13601.
13601.
    DESCO
    DESCO - 13601. - 2? x 3? Statshied® Transparent Metal-In Standard ESD Shielding Bags
13601. 数据手册
STATSHIELD® METAL-IN SERIES Low Charging Clear Zipper Specifications: Standard Document ANSI/ESD S541 (ANSI/ESD S20.20) ANSI/ESD S11.4 Lip 1" (±0.125") Electrical Properties Surface Resistance:   Outer Surface   Inner Surface Discharge Shielding Charge Generation Capacitance Probe (to dissipate 1 KV) Physical Properties Date & Lot Code Printed for QC Traceablility Weld Seal Side Weld Seals 0.375" (±0.10") Soft Fold Bottom Low Charging Static Dissipative Proprietary Outer Polyester Layer Aluminum Shielding Layer Low Charging Static Dissipative Proprietary Inner Polyethylene Layer 7 Film Thickness Width (Inside Dimensions) Length (Inside Dimensions) Light Transmission Heat Seal Tensile Strength Puncture Resistance Silicone Marking Adhesion Meets Requirements of: ESD Protective Packaging Level 3 Technical Requirements Typical Values Test Procedures/Method 1 x 104 to < 1 x 1011 ohms 1 x 104 to < 1 x 1011 ohms 10 lbs/in 4600 PSI, 32 MPa >10 lbs Not detected Pass MIL-STD-3010, 1003 ANSI/ESD S541 Section 6.2 Outside an EPA “Transportation of sensitive products outside of an EPA shall require packaging that provides: 1. Low charge generation 2. Dissipative or conductive materials for intimate contact 3. A structure that provides electrostatic discharge shielding.” RoHS, REACH, and Conflict Minerals Statement: See RoHS, REACH, and Conflict Minerals Statement at Desco.com. Limited Warranty See Desco’s Limited Warranty at Desco.com Mixed Unsortable Plastic Scrap Mixed unsortable plastic scrap shall contain assorted plastics of multiple grades that are co-extruded, bonded or laminated together which are unsortable into individual grades Desco’s bags are recyclable Statshield® bags are packaged 100 per package in an oversized shielding bag. See Shielding Bag Storage at TB-7057. Statshield® and Statfree® are Registered Trademarks of Desco Industries Inc. See Bag Selection Chart Click HERE STATSHIELD® BAG, SHIELDING, METAL-IN CONSTRUCTION, ZIPPER, 0.0030" (0.0762mm) DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2018 DESCO INDUSTRIES INC. Made in the United States of America Specifications and procedures subject to change without notice. DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 Employee Owned ASTM D-1003 375°F, 1/2 sec 60 psi ASTM 882 MIL-STD-3010, 2065 FTIR IPC-TM-650 2.4.1 DRAWING NUMBER 13605 DATE: February 2018
13601. 价格&库存
很抱歉,暂时无法提供与“13601.”相匹配的价格&库存,您可以联系我们找货
