Description
• Choice for shelf liner; flexible, tough, and fairly hard
• Low cost
• Made of a modified polyethylene; offers excellent chemical resistance
• Should not be used at solder stations
Specifications
Rs: 1 x 103 to < 1 x 106 ohms tested per IEC 61340-2-3 meets EN 61340-5-1
Rg: 1 x 103 to < 1 x 106 ohms tested per IEC 61340-2-3 meets EN 61340-5-1
Thickness: 1.5mm
Weight: 1.4 kg/m2
Colour: black
Item
Description
VER-27089 1.5mm x 0.9m x 0.54m, 4 x 10mm studs
“All working surfaces and storage racks on which unprotected ESDS [ESD sensitive
items] may be placed shall be capable of being connected to EPA ground and shall have
a point-to-point resistance and resistance to EPA ground in accordance with table 1 (Rp
greater or equal to 1 x 104, less than or equal to 1 x 109 ohms, and Rg greater or equal
to 7.5 x 105 to less than or equal to 1 x 109 ohms) and shall contain a groundable point.”
VER-26945 1.5mm x 1.2m x 0.54m, 4 x 10mm studs
VER-26946 1.5mm x 1.1m x 2.4m, no studs
*Colour and texture may vary between lots and mills
Made in the United Kingdom with globally sourced materials
If not otherwise noted, tolerance +/- 10%
EVA Bench Matting and Shelf Lining
VERMASON LTD.
UNIT C, 4TH DIMENSION, FOURTH AVENUE, LETCHWORTH,
HERTS, SG6 2TD UK
PHONE: +44 (0) 1462-672005, FAX: +44 (0) 1462-670440
E-MAIL:Service@Vermason.co.uk, INTERNET: Vermason.co.uk
© 2015 VERMASON LTD.
Drawing Number
VER-27089
DATE:
November
2015
很抱歉,暂时无法提供与“228295”相匹配的价格&库存,您可以联系我们找货
