TECHNICAL BULLETIN TB-3082
Statshield® Smocks with Convertible Sleeves
Grounding, Testing, and Maintenance
Made in the
United States of America
Statshield® smocks are available in the following styles
and sizes:
Sizes
Blue
Black
Grey
White Chest
Sleeve
X Small
74300 74310 74320 74330 30"-32" 33 3/4"
Small
74301 74311
Medium
74302 74312 74322 74332 38"-40" 34 3/8"
Large
74303 74313 74323 74333 42"-44" 35"
X Large
74304 74314 74324 74334 46"-48" 35 1/2"
74321 74331 34"-36" 34"
2X Large 74305 74315 74325 74335 50"-52" 35 1/2"
3X Large 74306 74316 74326 74336 54"-56" 37"
4X Large 74307 74317 74327 74337 58"-60" 36 1/2"
5X Large 74308 74318 74328 74338 62"-64" 36"
6X Large 74309 74319 74329 74339 66"-68" 36"
Figure 1. Desco Statshield® Smocks with Convertible
Sleeves and Snaps Cuffs.
Installation
Description
Follow the directions below for proper installation and
grounding of the Statshield® smock.
Desco Statshield® Smocks with Convertible Sleeves
are designed to be antistatic, low tribocharging,
and create a Faraday Cage around the torso and
arms of the wearer to protect ESD susceptible items
from electrostatic fields generated by clothing on
the operator’s clothing. Static control garments are
intended to attenuate electrostatic fields that may be
present on personnel clothing. Statshield® Smocks
meet the requirement for Groundable Static Control
Garment System per ANSI/ESD S20.20 required
limit of < 3.5 x 107 ohm Rtg tested per ANSI/ESD
STM2.1 and ESD TR53 (23° ± 1° C, 12% ± 3% RH,
and 50% ± 5% RH).
Yes
Statshield® smocks are constructed of a lightweight
dissipative material which made from texturized
polyester and a minimum of 9% carbon nylon
monofilament. The conductive nylon fibers are
woven in a chain-link design throughout the
material, providing continuous and consistent
charge dissipation. All of the seams in Statshield®
smocks are designed to maintain electrical continuity
from panel to panel and from sleeve to sleeve in
accordance with the ESD Association Garment
Standard, ESD-STM2.1.
Standard Colors Available:
Blue
Black
Grey
*Fabric lots vary slightly in color.
Yes
No
Figure 2. Proper Installation of Smock wearer’s body
1. Put on the smock and fasten all of the snaps on the
front of the smock, making sure that clothing is not
exposed outside of the smock.
2. Operators may roll up sleeves, so long as all clothing
remains covered. Operators wearing long sleeved
shirts must leave the sleeves down. Operators must
be grounded with foot grounders or wrist straps when
wearing a smock and handling any ESD susceptible
items.
3. Throughout use, it is essential that material be in
contact with operator’s skin.
White
DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178
DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Web Site: Desco.com
TB-3082 October 2019 Page 1 of 2
© 2019 DESCO INDUSTRIES INC
Employee Owned
Grounding Integrity Testing
Panel-to-panel conductivity is essential so as not
to leave portions of the smock as isolated charged
conductors. Panel-to-panel conductivity is can be
tested using the Surface Resistance Meter Kit. For
additional information, refer to ANSI/ESD S20.20,
ESD TR20.20, ESD TR53 and the Garment Standard,
ANSI/ESD STM2.1.
Specifications
Fabric Weight*
2.2 oz per square yard
Fabric Content
Texturized polyester and a
Carbon Mono-filament
Conductive at 1 x 104
ohms, nonflaking and
non-sloughing.
Surface Resistance
1 x 105 to < 1 x 107 ohms,
per ANSI/ESD STM2.1
and ESD TR53 of Fabrics
Glass Transition
Temperature
250°F
Flash Point
1040°F
Country of Origin
Heat Sealed Patches
Patches may be heat-sealed to the smocks. The
patch should be small and the smock should be
tested before and after application.
Maintenance
Desco recommends Woolite. Liquid detergents are
better than dry because there is less caking and
frictional wear. Use only non-ionic softeners and
detergents when laundering. Launder Statshield®
smocks in cool or warm water, tumble dry with
low heat or hang dry. DO NOT USE BLEACH OR
FABRIC SOFTENER.
*Fabric lots vary slightly in color and weight.
Limited Warranty, Warranty Exclusions, Limit of
Liability and RMA Request Instructions
See Desco Terms and Conditions
Use a standard household machine on gentle cycle or
industrial machine “Pony” (typically under 200 pound
loads) machine. It is not recommended to launder
these Statshield® smocks in heavy industrial laundry
machines because it will lead to premature wear;
degrading the ESD properties.
Statshield® smocks should be tumbled dry using
low heat. The carbon-suffused mono-filament nylon
is sensitive to heat and should not be exposed to
laundering heat in excess of 120°F. Under normal
wearing and recommended maintenance conditions,
Desco Statshield® ESD protective smocks will
maintain their usefulness and effectiveness for a
minimum of 100 washings.
TB-3082 Page 2 of 2
Employee Owned
很抱歉,暂时无法提供与“74309”相匹配的价格&库存,您可以联系我们找货
