Extended Cuffs
Standard Cuffs
A. 0.160” (4mm) stud to fit 1/8” (4mm) spring loaded medical snap.*
B. Exterior fabric is 97.9% textured polyester. Conductive fiber filament (Rgp
< 1 x 107 ohms) made of carbon suffused nylon 6 monofilament spaced every
0.25 inches. Material will not slough and can be precision cleaned for use in
cleanrooms down to class 100.
F
Can be washed multiple times in a mild detergent**.
C. Inner lining constructed of Nomex® makes gloves ideal for use in any process
involving heat up to 200°F (93.3°C).
E
D. Conductive, color coded cuff (see chart below) interconnects with the
conductive fiber and snap providing a true and rapid ground path.
Extended Cuffs
A
Item # (Sold in Pairs)
Size
Cuff Color
E
F
17007
Small
Tan
9”
13”
17008
Medium Blue
9”
13 1/4”
17009
Large
Brown
9”
13 1/2”
Size
Cuff Color
E
F
68112
Small
Tan
9”
9 3/8”
68111
Medium
Blue
9”
10”
68110
Large
Brown
9”
10 3/8”
Standard Cuffs
B
C
D
*Glove should be grounded to verify dissipation of static charges.
Use Desco 09480 coil cord or equivalent to ground.
**Glove Laundering
For proper operation, the ESD Gloves must be laundered periodically. Woolite works
well. Liquid detergents are better than dry in that there is less caking and frictional
wear. Launder glove in cool or warm water, tumble dry with low heat or hang dry.
Machine washing works well if using a standard house machine on gentle cycle. It is
not recommended to launder these gloves in heavy industrial laundry machines as it
will lead to premature wear. Gloves should be tumbled dry using low heat. DO NOT
BLEACH. After laundering, verify (Rgp) < 1 x 107 ohms.
E measures around the hand at the fullest part (excluding thumb)
F measures from the tip of the middle finger to the base of the hand
Unless otherwise noted, tolerance ± 1/2”
HOT GLOVES, STATIC DISSIPATIVE
DESCO WEST: 3651 WALNUT AVE, CHINO, CA 91710 WEBSITE: Desco.com
PHONE: (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE: (781) 821-8370
© 2017 DESCO INDUSTRIES INC.
Employee Owned
Made in the
United States of America
DRAWING
NUMBER
68110
DATE:
June
2017
很抱歉,暂时无法提供与“17008”相匹配的价格&库存,您可以联系我们找货
