STATSHIELD® FOIL MOISTURE BARRIER BAG WITH
IPC/JEDEC MOISTURE SENSITIVE CAUTION MARKINGS
Meets the required limits of ANSI/ESD S20.20, Packaging standard ANSI/ESD S541, and Static Control Bag
standard ANSI/ESD S11.4-2012 Level 2.
Specifications:
Date & Lot Code
Printed for QC
Traceablility
Side Weld Seal 3/8 in.
Electrical Properties
Surface Resistance
(both exterior and interior)
Discharge Shielding
Static Shielding
Charge Generation
Teflon
Quartz
Physical Properties
Thickness
Puncture Strength
Heat Seal Strength
(Vetrod bar sealer)
Seal Strength
MVTR
Silicone and Amine content
Contact Corrosion
Non-corrosive
Typical Values
Test Procedures/Method
1 x 104 to < 1 x 1011 ohms
很抱歉,暂时无法提供与“13963”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1051.537351+130.95105
