74325
74325
    DESCO
    聚酯 工作服,夹克长度,带按扣 2XLarge 灰色
74325 数据手册
TECHNICAL BULLETIN TB-3082 Statshield® Smocks with Convertible Sleeves Grounding, Testing, and Maintenance Made in the United States of America Statshield® smocks are available in the following styles and sizes: Sizes Blue Black Grey White Chest Sleeve X Small 74300 74310 74320 74330 30"-32" 33 3/4" Small 74301 74311 Medium 74302 74312 74322 74332 38"-40" 34 3/8" Large 74303 74313 74323 74333 42"-44" 35" X Large 74304 74314 74324 74334 46"-48" 35 1/2" 74321 74331 34"-36" 34" 2X Large 74305 74315 74325 74335 50"-52" 35 1/2" 3X Large 74306 74316 74326 74336 54"-56" 37" 4X Large 74307 74317 74327 74337 58"-60" 36 1/2" 5X Large 74308 74318 74328 74338 62"-64" 36" 6X Large 74309 74319 74329 74339 66"-68" 36" Figure 1. Desco Statshield® Smocks with Convertible Sleeves and Snaps Cuffs. Installation Description Follow the directions below for proper installation and grounding of the Statshield® smock. Desco Statshield® Smocks with Convertible Sleeves are designed to be antistatic, low tribocharging, and create a Faraday Cage around the torso and arms of the wearer to protect ESD susceptible items from electrostatic fields generated by clothing on the operator’s clothing. Static control garments are intended to attenuate electrostatic fields that may be present on personnel clothing. Statshield® Smocks meet the requirement for Groundable Static Control Garment System per ANSI/ESD S20.20 required limit of < 3.5 x 107 ohm Rtg tested per ANSI/ESD STM2.1 and ESD TR53 (23° ± 1° C, 12% ± 3% RH, and 50% ± 5% RH). Yes Statshield® smocks are constructed of a lightweight dissipative material which made from texturized polyester and a minimum of 9% carbon nylon monofilament. The conductive nylon fibers are woven in a chain-link design throughout the material, providing continuous and consistent charge dissipation. All of the seams in Statshield® smocks are designed to maintain electrical continuity from panel to panel and from sleeve to sleeve in accordance with the ESD Association Garment Standard, ESD-STM2.1. Standard Colors Available: Blue Black Grey *Fabric lots vary slightly in color. Yes No Figure 2. Proper Installation of Smock wearer’s body 1. Put on the smock and fasten all of the snaps on the front of the smock, making sure that clothing is not exposed outside of the smock. 2. Operators may roll up sleeves, so long as all clothing remains covered. Operators wearing long sleeved shirts must leave the sleeves down. Operators must be grounded with foot grounders or wrist straps when wearing a smock and handling any ESD susceptible items. 3. Throughout use, it is essential that material be in contact with operator’s skin. White DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Web Site: Desco.com TB-3082 October 2019 Page 1 of 2 © 2019 DESCO INDUSTRIES INC Employee Owned Grounding Integrity Testing Panel-to-panel conductivity is essential so as not to leave portions of the smock as isolated charged conductors. Panel-to-panel conductivity is can be tested using the Surface Resistance Meter Kit. For additional information, refer to ANSI/ESD S20.20, ESD TR20.20, ESD TR53 and the Garment Standard, ANSI/ESD STM2.1. Specifications Fabric Weight* 2.2 oz per square yard Fabric Content Texturized polyester and a minimum of 9% carbon Carbon Mono-filament Conductive at 1 x 104 ohms, nonflaking and non-sloughing. Surface Resistance 1 x 105 to < 1 x 107 ohms, per ANSI/ESD STM2.1 and ESD TR53 of Fabrics Glass Transition Temperature 250°F Flash Point 1040°F Country of Origin United States of America Heat Sealed Patches Patches may be heat-sealed to the smocks. The patch should be small and the smock should be tested before and after application. Maintenance Desco recommends Woolite. Liquid detergents are better than dry because there is less caking and frictional wear. Use only non-ionic softeners and detergents when laundering. Launder Statshield® smocks in cool or warm water, tumble dry with low heat or hang dry. DO NOT USE BLEACH OR FABRIC SOFTENER. *Fabric lots vary slightly in color and weight. Limited Warranty, Warranty Exclusions, Limit of Liability and RMA Request Instructions See Desco Terms and Conditions Use a standard household machine on gentle cycle or industrial machine “Pony” (typically under 200 pound loads) machine. It is not recommended to launder these Statshield® smocks in heavy industrial laundry machines because it will lead to premature wear; degrading the ESD properties. Statshield® smocks should be tumbled dry using low heat. The carbon-suffused mono-filament nylon is sensitive to heat and should not be exposed to laundering heat in excess of 120°F. Under normal wearing and recommended maintenance conditions, Desco Statshield® ESD protective smocks will maintain their usefulness and effectiveness for a minimum of 100 washings. DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Web Site: Desco.com TB-3082 Page 2 of 2 © 2019 DESCO INDUSTRIES INC Employee Owned
74325 价格&库存
很抱歉,暂时无法提供与“74325”相匹配的价格&库存,您可以联系我们找货
