66418
66418
    DESCO
    导电,耗散 桌子,工作台卷筒 接地垫 橡胶 蓝色,深色 20'(6.1m) X 3'(0.91m)
66418 数据手册
Color Dissipative Layer STATFREE® T2 PLUS DISSIPATIVE RUBBER Specifications Standard Document Meets Requirements of: ANSI/ESD S20.20 Worksurface Electrical Properties Dissipative Surface Layer Rtt Resistance: Rtg Resistance: Ground Plane Layer Rtt Resistance: 0.060" Conductive Black Layer 2-Layer Grounding & Cleaning If the material is used on top of an already properly grounded surface, grounding hardware may not be necessary. Where no properly grounded surface is available, grounding hardware is required to provide a path-to-ground. Rtg compliance verification measurements must be made as outlined in ESD TR53 with a surface resistance meter. See Tech Bulletin TB-7000 for Reztore® Surface & Mat Cleaner Application Instructions. Physical Properties Construction: Thickness: Color:² Embossing:² Weight: Hardness: Other Properties Heat Resistance: Chemical Resistance: Oil Absorption Resistance: Typical Values Test Procedures/Method 1 x 106 to < 1 x 109 ohms 1 x 106 to < 1 x 109 ohms ANSI/ESD S4.1 and ESD TR53 ANSI/ESD S4.1 and ESD TR53 < 1 x 106 ohms ANSI/ESD S4.1 and ESD TR53 Dual-layer rubber material¹ 0.060” (1.5mm) Blue (Top), Dark Blue (Top), Dark Grey (Top), Green (Top), Black (Bottom) Slight Texture 0.43 lbs./sq. ft. (0.2g/cm2) 65 ± 5 Shore “A”, per ASTM-D2240 Does not melt or burn when coming into contact with hot solder and soldering irons. Resistance to degradation by inorganic acids, organic acids, reducing agents, aliphatic hydrocarbons, mineral oil, aldehydes, and amines. Resists oil absorption to maintain physical and electrical properties. ¹Rubber material is vulcanized and may contain sulfur ²Color and texture may vary between lots and mills Limited Lifetime Warranty: Desco warrants for one year that Statfree® matting products will be free of defects in materials and workman­ship and will guarantee dissipative/ conductive mat properties for the life of the mat. Damage to matting caused by misuse of any kind, including using inappropriate cleaners is not covered by Desco Limited Warranty. RoHS 3, REACH, and Conflict Minerals Statement See the Desco Industries RoHS 3, REACH, and Conflict Minerals Statement: http://www.descoindustries.com/ROHS3.aspx Tolerances: Width ± 0.250" Length ± 0.250" every 1 linear foot of running material. Thickness ±10% Matting materials have a tendency to shrink slightly when first unrolled. In applications where length is critical, allow the material to condition for at least 4 hours before cutting to size. Always using care trim with a sharp knife or razor blade. *Color and texture may vary between lots and mills. For product listings, Click Here See the Desco Limited Warranty: http://desco.descoindustries.com/Limited-Warranty.aspx See the Desco Disclaimer: http://desco.descoindustries.com/Disclaimer.aspx Specifications and procedures subject to change without notice. **Tray liners have 3/4" radius corners and do not include grounding hardware. STATFREE® T2 PLUS DISSIPATIVE, RUBBER, 2-LAYER, 0.060" (1.5mm) DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2021 DESCO INDUSTRIES INC Employee Owned Made in the United States of America MATERIAL STATFREE® T2 Plus DRAWING PM-132 DATE: March 2021
66418 价格&库存
很抱歉,暂时无法提供与“66418”相匹配的价格&库存,您可以联系我们找货
