0.275 0.375 0.375 0.500 0.500 0.500 0.500 0.375 0.375 0.200 0.200 0.240 0.320 0.250 0.250 0.900 0.250 0.900 0.187 0.275 0.275 0.375 0.375 0.375 0.375 0.375 0.500 0.500 0.500 0.500 0.500 0.500 0.500 1.000 1.000 1.000 0.250 0.125 0.250 0.250 0.250 0.375 0.375 0.500 0.500 0.500 0.500 0.500 0.500 0.750 0.750 1.000 1.500 1.500 0.250 1.000 0.250 1.000 Surface Mount Technology (SMT) Top or Bottom Dimensions - mm A B 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 12.70 15.24 15.24 16.51 16.51 18.80 18.80 19.05 19.05 19.05 22.86 22.86 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 31.75 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 48.26 48.26 50.80 50.80 6.99 6.99 6.99 9.53 9.53 12.70 12.70 12.70 12.70 9.53 9.53 5.08 5.08 6.10 8.13 6.35 6.35 22.86 6.35 22.86 4.75 6.99 6.99 9.53 9.53 9.53 9.53 9.53 12.70 12.70 12.70 12.70 12.70 12.70 12.70 25.40 25.40 25.40 6.35 3.18 6.35 6.35 6.35 9.53 9.53 12.70 12.70 12.70 12.70 12.70 12.70 19.05 19.05 25.40 38.10 38.10 6.35 25.40 6.35 25.40 Surface Mount Technology (SMT) Through Hole Technology Top s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s s X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X • Yes, this material will work with this application. 1-888-272-3946 After Process X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • continued on page 20 X No, this material does not work with this application. s In extreme high temperatures, testing of these materials is recommended. Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. Through Hole Technology Bottom • www.bradyid.com/tls2200 19 Circuit Board and Component Labels Pre-Cut Labels Catalog Number BPTL-20-422 PTL-20-423 BPTL-20-423 PTL-20-428 BPTL-20-428 PTL-20-459 PTL-26-423 PTL-26-428 PTL-26-459 PTL-22-422 PTL-22-423 PTL-22-428 PTL-22-459 PTL-37-422 PTL-37-423 PTL-37-428 PTL-37-459 PTL-23-422 PTL-23-423 PTL-38-422 PTL-38-423 PTL-38-428 PTL-38-459 Through Hole Technology Top or Bottom continued from page 19 Diagram Material B-422 B-423 B-423 B-428 B-428 B-459 B-423 B-428 B-459 B-422 B-423 B-428 B-459 B-422 B-423 B-428 B-459 B-422 B-423 B-422 B-423 B-428 B-459 Labels per Roll 1000 100 1000 100 1000 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 Color White White White Silver Silver White White Silver White White White Silver White White White Silver White White White White White Silver White Dimensions - inches A B 2.000 1.000 2.000 1.000 2.000 1.000 2.000 1.000 2.000 1.000 2.000 1.000 2.750 1.250 2.750 1.250 2.750 1.250 3.000 1.000 3.000 1.000 3.000 1.000 3.000 1.000 3.000 1.900 3.000 1.900 3.000 1.900 3.000 1.900 4.000 1.000 4.000 1.000 4.000 1.900 4.000 1.900 4.000 1.900 4.000 1.900 Dimensions - mm A B 50.80 25.40 50.80 25.40 50.80 25.40 50.80 25.40 50.80 25.40 50.80 25.40 69.85 31.75 69.85 31.75 69.85 31.75 76.20 25.40 76.20 25.40 76.20 25.40 76.20 25.40 76.20 48.26 76.20 48.26 76.20 48.26 76.20 48.26 101.60 25.40 101.60 25.40 101.60 48.26 101.60 48.26 101.60 48.26 101.60 48.26 Surface Mount Technology (SMT) Top or Bottom Surface Mount Technology (SMT) X X X X X X X X X X X X X X X X X X X X X X X Through Hole Technology Top s s s s s s s s s s s s s s s s s s s s s s s Through Hole Technology Bottom X X X X X X X X X X X X X X X X X X X X X X X After Process • • • • • • • • • • • • • • • • • • • • • • • • Yes, this material will work with this application. X No, this material does not work with this application. s In extreme high temperatures, testing of these materials is recommended. Through Hole Technology Top or Bottom Polyimides Diagram = Catalog Number PTL-1-426 PTL-1-457 PTL-1-477 PTL-1-478 PTL-1-479 PTL-1-495 PTL-3-426 PTL-3-457 PTL-3-477 PTL-3-478 PTL-3-479 PTL-3-495 PTL-4-426 PTL-4-457 PTL-4-478 PTL-4-479 PTL-4-495 PTL-6-426 PTL-6-457 PTL-6-478 PTL-6-479 PTL-6-495 PTL-9-426 PTL-9-457 PTL-9-477 PTL-9-478 PTL-9-479 PTL-9-495 Material B-426 B-457 B-477 B-478 B-479 B-495 B-426 B-457 B-477 B-478 B-479 B-495 B-426 B-457 B-478 B-479 B-495 B-426 B-457 B-478 B-479 B-495 B-426 B-457 B-477 B-478 B-479 B-495 Labels per Roll 750 750 750 750 750 750 500 500 500 500 500 500 500 500 500 500 500 750 750 750 750 750 750 750 750 750 750 750 Color Amber White White White White White Amber White White White White White Amber White White White White Amber White White White White Amber White White White White White • Yes, this material will work with this application. 20 1-888-272-3946 • Dimensions - inches A B 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.250 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.400 0.400 0.400 0.400 0.400 0.400 0.400 0.400 0.400 0.400 0.500 0.275 0.500 0.275 0.500 0.275 0.500 0.275 0.500 0.275 0.650 0.200 0.650 0.200 0.650 0.200 0.650 0.200 0.650 0.200 0.650 0.200 X Dimensions - mm A B 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 10.16 10.16 10.16 10.16 10.16 10.16 10.16 10.16 10.16 10.16 12.70 6.99 12.70 6.99 12.70 6.99 12.70 6.99 12.70 6.99 16.51 5.08 16.51 5.08 16.51 5.08 16.51 5.08 16.51 5.08 16.51 5.08 Maximum Bar Code Characters 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 2 2 2 2 2 No, this material does not work with this application. www.bradyid.com/tls2200 Surface Mount Technology (SMT) Top or Bottom Through Hole Technology Top Through Hole Technology Bottom Surface Mount Technology (SMT) After Process • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • X • • • • • X • • • • X • • • • X • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • X continued on page 21 Circuit Board and Component Labels Polyimides Diagram = Catalog Number PTL-10-426 PTL-10-457 PTL-10-477 PTL-10-478 PTL-10-479 PTL-10-495 PTL-13-426 PTL-13-457 PTL-13-478 PTL-13-479 PTL-13-495 PTL-14-457 PTL-14-477 PTL-14-478 PTL-14-479 PTL-14-495 PTL-16-426 PTL-16-457 PTL-16-478 PTL-16-479 PTL-16-495 PTL-17-426 PTL-17-478 PTL-17-479 PTL-17-495 PTL-25-426 PTL-25-457 PTL-25-477 PTL-25-478 PTL-25-479 PTL-25-495 PTL-27-426 PTL-27-457 PTL-27-477 PTL-27-478 PTL-27-479 PTL-27-495 PTL-28-426 PTL-28-457 PTL-28-477 PTL-28-478 PTL-28-479 PTL-28-495 PTL-2-426 PTL-2-457 PTL-2-477 PTL-2-478 PTL-2-479 PTL-2-495 Material B-426 B-457 B-477 B-478 B-479 B-495 B-426 B-457 B-478 B-479 B-495 B-457 B-477 B-478 B-479 B-495 B-426 B-457 B-478 B-479 B-495 B-426 B-478 B-479 B-495 B-426 B-457 B-477 B-478 B-479 B-495 B-426 B-457 B-477 B-478 B-479 B-495 B-426 B-457 B-477 B-478 B-479 B-495 B-426 B-457 B-477 B-478 B-479 B-495 Labels per Roll 750 750 750 750 750 750 750 750 750 750 750 750 750 750 750 750 500 500 500 500 500 500 500 500 500 750 750 750 750 750 750 750 750 750 750 750 750 750 750 750 750 750 750 100 100 100 100 100 100 continued from page 20 Color Amber White White White White White Amber White White White White White White White White White Amber White White White White Amber White White White Amber White White White White White Amber White White White White White Amber White White White White White Amber White White White White White • Yes, this material will work with this application. Dimensions - inches A B 0.750 0.250 0.750 0.250 0.750 0.250 0.750 0.250 0.750 0.250 0.750 0.250 0.900 0.250 0.900 0.250 0.900 0.250 0.900 0.250 0.900 0.250 1.000 0.187 1.000 0.187 1.000 0.187 1.000 0.187 1.000 0.187 1.000 0.375 1.000 0.375 1.000 0.375 1.000 0.375 1.000 0.375 1.000 0.500 1.000 0.500 1.000 0.500 1.000 0.500 1.250 0.250 1.250 0.250 1.250 0.250 1.250 0.250 1.250 0.250 1.250 0.250 1.500 0.125 1.500 0.125 1.500 0.125 1.500 0.125 1.500 0.125 1.500 0.125 1.500 0.250 1.500 0.250 1.500 0.250 1.500 0.250 1.500 0.250 1.500 0.250 2.000 0.250 2.000 0.250 2.000 0.250 2.000 0.250 2.000 0.250 2.000 0.250 X Through Hole Technology Top or Bottom Dimensions - mm A B 19.05 6.35 19.05 6.35 19.05 6.35 19.05 6.35 19.05 6.35 19.05 6.35 22.86 6.35 22.86 6.35 22.86 6.35 22.86 6.35 22.86 6.35 25.40 4.75 25.40 4.75 25.40 4.75 25.40 4.75 25.40 4.75 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 9.53 25.40 12.70 25.40 12.70 25.40 12.70 25.40 12.70 31.75 6.35 31.75 6.35 31.75 6.35 31.75 6.35 31.75 6.35 31.75 6.35 38.10 3.18 38.10 3.18 38.10 3.18 38.10 3.18 38.10 3.18 38.10 3.18 38.10 6.35 38.10 6.35 38.10 6.35 38.10 6.35 38.10 6.35 38.10 6.35 50.80 6.35 50.80 6.35 50.80 6.35 50.80 6.35 50.80 6.35 50.80 6.35 Surface Mount Technology (SMT) Top or Bottom Maximum Bar Code Characters 2 2 2 2 2 2 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 8 8 8 8 8 8 8 8 8 8 8 8 11 11 11 11 11 11 Through Hole Technology Top Through Hole Technology Bottom Surface Mount Technology (SMT) After Process • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • X • • • • X • • • • X • • • • X • • • X • • • • • X • • • • • X • • • • • X • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • X No, this material does not work with this application. Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. 1-888-272-3946 • www.bradyid.com/tls2200 21 Circuit Board and Component Labels Through Hole Technology Top or Bottom Tedlar® (B-437) Diagram = Catalog Number Labels per Roll PTL-9-437 PTL-10-437 PTL-15-437 PTL-29-437 750 750 750 500 Dimensions - inches A B 0.650 0.750 1.000 1.500 0.200 0.250 0.275 0.500 Dimensions - mm A B 16.51 19.05 25.40 38.10 Maximum Bar Code Characters Through Hole Technology Top Through Hole Technology Bottom Surface Mount Technology (SMT) After Process 2 2 4 8 s s s s X X X X X X X X • • • • 5.08 6.35 6.99 12.70 • Yes, this material will work with this application. s In extreme high temperatures, testing of these materials is recommended. Surface Mount Technology (SMT) Top or Bottom X No, this material does not work with this application. Tedlar is a registered trademark of DuPont ® Datacomm Labels Communications Cabling, Self-Laminating Vinyl (B-427) Catalog Number Labels per Roll Color A A Dimensions - mm B PTL-19-427 BPTL-19-427 PTL-19-427-BL PTL-19-427-BR PTL-19-427-GR PTL-19-427-GY PTL-19-427-OR PTL-19-427-PL PTL-19-427-RD PTL-19-427-YL PTL-31-427 250 2500 250 250 250 250 250 250 250 250 250 White White Blue Brown Green Gray Orange Purple Red Yellow White 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.500 C Application 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.375 0.500 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 38.10 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 12.70 1.500 0.500 25.40 38.10 12.70 1.000 1.500 0.500 25.40 38.10 12.70 Brown 1.000 1.500 0.500 25.40 38.10 12.70 250 Green 1.000 1.500 0.500 25.40 38.10 12.70 PTL-31-427-GY 250 Gray 1.000 1.500 0.500 25.40 38.10 12.70 PTL-31-427-OR 250 Orange 1.000 1.500 0.500 25.40 38.10 12.70 PTL-31-427-PL 250 Purple 1.000 1.500 0.500 25.40 38.10 12.70 PTL-31-427-RD 250 Red 1.000 1.500 0.500 25.40 38.10 12.70 PTL-31-427-YL 250 Yellow 1.000 1.500 0.500 25.40 38.10 12.70 PTL-21-427 BPTL-21-427 PTL-21-427-BL PTL-21-427-BR PTL-21-427-GR PTL-21-427-GY 100 1000 100 100 100 100 White White Blue Brown Green Gray 1.000 1.000 1.000 1.000 1.000 1.000 2.500 2.500 2.500 2.500 2.500 2.500 0.750 0.750 0.750 0.750 0.750 0.750 25.40 25.40 25.40 25.40 25.40 25.40 63.50 63.50 63.50 63.50 63.50 63.50 19.05 19.05 19.05 19.05 19.05 19.05 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 2 Pair Fiber, Single/Multi-Mode 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 Pair UTP, CAT 5, CAT 5E, CAT 6, Silver Satin, UTP Copper, RG-6 Coax, RG-59 Coax 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper BPTL-31-427 2500 White 1.000 PTL-31-427-BL 250 Blue PTL-31-427-BR 250 PTL-31-427-GR Diagram Dimensions - inches B C continued on page 23 22 1-888-272-3946 • www.bradyid.com/tls2200 Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. Datacomm Labels Communications Cabling, Self-Laminating Vinyl (B-427) Catalog Number Labels Diagram per Roll 100 100 100 100 100 1000 100 1000 100 100 100 100 100 100 100 100 100 500 100 100 100 100 100 100 100 100 50 500 50 50 50 50 50 50 50 50 100 PTL-21-427-OR PTL-21-427-PL PTL-21-427-RD PTL-21-427-YL PTL-64-427 BPTL-64-427 PTL-23-427 BPTL-23-427 PTL-23-427-BL PTL-23-427-BR PTL-23-427-GR PTL-23-427-GY PTL-23-427-OR PTL-23-427-PL PTL-23-427-RD PTL-23-427-YL PTL-33-427 BPTL-33-427 PTL-33-427-BL PTL-33-427-BR PTL-33-427-GR PTL-33-427-GY PTL-33-427-OR PTL-33-427-PL PTL-33-427-RD PTL-33-427-YL PTL-34-427 BPTL-34-427 PTL-34-427-BL PTL-34-427-BR PTL-34-427-GR PTL-34-427-GY PTL-34-427-OR PTL-34-427-PL PTL-34-427-RD PTL-34-427-YL PTL-66-427 Color Orange Purple Red Yellow White White White White Blue Brown Green Gray Orange Purple Red Yellow White White Blue Brown Green Gray Orange Purple Red Yellow White White Blue Brown Green Gray Orange Purple Red Yellow White continued from page 22 Dimensions - inches A B C Dimensions - mm A B C 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.938 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 49.23 2.500 2.500 2.500 2.500 3.375 3.375 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 4.000 6.000 6.000 6.000 6.000 6.000 6.000 6.000 6.000 6.000 6.000 3.150 0.750 0.750 0.750 0.750 1.125 1.125 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.500 1.000 63.50 63.50 63.50 63.50 85.73 85.73 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 101.60 152.40 152.40 152.40 152.40 152.40 152.40 152.40 152.40 152.40 152.40 80.00 19.05 19.05 19.05 19.05 28.58 28.58 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 25.40 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 38.10 25.40 Application 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper 4 - 12 Pair Fiber, 4 Pair STP, 25 Pair Copper CAT 5, 4 Pair UTP Copper CAT 5, 4 Pair UTP Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper Backbone Cable, 24 Pair Fiber, 50 Pair Copper 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 50 Pair Copper, 24 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber 100 Pair Copper, 36 Pair Fiber Backbone Cable, 50 Pair Copper, 24 Pair Fiber Patch Panel Labels Catalog Number Diagram Patch Panel - 4 and 6 Port PTL-39-422 PTL-39-430 Patch Panel - ID Port PTL-44-430 PTL-44-422 PTL-7-430 PTL-7-422 PTL-11-432 PTL-10-423 PTL-10-432 Material Labels per Roll Color Dimensions - inches A B B-422 B-422 750 750 White Clear 0.600 0.600 0.375 0.375 15.24 15.24 9.53 9.53 B-430 B-422 B-430 B-422 B-432 B-423 B-432 500 500 500 500 500 750 750 Clear White Clear White Clear White Clear 0.500 0.500 0.500 0.500 0.750 0.750 0.750 0.375 0.375 0.500 0.500 0.500 0.250 0.250 12.70 12.70 12.70 12.70 19.05 19.05 19.05 9.53 9.53 12.70 12.70 12.70 6.35 6.35 A Dimensions - mm B 1-888-272-3946 • www.bradyid.com/tls2200 23 Datacomm Labels Patch Panel Continuous Tapes and Strips Catalog Number Diagram Continuous Tapes PTL-101-432 PTL-101-483 PTL-101-489 PTL-46-422 PTL-46-430 Broadcast Patch Bay Strips PTL-55-412 PTL-56-412 PTL-57-412 PTL-58-412 PTL-59-412 Dimensions - inches A B Material Color B-432 B-483 B-489 B-422 B-430 Clear White White White Clear 0.250 0.250 0.250 0.375 0.375 B-412 B-412 B-412 B-412 B-412 White White White White White 0.230 0.375 0.500 0.535 0.785 Dimensions - mm A B 50 ft. 50 ft. 50 ft. 50 ft. 50 ft. 6.35 6.35 6.35 9.53 9.53 15.24 m 15.24 m 15.24 m 15.24 m 15.24 m 50 ft. 50 ft. 50 ft. 50 ft. 50 ft. 5.84 9.53 12.70 13.59 19.94 15.24 m 15.24 m 15.24 m 15.24 m 15.24 m Power and Ground Cable Labels Catalog Number Diagram PTL-36-109 PTL-111-145-GY PTL-111-145-FR BPTL-111-145-GY BPTL-111-145-FR PTL-110-145-GY PTL-110-145-FR BPTL-110-145-GY BPTL-110-145-FR PTL-12-109 BPTL-12-109 24 1-888-272-3946 • Material Labels per Roll Color B-109 B-145 B-145 B-145 B-145 B-145 B-145 B-145 B-145 B-109 B-109 250 100 100 1000 1000 100 100 1000 1000 100 1000 White Gray Gray Gray Gray Gray Gray Gray Gray White White www.bradyid.com/tls2200 Dimensions inches A B 1.125 1.206 1.206 1.206 1.206 1.750 1.750 1.750 1.750 3.000 3.000 1.750 0.758 0.758 0.758 0.758 1.000 1.000 1.000 1.000 0.750 0.750 Dimensions mm A B 28.57 30.63 30.63 30.63 30.63 44.45 44.45 44.45 44.45 76.20 76.20 44.45 19.25 19.25 19.25 19.25 25.40 25.40 25.40 25.40 19.05 19.05 Application Panel Identification, Voice/Data Identification, Wire & Cable Marking Wire & Cable Marking, Panel Identification, Voice/Data Identification Wire & Cable Marking, Flame Retardant, Voice/Data Identification Wire & Cable Marking, Panel Identification, Voice/Data Identification Wire & Cable Marking, Flame Retardant, Voice/Data Identification Wire & Cable Marking, Panel Identification, Voice/Data Identification Wire & Cable Marking, Flame Retardant, Voice/Data Identification Wire & Cable Marking, Panel Identification, Voice/Data Identification Wire & Cable Marking, Flame Retardant, Voice/Data Identification Wire & Cable Marking, Panel Identification, Voice/Data Identification Wire & Cable Marking, Panel Identification, Voice/Data Identification Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. Datacomm Labels Workstation Labels Catalog Number Desi-Strip Inserts PTL-40-412 BPTL-40-412 Location ID PTL-16-422 PTL-16-430 PTL-17-422 PTL-17-430 PTL-45-422 PTL-45-430 PTL-29-422 PTL-29-430 Outlet/Jack ID PTL-39-422 PTL-39-430 PTL-44-422 PTL-44-430 PTL-7-422 PTL-7-430 PTL-68-430 PTL-70-430 PTL-71-430 PTL-69-430 PTL-85-430 PTL-99-430 Diagram Material Labels per Roll Color Dimensions - inches A B Dimensions - mm A B B-412 B-412 750 5000 White White 1.938 1.938 0.375 0.375 49.23 49.23 9.53 9.53 Desi-Strips Desi-Strips B-422 B-430 B-422 B-430 B-422 B-430 B-422 B-430 500 500 500 500 500 500 500 500 White Clear White Clear White Clear White Clear 1.000 1.000 1.000 1.000 1.500 1.500 1.500 1.500 0.375 0.375 0.500 0.500 0.375 0.375 0.500 0.500 25.40 25.40 25.40 25.40 38.10 38.10 38.10 38.10 9.53 9.53 12.70 12.70 9.53 9.53 12.70 12.70 1-4 Outlet Faceplates 1-4 Outlet Faceplates 1-4 Outlet Faceplates 1-4 Outlet Faceplates 1-2 Outlet Faceplates 1-2 Outlet Faceplates 1-2 Outlet Faceplates 1-2 Outlet Faceplates B-422 B-430 B-422 B-430 B-422 B-430 B-430 B-430 B-430 B-430 B-430 B-430 750 750 500 500 500 500 750 750 750 750 750 750 White Clear White Clear White Clear Clear Clear Clear Clear Clear Clear 0.375 0.375 0.500 0.500 0.500 0.500 0.240 0.240 0.350 0.530 0.740 0.740 0.600 0.600 0.375 0.375 0.500 0.500 0.150 0.200 0.200 0.150 0.240 0.320 9.53 9.53 12.70 12.70 12.70 12.70 6.10 6.10 8.89 13.46 18.80 18.80 15.24 15.24 9.53 9.53 12.70 12.70 3.81 5.08 5.08 3.81 6.10 8.12 1-6 Outlet Faceplates 1-6 Outlet Faceplates 1-6 Outlet Faceplates 1-6 Outlet Faceplates 1-6 Outlet Faceplates 1-6 Outlet Faceplates Siemen Faceplates Siemen Faceplates Siemen Faceplates Siemen Faceplates Siemen Faceplates Siemen Faceplates Application Fiber Optic Labels/Flags Catalog Number PTLFP-01-425 PTLFP-01-8425 PTLFT-01-425 PTLFT-01-8425 Diagram Material B-425 B-8425 B-425 B-8425 Labels per Roll 250 250 250 250 Dimensions inches A B 1.180 0.788 1.180 0.788 1.180 0.788 1.180 0.788 Dimensions mm A B 30.00 20.00 30.00 20.00 30.00 20.00 30.00 20.00 Application Pig-tail and single fiber ID Pig-tail and single fiber ID Pig-tail and single fiber ID Pig-tail and single fiber ID 1-888-272-3946 • www.bradyid.com/tls2200 25 Laboratory Labels FreezerBondz™ Polyester Labels (B-490) Diagram = for vials, centrifuge tubes, test tubes, straws, and slides Catalog Number Labels per Roll A Dimensions - inches B A Dimensions - mm B PTL-112-490 PTL-76-490 PTL-78-490 PTL-113-490 PTL-114-490 500 250 250 100 100 1.250 1.625 1.900 2.200 3.875 0.375 0.600 1.000 1.500 1.500 31.75 41.28 48.26 55.88 98.43 9.53 15.24 25.40 38.10 38.10 General Self-Laminating Labels for vials, tubes, straws and more Catalog Number PTL-108-461 PTL-73-461 PTL-72-461 PTL-74-461 PTL-74-427 PTL-76-461 PTL-77-461 PTL-86-461 PTL-79-461 PTL-75-461 BPTL-75-461 PTL-75-461YL PTL-75-427 PTL-64-427 BPTL-64-427 26 Diagram 1-888-272-3946 Material B-461 B-461 B-461 B-461 B-427 B-461 B-461 B-461 B-461 B-461 B-461 B-461 B-427 B-427 B-427 • Labels per Roll 750 500 500 100 100 250 250 100 100 100 1000 100 100 100 1000 www.bradyid.com/tls2200 Color White White White White White White White White White White White Yellow White White White Dimensions - inches A B C 0.187 1.500 0.700 0.375 1.800 0.375 0.500 1.800 0.500 0.500 2.200 0.750 0.500 2.200 0.750 0.600 1.625 0.600 1.500 3.500 1.250 0.600 2.625 1.000 0.750 3.750 1.000 1.000 2.625 1.000 1.000 2.625 1.000 1.000 2.625 1.000 1.000 2.625 1.000 1.000 3.375 1.125 1.000 3.375 1.125 Dimensions - mm A B C 4.75 38.10 17.78 9.53 45.72 9.53 12.70 45.72 12.70 12.70 55.88 19.05 12.70 55.88 19.05 15.24 41.28 15.24 38.10 88.90 31.75 15.24 66.68 25.40 19.05 95.25 25.40 25.40 66.68 25.40 25.40 66.68 25.40 25.40 66.68 25.40 25.40 66.68 25.40 25.40 85.73 28.58 25.40 85.73 28.58 Brady also offers custom label solutions to meet your needs, designed to your exact specification. Call 1-888-272-3946. More Brady Printers The right choices for every application. Brady’s full line of printers offer heavy-duty construction, versatile design features, and the specialty labels you need for every job. Designed to work with our easy-to-use software applications and our full range of Brady industrial label materials, these printers let you create professional, custom labels quickly, easily, and cost-effectively. HandiMark® Portable Label Maker On-the-spot-ID. Create custom labels wherever you need them at a fraction of the cost of custom printed or engraved labels. You can customize labels with various colors, type styles, and an extensive library of 113 built-in symbols and pictograms with multi-language capability. Limitless applications, real value: Ideal for facility identification, pipe marking, shelf/bin labels, and equipment identification n More text features including auto framing, multiple sizes of text on one label, bar codes, left/center/right justify text, vertical print and more n n n Robust text editing capabilities include text sizes from 0.8” to 1.7”, multiple sizes of text on one label, plus bold, italics, and more Outdoor-grade vinyl tape in 14 colors, plus reflective, repositionable, and tamper-resistant specialty tapes give you more options Portable Printers Engineered for the field. Brady’s IDXPERT™ v2.0 Handheld Labeler and ID PAL™ Labeling Tool are portable, thermal transfer printers that are indispensable tools for contractors in the field. IDXPERT™ v2.0 Handheld Labeler The IDXPERT v2.0 printer offers crisp printing, easy formatting, and convenient label sizes. Version 2.0 features include: n Pre-sized and pre-formatted Punch Block ID Strips for 110-blocks, 66-blocks, BIX-blocks, and patch panels n Pre-sized 1.9” Desi-Strip Faceplate inserts fit into recessed areas commonly found on network port face plates n More text editing options with 21 font sizes, plus font autosizing, fine-tunable HR barcode fonts, and a narrow-width barcode option ID PAL™ Labeling Tool The ID PAL tool is tough, powerful, easy-to-use, and ideal for general one-off labeling. With the ID PAL Labeling Tool, you’ll get: n Intuitive keypad with electrical and datacomm symbols n Special wire marking mode with 10 preset lengths n Multiple line printing and serialization Tagus™ T300 Thermal Transfer Printer The Choice for Versatility. The Brady Tagus printer is an industrial powerhouse in a small package. With the ability to print up to 3,500 labels per day, this printer is ideal for electrical, industrial, safety, laboratory, health care, and panel shop labeling applications. Versatile, easy to use, reliable: One-button calibration of media – saves time and materials n Designed for use with Brady performance materials, including thicker raised panel labels n 300dpi thermal transfer printing for clear, durable labels 1-888-272-3946 n • www.bradyid.com/tls2200 27 Introducing Version 4.0 – The newest version of the TLS 2200 ® Thermal Labeling System provides even more value and labeling flexibility, including: n Increased Processing Speed – nearly 100% faster data processing – so labels print even faster. n Clearer Graphical Display – increased screen resolution and contrast so on-screen text is easier to read, even in low-light conditions. n New Sleep Mode – the printer can be set to “sleep” after 1, 3 or 5 minutes of non-use, extending battery life and increasing productivity. n More Bar Code Symbologies – including Code 128, IFT 25, and Codabar. The TLS 2200 v4.0 system is a powerful, portable thermal label printer ideal for datacomm identification, electrical wire and cable marking, industrial labels, nameplate labels, tamper-evident labels, and many other general labeling applications. For more information visit our website at www.bradyid.com/tls2200 Brady Worldwide, Inc. 6555 W. Good Hope Road Milwaukee, WI 53223 1-888-272-3946 www.bradyid.com © 2007 Brady Worldwide, Inc. All Rights Reserved. Printed in U.S.A. 10-07-AA-40K Y37455 MS37455 Brady Canada 355 Apple Creek Blvd. Markham, ON L3R 9X7 1-800-272-3946 www.bradycanada.com
18551 价格&库存
很抱歉,暂时无法提供与“18551”相匹配的价格&库存,您可以联系我们找货
