09215
09215
    DESCO
    腕带,带软线 10'(3.05m) 统一尺寸 白色
09215 数据手册
CAM CENTER OPEN CAM CENTER CLOSED Made in the United States of America A. Magnetic connection creates a superior connection with wristband. Maintains 1-5 pound release. B. Small cam lock, allows material replacement. 300 series stainless steel. C. Large cam lock, allows size adjustment, maintains electrical continuity even when open. 300 series stainless steel. Floating cam lock allows wide opening for easy adjustment and secures material down against base plate when closed. D. 300 series stainless steel backplate (0.016" thick). Manufacturing date code is stamped into stainless steel backplate.   CIRCUMFERENCE ITEM DESCRIPTION MIN MAX E. Insulating cap, white ABS plastic. F. Knit elastic band material. 0.875" (22mm) wide and 0.10" (2.5mm) thick. 50 strands of textured polyester, 36 strands of lycra spandex and 14 strands of silver plated polypropylene yarn. Outer surface (grey color) of fibers act as an insulator. G. Inner conductive surface. 14 strands (13.5% of the material by weight) of silver bound polypropylene fibers are randomly knit on the inner surface of the material. Electrically isolated from the outer surface (grey side). Silver fibers provide antimicrobial and anti-odor properties. H. Underwriters Laboratory listing 90P1. Note: Used with cord meets ANSI/ESD S20.20 tested per ANSI/ESD S1.1 and ESD TR53 WIDTH 09213 Wristband only 2.5" (63.5mm) 13" (330mm) 0.875" (22mm) 09214 Wristband w/ 6' Cord 2.5" (63.5mm) 13" (330mm) 0.875" (22mm) 09215 Wristband w/ 10' Cord 2.5" (63.5mm) 13" (330mm) 0.875" (22mm) Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. JEWEL MAGSNAP® WHITE ELASTIC WRIST STRAPS DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2014 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 09213 DATE: August 2014
09215 价格&库存
很抱歉,暂时无法提供与“09215”相匹配的价格&库存,您可以联系我们找货
