17009
17009
    DESCO
    GLOVES STATIC DISSIPATIVE NOMEX
17009 数据手册
Extended Cuffs Standard Cuffs A. 0.160” (4mm) stud to fit 1/8” (4mm) spring loaded medical snap.* B. Exterior fabric is 97.9% textured polyester. Conductive fiber filament (Rgp < 1 x 107 ohms) made of carbon suffused nylon 6 monofilament spaced every 0.25 inches. Material will not slough and can be precision cleaned for use in cleanrooms down to class 100. F Can be washed multiple times in a mild detergent**. C. Inner lining constructed of Nomex® makes gloves ideal for use in any process involving heat up to 200°F (93.3°C). E D. Conductive, color coded cuff (see chart below) interconnects with the conductive fiber and snap providing a true and rapid ground path. Extended Cuffs Item # (Sold in Pairs) Size Cuff Color E F 17007 Small Tan 4.5” 12 3/4” 17008 Medium Blue 17009 Large 4 3/4” 13” 5” 13” 17016 X-Large Gray 6” 14 1/4” Item # (Sold in Pairs) Size Cuff Color E F 68112 Small Tan 9” 9 3/8” 68111 Medium Blue 9” 10” 68110 Large Brown 9” 10 3/8” Brown A Standard Cuffs B C D *Glove should be grounded to verify dissipation of static charges. Use Desco 09480 coil cord or equivalent to ground. **Glove Laundering For proper operation, the ESD Gloves must be laundered periodically. Woolite works well. Liquid detergents are better than dry in that there is less caking and frictional wear. Launder glove in cool or warm water, tumble dry with low heat or hang dry. Machine washing works well if using a standard house machine on gentle cycle. It is not recommended to launder these gloves in heavy industrial laundry machines as it will lead to premature wear. Gloves should be tumbled dry using low heat. DO NOT BLEACH. After laundering, verify (Rgp) < 1 x 107 ohms. E measures around the hand at the fullest part (excluding thumb) F measures from the tip of the middle finger to the base of the hand Unless otherwise noted, tolerance ± 1/2” HOT GLOVES, STATIC DISSIPATIVE DESCO WEST: 3651 WALNUT AVE, CHINO, CA 91710 WEBSITE: Desco.com PHONE: (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE: (781) 821-8370 © 2021 DESCO INDUSTRIES INC. Employee Owned Made in the United States of America DRAWING NUMBER 68110 DATE: April 2021
17009 价格&库存
很抱歉,暂时无法提供与“17009”相匹配的价格&库存,您可以联系我们找货
