62AG11-H0-060C
62AG11-H0-060C
    GRAYHILLINC.
    ROTARY ENCODER OPTICAL 32PPR
62AG11-H0-060C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62AG Price Competitive Solution FEATURES • • • • • • • • • Over 1 million rotational cycles 2-bit gray code output Quadrature coding Available in 16, 20, 24 and 32 detent positions Choices of cable length and terminations Available for 5Vdc and 3.3Vdc Optional integrated pushbutton Patented light pipe technology Cost competitive with mechanical encoders at higher volumes APPLICATIONS • Automotive - audio systems - navigation systems • Medical - patient monitoring systems • Test & Measurement - analyzers - oscilloscopes • Audio & Video - consumer electronics - professional editing equipment DIMENSIONS in inches (and millimeters) Optical and Mechanical Encoders .152 ±.002 [3,86 ] .066 ±.002 [1,68 ] Unless otherwise specified, standard tolerances are: Linear ± .025 Diameter ± .010 Angle ± 2.0 0 .500 [12,7] .580 [14,73] Ø.249 ±.002 [ 6,32 ] SHAFT .687 .219 ±.004 [ 5,56 ] .250 [6,35] .312 [ 7,92 ] [ 17,45 ] 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER NOTE: GRAYHILL ALLOWS MULTIPLE ORIENTATIONS FOR THE GRAYHILL TEXT ON THE BACKPLATE. CONNECTOR IS AMP P/N 7-215083-6 OR EQUIVALENT .532 ±.015 [ 13,51 ] .512 [ 13 ] x.xx ± .200 [x.xx ± 5,08] .161 ± .002 [ 4,09 ± 0,05 ] Ø .380 ± .003 [ 9,65 ± 0,07 ] .057 ± .002 [ 1,45 ± 0,05 ] Suggested Mounting Panel Cutout Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders Termination Options SEE DE DETAIL KE KEY .290 [7,37] .250 [6,35] .500 [12,7] .125 [3,18] .250 [6,35] .420 [10,67] .580 [14,73] .219 ` .004 [ 5,56 ` 0,1 ] .250 [6,35] .687 [ +.010 -.020 17,45 +0,25 -0,50 .312 [7,92] ] n .249 ` .002 [ 6,32 ` 0,05 ] 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER .512 [13] .672 ` .020 [ 17,07 ` 0,5 ] Optical and Mechanical Encoders .532 ` .015 [ 13,51 ` 0,38 ] .370 [9,4] .016 [0,41] SQU SQ UARE 6 PLA PLACES .050 [1,27] 5 PLA PLACES .130 [3,3] P - .050 Center Pins with 0.185 inch length .290 [7,37] .290 [7,37] SEE DE DETAIL KE KEY .500 [12,7] .500 [12,7] .250 [6,35] .687 [ +.010 -.020 17,45 .250 [6,35] .219 ` .004 [ 5,56 ` 0,1 ] .580 [14,73] ] .250 [6,35] .512 [13] .532 ` .015 [ 13,51 ` 0,38 ] .580 [14,73] .219 ` .004 [ 5,56 ` 0,1 ] n .249 ` .002 [ 6,32 ` 0,05 ] n .249 ` .002 [ 6,32 ` 0,05 ] .312 [7,92] +0,25 -0,50 SEE DE DETAIL KE KEY 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER .687 [ +.010 -.020 17,45 +0,25 -0,50 ] CONNE ONNECCTOR IS AMP P/N 7-215083-6 OR EQUIV EQUIVALENT XXXX ` .200 XX [XX XXXX ` 5,08] SEE PART NUMBER INFORM INFOR MATION ON SHEEET 4 SHE C - .050 Center Ribbon Cable with connector Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .312 [7,92] .512 [13] .532 ` .015 [ 13,51 ` 0,38 ] .250 [6,35] 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER .100 [2,54] CONDU ONDUCCTORS ARE TOP OPCCOATED XXXX ` .200 XX [XX XXXX ` 5,08] SEE PART NUMBER INFORM INFOR MATION ON SHEEET 4. SHE S - .050 Center Ribbon Cable with .100 stripped end 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders WAVEFORM AND TRUTH TABLE PIN # Standard 5.0V (Style AG) 6 POWER +5V R* OUTPUT A OUTPUT B R* *10K Ω PULL-UP RESISTOR REQUIRED FOR OPERATION **NOISE FILTERING CAPACITOR, LESS THAN 1000pf 5 4 NORMALLY OPEN PUSHBUTTON SWITCH 3 GROUND 1 WAVEFORM (CW ROTATION) R* OUTPUT A OUTPUT B R* 3 GROUND 1 ** ** 2 2 4 LOW POSITION: OUTPUT B 3 OUTPUT B 4 OUTPUT A 1 HIGH 5 NORMALLY OPEN PUSHBUTTON SWITCH POSITION LOW 6 POWER +3.3V TRUTH TABLE (CW ROTATION) HIGH OUTPUT A PIN # Standard 3.3V (Style VG) CW ROTATION ** ** 2 1 2 3 4 5 6... BLANK = LOGIC LOW = LOGIC HIGH CODE REPEATS EVERY FOUR POSITIONS. SPECIFICATIONS Environmental Specifications Rotary Electrical and Mechanical Specifications Operating Voltage: AG Style 5.00±0.25 Vdc VG Style 3.30±0.125 Vdc Supply Current: AG Style 30 mA maximum VG Style 30 mA maximum Logic Output Characteristics: AG Style - Logic high no less than 3.0 Vdc. Logic low shall be no greater than 1.0 Vdc. VG Style - Logic high no less than 2.0 Vdc. Logic low shall be no greater than 1.0 Vdc. Output: Open Collector Phototransistor Optical Rise Time: 30ms maximum. Optical Fall Time: 30ms maximum. Average Rotational Torque: Low = 2.0±1.4 in-oz initially. High = 3.5±1.4 in-oz initially. 50% of initial value after 1 million cycles. Mechanical Life: 1,000,000 cycles of operation. 1 cycle is a rotation through all positions and a full return. Mounting Torque: 15in-lbs. maximum Shaft Pushout Force: 45 lbs. minimum Terminal Strength: 15 lbs. Cable pull out force minimum Solderability: 95% free of pin holes & voids Maximum rotational speed: 100 rpm. Hex Nut: Brass, Plated with nickel Lockwasher: Zinc Plated Spring Steel with Clear Trivalent Chromate Finish Cable: Copper Stranded with topcoat in PVC insulation Connector (.050 center): PA4.6 with tin/nickel plated phosphor bronze. This product series is ROHS Compliant. Pushbutton Electrical and Mechanical Specifications Rating: 10 mA @ 5 Vdc Contact Resistance:
62AG11-H0-060C 价格&库存
很抱歉,暂时无法提供与“62AG11-H0-060C”相匹配的价格&库存,您可以联系我们找货
62AG11-H0-060C
