DEL-BIA-RD
DEL-BIA-RD
    BRADY
    BRADY  BIA-RD  LABEL, PREPRINTED, 3.18MMX4.83MM, 576PCS
DEL-BIA-RD 数据手册
Technical Data Sheet BRADY B­500 POLYMER COATED CLOTH TAPE TDS No. B­500 Effective Date: 08/19/2005 Description: Brady B­500 is a polymer coated cloth with a printable topcoat and a rubber based pressure sensitive adhesive. Brady B­500 is a general purpose material for a variety of pre­printed labeling and wire marking applications requiring durability and economy. Brady B­500 has good oil and water resistance and good print durability. B­500 has excellent flexibility for wrapping around curved surfaces. Details: PHYSICAL PROPERTIES Thickness Adhesion to: ­Stainless Steel TEST METHODS ASTM D 1000 ASTM D 1000 20 minute dwell 24 hour dwell ­Polypropylene 20 minute dwell 24 hour dwell ­Textured ABS 20 minute dwell 24 hour dwell ASTM D 2979 Polyken™ Probe Tack 1 second dwell ASTM D 1000 ­Machine Direction ­Cross Direction Lowest application temperature to stainless steel Tack Tensile Strength and Elongation Application Temperature AVERAGE RESULTS 0.0088 inch (0.223 mm) 68 oz/in (74 N/100 mm) 75 oz/in (82 N/100 mm) 63 oz/in (69 N/100 mm) 68 oz/in (74 N/100 mm) 20 oz/in (22 N/100 mm) 25 oz/in (27 N/100 mm) 35 oz (1000 g) 45 lbs/in (788 N/100 mm), 7% 32 lbs/in (560 N/100 mm), 18% 50°F (10°C) The following testing is performed with pre­printed B­500 white wiremarkers and unprinted flat B­500 samples. Wiremarker samples were wrapped on 0.080" OD wires and flat samples were applied to flat aluminum panels. All samples allowed to dwell 24 hours prior to testing. PERFORMANCE PROPERTIES High Service Temperature Low Service Temperature Humidity Resistance UV Light Resistance Weatherability Salt Fog Resistance Abrasion Resistance TEST METHODS 30 days at 175°F (80°C) 30 days at ­40°F (­40°C) 30 days at 100°F (37°C), 95% R.H. 30 days in UV Sunlighter™ 100 ASTM G 155, Cycle 1 30 days in Xenon Arc Weatherometer ASTM B 117 30 days in 5% salt fog solution chamber Taber Abraser, CS­10 grinding wheels, 250 g/arm (Fed. Std. 191A, Method 5306) TYPICAL RESULTS Slight topcoat darkening at 80°C No visible effect No visible effect N o visible effect Very slight unwrap to wiremarker, no visible effect to printing Slight unwrap to wiremarker, no visible effect to printing Pre­printed wiremarker still legible after 100 cycles PERFORMANCE PROPERTY CHEMICAL RESISTANCE Pre­printed B­500 white wiremarkers were wrapped around 0.080" OD wire and unprinted B­500 samples were laminated to flat aluminum panels. Samples allowed to dwell 24 hours prior to test. Testing consisted of 5 cycles of 10 minute immersions in the specified chemicals followed by 30 minute recovery periods. Testing was conducted at room temperature. CHEMICAL REAGENT SUBJECTIVE OBSERVATION OF VISUAL CHANGE Methyl Ethyl Ketone 1,1,1­Trichloroethane Isopropyl Alcohol JP­4 Jet Fuel SAE 20 WT Oil Mil 5606 Oil Speedi Kut Cutting Oil 332 Gasoline Rust Veto® 377 Skydrol® 500B­4 Super Agitene® Deionized Water 3% Alconox® Detergent 10% Sodium Hydroxide Solution 10% Sulfuric Acid Solution Northwoods™ Buzz Saw Citrus Degreaser 5% Salt Water Solution APPEARANCE OF WIREMARKER Marker fell off Severe unwrap, topcoat wrinkled Slight unwrap Slight unwrap No visible effect Slight unwrap No visible effect Moderate unwrap Slight unwrap Severe unwrap, topcoat wrinkled, adhesive soft Moderate unwrap No visible effect No visible effect Severe unwrap No visible effect Slight unwrap APPEARANCE OF FLAT SAMPLE Topcoat removed, adhesive failure Topcoat delamination, adhesive failure No visible effect No visible effect No visible effect No visible effect No visible effect Slight adhesive ooze No visible effect Topcoat delaminated from cloth No visible effect No visible effect Slight adhesive ooze No visible effect No visible effect Severe edge lift No visible effect No visible effect Note: Environmental aging and chemical resistance test results may be different on colored B­500 wiremarkers. Product testing, customer feedback, and history of similar products, support a customerperformance expectation of at leasttwo years from the date of receipt for this product as long as this product is stored in its original packaging in an environment below 80 degrees F (27°C) and 60% RH . We are confident that our product will perform well beyond this time frame. However, it remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional testing protocols that will qualify a product's fitness for use, in their actual applications.  Trademarks: Alconox® is a registered trademark of Alconox Co. Northwoods™ is a trademark of the Superior Chemical Corporation Polyken™ is a trademark of Testing Machines Inc. Rust Veto® is a registered trademark of the E.F. Houghton & Co. Skydrol® is a registered trademark of the Monsanto Company Sunlighter™ is a trademark of the Test Lab Apparatus Company Super Agitene® is a registered trademark of Graymills Corporation ASTM: American Society for Testing and Materials (U.S.A.) SAE: Society of Automotive Engineers (U.S.A.) !All S.I. Units (metric) are mathematically derived from the U.S. Conventional !Units.! All S.I. Units (metric) are mathematically derived from the U.S. Conventional Units. Note: All values shown are averages and should not be used for specification purposes.  Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2016 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414­358­6600 | Fax: 800­292­2289
DEL-BIA-RD 价格&库存
很抱歉,暂时无法提供与“DEL-BIA-RD”相匹配的价格&库存,您可以联系我们找货
