09210
09210
    DESCO
    腕带 统一尺寸 白色
09210 数据手册
A. Fixed light gray ABS cap with slotted opening to allow size adjustment. B. 300 series stainless steel backplate forms channel to hold up to 10 links of band allowing size adjustment. C. Machined nickel plated steel stud. Fits Desco’s MagSnap® coil cords. Coil cord disengages from from snap with 1-5 lbs. of perpendicular force. D. Metal expansion wrist strap. Inside links are constructed of 300 series stainless steel. Width of links is 0.630". Minimum Circumference: 5.75" and Maximum Circumference: 13". E. 0.002" polyphenylsulfone sheet is laminated to each link. Provides >5,000 volt RMS insulation per ASTM D149. Scratch resistant. Color white. F. Size is adjusted by sliding 1 to 10 links of the band into the backplate “C” channel. G. 300 series stainless steel clip for electrical contact between stud and backplate. H. Underwriters Laboratory listing 90P1C. Meets ANSI/ESD S20.20 and Wrist Strap standard ANSI/ESD S1.1. Standard items that include MagSnap® Metal Expansion Wristbands Item Description Cord Style Accessories 09210 Wristband N/A None 09211 Wrist Strap 6 Foot Magsnap® Coil Cord Alligator Clip Wrist Strap 10 Foot Magsnap® Coil Cord Alligator Clip 09212 Unless otherwise noted, tolerance ± 10% Specifications and procedures subject to change without notice. Meets ANSI/ESD S20.20 wristband resistance interior < 100 kilohms (< 1 x 105 ohms)​per ANSI/ESD S1.1. Meets ANSI/ESD S20.20 wristband resistance exterior >10 megohms (> 1 x 107 ohms) per ANSI/ESD S1.1. JEWEL MAGSNAP® WHITE METAL ADJUSTABLE WRIST STRAPS DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2014 DESCO INDUSTRIES INC. Employee Owned Made in the United States of America DATE: DRAWING NUMBER September 09210 2014
09210 价格&库存
很抱歉,暂时无法提供与“09210”相匹配的价格&库存,您可以联系我们找货
