17134
17134
    DESCO
    聚乙烯 手套,不区分性别 - 耗散 大型 灰色,白色 耐切割,静电耗散
17134 数据手册
Specifications: Electrical Properties Surface Resistivity: Typical Values < 1 x 109 ohms Product Description Fabric: Confifuration: Liner Color: Coating Color: Shelf Life: Ultra-high-molecular-weight polyethylene Elastic Wrist Grey White Functional: 1 year Functional Properties Thickness on Coated Area 1.0 mm ( ± 0.2) Abrasion Resistance (Revs) 4 - Performance Blade Cut Resistance 5 - Performance Tear Resistance (N) 4 - Performance Puncture Resistance 2 - Performance Item Size Length* 17131 Small 8-1/4" 210 mm 17132 Small 8-5/8" 220 mm 17133 Medium 17134 Large 9-1/2" 240 mm X-Large 9-7/8" 250 mm 17135 17136 9" 230 mm XX-Large 10-1/4" 260 mm Sold in Pairs Test Procedures/Method Surface Resistivity Meter Level Level Level Level Thickness Gage (Dial Type/ Digimtic Type) EN 388: 2003 EN 388: 2003 EN 388: 2003 EN 388: 2003 Glove Laundering For proper operation, the ESD Gloves must be laundered periodically. Woolite works well. Liquid detergents are better than dry in that there is less caking and frictional wear. Launder glove in cool or warm water, tumble dry with low heat or hang dry. Machine washing works well if using a standard house machine on gentle cycle. It is not recommended to launder these gloves in heavy industrial laundry machines as it will lead to premature wear. Gloves should be tumbled dry using low heat. DO NOT BLEACH. After laundering, verify < 1 x 109 ohms. *Length is measured from the tip of the fingers to the bottom of the glove. Tolerance: ±3/8” Cut Resistant Gloves In Use Specifications and procedures subject to change without notice. Country of Origin: Israel ESD CUT RESISTANT GLOVES DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2019 DESCO INDUSTRIES INC Employee Owned DRAWING NUMBER 17131 DATE: October 2019
17134 价格&库存
很抱歉,暂时无法提供与“17134”相匹配的价格&库存,您可以联系我们找货
