CAM CENTER OPEN
CAM CENTER CLOSED
Made in the
United States of America
A. Magnetic connection creates a superior connection with wristband.
Maintains 1-5 pound release.
B. Small cam lock, allows material replacement. 300 series stainless
steel.
C. Large cam lock, allows size adjustment, maintains electrical
continuity even when open. 300 series stainless steel. Floating cam
lock allows wide opening for easy adjustment and secures material
down against base plate when closed.
D. 300 series stainless steel backplate (0.016" thick). Manufacturing
date code is stamped into stainless steel backplate.
CIRCUMFERENCE
ITEM DESCRIPTION
MIN
MAX
E. Insulating cap, white ABS plastic.
F. Knit elastic band material. 0.875" (22mm) wide and 0.10" (2.5mm) thick.
50 strands of textured polyester, 36 strands of lycra spandex and 14
strands of silver plated polypropylene yarn. Outer surface (grey color) of
fibers act as an insulator.
G. Inner conductive surface. 14 strands (13.5% of the material by weight) of
silver bound polypropylene fibers are randomly knit on the inner surface of
the material. Electrically isolated from the outer surface (grey side). Silver
fibers provide antimicrobial and anti-odor properties.
H. Underwriters Laboratory listing 90P1.
Note: Used with cord meets ANSI/ESD S20.20 tested per ANSI/ESD S1.1 and ESD TR53
WIDTH
09213 Wristband only
2.5" (63.5mm)
13" (330mm) 0.875" (22mm)
09214 Wristband w/ 6' Cord
2.5" (63.5mm)
09215 Wristband w/ 10' Cord
2.5" (63.5mm)
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
JEWEL MAGSNAP® WHITE ELASTIC WRIST STRAPS
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370
© 2014 DESCO INDUSTRIES INC.
Employee Owned
DRAWING NUMBER
09213
DATE:
August
2014
很抱歉,暂时无法提供与“09214”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+276.960201+35.99808
- 国内价格 香港价格
