WORKSURFACE GROUNDING
COMMON POINT GROUND FOR BENCH
MAT AND TWO WRIST STRAPS
09820
09821
09825
09826
14213
09821
Without Resistor, 10mm Socket, 10' Cord
With Resistor, 10mm Socket, 10' Cord
Without Resistor, 10mm Stud, 15' Cord
With Resistor, 10mm Stud, 15' Cord
Complete Bench Ground Kit, With Resistor
• Two banana jacks
Provides two grounding points for wrist straps or carts
• Ring terminal at end of ground cord
Allows easy attachment to electrical ground
• Low profile
Reduces snagging of clothes and work instruments
• Extra ring terminal included
Allows for customizing cord length
• Two versions available
User can choose between snap socket and snap stud as needed
• Available as a kit
14213 Kit includes one 09826 common point ground and one
09864 universal snap kit
• Made in America
Drawings 09820 and 09825, Technical Bulletins TB-2003, TB-2000
BENCH MOUNTED GROUND WITH TWO
BANANA JACKS
09740
09741
09740
Dual Wrist Strap Ground Without Resistor, 10' Cord
Bench Mounted Ground, Parking Station, Without Resistor, 10' Cord
Wrist strap parking station on unit (09741 only)
Allows operator to hang wrist strap when leaving workstation
Two banana jacks
Mounts under the front edge of workstation
Saves work space
2 “Parking Studs”
Helps prevent damage to wrist strap cord when not in use
Made in America
Drawing 09740, Technical Bulletins TB-2003, TB-2000
09741
QUAD COMMON POINT GROUND
09835
09836
09835
Without Resistor, 10mm Stud, 10' Cord
With Resistor, 10mm Stud, 10' Cord
• Four banana jacks
Provides for four grounding points for operators, visitors, and/or carts
• Compact design
Fits neatly under bench top - does not use valuable worksurface space
• Pair of mounting holes with two #10 screws
Allows unit to be permanently installed to workbench
Provided for customizing cord length
• Made in America
Drawing 09835, Technical Bulletins TB-2003, TB-2000
See our products being
Made in America
on our web site:
www.desco.com/factory
Web Site: www.desco.com • Phone: (909) 627-8178 • Fax: (909) 627-7449
MULTI GROUNDING HUB
09837
Without Resistor, 12 ground points, 6' cord
• Six banana jacks and six 10-32 screws with split washer
Provides numerous groundable points for wrist straps, carts and
other items
• Includes one 6' long ground cord terminated with 0.200"
ID #10 ring terminal
• Includes mounting hardware, one 10-32 x 1.75" socket
headscrew with split washer and nut
Easy to install, just drill hole through table top or leg and tighten
nut to secure
• Made in America
09837
12' Ground cord
included with Multi
Grounding Hub
(image not to scale)
Drawing 09837, Technical Bulletins TB-2003, TB-2000
MAT GROUND CORD WITH
10MM SOCKET
09817
09818
With Resistor, 10mm Socket 10' Cord
10mm (0.395") female snap socket
Easily snaps to mat stud
Ground cord terminated with ring terminal
Made in America
09818
Drawing 09817, Technical Bulletin TB-2000
FLOOR AND WORKSURFACE
GROUND CORD WITH 10MM STUD
09813
09814
14234
With Resistor, 10mm Stud 15' Cord
Complete Floor Ground Kit, With Resistor
• Low profile
Reduces inadvertent snagging or tripping that may disconnect
ground cord
• 10mm (0.395") snap stud
Easily snaps to mat socket, flush to mat surface
• Stud has threaded hole; 6-32x1/4" flat head screw and
countersunk washer are provided
Allows ground cord to be optionally bolted mat; keeps cord
from disconnecting; ensures proper grounding
14234 kit includes one 09813 ground cord and one 09864
universal snap kit
• Versatile
Can be used with worksurface mat
• Made in America
Drawing 09814, Technical Bulletin TB-2000
For detailed information on
all Desco worksurface
grounding products:
09813
Screw allows
ground cord
to be
bolted to mat;
keeps cord from
disconnecting.
www.desco.com/catalog
Made in America
on our web site:
21
GROUND CORD WITH BANANA PLUG
09816
Without Resistor, 10mm Stud, 6' Cord
• Ground cord terminated with a banana plug
Connects from mat socket to banana jack*
• Low profile
Reduces inadvertent snagging that may disconnect ground cord
Allows ground cord to be optionally bolted mat; keeps cord from
• Made in America
Drawing 09816, Technical Bulletin TB-2000
*Note: Ground cord with banana plug is used and included with 19120 Workstation
Continuous Monitor
09816
grounding products:
GROUND POINT ADAPTERS
09700
09750
09780
09782
Alligator Clip
Large Clip with Banana Jack 10-32 x 1/2" threaded
hole accepts standard banana plug or 10-32 thread
Ring Terminal Banana Jack
Stacking Snap Banana Jack, 10mm Snap and 10mm
Socket
09700
09750
09780
09782
• All adapters designed to accept standard banana plug
• Made in America
CLEAN YOUR MATS WITH
REZTORE™ ANTISTATIC SURFACE &
MAT CLEANER
10434
10435
10438
10601
10600
Reztore™ Surface & Mat Cleaner, 16 Ounce Spray, Carton of 12
Reztore™ Surface & Mat Cleaner, 1 Quart Spray
Reztore™ Surface & Mat Cleaner, 2.5 gallon cube bag-in-box
Static-Wipes, Pop-Up Dispenser, 60 Wipes, Carton of 12
Static-Wipes, Pop-Up Dispenser, 160 Wipes
• Static dissipative solution
Cleans and restores ESD mats
• Does not contain silicone
Cleaners with silicone leave an insulative layer preventing conductive
or dissipative mats from functioning properly
• Leaves no insulative residue
Will not degrade surface's ability to drain charges
• Made in America
Technical Bulletins TB-7000 (Surface & Mat Cleaner) and
TB-7020 (Static-Wipes)
22
Made in America
on our web site:
10435
10434
10601
10600
UNIVERSAL SNAP KIT
09864
Universal Snap Kit
Snap is user installable
Allows installation of snap exactly where needed
Kit includes a 10mm stud, 10 mm socket, long screw and short screw
Allows for user preference and can be used for a range of mat thickness
ESD Common Point Ground Symbol Label
Used to indicate the location of an acceptable common point ground as defined by
ANSI/EOS-ESD-S6.1
Made in America
09864
Drawing 09864, Technical Bulletin TB-2000
INDUSTRIAL SNAP ATTACHING TOOL
09857
09856
09867
10mm Sockets and Rivets, 100 per pack
10mm Studs and Rivets, 100 per pack
Snap Attaching Tool, 5 3/8" x 12"
• High leverage actuation
Makes installing snaps easy - Ideal for multiple snap installation
• Can be used to install studs or sockets
Versatile tool
• Made in America
Drawing 09867, Technical Bulletin TB-2000
grounding products:
09867
PUSH AND CLINCH SNAPS
09863
09861
10mm Socket
10mm Stud
• Pronged 10mm stud or socket snap
Ideal for multi-layer mats with a conductive inner layer
• Push and clinch installation
Easy to use; secure installation
• Common Point Ground Symbol Label
ground as defined by ANSI/EOS-ESD-S6.1
• Made in America
09863
09861
Use our 14213 Mat
Ground Kit to
Ground your
Worksurface Mats.
Use our 14234
Mat Ground Kit
to Ground your
Floor Mats.
Snaps to common
point ground and has 2
banana jacks.
See Page 20
See Page 21
Made in America
on our web site:
23
