BALL VALVE LOCKOUT-PR-SMALL
    BRADY
    BRADY - BALL VALVE LOCKOUT-PR-SMALL - PRINZING BALL VALVE LOCKOUT, RED
BALL VALVE LOCKOUT-PR-SMALL 数据手册
Technical Data Sheet Prinzing Ball Valve Lockout TDS No. LOTO-​22 Effective Date: 10/09/2017 Description: Design ● ● ● ● Made from ultra tough polypropylene Small lockout locks OUT pipes 1/2" to 2.5" in diameter, and can also be used to lock valves OPEN on pipes from 1/2" to 1.25" in diameter Large lockout locks out pipes 2" to 8" in diameter Available in four colors Material ● Chemical Polypropylene ◌ Colors: Red, Yellow, Blue, and Green Temperature Range ● Polypropylene: ​-20° to 80°C (0° to 175°F) Chemical Resistance All approved chemicals listed are based on the manufactures specified chemical resistance chart for plastic material only. °C Chemical °C Acetone 25 Petroleum 25 Acetone 60 Turpentine oil 25 Chlorine, chlorine water 25 Turpentine substitute (white spirit) 25 Fuel, engine: Gasoline (normal & premium grade) 85 Trichloroethane 1,1,1 45 Lubrication oil: gear oil < 120 Lubricating oil: HD engine oils, hydraulic oils, transformer oils < 120 Fuel, engine: M15 mixture (15% methanol) 70 Water (including seawater) 25 Methanol 25 Water (including seawater), chlorinated (
BALL VALVE LOCKOUT-PR-SMALL 价格&库存
很抱歉,暂时无法提供与“BALL VALVE LOCKOUT-PR-SMALL”相匹配的价格&库存,您可以联系我们找货
