13962
13962
    DESCO
    MBBIPC/JEDEC4MIL12X20"100/PK
13962 数据手册
STATSHIELD® FOIL MOISTURE BARRIER BAG WITH IPC/JEDEC MOISTURE SENSITIVE CAUTION MARKINGS Meets the required limits of ANSI/ESD S20.20, Packaging standard ANSI/ESD S541, and Static Control Bag standard ANSI/ESD S11.4-2012 Level 2. Specifications: Date & Lot Code Printed for QC Traceablility Side Weld Seal 3/8 in. Electrical Properties Surface Resistance (both exterior and interior) Discharge Shielding Static Shielding Charge Generation Teflon Quartz Physical Properties Thickness Puncture Strength Heat Seal Strength (Vetrod bar sealer) Seal Strength MVTR Silicone and Amine content Contact Corrosion Non-corrosive Typical Values Test Procedures/Method 1 x 104 to < 1 x 1011 ohms
13962 价格&库存
很抱歉,暂时无法提供与“13962”相匹配的价格&库存,您可以联系我们找货
