Specifications:
Electrical Properties
Surface Resistivity:
Typical Values
< 1 x 109 ohms
Product Description
Fabric:
Confifuration:
Liner Color:
Coating Color:
Shelf Life:
Ultra-high-molecular-weight polyethylene
Elastic Wrist
Grey
White
Functional: 1 year
Functional Properties
Thickness on Coated Area
1.0 mm ( ± 0.2)
Abrasion Resistance (Revs)
4 - Performance
Blade Cut Resistance
5 - Performance
Tear Resistance (N)
4 - Performance
Puncture Resistance
2 - Performance
Item
Size
Length*
17131
Small
8-1/4" 210 mm
17132
Small
8-5/8" 220 mm
17133
Medium
17134
Large
9-1/2" 240 mm
X-Large
9-7/8" 250 mm
17135
17136
9"
230 mm
XX-Large 10-1/4" 260 mm
Sold in Pairs
Test Procedures/Method
Surface Resistivity Meter
Level
Level
Level
Level
Thickness Gage (Dial Type/
Digimtic Type)
EN 388: 2003
EN 388: 2003
EN 388: 2003
EN 388: 2003
Glove Laundering
For proper operation, the ESD Gloves must be laundered
periodically. Woolite works well. Liquid detergents are
better than dry in that there is less caking and frictional
wear. Launder glove in cool or warm water, tumble dry
with low heat or hang dry. Machine washing works well if
using a standard house machine on gentle cycle. It is not
recommended to launder these gloves in heavy industrial
laundry machines as it will lead to premature wear.
Gloves should be tumbled dry using low heat. DO NOT
BLEACH. After laundering, verify < 1 x 109 ohms.
*Length is measured from the tip of
the fingers to the bottom of the glove.
Tolerance: ±3/8”
Cut Resistant Gloves In Use
Specifications and procedures subject to change without notice.
Country of Origin: Israel
ESD CUT RESISTANT GLOVES
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370
© 2019 DESCO INDUSTRIES INC
Employee Owned
DRAWING NUMBER
17131
DATE:
October
2019
很抱歉,暂时无法提供与“17132”相匹配的价格&库存,您可以联系我们找货
