TECHNICAL BULLETIN TB-3052
Ionizer Mounting Arm
Installation and Maintenance
Made in America
Packaging
1 Ionizer Mounting Arm with C-Clamp
4 Screws
4 Nuts
Installation
Mount the arm at the desired
location of the workbench
using the C-Clamp mounting
system. Figure 2 shows the
proper mounting of the arm
on a workbench. Tighten the
C-Clamp securely.
The neck piece on the Arm
allows for easy mounting
of a Desco Chargebuster
Jr. Ionizer or High Output
Bench Top Ionizer via its
stand assembly. The ionizer
should be mounted to the
Mounting Arm using the 4
included screws and nuts.
See Figure 3.
Figure 2. Installing the
Ionizer Mounting Arm to
a workbench
Figure 1. Desco 60466 Ionizer Mounting Arm
Description
The Desco 60466 Ionizer Mounting Arm is designed as
a mounting alternative for the Chargebuster Jr. Ionizer
and High Output Bench Top Ionizer. The arm allows
the ionizer to be mounted off the worksurface, saving
valuable work space. The articulated movement of the
arm assembly allows the user to focus the ionizer’s
output directly onto the desired areas. The Ionizer
Mounting Arm includes a C-Clamp style mounting
system for ease of installation.
The 60466 Ionizer Mounting Arm is compatible with the
following Desco items:
Item
neck piece end on
the Mounting Arm
mounting holes on
ionizer stand
Description
60500 Chargebuster Jr. Ionizer, 120VAC
60501 Chargebuster Jr. Ionizer, with Heater, 120VAC
60505 High Output Bench Top Ionizer, 120VAC
NOTE: The 60466 Ionizer Mounting Arm is not
compatible with ionizers built prior to 2011. The drill
pattern can be found on page 2. Contact customer
service for more information.
Figure 3. Installing the ionizer’s stand to the Ionizer
Mounting Arm
DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 • Fax (909) 627-7449
DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Fax (781) 575-0172 • Website: Desco.com
TB-3052 Page 1 of 2
March 2011
© 2011 DESCO INDUSTRIES, INC.
Employee Owned
Specifications
Construction:
Metal with springs
Weight:
4.8 lbs
Maximum Extension:
38"
Maximum Weight Capacity:
8 lbs
Drill Pattern Templates
Ionizer Link
60500
Download Template
60501
Download Template
60505
Download Template
Limited Warranty
Desco expressly warrants that for a period of one (1) year from the date of
purchase, Desco Ionizer Mounting Arms will be free of defects in material
(parts) and workmanship (labor). Within the warranty period, a credit for
purchase of replacement Desco products, or, at Desco’s option, the product
will be repaired or replaced free of charge. If product credit is issued, the
amount will be calculated by multiplying the unused portion of the expected
one year life times the original unit purchase price. Call Customer Service
at 909-627-8178 (Chino, CA) or 781-821-8370 (Canton, MA) for Return
Material Authorization (RMA) and proper shipping instructions and address.
Include a copy of your original packing slip, invoice, or other proof of date of
purchase. Any unit under warranty should be shipped prepaid to the Desco
factory. Warranty replacements will take approximately two weeks.
If your unit is out of warranty, Desco will quote repair charges necessary
to bring your unit up to factory standards. Call Customer Service at 909627-8178 (Chino, CA) or 781-821-8370 (Canton, MA) for a Return Material
Warranty Exclusions
THE FOREGOING EXPRESS WARRANTY IS MADE IN LIEU OF
ALL OTHER PRODUCT WARRANTIES, EXPRESSED AND IMPLIED,
INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE WHICH ARE SPECIFICALLY DISCLAIMED. The express
warranty will not apply to defects or damage due to accidents, neglect,
misuse, alterations, operator error, or failure to properly maintain, clean or
repair products.
Limit of Liability
In no event will Desco or any seller be responsible or liable for any
injury, loss or damage, direct or consequent, arising out of the use of or
the inability to use the product. Before using, users shall determine the
suitability of the product for their intended use, and users assume all risk
and liability whatsoever in connection therewith.
Figure 4. Drill pattern for 60466 Ionizer Mounting Arm
TB-3052 Page 2 of 2
Employee Owned
很抱歉,暂时无法提供与“60466.”相匹配的价格&库存,您可以联系我们找货
