B30EP-171-593-WT
B30EP-171-593-WT
    BRADY
    LABEL 0.49"HX1.06"W WH 1=500PCS
B30EP-171-593-WT 数据手册
Technical Data Sheet BRADY B­593 RAISED PANEL LABEL TDS No. B­593 Effective Date: 07/09/2010 Description: GENERAL Print Technology: Thermal Transfer Material Type: Polyester Finish: White, Black, Yellow, Metallized, Red, Green Adhesive: Permanent Acrylic, Foam Backed APPLICATIONS B­593 Raised Panel labels are designed for patch panel identification in identifying external push­buttons, switches, and internal connection points. B­593 is also used as rating and serial plates using alphanumerics that require name plate quality. RECOMMENDED RIBBONS Brady Series R6000 Brady Series R6000HF (low halogen) Brady Series R4400 white   REGULATORY/AGENCY APPROVALS UL:  B­593 (white, metallized, yellow, red and green) is a UL Recognized Component when printed with the Brady R6000 Series and R6000HF Series black ribbons.   B­593 (red, green and black) is a UL Recognized Component when printed with the Brady R4400 Series white ribbon.  See UL file PGJI2.MH17154 for specific details.  UL information can be accessed on line at UL.com.  Search in Certifications area. cUL:  B­593 (white, metallized, yellow, red and green)  is a cUL Recognized Component when printed with the Brady R6000 Series black ribbon.  B­593 (red, green and black) is a cUL Recognized Component when printed with the Brady R4400 Series white ribbon.  See UL file PGJI8.MH17154 for specific details.  UL information can be accessed on line at UL.com.  Search in Certifications area.   Brady B­593 is RoHS compliant to 2005/618/EC MCV amendment to RoHS Directive 2002/95/EC.   SPECIAL FEATURES Brady B­593 Raised Panel Labels have been found to be functional for the following outdoor durations based on long term accelerated weathering tests: Brady B­593 Label Color/Ribbon Estimated Outdoor Durability White/R6000 Black 10 years Yellow/R6000 Black 5 years Silver/R6000 Black 5 years Green/R6000 Black 5 years Red/R6000 Black 5 years Red/R4400 White 3 years Black/R4400 White 3 years Green/R4400 White 3 years   Details regarding label and print appearance are given in the Performance Properties ­ Environmental section below.   Details:   PHYSICAL PROPERTIES Thickness ­ Stainless Steel 20 minute dwell 24 hour dwell AVERAGE RESULTS   0.0079 inch (0.200 mm) 0.0177 inch (0.450 mm) 0.0256 inch (0.650 mm)     32 oz/inch (35 N/100 mm) 90 oz/inch (98 N/100 mm) ­ Smooth ABS 20 minute dwell 88 oz/inch (96 N/100mm) Adhesion to: TEST METHODS ASTM D 1000 ­ Substrate ­ Foam backed adhesive ­ Total ASTM D 1000 24 hour dwell 134 oz/inch (147 N/100 mm) ­ Powdercoated surface 20 minute dwell 24 hour dwell 109 oz/inch (120 N/100mm) 166 oz/inch (182 N/100 mm)  ­ Polyethylene 20 minute dwell 24 hour dwell PSTC­7 (except use 1/2" x 1" sample) ASTM D2979 Polyken™ Probe Tack (1 second dwell) Drop Shear Tack 130 oz/inch (142 N/100mm)   > 200 oz/inch (> 200 N/100 mm) 35 hours   16.5 oz (469 g)     PERFORMANCE  PROPERTIES ENVIRONMENTAL   B­593 white, silver, yellow, red and green label samples were printed with the R6000 Series and R6000HF Series ribbons and B­593 black, red and green label samples were printed with the R4400W series ribbon and dwelled for 24 hours prior to test.   PERFORMANCE TEST METHODS TYPICAL RESULTS TYPICAL RESULTS TYPICAL RESULTS PROPERTIES White B­593/R­6000 Black B­593/R­4400W Metallized B­593/R­ and B­593/R6000HF 6000 High Service 1000 hours at 100°C No visible effect No visible effect No visible effect Temperature (212°F) Low Service 1000 hours at ­20°C No visible effect No visible effect No visible effect Temperature (­4°F) Humidity Resistance 1000 hours at 37°C No visible effect No visible effect No visible effect (100°F), 95% R.H. Salt fog 1000 hours at 5% Salt No visible effect No visible effect No visible effect Spray Abrasion Resistance Taber Abraser, CS­10 Number of cycles until Number of cycles until Numbers of cycles until wheels, 500 g/arm print is illegible print is illegible print is illegible (Fed. Std. 191A, 175 cycles 75 cycles 175 cycles Method 5306)   Brady B­593 labels underwent accelerated weathering testing (ASTM G155, Cycle 1) over the course of one year. Observations regarding the appearance of the B­593 labels and print on the labels were made at 4 intervals during the one year and are given in the table below.    Weatherometer Label Color Effect to Label and Print Duration Effect to Label Color Effect To R6000 Effect to R4400W Series Series Printing Printing 1000 hours White Red Green Yellow Silver Black No visible effect Slight discoloration Slight discoloration No visible effect No visible effect No visible effect No visible effect for all label colors.       n/a n/a No visible effect No visible effect n/a n/a No visible effect 2400 hours White Red Green Yellow Silver Black No visible effect No visible effect Severe discoloration, retains a Slight print fade trace of red No visible effect Moderate discoloration No visible effect Slight discoloration No visible effect Slight discoloration n/a` Slight loss of gloss n/a Slight print fade No visible effect n/a n/a no visible effect 4800 hours White Red Green Yellow Silver Black No visible effect No visible effect Severe discoloration, retains a Slight print fade trace of red No visible effect Moderate discoloration No visible effect Slight discoloration No visible effect Moderate discoloration n/a Slight loss of gloss n/a slight print discoloration slight print discoloration n/a n/a no visible effect 9100 hours White Red Green Slight discoloration No visible effect Severe discoloration, retains a Slight print fade trace of red Slight print fade n/a Severe print removal, print is barely legible* Yellow Silver Black Moderate discoloration Moderate discoloration Severe discoloration Slight loss of gloss Slight print fade Slight print fade n/a Severe print removal, print is barely legible* n/a n/a no visible effect Based on internal testing results, 800 hours in the Weatherometer is approximately equivalent to one year of outdoor exposure in Wisconsin. *print can be rubbed off with finger   PERFORMANCE PROPERTY CHEMICAL RESISTANCE B­593 white printed with the R6000 Series and R6000HF Series ribbons and B­593 black printed with the R4400 white series ribbon, and dwelled 24 hours prior to test. Testing consisted of 5 cycles of 10 minute immersions in the specified chemical reagent followed by 30 minute recovery periods. After final immersion, samples rubbed 10 times with cotton swab saturated with test fluid.      SUBJECTIVE OBSERVATION OF VISUAL CHANGE ­ B­593 White CHEMICAL REAGENT EFFECTS TO THE PRINTED IMAGE R6000 R6000HF Without Rub With Rub Without Rub With Rub Isopropyl alcohol 1 1 1 1 Methyl ethyl ketone NP NP 1 5 Alcohol mix* 1 1 1 1 Gasoline 1 5 1 1 Diesel 1 1 1 1 Skydrol® 500B­4 1 5 1 2­3 Mil 5606 Oil 1 1 1 1 1,1,1­Trichloroethane 1 5 Fluid obsolete 5% Sodium hydroxide 1 1 1 1 10% Sulfuric acid solution 1 1 1 1 Deionized water 1 1 1 1 10% Salt water solution 1 1 1 1 n­Hexane 1 1 Not tested Iso­octane 1 1 Not tested Ethanol 1 1 1 1 ASTM #3 oil 1 1 1 1 Acetone 1 5 1 5 * Alcohol mix is 50% ethanol, 30% methanol, and 20% water by volume.     SUBJECTIVE OBSERVATION OF VISUAL CHANGE – B­593 Black CHEMICAL REAGENT EFFECTS TO THE PRINTED IMAGE R4400W Without Rub With Rub Isopropyl alcohol 1 5 Methyl ethyl ketone NP NP Alcohol mix* 1 1 Gasoline 1 5 Diesel 1 1 Skydrol® 500B­4 NP NP Mil 5606 Oil 1 1 1,1,1­Trichloroethane 1 5 5% Sodium hydroxide 1 1 10% Sulfuric acid solution 1 1 Deionized water 1 1 10% Salt water solution 1 1 n­Hexane 1 1 Iso­octane 1 1 Ethanol 1 4 ASTM #3 oil 1 4 Acetone NP NP  * Alcohol mix is 50% ethanol, 30% methanol, and 20% water by volume. Rating Scale: 1=no visible effect 2=slight print smear, fade or removal 3=moderate smear, fade or print removal (print is still legible) 4=severe smear, fade or print removal 5=complete print and/or topcoat removal NP=print removed during immersion Product testing and history of similar products, support a customer performance expectation of at least two years from the date of receipt for this product as long as this product is stored in its original packaging in an environment below 80°F (27°C) and 60% RH. We are confident that our product will perform well beyond this time frame. However, it remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional testing protocols that will qualify a product's fitness for use, in their actual application. Trademarks: Polyken™ is a trademark of Testing Machines Inc. Skydrol® is a registered trademark of the Monsanto Company ASTM: American Association for Testing and Materials (U.S.A.) S. I.: International System of Units Note: All values shown are averages and should not be used for specification purposes.  Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2016 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414­358­6600 | Fax: 800­292­2289
B30EP-171-593-WT 价格&库存
很抱歉,暂时无法提供与“B30EP-171-593-WT”相匹配的价格&库存,您可以联系我们找货
B30EP-171-593-WT
  • 1+2353.637691+305.86123
库存:25
