BMP41-MAGNET
BMP41-MAGNET
    BRADY
    BMP41 MAGNETIC ACCESSORY
BMP41-MAGNET 数据手册
BMP™41 Label Printer One and done The BMP™41 Label printer is a rugged, portable solution that gives you the versatility to create die-cut or continuous labels up to 25 mm wide, anywhere, anytime! Whether you are faced with your jobs for the day or one-off tasks, the BMP™41 printer is the one device for all your labelling jobs - from wire marking and general ID to multi-area labels such as patch panel, terminal block and more. Print it once, print it all, get it done! Built to be rugged in any environment ■■ Drop-tested printer with rubber corner bumpers provide optimal protection and security from falls and wear and tear conditions ■■ Ergonomic, center balanced printer with grab and go ridged grip for easy handling ■■ Long life rechargeable battery allows printing on the go and decreases the need for frequent charging ■■ Prints up to 250 labels per day for higher volume printing Designed to be easy ■■ Large LCD backlit display provides clear visibility keypad, graphics library, hot keys and menu functions for fast label creation ■■ WYSIWYG functionality means you can see what you are printing – you’ll only need to print once ■■ Magnet accessory for hands free printing ■■ QWERTY Engineered long lasting material quality ■■ Prints durable true-sized 25.4 mm wide identification to maximise amount of data on your label ■■ Take pride in your work with die-cut materials that make your job look uniform and professional or use a continuous material if you need to adjust the length of the label ■■ Fulfill your requirements with up to 10 different industry specified materials that last Advanced all-in-one cartridge system ■■ Smart Cell Technology means your label format is automatically set up with no calibration ■■ Correct ribbon match for optimal print permanence ■■ Easy storage, transport and use of multiple cartridges ■■ Quick and easy to change supplies, just pop in the needed cartridge ■■ Pull tab on cartridge allows for one handed removal when changing supplies Prints for a variety of applications. Key applications include wire marking, sleeving, panel labelling, terminal block, patch panel, general identification and more! Printer Part Numbers Article No. Order Reference Description 133254 711213 711214 711215 BMP41-KIT-EU BMP41-KIT-UK BMP41-KIT-EU-LM BMP41-KIT-UK-LM 711216 BMP41-KIT-EU-LM-HC 711217 BMP41-KIT-UK-LM-HC BMP41 EU Label Printer BMP41 UK Label Printer BMP41 EU Label Printer with LabelMark BMP41 UK Label Printer with LabelMark BMP41 EU Label Printer with LabelMark and Hard Case BMP41 UK Label Printer with LabelMark and Hard Case 2 YEAR WARRANTY Printer Kit supplied with Nickel Battery Pack, MC1-1000-595-WT-BK cartridge, USB cable, AC adapter, Power Cord, Product CD, Brady Printer Drivers CD and Quick Start Guide. LabelMark Software Optional. Printer Technical Data Brady’s LabelMark™ Labelling Software lets you easily design, edit and print labels for Asset ID, Component Marking, Telecom/ Datacom Labelling, Wiremarkers and more. Integrates completely with Microsoft® Office, Autocad® applications and more. You can download more detailed information on our LabelMark Labelling Software on www.bradyeurope.com. The BMP™41 Label Printer is a rugged, portable solution that gives you the versatility to create die-cut or continuous labels up to 25 mm wide, anywhere, anytime! Whether you are faced with your jobs for the day or one-off tasks, the BMP™41 printer is the one device for all of your labelling jobs - from wire marking and general ID to multiarea labels such as patch panel or terminal block and more. Print it once, print it all, get it done! Specifications Print Technology Print Resolution (dpi) Print Speed (mm/sec) Colour Capability Continuous vs Die-cut Labels Max. Label Width Max. Print Length Recommended Usage/ Labels per Day Stand-alone Printing (Detached from PC) Connectivity Options PC Connectivity Thermal Transfer 300 dpi 33 mm/second Monocolour Continuous Tape & Die Cut Labels 25.40 mm 990 mm Electrical Kit 250 Yes Built-in Symbols Software Compatibility USB Yes Wire Wrap, Terminal Block, Patch Panel, Flags, General, 66-Block, 110-Block, DesiStrip Print Preview, Serialisation, Date/Time Stamp, Fixed Length, Mirror, Vertical, Rotate, Auto Format, Multi-copy, Banner, Frame Feature Code 39 & UCC 128 Stand-alone, additional via software 445 LabelMark Physical Properties Depth x Height x Width Weight (kg) Keyboard Display Cutter Warranty 90 mm x 290 mm x 150 mm 1.3 QWERTY Large backlit screen Standard, Built-in, Manual 2 years Printing Modes Printing Functions Bar Code Capability Article No. Order Reference Description 711218 711219 BMP41 EU Label Printer Electrical Kit BMP41 UK Label Printer Electrical Kit BMP41-KIT-EU-ELEC BMP41-KIT-UK-ELEC Kit includes one of each BMP41 EU Label Printer or BMP41 UK Label Printer BMP41-HC BMP41 Hard Case BMP41-MAGNET BMP41 Magnet LM5 Std LabelMark 5 Standard Labelling Software M-91-427 Black on White/Transparent Self-laminating Vinyl, 25.40 mm x 38.10 mm, 180 labels / Cartridge MC1-1000-595-WT-BK Black on White Vinyl, 25.40 mm x 7.62 m, 1 / Cartridge M-131-499 Black on White Nylon Cloth, 12.70 mm x 25.40 mm, 180 labels / Cartridge Voice & Datacom Kit Article No. Order Reference Description 711220 711221 BMP41 EU Label Printer Voice & Data Kit BMP41 UK Label Printer Voice & Data Kit BMP41-KIT-EU-DATA BMP41-KIT-UK-DATA Kit includes one of each BMP41 EU Label Printer or BMP41 UK Label Printer BMP41-HC BMP41 Hard Case BMP41-MAGNET BMP41 Magnet LM5 Std LabelMark 5 Standard Labelling Software M-48-427 Black on White/Transparent Self-laminating Vinyl, 25.40 mm x 19.05 mm, 200 labels / Cartridge MC1-1000-595-WT-BK Black on White Vinyl, 25.40 mm x 7.62 m, 1 / Cartridge MC-375-422 Black on White Polyester, 9.53 mm x 7.62 m, 1 / Cartridge 20/08/2013 Your Brady Distributor Brady EMEA Locations +27 11 704 3295 +32 (0) 52 45 78 11 +421 2 3300 4800 +45 66 14 44 00 +33 (0) 3 20 76 94 48 +49 (0) 6103 7598 660 +36 23 500 275 +39 02 26 00 00 22 © 2013 Brady Worldwide Inc. ALL RIGHTS RESERVED Middle East Norway Romania Russia Spain & Portugal Sweden Turkey UK & Ireland +971 4881 2524 +47 70 13 40 00 +40 21 202 3032 +7 495 225 93 62 +34 900 902 993 +46 (0) 8 590 057 30 +90 212 264 02 20 +44 (0) 1295 228 288 EUR-M-428-EN Africa Benelux Central & Eastern Europe Denmark France Germany Hungary Italy www.bradyeurope.com
BMP41-MAGNET 价格&库存
很抱歉,暂时无法提供与“BMP41-MAGNET”相匹配的价格&库存,您可以联系我们找货
BMP41-MAGNET
