TLS 2200® Wire & Cable Materials
BradyID.com/tls2200
B-342 PermaSleeve Single-Sided Polyolefin Wire Marking Sleeves
3:1 heat shrinkable sleeve fits snuggly around wire for identification and protection. Fade resistant
and flame retardant. Meets the following material and physical property specifications.
• MIL-STD-202
• RoHS Compliant
• UL Recognized
Tested per:
• ASTM E162
• ASTM E662
Portable Printers
• SAE-AMS-DTL-23053/5C
(Class 1)
• SAE-AS-81531
Part Number
Sleeves
Per Roll
Approx.
Wire Gauge
Range of Wire Diameter
Inch (mm)
Min.
Max.
Supplied
Diameter
Inch (mm)
Recovered
Diameter
Inch (mm)
Recovered Wall
Thickness
Inch (mm)
Sleeve Width
Inch (mm)
Rec.
Ribbon
PSPT-094-1-WT
PSPT-094-175-WT
BM71-94-1-342
BM71-94-175-342
PSPT-125-1-WT
PSPT-125-175-WT
BM71-125-1-342
BM71-125-175-342
PSPT-187-1-WT
PSPT-187-175-WT
BM71-187-1-342
BM71-187-175-342
PSPT-250-1-WT
PSPT-250-175-WT
BM71-250-1-342
BM71-250-175-342
PSPT-375-1-WT
PSPT-375-175-WT
BM71-375-1-342
BM71-375-175-342
PSPT-500-1-WT
PSPT-500-175-WT
BM71-500-1-342
BM71-500-175-342
PSPT-1000-1-WT
PSPT-1000-175-WT
BM71-1000-175-342
100
100
2500
2500
100
100
1000
1000
100
100
1000
1000
100
100
1000
1000
100
100
1000
1000
100
100
1000
1000
50
50
500
28 to 20
28 to 20
28 to 20
28 to 20
22 to 16
22 to 16
22 to 16
22 to 16
20 to 10
20 to 10
20 to 10
20 to 10
16 to 8
16 to 8
16 to 8
16 to 8
12 to 4
12 to 4
12 to 4
12 to 4
8 to 1
8 to 1
8 to 1
8 to 1
2 to 0.950 dia.
2 to 0.950 dia.
2 to 0.950 dia.
0.023 (0.6) - 0.080 (2.0)
0.046 (1.2) - 0.110 (2.8)
0.062 (1.6) - 0.150 (3.8)
0.094 (2.4) - 0.215 (5.5)
0.125 (3.2) - 0.320 (8.13)
0.187 (4.8) - 0.450 (11.4)
0.333 (8.5) - 0.950 (24.1)
0.094 (2.4)
0.094 (2.4)
0.094 (2.4)
0.094 (2.4)
0.125 (3.2)
0.125 (3.2)
0.125 (3.2)
0.125 (3.2)
0.187 (4.7)
0.187 (4.7)
0.187 (4.7)
0.187 (4.7)
0.250 (6.4)
0.250 (6.4)
0.250 (6.4)
0.250 (6.4)
0.375 (9.5)
0.375 (9.5)
0.375 (9.5)
0.375 (9.5)
0.500 (12.7)
0.500 (12.7)
0.500 (12.7)
0.500 (12.7)
1.000 (25.4)
1.000 (25.4)
1.000 (25.4)
0.024 (0.6)
0.024 (0.6)
0.024 (0.6)
0.024 (0.6)
0.047 (1.2)
0.047 (1.2)
0.047 (1.2)
0.047 (1.2)
0.062 (1.6)
0.062 (1.6)
0.062 (1.6)
0.062 (1.6)
0.093 (2.4)
0.093 (2.4)
0.093 (2.4)
0.093 (2.4)
0.125 (3.1)
0.125 (3.1)
0.125 (3.1)
0.125 (3.1)
0.187 (4.7)
0.187 (4.7)
0.187 (4.7)
0.187 (4.7)
0.375 (9.5)
0.375 (9.5)
0.375 (9.5)
.024 (0.6) ± .003 (0.07)
.020 (0.5) ± .003 (0.07)
.025 (0.6) ± .003 (0.07)
.036 (0.9) ± .003 (0.07)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.015 (25.8)
1.765 (44.8)
1.765 (44.8)
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
R4310
TLS 2200 Wire & Cable
Performance Attributes:
Approx. wire gauge based on AWG for THHN wire.
*Choose Your PermaSleeve Color:
You may also choose to order your sleeves in the custom olors listed below. Simply replace “WT” with the abbreviation of the desired color.
Example: PSPT-187-175-WT becomes PSPT-187-175-YL
Available custom colors: WT=White, YL=Yellow, BK=Black, BL=Blue, BR=Brown, GR-Green, GY-Gray, OR-Orange, PK=Pink, RD=Red, VT=Violet
WT = White
YL = Yellow
GY = Gray
BK = Black
OR = Orange
BL = Blue
PK = Pink
GR = Green
BR = Brown
RD = Red
VT = Violet
Did You Know?
Brady’s PermaSleeve® Wire Marking Sleeves feature these unique characteristics
• Does not smudge or fade when printed; print is permanent
• Unique flattened full-circle design provides fast, permanent wire marking
• Kitted in a convenient format, easily dispensed for printing
• Conforms tightly to wire after heat is applied which prevents markers from sliding
TLS2200 Printer Ribbons on page 57.
Full Material Properties on page 227.
1-888-272-3946
BradyID.com
51
很抱歉,暂时无法提供与“BM71-94-1-342”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11937.115931+1543.99816
