Description:
Statfree® DPL Plus™ floor mat is made with conductive vinyl top layer laminated to an anti-fatigue
foam rubber bottom layer. The product is designed to provide a flooring surface that does not generate
a static charge and will act as part of the path-to-ground personnel wearing ESD footwear. The
resistance range (1 x 103 to < 1 x 106 ohms Rtt) of the top black layer will remain low enough to act as
a path-to-ground with normal dirt and grim build-up on a floor and meet the required limit of ANSI/ESD S20.20
footwear/flooring system. < 1 x 109 ohms tested per ANSI/ESD STM97.1, ANSI/ESD STM7.1, or ESD TR53.
While the foam rubber bottom layer and the top yellow safety border are insulative, the black vinyl top does
make sufficient contact to be grounded when placed upon ESD flooring. The insulative bottom foam rubber
layer is designed to reduce standing worker’s fatigue and improve productivity. The diamond plate pattern
increases traction and tapered edges with radius corners help to prevent curling and reduce tripping in work
areas.
Made in the
United States of America
Electrical Properties:
Side View
Disclaimer:
All statements, technical data, and recommendations
contained herein are based upon tests we believe to
be reliable. However, the accuracy or completeness
thereof is not guaranteed. The proper and correct
applications of products and data is the responsibility
of the user. Statements or recommendations not
contained herein shall have no force or effect
unless embodied in a written agreement signed by
authorized offers of Desco Industries, Inc.
RoHS 2 and REACH Statement
None of the RoHS 2 restricted materials or REACH
substances of very high concern as of 2014-06-16
are intentionally added in manufacturing this
product. Ref: European Union Directive 2011/65/EU
and Regulation (EC) No. 1907/2006/CE. See Desco
Limited Warranty at Desco.com.
Property
Rtt Resistance:
Rtg Resistance:
Test Method
ANSI/ESD STM7.1
ANSI/ESD STM7.1
Specifications:
Construction:
Thickness:*
Radius:
Surface:
Hardness:
Heat Resistance:
Weight:
Density:
Conductive vinyl top layer laminated to an insulative foam rubber bottom layer. Note: top yellow border is insulative.
0.450" (11.4mm)
1"
Embossed Diamond Plate Design
90 Shore A
0°F to 150°F continuous
1.45 lbs. per square foot
Average: 33 lbs. per cubic foot
*Color, texture and thickness may vary between lots and mills
Grounding: This material must be properly grounded for optimum electrical performance; ground point needs to be attached to top black
area. See for Technical Bulletin TB-2000 for mat grounding instructions. Part numbers 40979, 40980, & 40981 include 14234 grounding kit.
Cleaning: For optimum electrical performance, surface must be cleaned regularly using an ESD mat cleaner. We suggest using our
Statguard™ Floor Mat Cleaner. Do not use cleaners with silicone. Silicone buildup will create an insulative film on the surface.
Floor Mat Kit Item Numbers
Limited Lifetime Warranty
Desco warrants for one year that Statfree® matting
products will be free of defects in materials and
workmanship and will guarantee dissipative/
conductive mat properties for the life of the mat.
Damage to matting caused by misuse of any kind,
including using inappropriate cleaners is not covered
by Desco Limited Warranty.
Tolerances:
Width ± 0.250"
Length ± 0.250" every linear foot of material.
Value
Item
40979
40980
40981
Size
24"
36"
x
x
36"
48"
36"
x
60"
FLOOR MAT KITS INCLUDE
1 Floor Mat, size as specified
1 Grounding Kit 14234
Roll Material Item Numbers
Item
Size
40982
36" x 60'
Matting materials have a tendency to shrink
slightly when first unrolled. In applications where
length is critical, allow the material to relax for at
least 4 hours before cutting to size. Always trim
with a sharp knife or razor blade.
NOTE: If a ground cord is used it is recommended to be attached to the black portion of the mat
and not the yellow border.
Specifications and procedures subject to change without notice.
STATFREE DPL PLUS™ FLOOR MAT, VINYL, CONDUCTIVE, ANTI-FATIGUE
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370
© 2014 DESCO INDUSTRIES INC.
Employee Owned
DATE:
DRAWING NUMBER December
PM-125
2014
很抱歉,暂时无法提供与“40981.”相匹配的价格&库存,您可以联系我们找货
