CAM CENTER OPEN
CAM CENTER CLOSED
Made in America
A. Insulating cap, blue ABS plastic.
B. 300 series stainless steel backplate (0.016” thick). Manufacturing date
code is stamped into stainless steel backplate.
C. Small cam lock, allows material replacement. 300 series stainless
steel.
D. Large cam lock, allows size adjustment, maintains electrical
continuity even when open. 300 series stainless steel.
E. Patented* floating cam lock allows wide opening for easy adjustment
and secures material down against base plate when closed.
CIRCUMFERENCE
ITEM DESCRIPTION
MIN
MAX
09028 Band Only
09069 Band w/12’ Black Cord
09070 Band w/6’ Black Cord
09029 Replacement Strip
*U.S. Patent No. 4,662,695
2.5”
2.5”
2.5”
2.5”
(63.5mm)
(63.5mm)
(63.5mm)
(63.5mm)
13” (330mm)
13” (330mm)
13” (330mm)
13” (330mm)
WIDTH
.875” (22mm)
.875” (22mm)
.875” (22mm)
.875” (22mm)
F. 4mm snap stud machined from 300 series stainless steel. Fits to 4mm
spring loaded medical type socket. Coil cord disengages from snap
with 1-5 lbs. of perpendicular force, fulfilling ESD-S1 paragraph 4.1.6
breakaway force requirement. Durable, providing long life well beyond
that of sheet metal snaps.
G. Knit elastic band material of light blue fiber; .875” (22mm) wide
and 0.10” (2.5mm) thick. 50 strands of textured polyester, 36 strands
of lycra spandex and 14 strands of silver plated polypropylene yarn.
Made with pure silver irreversibly bound to fibers providing both
antimicrobial and anti-odor properties. Outer surface of light blue fibers
act as an insulator.
H. The conductive silver plated polypropylene (see G) represents 13.5%
of the material by weight. The 14 strands of conductive polypropylene
are randomly knit on the inner surface of the material and are
electrically isolated from the outer surface (blue side).
I. Underwriters Laboratory listing 90P1.
Meets or exceeds requirements of ANSI ESD-S20.20 and EOS/ESD-S1-1987.
Specifications and procedures subject to change without notice.
WRISTBAND, ELASTIC, ADJUSTABLE
DESCO WESt: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178 FAX (909) 627-7449
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370 FAX (781) 575-0172
© 2010 Desco Industries Inc.
Employee Owned
DRAWING NUMBER
09028
DATE:
February
2010
很抱歉,暂时无法提供与“09069.”相匹配的价格&库存,您可以联系我们找货
