Specifications
Standard Document
ANSI/ESD S20.20
Electrical Properties
Rs Resistance:
Meets Requirements of:
Packaging
Typical Values
1 x 109 to < 1 x 1011 ohms
Test Procedures/Method
ANSI/ESD STM11.11
Physical Properties
Antistatic Tape
Antistatic Tape
Imprint on Clear Cellulose
with Symbols
Imprint on Clear Cellulose w/
Symbols w/Yellow Stripe
RoHS 3, REACH, and Conflict Minerals Statement
See the Desco Industries RoHS 3, REACH, and Conflict Minerals Statement:
http://www.descoindustries.com/ROHS.aspx
See the Desco Limited Warranty:
http://desco.descoindustries.com/Limited-Warranty.aspx
See the Desco Disclaimer:
http://desco.descoindustries.com/Disclaimer.aspx
No sulfur, surfactants, amines, or silicone based material (adhesive, film backing,
release material) is used in the manufacture of our cellulose tape.
Wescorp Tape Storage and Limited Warranty:
The user must determine the suitability for use of an ESD tape for his particular
application. For best results, tape inventory should be continually replenished. It
is recommended that rolls of tape be stored flat and rotated (flipped over to the
other side) periodically. Tapes should be stored in a dry, well ventilated room with a
reasonably consistent temperature of 68°F (20°C) and be protected from exposure
to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat.
Tape over one year old should be evaluated by the user to determine acceptability for
the user’s application. Desco Industries, Inc. recommends those tracking useful life of
product to use shipping/invoice date as Desco Industries, Inc. expressly warrants that
for a period of one (1) year from the date of purchase, our Wescorp Brand ESDTape
will be free of defects in material (parts) and workmanship (labor). See details of
Limited Warranty online at Desco.com/Warranty.aspx
*Wescorp is a Desco Industries brand.
Construction:
Thickness:
Color:*
Temperature Range:
Cellulose film tape coated with a high tack, non-staining, rubber
adhesive system on plastic core
1.9 mil 0.0019”, (0.06 mm)
Clear, with ESD Symbols
-10°C to +71°C (+14°F -to +160°F) 100°C for 10 min max
Sulfur Content:
No Sulfur
Backing: Cellulose
Adhesive:
Synthetic Rubber
Tensile:
22 LBS./IN
Adhesion: 59 OZ/IN
Elongation: 22.5%
Tape
0.5"
0.75"
Clear
79200
79203
79201
79204
79209
79275
Clear with Symbols
Clear w/ Symbols and Yellow
Stripe
1"
2"
Core
Length
79202
79205 79206
1"
3"
36 yds
72 yds
79210
79211
79212
3"
72 yds
79276
79277 79278
3"
72 yds
Width tolerance ±1/32"
*Military organizations sometimes use MIL-STD-1285 for
hardware marking and that document once required the use
of the “three arrows in a circle” symbol. That symbol has been
changed for consistency with industry marking to the “hand in
triangle” ESD Susceptibility symbol.“
(Ref: ESD TR20.20 section 5.3.14.1)
Specifications and procedures subject to change without notice
Tape widths are nominal
metric ±0.8 mm (±1/32")
1/4"
1/2"
3/4"
1"
2"
is 6 mm
is 12 mm
is 18 mm
is 24 mm
is 48 mm
nominal
nominal
nominal
nominal
nominal
or
or
or
or
or
0.236"
0.472"
0.709"
0.945"
1.890"
Note: Tape rolls may vary slightly in color.
WESCORP* ESD CELLULOSE TAPE, PLASTIC CORE
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710
WEB SITE: Desco.com PHONE (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
WEB SITE: Desco.com PHONE (781) 821-8370
© 2017 DESCO INDUSTRIES INC.
Employee Owned
DRAWING
NUMBER
79200
DATE:
July
2017
很抱歉,暂时无法提供与“79211.”相匹配的价格&库存,您可以联系我们找货
