66467 - TRAY LINER, STATFREE T2 PLUS
RUBBER, DISSIPATIVE, GREEN, 0.060'' x 16'' x 24''
W/RADIUS CORNERS
Features
Dissipative Dual Layer ESD Worksurface
Provides a worksurface that does not generate a static charge and will
control the discharge rate from all conductors (including ESD susceptible
items) that are placed on the surface1.
NEW Nitrile Rubber Oil Resistant Compound
Improved material compound limits oil absorption to improve electrical and physical properties through the
lifespan of the material. May be used in soldering applications with flux and other chemicals. Click Here for
Chemical Resistance Chart (http://www.desco.com/PDF/ChemicalResistanceChart.pdf)
6
9
Dissipative (1 x 10 to
很抱歉,暂时无法提供与“66467”相匹配的价格&库存,您可以联系我们找货
