Color Dissipative Layer
STATFREE T2 PLUS™ DISSIPATIVE RUBBER
Specifications
Standard Document
Meets Requirements of:
ANSI/ESD S20.20 Worksurface
Electrical Properties
Dissipative Surface Layer
Rtt Resistance:
Rtg Resistance:
Ground Plane Layer
Rtt Resistance:
0.060"
Conductive Black Layer
2-Layer
Grounding & Cleaning
If the material is used on top of an already properly grounded surface,
grounding hardware may not be necessary. Where no properly
grounded surface is available, grounding hardware is required to provide
a path-to-ground. Rtg compliance verification measurements must be
made as outlined in ESD TR53 with a surface resistance meter.
See Tech Bulletin TB-7000 for Reztore® Surface & Mat Cleaner
Application Instructions.
Limited Lifetime Warranty:
Desco warrants for one year that Statfree® matting products will be free
of defects in materials and workmanship and will guarantee dissipative/
conductive mat properties for the life of the mat. Damage to matting
caused by misuse of any kind, including using inappropriate cleaners is
not covered by Desco Limited Warranty.
RoHS 3, REACH, and Conflict Minerals Statement
See the Desco Industries RoHS 3, REACH, and Conflict Minerals
Statement:
http://www.descoindustries.com/ROHS3.aspx
Physical Properties
Construction:
Thickness:
Color:*
Embossing:*
Weight:
Hardness:
Other Properties
Heat Resistance:
Chemical Resistance:
Oil Absorption Resistance:
Typical Values
Test Procedures/Method
1 x 106 to < 1 x 109 ohms
ANSI/ESD S4.1 and ESD TR53
< 1 x 106 ohms
Dual-layer rubber material
0.060” (1.5mm)
Blue (Top), Dark Blue (Top), Dark Grey (Top), Green (Top), Black (Bottom)
Slight Texture
0.43 lbs./sq. ft. (0.2g/cm2)
65 ± 5 Shore “A”, per ASTM-D2240
Does not melt or burn when coming into contact with hot solder and soldering irons.
Resistance to degradation by inorganic acids, organic acids, reducing agents, aliphatic
hydrocarbons, mineral oil, aldehydes, and amines.
Resists oil absorption to maintain physical and electrical properties.
Tolerances:
Width ± 0.250"
Length ± 0.250" every 1 linear foot of running material.
Thickness ±10%
Matting materials have a tendency to shrink slightly when first unrolled. In applications where length is critical, allow the
material to condition for at least 4 hours before cutting to size. Always using care trim with a sharp knife or razor blade.
*Color and texture may vary between lots and mills.
For product listings, Click Here
See the Desco Limited Warranty:
http://desco.descoindustries.com/Limited-Warranty.aspx
See the Desco Disclaimer:
http://desco.descoindustries.com/Disclaimer.aspx
Specifications and procedures subject to change without notice.
**Tray liners have 3/4" radius corners and do not include grounding hardware.
STATFREE T2 PLUS™ DISSIPATIVE, RUBBER, 2-LAYER, 0.060" (1.5mm)
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370
© 2019 DESCO INDUSTRIES INC
Employee Owned
Made in the
United States of America
MATERIAL
DATE:
STATFREE T2 Plus™ September
DRAWING PM-132
2019
很抱歉,暂时无法提供与“66470”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11748.167421+1467.31730
